[Plugin Beta] Curviloft 1.8a - 31 Oct 18 (Loft & Skinning)
Re: [Plugin Preview] Curviloft 1.0 (Loft and Skinning)
Postby DIEGO-RODRIGUEZ » Thu May 27, 2010 6:21 pm
fredo, great plugins. thank you very much for their continued contributions to the user of sketchup
two questions.
floating panel interface, which uses programming language?
you can use images *. png or other format for icons?
when can download the first version of the plugins?
DIEGO-RODRIGUEZ
Banned
Postby fredo6 » Thu May 27, 2010 7:02 pm
DIEGO-RODRIGUEZ wrote:floating panel interface, which uses programming language?
It is written in pure Ruby and SU API (which makes it portable PC and Mac).
Unfortunately, png cannot be used (the SU API is missing this functionality, but it would be a good idea to add it)
DIEGO-RODRIGUEZ wrote:when can download the first version of the plugins?
Probably not before a month, except if I released only a subset.
This is also why I need to have some sample geometry, beyond what I am doing test with, because I prefer to adapt the algorithm before the script is released)
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby fredo6 » Thu May 27, 2010 7:08 pm
EarthMover wrote:Holy crap!!! Is that speed realtime? Looks amazing! Do the number of segments in the rails matter? Could this possibly be used to replace the standard from contours in the sandbox tools to create graded terrains?
Videos are real time. As usal the performance is driven by the number of facets created, with the exponential slow-down noticed in all scripts.
The number of segments does matter because Curviloft always respects the vertices of the contours and rails. This is why meshes created can be unbalanced or very crowded. In principle, it would be good that users do a rebalancing before applying Curviloft.
For terrain shaping, I would appreciate if you had an example, so that I can answer more accurately.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby solo » Thu May 27, 2010 7:35 pm
Fredo, what kind of example would work for you?
contour maps, completed terrains, an image, point cloud?
http://www.solos-art.com
I'm better with polys than words
solo
Global Moderator
Postby bagatelo » Thu May 27, 2010 7:47 pm
Yes, Only Fredo6... OMG
I can't wait to try this one.
bagatelo
Postby Fletch » Thu May 27, 2010 8:44 pm
Fredo, this is simply astounding work, you are absolutely incredible! :enlight:
Fletch
Twilight Render
Postby fredo6 » Thu May 27, 2010 8:44 pm
solo wrote:Fredo, what kind of example would work for you?
Actually, a SKP model with contours where you want to generate the surface. Curviloft does not work on point clouds.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby thomthom » Thu May 27, 2010 9:11 pm
Fredo6 wrote:It is written in pure Ruby and SU API (which makes it portable PC and Mac).
I've also requested that SU supports this.
Meanwhile, I've made a framework to read BMP images and render them to screen. Though you can't have too many as it'll slow down. But it works fine for creating toolbars.
PluginStore Author
PluginStore Author
Postby fredo6 » Thu May 27, 2010 9:15 pm
Tom,
This was also my first approach (with view.draw GL_POINTS) but it was definitely too slow. I think that if this is added in native code, it can be ultra fast, even fatser than drawing lines and polygons by view.draw.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby thomthom » Thu May 27, 2010 9:23 pm
What speeds up thing greatly is if when you load the bitmaps you sort the pixels by colour, and then draw each colour in bulk.
I load each bitmap for each toolbar button into a hash with the colour as key and the value as an array of point3d objects. Note that I merge all buttons into one hash.
This means that if you are careful about your icon creation and use a palette of fewer colours you increase performance. A little bit pre-processing required, but the bulk drawing makes up for it many times over.
PluginStore Author
PluginStore Author
Postby fredo6 » Thu May 27, 2010 9:25 pm
One more video, on the possibility to borrow contours from within components....
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby thomthom » Thu May 27, 2010 9:27 pm
Fredo6 wrote:One more video, on the possibility to borrow contours from within components....
:thumb: :thumb: :D
PluginStore Author
PluginStore Author
Postby EscapeArtist » Thu May 27, 2010 9:30 pm
That last process vid you just posted would be a great time saver all by itself. I'm trying to think of something creative to offer as a sample, but you've covered pretty much what I'd use already.
EscapeArtist
Top SketchUcator
Postby pilou » Thu May 27, 2010 10:34 pm
On the last example, the curve can make a loop on the same plan?
