by akigrimm » Fri Oct 29, 2010 10:49 am
Is there anything special about the installation. I can't see the plugin in SU . I unpacked to plugins and it created a folder and a rb file ChrisP_ColorEdge_EN. Anything else? I would be very happy when I could draw dotted lines.
akigrimm
by JuanV.Soler » Fri Oct 29, 2010 2:47 pm
It is under ...VIEW __TOOLBARS ^`...Color Edge
_,_)))_,_
JuanV.Soler
- Name: Juan Víctor
- Operating system: Windows
- SketchUp version: 8
- License type: Pro
- SketchUp use: landscape architecture
by c.plassais » Fri Oct 29, 2010 7:41 pm
Thanks Juan
c.plassais
by Builder Boy » Mon Nov 01, 2010 10:19 pm
Shade by 3 colors dosn't work for me  Instead, it gives me the dialog, and when I click ok, NOTHING HAPPENS!
Builder Boy
- Name: Michael
by JuanV.Soler » Mon Nov 01, 2010 11:47 pm
Yes, I don´t understand the tool neither. Use it for lines, enough for me. Sorry. I have to investigate though I have the feeling that it is not tunned yet or updated.
_,_)))_,_
JuanV.Soler
- Name: Juan Víctor
- License type: Pro
by c.plassais » Mon Nov 08, 2010 9:36 pm
Hi, This tool allows to colorize the edges on a same plane by a mixture of two basic colors depending on the angle and possibly a second plane and a third color
c.plassais
by schnydix » Fri Dec 31, 2010 7:50 pm
hello i would like tranlate this plugin to german but how ? And it is Possible to have a different line width. Thanks for the great work best-off@gmx.net
schnydix
by c.plassais » Fri Dec 31, 2010 11:33 pm
Good evening, for the width lines it's not possible. I will soon publish a new version, including a Spanish version translated by Diego Rodriguez. The new version adds faces to the lines drawn. Can work on inner edges are groups and components. It is possible to include a German version. Here are the lines to translate - Code: Select all
$aa_01 = "Length " $aa_02 = "TAB to modify parameters " $aa_03 = "Select the end of the edge == TAB to modify colors " $aa_04 = "Color on axis X " $aa_05 = "Color on axis Y " $aa_06 = "Color on axis Z " $aa_07 = "Color 45 degree " $aa_08 = "Color other axix " $aa_09 = "Color single " $aa_10 = "Color " $aa_11 = "Select the start of the edge == TAB to modify colors " $aa_12 = "No color " $aa_13 = "No RGB" $aa_14 = "RGB " $aa_15 = "TAB to modify colors " $aa_16 = "By Layer " $aa_17 = "No selection, do you want apply\nthe operation to all entities? " $aa_18 = "Stippling " $aa_19 = "% or cm " $aa_20 = "Adapt length " $aa_21 = "Color 1 " $aa_22 = "Color 2 " $aa_23 = "There are several instances\nDo make unique instance?\nOtherwise the definition will be modified... " $aa_24 = "Angle length " $aa_25 = "Angle color " $aa_26 = "Edge color " $aa_27 = "ColorEdge " $aa_28 = "Draw Color Edge " $aa_29 = "Draw edge by color by vector " $aa_30 = "Edge single color on select " $aa_31 = "Edge color by axis on select " $aa_32 = "Modify select in dotted line " $aa_33 = "Color Edge by click " $aa_34 = "Dotted line by click " $aa_35 = "Colored angle by click " $aa_36 = "Colors blend " $aa_37 = "Color select " $aa_38 = "Colored angle " $aa_39 = "Dotted line" $aa_40 = "By default" $aa_41 = "Active layer" $aa_42 = "All" $aa_43 = "Delete" $aa_44 = "Color layer" $aa_45 = "Keep" $aa_46 = "Whithout" $aa_47 = "Invisible" $aa_48 = "Yes" $aa_49 = "No" $aa_50 = "Selection of colors to use" $aa_51 = "Valid and save" $aa_52 = "Valid" $aa_53 = "Uncheck all" $aa_54 = "Chech all" $aa_55 = "Cancel" $aa_56 = "Color choice " $aa_57 = "Add face " $aa_58 = "Inputbox setup " $aa_59 = "Inputbox setup..........................................You must before colors selected " $aa_60 = "Language choice " $aa_61 = "List chosen colors " $aa_62 = "Parameters " $aa_63 = "Yes|No"
ChrisP
c.plassais
by sketchupjockey » Fri Jan 14, 2011 11:10 pm
thanks i will check it out.
sketchupjockey
- Name: Larry Holman
by brookefox » Mon Apr 16, 2012 5:24 pm
I am late to this party, as well, but so glad to be here.
Thank you so much, Christophe, for your generosity and delicious plugin.
~ Brooke
brookefox
- Name: Brooke
- License type: Free/Make
- SketchUp use: architecture
by brookefox » Wed Apr 18, 2012 5:40 pm
I wish: 1. it worked on groups as groups 2. settings were remembered 3. setting units respected those active in SU 4. it worked on circles, arcs Please see the image, which I hope explains my comments better. In this case I'm really just looking for a consistent appearance for the perimeter edges.
Please, register (free) to access all the attachments on the forums. ~ Brooke
brookefox
- Name: Brooke
by ramonbastos » Thu Nov 01, 2012 8:18 pm
Hi Chris, would you help me please? I colored some edges on my model, but now i want it all to go back to default.. How do i do it? Thanks
ramonbastos
- Name: ramonbastos
by Alainbo » Fri Jan 18, 2013 3:23 pm
Very usefull, thanks for this plugin.
It seems there is a problem when we don't select any edge. It asks if we want to apply the color to all entities but it that case, I got nothing !?! It would be nice if it would keep the last selected color instead of having to choose it in the list.
Regards, Alain
Alainbo
- Name: Alain bonnefoy
- License type: Pro
by nida12345m » Tue Apr 09, 2013 10:21 am
hello everyone, sorry am new to this , but I have added the ruby of this plugin to my sketchup plugins file, but i still dont get the menu .. what is the problem? and how can i show the menu?
nida12345m
- Name: nida12345m
by Pilou » Tue Apr 09, 2013 12:47 pm
It's not on Menu Plugins!!! It is only under Menu ...VIEW __TOOLBARS ^`...Color Edge
Pilou
- Top SketchUcator
- SketchUp version: 6
- SketchUp use: hobby
- Level of SketchUp: Advanced
Return to Plugins
