[Plugin Beta] Curviloft 1.8a - 31 Oct 18 (Loft & Skinning)
Re: [Plugin Preview] Curviloft 1.0 (Loft and Skinning)
Postby pilou » Thu May 27, 2010 8:40 am
I guess this is a job for JPP. Curviloft only generates the thin surface.
JPP : the "Jean Pierre Papin des surfaces" ;)
( a famous French footballer ;)
-1
Speedy Galerie
Top SketchUcator
Postby fredo6 » Thu May 27, 2010 8:43 am
thomthom wrote:Looking very nice. Can one edit the control splines afterwards?
1:24 - Float Pal window: is that done using view.draw* method?
Tom,
Yes the button palettes are all based on view.draw methods. And for Curviloft, I had to introduce the concept of a floating palette to allow edition of each of the individual sections, as shown on this small video:
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby TIG » Thu May 27, 2010 9:12 am
Fredo
As ever, a "tour de force".
Can't wait to try your new tools...
Very impressive interface and speed.
:bounce:
Global Moderator
Postby CadFather » Thu May 27, 2010 9:57 am
sugar.. everytime Fredo starts these things, it's like another copernican revolution! :lol:
Quarr-IT - SketchUp Training from the Master.. http://quarr-it.com/
CadFather
PluginStore Author
PluginStore Author
Postby thomthom » Thu May 27, 2010 10:00 am
Fredo6 wrote:And for Curviloft, I had to introduce the concept of a floating palette to allow edition of each of the individual sections, as shown on this small video:
Is that adjustments one makes before you end the tool? Or can you take a shape you created earlier and readjust it? On other words, is it parametric?
PluginStore Author
PluginStore Author
Postby fredo6 » Thu May 27, 2010 11:30 am
It's difficult to make things parametric in Sketchup, because all you have at the end is faces and edges.
My plan to help a little bit would be to attach some information to the Component created so that you can reedit later on.
also, and already working is the possibility to generate the juctions as curves so that when you move the profiles, then the shape deforms accordingly (something that is shown in Kirill's scripts).
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby thomthom » Thu May 27, 2010 11:34 am
Yea - it was something like that I was wondering if it would do. Very promising!
Once I get Vertex Edit out of the way I want to make Bezier Path modelling tools. The control points stored as attributes for later edit-ability. Of course, if the user was to edit the geometry with other tools that would be ignored.
If the observers behave better in the next SU I want to make modifiers that one can apply to groups/components. Stack them up and apply the modifications after the user edit the base shape.
PluginStore Author
PluginStore Author
Postby notareal » Thu May 27, 2010 11:45 am
Stunning! What a return.
notareal
Thea Render Support
Thea Render Support
Postby Mike Lucey » Thu May 27, 2010 12:39 pm
I think I've figured out how Fredo is doing all this fantastic work ...... if you listen carefully to the video you will hear a lot of squeeking going on in the background ....... well these can only be Creative Gremlins! :thumb:
Mike Lucey
Mayor
Postby olishea » Thu May 27, 2010 2:25 pm
wow :shock:
oli
olishea
Premium Member
Premium Member
Postby Jim Smith » Thu May 27, 2010 4:26 pm
Big thanks in advance for creating this plugin. :ecstatic: Frank Gehry will probably be switching to GSU pretty soon if Fredo keep this up :roll:
"Out of clutter find simplicity,
from discord find harmony,
In the middle of difficulty lies opportunity"
Albert Einstein
Jim Smith
Premium Member
Premium Member
Postby shura » Thu May 27, 2010 4:29 pm
Omg, we are drowning in pleasant anticipation!
shura
Postby Rainie » Thu May 27, 2010 4:53 pm
Hi all,
where we can download this very helpful plugin!!! Thanks!!!
Rainie
Postby thomthom » Thu May 27, 2010 5:10 pm
Rainie wrote:Hi all,
When it is released. This was just a teaser. ;)
PluginStore Author
PluginStore Author
Postby solo » Thu May 27, 2010 5:35 pm
Fredo strikes again!!
Looking forward to another true Gem.
www.solos-art.com
I'm a social vegan, I avoid meet.
solo
Global Moderator
Postby DIEGO-RODRIGUEZ » Thu May 27, 2010 6:21 pm
fredo, great plugins. thank you very much for their continued contributions to the user of sketchup
two questions.
floating panel interface, which uses programming language?
you can use images *. png or other format for icons?
when can download the first version of the plugins?
