SketchUcation Premium Membership
[Plugin Beta] Curviloft 1.2d - 13 Apr 12 (Loft & Skinning)
Re: [Plugin Beta] Curviloft 1.2d - 13 Apr 12 (Loft & Skinnin
Postby Pherim » Mon Apr 23, 2012 4:10 pm
Dave R wrote:As Jeff asked, post the SKP file where it doesn't work.
I'm sorry I was in a hurry when I wrote my last reply and I was unable to look into the forums for the last few days. I have attached a sample file with explaining notes. However, this appears to happen with every flat surface, at least the ones I tried.
Skin_test.skp
Pherim
Postby TIG » Mon Apr 23, 2012 4:17 pm
I fail to see why you need to use this tool to do this...
If you select one or more edges in the coplanar set... and run one of the several 'add-faces' tools available... it faces almost instantly...
If you want to 'mesh' the 'flat' one face then my ExtrudeEdgesByRails will do it thus.
No smoothing etc to show messy mesh because of uneven vertices distribution in the two original wavy curves...
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby Pherim » Mon Apr 23, 2012 4:38 pm
Yes I tried to do what your ExtrudeEdgesByRails appears to do. Will try it in a minute! I realize that the edges are not perfect for that purpose, but it's just an example file.
edit: It works. Thank you!
Pherim
Postby Jeff Hammond » Mon Apr 23, 2012 6:06 pm
Skin_test.skp
a workaround you can do at this time is:
select the edges / choose curviLoft 'skinning of shapes'
under Geometry in curviloft, click 'Generate the Junctions as SU Curves' (the last icon in geometry)
this will give you the lines you're seeking, albeit they are softened..
(for purposes of this example, explode the curviloft generated group at this time)
select everything then right-click -> Soften/Smooth edges
set the slider to zero which will unhide the lines..
switch to wireframe mode then select all the lines and copy/move them to a new location..
switch back to a shaded mode and only your curves/junction edges will in the copied set of geometry..
(and maybe the way i described it there sounds worse than doing it in reality.. :) .. it's pretty quick/painless )
dotdotdot
Jeff Hammond
Global Moderator
Operating system: Mac
SketchUp version: 8
License type: Pro
Postby Pherim » Mon Apr 23, 2012 6:16 pm
Thank you, that worked!
Pherim
Postby brookefox » Sun Apr 29, 2012 8:30 pm
Just a quick note of thanks to Fredo. Here's a pic of a modest result which well pleases me.
Merci, monsieur.
~ Brooke
brookefox
SketchUp version: 8
License type: Free
Postby brookefox » Mon Apr 30, 2012 7:11 pm
The pic shows two arc profiles desired to be swept along an arc path in red. Though the two profiles are separate curves, 'loft along path' makes them one when picked. One should be a beginning transitioning to the other as an ending.
~ Brooke
brookefox
SketchUp version: 8
License type: Free
Postby fredo6 » Mon Apr 30, 2012 7:27 pm
brookefox wrote:The pic shows two arc profiles desired to be swept along an arc path in red. Though the two profiles are separate curves, 'loft along path' makes them one when picked. One should be a beginning transitioning to the other as an ending.
It depends on the edge selection you choose (follow or curve) and also you need to click in the empty space to force the separation of the 2 contours since they are contiguous
Fredo
fredo6
Top SketchUcator
Postby brookefox » Mon Apr 30, 2012 7:35 pm
I guess there is no way as even if the two arcs are perpendicular to each other it treats them as one.
~ Brooke
brookefox
SketchUp version: 8
License type: Free
Postby brookefox » Mon Apr 30, 2012 7:44 pm
Fredo6 wrote:It depends on the edge selection you choose (follow or curve) and also you need to click in the empty space to force the separation of the 2 contours since they are contiguous.
OK, I thought I had tried that. I will now for sure. Thank you. For me a work around is to make it in two moves with 'skinning'. Pic shows the desired and thusly achieved results.
~ Brooke
brookefox
SketchUp version: 8
License type: Free
Postby brookefox » Mon Apr 30, 2012 7:58 pm
I got the profiles distinguished as you said, but have had no success with the sweep, no matter the settings. But it is a complex tool and I do not have a solid grasp of the variables, to say the least. Merci, Fredo.
~ Brooke
brookefox
SketchUp version: 8
License type: Free
Postby brookefox » Wed May 02, 2012 7:26 pm
Cross post from elsewhere to here, where it may be of some use...model here with Fredo's Curviloft tools and TIG's Extrusion Tools.
~ Brooke
brookefox
SketchUp version: 8
License type: Free
Postby artcrazy1313 » Mon Jun 04, 2012 3:19 am
Hi Guys
I am new in this scetchup world and I need some help.
