SketchUcation Premium Membership
[Plugin Beta] Curviloft 1.2d - 13 Apr 12 (Loft & Skinning)
Re: [Plugin Beta] Curviloft 1.2a - 21 Sep 11 (Loft & Skinnin
Postby thomthom » Mon Sep 26, 2011 8:24 am
:thumb: :thumb:
Very nice Fredo.
I'll be looking into the revised definition of a Quad this week. I like your suggestion.
(Btw, I see that the preview still display black meshes - you know that SU8 now makes use of view.drawingcolor, yes?)
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby fredo6 » Mon Sep 26, 2011 10:19 am
thomthom wrote::thumb: :thumb:
Very nice Fredo.
I will release an update with
- Border: Soft + Smooth
- Diagonals: Soft + Smooth + Hidden
thomthom wrote:(Btw, I see that the preview still display black meshes - you know that SU8 now makes use of view.drawingcolor, yes?)
I know, but for Curviloft, I'll keep Black anyway (due to the visual matching with the various colors of the lines).
Fredo
fredo6
Top SketchUcator
Re: [Plugin Beta] Curviloft 1.2b - 26 Sep 11 (Loft & Skinnin
Postby fredo6 » Mon Sep 26, 2011 12:09 pm
NEW RELEASE: Curviloft 1.2b - 26 Sep 11
IMPORTANT: you need to install LibFredo6 4.2 (or higher). With this version of LibFredo6, the ZLoader__Curviloft.rb is no longer necessary.
This release includes more options for the generation of pseudo-quads for usage by the new QuadFaceTools by Thomthom.
Options are available in the Default Parameters dialog box
By default, pseudo-quads are generated with:
- Borders: Soft + Smooth
This allows to have a nice-looking surface, while being compliant with all functionality of Thomthom quads tool (which should be upgraded soon)
See main post for download
Fredo
fredo6
Top SketchUcator
Postby thomthom » Mon Sep 26, 2011 12:17 pm
:thumb:
FYI to users of QuadFace 0.3 and earlier, you must set the border edges to not be soft.
So for QuadFace 0.3 and earlier:
Diagonal: Soft + Smooth (Hidden may be set - not required)
Border: Not Soft (Smooth and Hidden can be set, but not a requirement)
QuadFace 0.4
Diagonal: Soft + Smooth + Hidden (All required)
Border: Not diagonal. (Any combo can be used as long as not all the checkboxes are ticked.)
Global Moderator
SketchUp version: 8
License type: Pro
Postby Dave R » Mon Sep 26, 2011 12:44 pm
Thank you Fredo.
thomthom wrote:QuadFace 0.4
Thomas, I see links to 0.3 but not 0.4. I must be looking in the wrong place?
Inspecting mirrors is a job I could easily see myself doing.
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: woodworking
Postby Carrozza » Mon Sep 26, 2011 12:47 pm
Thanks for this great plugin! ^__^
Carrozza
Postby thomthom » Mon Sep 26, 2011 1:30 pm
Dave R wrote:Thank you Fredo.
Yes, you must look on the harddisk of my private computer for version 0.4. ;)
( There's a teaser video in the first post: viewtopic.php?f=323&t=39442 - Toob: http://www.youtube.com/watch?v=NY-l93C-fPw )
Global Moderator
SketchUp version: 8
License type: Pro
Postby Ben Ritter » Mon Sep 26, 2011 2:46 pm
Fredo, thank you again.
Ben Ritter
Postby dereeei » Mon Sep 26, 2011 4:55 pm
One question, this version doesn't use anymore ZLoader__Curviloft.rb file? I downloaded it and I found just the directory inside.
Thank you.
dereeei
Postby fredo6 » Mon Sep 26, 2011 5:50 pm
dereeei wrote:One question, this version doesn't use anymore ZLoader__Curviloft.rb file? I downloaded it and I found just the directory inside.
Thank you.
With LibFredo6 v4.0 and above, the ZLoader__xxx files are no longer used.