DIEGO-RODRIGUEZ
Banned
Postby fredo6 » Thu May 27, 2010 7:02 pm
DIEGO-RODRIGUEZ wrote:floating panel interface, which uses programming language?
It is written in pure Ruby and SU API (which makes it portable PC and Mac).
Unfortunately, png cannot be used (the SU API is missing this functionality, but it would be a good idea to add it)
DIEGO-RODRIGUEZ wrote:when can download the first version of the plugins?
Probably not before a month, except if I released only a subset.
This is also why I need to have some sample geometry, beyond what I am doing test with, because I prefer to adapt the algorithm before the script is released)
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby fredo6 » Thu May 27, 2010 7:08 pm
EarthMover wrote:Holy crap!!! Is that speed realtime? Looks amazing! Do the number of segments in the rails matter? Could this possibly be used to replace the standard from contours in the sandbox tools to create graded terrains?
Videos are real time. As usal the performance is driven by the number of facets created, with the exponential slow-down noticed in all scripts.
The number of segments does matter because Curviloft always respects the vertices of the contours and rails. This is why meshes created can be unbalanced or very crowded. In principle, it would be good that users do a rebalancing before applying Curviloft.
For terrain shaping, I would appreciate if you had an example, so that I can answer more accurately.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby solo » Thu May 27, 2010 7:35 pm
Fredo, what kind of example would work for you?
contour maps, completed terrains, an image, point cloud?
www.solos-art.com
solo
Global Moderator
Postby bagatelo » Thu May 27, 2010 7:47 pm
Yes, Only Fredo6... OMG
I can't wait to try this one.
bagatelo
Postby Fletch » Thu May 27, 2010 8:44 pm
Fredo, this is simply astounding work, you are absolutely incredible! :enlight:
Fletch
Twilight Render
Postby fredo6 » Thu May 27, 2010 8:44 pm
solo wrote:Fredo, what kind of example would work for you?
Actually, a SKP model with contours where you want to generate the surface. Curviloft does not work on point clouds.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby thomthom » Thu May 27, 2010 9:11 pm
Fredo6 wrote:It is written in pure Ruby and SU API (which makes it portable PC and Mac).
I've also requested that SU supports this.
Meanwhile, I've made a framework to read BMP images and render them to screen. Though you can't have too many as it'll slow down. But it works fine for creating toolbars.
PluginStore Author
PluginStore Author
Postby fredo6 » Thu May 27, 2010 9:15 pm
Tom,
This was also my first approach (with view.draw GL_POINTS) but it was definitely too slow. I think that if this is added in native code, it can be ultra fast, even fatser than drawing lines and polygons by view.draw.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby thomthom » Thu May 27, 2010 9:23 pm
What speeds up thing greatly is if when you load the bitmaps you sort the pixels by colour, and then draw each colour in bulk.
I load each bitmap for each toolbar button into a hash with the colour as key and the value as an array of point3d objects. Note that I merge all buttons into one hash.
This means that if you are careful about your icon creation and use a palette of fewer colours you increase performance. A little bit pre-processing required, but the bulk drawing makes up for it many times over.
PluginStore Author
PluginStore Author
Postby fredo6 » Thu May 27, 2010 9:25 pm
One more video, on the possibility to borrow contours from within components....
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby thomthom » Thu May 27, 2010 9:27 pm
Fredo6 wrote:One more video, on the possibility to borrow contours from within components....
:thumb: :thumb: :D
PluginStore Author
PluginStore Author
Postby EscapeArtist » Thu May 27, 2010 9:30 pm
That last process vid you just posted would be a great time saver all by itself. I'm trying to think of something creative to offer as a sample, but you've covered pretty much what I'd use already.
EscapeArtist
Top SketchUcator
Postby pilou » Thu May 27, 2010 10:34 pm
On the last example, the curve can make a loop on the same plan?
If yes,there is an automatic clean of the complex auto-intersect skin resulting?
Speedy Galerie
Top SketchUcator
Postby EarthMover » Thu May 27, 2010 10:35 pm
Bloody genius! I'd swear I was looking a video from Rhino or Bonzai!!! :thumb: :thumb:
Content Creator at Skapeup
EarthMover
Premium Member
Premium Member
Next
Return to Plugins
cron
Users browsing this forum: No registered users and 23 guests