If yes,there is an automatic clean of the complex auto-intersect skin resulting?
Speedy Galerie
Top SketchUcator
Postby EarthMover » Thu May 27, 2010 10:35 pm
Bloody genius! I'd swear I was looking a video from Rhino or Bonzai!!! :thumb: :thumb:
Content Creator at Skapeup
EarthMover
Premium Member
Premium Member
Postby solo » Thu May 27, 2010 10:41 pm
oooh, good thinking.
Would it make a torus shape?
solo
Global Moderator
Postby TIG » Thu May 27, 2010 10:51 pm
A Torus is easily made using the built-in FollowMe tool or even my EEbyLathe - BUT Fredo's new tool seems far more powerful, and so it should be able to do much greater things :bounce:
We await in anticipation...
Global Moderator
Postby solo » Thu May 27, 2010 10:59 pm
Okay, let's up the ante.
solo
Global Moderator
Postby Daniel S » Fri May 28, 2010 1:50 am
Fredo
For loft along path you always show two faces or surface and a path...
It will be possible to select more faces?
Something like this image that I found:
And I attach some models to see if they work with loft along path.
Daniel S
Daniel S
Postby bagatelo » Fri May 28, 2010 2:19 am
Fredo
This remember solidworks. Non destructive work can be very interesting. And if can be possible to make smooth junctions.
Fredo, never doubt: WE LOVE YOU!!!
bagatelo
Postby driven » Fri May 28, 2010 3:02 am
hi Fredo,
if you need a mac tester...
this is a simple version of something I can't get any of the other tools to manage easily, but maybe it's me...
cantfollow.skp
driven
PluginStore Author
PluginStore Author
Postby Daniel S » Fri May 28, 2010 3:34 am
driven wrote:this is a simple version of something I can't get any of the other tools to manage easily, but maybe it's me...
I don´t know how to explain it in english, but you follow and rotate. So if curviloft works with closed paths and you can select more than 2 faces you will need to make something like the attachment.
Not really sure, but this is how should work this feature Fredo?
Daniel S
Daniel S
Postby DIEGO-RODRIGUEZ » Fri May 28, 2010 4:17 am
Hi FREDO
I have drawn some models for you to teste the loft plugins
you need other models?
DIEGO-RODRIGUEZ
Banned
Postby Panga » Fri May 28, 2010 8:54 am
Hi Fredo,
As promised, I attach to this post some test files in order you can evaluate your plugin with terrain work.
The first file (road test.skp), show you one of my principal process in order to make roads, and the boring step of cleaning the faces outside the original contours after using the sandbox...I weld all the contours of the road, but I think you'll have to create somme edges in order to divide the whole road in parts.
The second file are classic contours for terrain.
Hope it will help you to test your plugin.
Regards.
Panga
Premium Member
Premium Member
Postby Rainie » Fri May 28, 2010 9:54 am
When it is released. This was just a teaser. ;)
Hi, Thanks Thom for your very quick reply..Thanks!
Rainie
Postby gofrez » Fri May 28, 2010 11:25 am
When i've seen this plugin i falled down the chair!! Amazing Fredo!!
Frez
gofrez
Postby Daniel S » Fri May 28, 2010 1:13 pm
Here I make another quick test for loft feature. It´s simple but y really want to know if it would work in this cases.
Daniel S
Daniel S
Postby robert111 » Fri May 28, 2010 1:18 pm
i like this plugin, but i dont see link to dowload it
can anyone have link for this good plugin??
robert111
Postby solo » Fri May 28, 2010 1:22 pm
See title, it's a 'Preview', the plugin is still under construction and is not yet available.
solo
Global Moderator
Postby Howard leslie » Fri May 28, 2010 1:56 pm
Fredo,
Looks really good.
See attached file - a question for both you Fredo and TIG
The Demo video shows clicking of 3 or 4 seperate lines.
Will it be able to skin the attached file - a closed (welded) single polyline ???
or would it have to be broken up into 3 or 4 seperate polylines first ???
Maybe one of TIGs Extrude Tools can handle closed polylines like the attached file ???
This would be really useful and a feature I'd request if this Script doesn't do it already
(or if TIGs Extrude Tool doesn't already do it).
Regards
Howard L'
Howard leslie
PreviousNext
Return to Plugins
Users browsing this forum: elkadom, gyumin choi, mdsyagora and 13 guests