You can purge them by using the menu Windows > LibFredo6 Settings... > Purge Obsolete Files
Fredo
fredo6
Top SketchUcator
Postby dereeei » Mon Sep 26, 2011 6:14 pm
thanks, I did it!
dereeei
Postby ivreich » Wed Sep 28, 2011 2:41 pm
Hi Fredo
I'm not sure if this question has been answered before, but is there a way to ensure all segments in a loft have the same number of columns of quads and that all the junction curves meet up? I have played around with all the various lofting options with no success.
For example, in this image below all three profile curves have 30 segments but the resulting mesh has disjointed junction curves, making it hard to use thomthom's loop/ring selection tools properly. Also, some of the quads seem to be merged into a single long surface?
Cheers,
Joel
ivreich
SketchUp version: 8
License type: Pro
Postby fredo6 » Wed Sep 28, 2011 6:02 pm
Joel,
Sections are computed idependently for the vertex matching, so if contours are very different, you may end up with the situation you describe.
So far, the only possibility is to use the Global F-spline options. It draws a mesh between the first and last contours trying to be as close as posible to the intermediate contours (but not matching their vertex).
This method is the first one of the group of two icons at the right of the Junction methods section in the palette.
Thanks to tell me if this option is useful (I included it just in case....)
Fredo
fredo6
Top SketchUcator
Postby ivreich » Thu Sep 29, 2011 5:37 am
Fredo
Hi Fredo
Thanks for your reply. yes i did try the global F-spline options and these are the only options which work. They are definitely very useful; thanks for including them!
What I don't understand however is that the 3 profile curves shown in my example are very similar: they are actually three copies of the same uniform b-spline with slight adjustments to each. They have exactly same number of segments and the segments are all aligned approximately above each other, So I'm not sure why curviloft creates extra intermediate junction curves in some places?
Is it possible for Curviloft to gauge when all the profile curves have the same number of segments and do direct vertex matching without the extra junction curves? The reason being that the most logical way/neatest way of doing a loft is to use Bezierspline to give each of the profile curves the same number of segments before lofting.
Also, any idea about the second issue? the one where the quads are all merged into a single long face? Sorry if I'm a bit long winded, but I'm just very excited about the integration between Curviloft and Quad face tools...
Cheers,
Joel
ivreich
SketchUp version: 8
License type: Pro
Postby fredo6 » Thu Sep 29, 2011 6:25 am
Could you post the model so that I have a closer look
Fredo
fredo6
Top SketchUcator
Postby jgb » Thu Sep 29, 2011 12:36 pm
ivreich wrote: They have exactly same number of segments and the segments are all aligned approximately above each other, So I'm not sure why curviloft creates extra intermediate junction curves in some places?
Joel
I too have noticed (and remarked about a long time ago) CL's penchant for adding multiple vertexes where none should be logical.
CL does a fantastic job of lofting, but often adds a lot of unnecessary lines that I spend a lot of time simplifying by simply deleting the redundant lines and triangulating the quad face. It is rarely a logical midpoint on a straight-line split, they seem to me to be almost random in generation, both position and number.
I haven't tried the new version yet, and I won't have time for a while, as I only get less than an hour on the PC a day due to a temp. 12 hour a day job.
__________________
jgb
jgb
SketchUp version: 8
License type: Free
SketchUp use: engineering and mechanical design
Postby ivreich » Thu Sep 29, 2011 2:28 pm
Fredo6 wrote:Could you post the model so that I have a closer look
Fredo
Hi Fredo
I've attached a model showing the problems I described. I've showed the exact steps i took and colour coded/labelled the problematic areas.
Thanks so much for looking into this!
Cheers,
Joel
ivreich
SketchUp version: 8
License type: Pro
Postby Pilou » Thu Sep 29, 2011 5:50 pm
Have you same result when you scale the B Splines *100 ?
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby fredo6 » Thu Sep 29, 2011 8:33 pm
ivreich wrote:I've attached a model showing the problems I described. I've showed the exact steps i took and colour coded/labelled the problematic areas.
Joel,
I had a look and there is definitely a problem in the vertex matching. Actually, even if the number of vertices are the same, thereare some which are very close and unequally spaced. This create issues with the current matching algorithm which still needs to be improved in case there is no 'sharp' edges to be used as a reference start point.
In addition, the problem of vertex matching makes the Global F-Spline method not really work. But I knew I had problem on this one.