I am trying to download .rb in my scetchup8. I do everything it was asked and put in scetchup plugin foldr but for some reason nothing comes out.. Please have someone help me out.
I am also tring to download this .rb for round corners , but cand find a link for download.
artcrazy1313
Postby TIG » Mon Jun 04, 2012 9:42 am
artcrazy1313 wrote:Hi Guys
The download link is almost always on the first post in any tools thread [it also has '[Plugin]' at the start of the thread's title]. The Plugins Idex red-button takes you to a page that in turn links off to all plugins available here, and a few elsewhere too...
Be sure to read the tool's download page - sometimes you need to get and install a help file or a library of helpers [like this tool] that are kept in their own subfolder.
Be sure to follow the tool's instructions for download, extraction and placement in the Plugins folder.
If the tool comes in a zip file ensure that the 'loose' files go into the Plugins folder and that any helper files zipped inside a subfolder are put into Plugins still INSIDE that subfolder - never move files around as the tool will break.
You are on a MAC so ensure you are using the right root-level 'HD' library Plugins folder and NOT a 'user' one...
There are several helpful threads about installing scripts/plugins - do a forum Search.
Thomthom has also made a 'Simple Installer' tool [>=v8M2 only] that will automatically install scripts and extract/install from archives of scripts - look for that in the Plugins Index...
Note that some tools [like this one] are Extensions that need activating [one-time-only] from the Window > Preferences dialog, then the tool's Toolbar probably needs activating from the View...menu item...
Note also how each tool is activated/used...
Many new tools do appear in the Plugins-menu... BUT many do not - for example the menu items for this very tool are found in Tools > Fredo Collection > CurviLoft submenu !!!
Global Moderator
SketchUp version: 8
License type: Pro
Postby baz » Mon Jun 04, 2012 10:50 am
Off topic.
Tig, you are so patient and helpful. I saw this post and my first thought was has he tried 'search', has he looked at the 'how to download plugins' tut, has he made any effort at all? Or is he a first poster who needs some direction about how to help him/her self
I guess what I'm trying to say is that you and others on this forum contribute so much, I worry that you get overloaded with things that don't really help to progress SU.
Your call though, I'm inclined to 'tough love' myself.
"What do we want?...Time travel... When do we want it?... Irrelevant"
Thanks to Funny Pics
baz
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby artcrazy1313 » Mon Jun 04, 2012 5:33 pm
First of all I want to thank you for your detail info and your time... As much as I appreciate your help , this is to me a Chinese :)
I was wondering if we could connect and I gave you permission to enter in my computer and show me how to install this things. I really need your plug ins. They re great. I am willing to pay for your time... thank you..
artcrazy1313
Postby artcrazy1313 » Mon Jun 04, 2012 5:58 pm
artcrazy1313
Postby leroy_elroy » Wed Jun 13, 2012 7:32 am
Hi all,
another noob having problems installing to sketchup 8 here. But I have done my research before posting... I have extraced the files and moved them into the plugin folder as described, but upon starting SU the error windows keep coming up.
I tried extracting them with winrar, explorer and 7-zip, even tried installing the plugin-finding plugin as suggested in earlier posts, but to no avail.
and yes, the latest libfredo plugin is loaded and running fine. I have tried this process at two computers to the same result. Ideas?
Also just wanted to say well done for taking a frustratingly basic modelling platform and taking it up to the next level. As somebody who learnt Rhino before SU I've had moments of agony, but this is bringing it up to speed.. Assuming I can get it to work.. I wonder how long before we see the equivelant of Grasshopper and Kangaroo for Rhino.... :)
leroy_elroy
Postby baz » Wed Jun 13, 2012 8:29 am
I think you have the files in the wrong place. On my puter the files you show are in Plugins/CURVILOFT_Dir_12
You seem to have lost the parent folder.
baz
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby thomthom » Wed Jun 13, 2012 8:31 am
leroy_elroy wrote:another noob having problems installing to sketchup 8 here. But I have done my research before posting...
You missed the footprint description:
You extracted the content of the CURVILOFT_Dir_12 folder directly into your plugins folder instead of preserving it.
I made a small utility plugin to help the installation process: viewtopic.php?t=42315
Global Moderator
SketchUp version: 8
License type: Pro
Postby leroy_elroy » Wed Jun 13, 2012 9:13 am
derp.
I stand corrected, thanks for the help!
leroy_elroy
Postby keith siu » Sat Jun 16, 2012 2:47 am
HI, I am new. After installation, can't find Curviloft at Tool or plugin. What can I do?
keith siu
Postby Dave R » Sat Jun 16, 2012 11:16 am
keith siu wrote:HI, I am new. After installation, can't find Curviloft at Tool or plugin. What can I do?
You haven't given us anything to help you with. The first thing is go back and read the first post thoroughly and make sure you did everything right. Did you install the plugin correctly? Does it have the footprint as shown in the first post? Did you install the current version of Libfredo6? Did you look under View>Toolbars for the Curviloft toolbar? Do you find Fredo6 Collection in the Tools menu?
Inspecting mirrors is a job I could easily see myself doing.
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: woodworking
Postby jgb » Wed Jul 18, 2012 3:11 pm
Strange one here. It's a simple surface to form, I've done way more complex ones.
When I select all, and hit "Skin" the selects go white and nothing happens. :shock:
It does skin manually by joining the vertexes into triangles.
I have redrawn every line, there are no gaps, no fragments, nothing I can see.
If I join any 2 vertices, either side will skin. Remove the join and no skin. :?
What's wrong :?: :?:
BTW, at first I thought it may be an interference with the SimFonIA plugin I just loaded.
But Curviloft worked OK on other more complex surfaces in the same drawing that this shape originated in.
Curviloft Problem.skp
__________________
jgb
jgb
SketchUp version: 8
License type: Free
SketchUp use: engineering and mechanical design
Postby Rich O Brien » Wed Jul 18, 2012 3:33 pm
You need to add some 'breakers' to allow Curviloft to read your mind.
:::Blog:::
I'm a Trimbler now!
Rich O Brien
Administrator
SketchUp version: 8
License type: Pro
Postby Pilou » Wed Jul 18, 2012 4:05 pm
Ah damned someone send a similar trick in the same time! :)
Just divide this segment and all will works fine! ;)
But that is not very normal :)
PS If you can save your file in v6, this will be very fine for nostalgic people who don't use V7, v8 :enlight:
(i must use some usb keys between computers :oops:
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby Dave R » Wed Jul 18, 2012 5:53 pm
Off-Topic:
We should take up a collection for our poor friend, Pilou. He needs to move into the current century with his computer. I'll donate a graphics card. Does anyone have a spare motherboard? Memory? Hard drive? Etc. :D
Global Moderator
SketchUp version: 8
License type: Pro
Postby jgb » Wed Jul 18, 2012 7:03 pm
Rich O Brien wrote:You need to add some 'breakers' to allow Curviloft to read your mind.
If you mean those 4 lines at the vertexes, I just tried that, and Pilou's segment break, and still, no skinning. Don't understand why they did not work for me.
In that same model, I just did 3 more similar shapes and the same thing happened. But when I joined any 2 vertexes in those constructs, (as well as the original problem), they skinned normally. So I joined 2 vertices at 1 end to form a triangle, and the rest of the construct skinned when selected.
That made me think Curviloft can't handle 2 or more acute angles. Yep!!!
I moved 1 end vertex in at varying angles.
As soon as the angle was 90 deg or more the construct skinned.
Something for Fredo to look into.
__________________
jgb
jgb
SketchUp version: 8
License type: Free
Postby Rich O Brien » Wed Jul 18, 2012 7:06 pm
Did you look at how i picked the profiles and rails independently?
:::Blog:::
I'm a Trimbler now!
Rich O Brien
Administrator
SketchUp version: 8
License type: Pro
Postby jgb » Wed Jul 18, 2012 8:26 pm
Rich O Brien wrote:Did you look at how i picked the profiles and rails independently?
I noticed, but I never had any real success doing that, so I ignored it.
There is a whole lot about CL that I do not understand, particularly the toolbar. :(
Fredo really needs to define what the colors mean (red, magenta, etc) when the perimeter has a problem.
I tried playing with "errors" (gaps, fragments and double lines) but could not get consistent, if any idea of the feedback from CL. Same with the toolbar, changing parameters seemed to have no effect.
So now I just select a perimeter and hit either "skin" or "loft" depending.
On most of my complex surfaces (wing fairings, etc) I usually end up redrawing most of the skin to simplify (line reduction) the result, as I find CL tends to create far more small triangles than necessary, but at least it does a very good job of making the curves, that I know take would hours to tweak if done manually from scratch, having done many before I discovered CL.
It is one of the few core plugins that I could not live without now. :sketchstatic:
__________________
jgb
jgb
SketchUp version: 8
License type: Free
Keyframe Animation plugin - animate your SketchUp model by adding movement to any object.
PreviousNext
Return to Plugins
Users browsing this forum: CadFather, fwu014, giosrd, iwazz, nikibg2002, OuchOuchOuch and 12 guests