I am afraid that this cannot be fixed instantly. What I suggest is that you play with the vertex matchning by dragging the junction curves and eliminating the auto-pairs.
Fredo
fredo6
Top SketchUcator
Postby ivreich » Fri Sep 30, 2011 3:46 pm
Fredo
Thanks for looking into it anyway Fredo. I guess this issue of vertex matching becomes very important now that there is a lot of buzz going on around thomthom's quad face tools which require a regular set-out of quad faces in order to properly utilise features such as loop and ring select etc.
My dream is that one day this kind of quad-based system will lead to a free-form paneliser tool for SU. I posted a topic on it here:
http://forums.sketchucation.com/viewtopic.php?f=323&t=39992
It has huge architectural implications for architects like me who use SU heavily as a design tool. Not many people seem to be interested in it though...which is rather strange.
Cheers,
Joel
ivreich
SketchUp version: 8
License type: Pro
Postby konara » Sat Oct 01, 2011 1:47 am
thanks freddo ...!!unbeleivable..
konara
Name: Konstantinos Chochlakis
Postby Mcgee2005 » Mon Oct 03, 2011 12:22 pm
Hello everyone! I'm newbie to this community so I just wanted to thank you for sharing this wonderful information in this thread, it really helped me a lot!
Mcgee2005
Postby taiyungokjoseph » Mon Oct 03, 2011 12:58 pm
this is great
taiyungokjoseph
Name: yu ngok tai
Postby thomthom » Thu Oct 06, 2011 2:09 pm
I'm loving this tool Fredo! So quick to generate a nice clean mesh - and with the latest Quad option - working with it afterwards is such a joy!
Global Moderator
SketchUp version: 8
License type: Pro
Postby fredo6 » Thu Oct 06, 2011 11:02 pm
thomthom wrote:I'm loving this tool Fredo! So quick to generate a nice clean mesh - and with the latest Quad option - working with it afterwards is such a joy!
Glad to see that this is useful for real-world modelling.
I have installed the Quadtools and start playing with it, trying to catch the essence of the tutorial videos. So far, I am still struggling to understand how to do a simple application of an image texture on a shape, but I will try again.
Fredo
fredo6
Top SketchUcator
Postby thomthom » Fri Oct 07, 2011 7:37 am
I got on my todo list to make some more tutorials.
I also need to update QuadFace Tools to give proper feedback to the user when the shape can't be mapped to a 2D grid. Please post back with the things you find troublesome - with sample models would be great.
Global Moderator
SketchUp version: 8
License type: Pro
Postby lauris.gouiran » Sun Oct 09, 2011 5:40 pm
Bonjour
est ce que Curviloft marche sous Sketchup8 (mac)?
Merci
Hello,
does Curviloft work under Sketchup8 for mac?
Thank you
lauris.gouiran
Postby fredo6 » Sun Oct 09, 2011 7:10 pm
lauris.gouiran wrote:Hello,
Yes it does
Fredo
fredo6
Top SketchUcator
Postby WDITrent » Sat Oct 15, 2011 4:42 am
Hey everyone, I downloaded this plugin and sketchup tells me that there have been errors loading the Curviloft plugins, though they are in the same folder as the LibFredo6 plugin as well as Tools On Surface plugin (which works great, by the way). Is it a bug with this version? I tried telling the Ruby Console to load the plugins, and it accepted some of them but about half of them have problems and as a result Sketchup won't show me any of the tools for Curviloft.
Thanks!
WDITrent
Postby fredo6 » Sat Oct 15, 2011 10:32 am
WDITrent wrote:Hey everyone, I downloaded this plugin and sketchup tells me that there have been errors loading the Curviloft plugins, though they are in the same folder as the LibFredo6 plugin as well as Tools On Surface plugin (which works great, by the way). Is it a bug with this version? I tried telling the Ruby Console to load the plugins, and it accepted some of them but about half of them have problems and as a result Sketchup won't show me any of the tools for Curviloft.
Thanks!
What are the errors you get ?
Fredo
fredo6
Top SketchUcator
Need SketchUp Books, Models, Styles or Textures? Check out our One Stop Shop for SketchUp.
PreviousNext
Return to Plugins
