[Plugin Beta] Curviloft 1.8a - 31 Oct 18 (Loft & Skinning)
Re: [Plugin Beta] Curviloft 1.6a - 13 Aug 17 (Loft & Skinnin
Postby jgb » Sun Aug 13, 2017 3:30 pm
NEW RELEASE: Curviloft v1.6a - 13 Aug 17
This is Sunday. Don't you ever take a day off???
__________________
jgb
jgb
Postby fredo6 » Sun Aug 13, 2017 4:26 pm
jgb wrote:NEW RELEASE: Curviloft v1.6a - 13 Aug 17
Precisely, ...I work on the other days...
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby TIG » Wed Aug 16, 2017 12:43 pm
@SWills
Please upload a SKP displaying this issue.
It need not be a big file, just the part with the problem...
Global Moderator
Postby deezprez » Sat Aug 26, 2017 1:18 am
I recently started to have a problem with curviloft lofting along a path. When I choose the two shapes and path it doesnt work, the part outlines change color and nothing happens. This just started two days ago but I have been having issues for a while were it waits for a path to be made and never finishes. I could fix this by closing and reopening sketchup. I really dont know what is happening. I will post the file were im triying to loft the specific shape that just wont work.
deezprez
Postby Dave R » Mon Aug 28, 2017 10:30 am
deezprez wrote:I recently started to have a problem with curviloft lofting along a path. When I choose the two shapes and path it doesnt work, the part outlines change color and nothing happens. This just started two days ago but I have been having issues for a while were it waits for a path to be made and never finishes. I could fix this by closing and reopening sketchup. I really dont know what is happening. I will post the file were im triying to loft the specific shape that just wont work.
I expect it has to do with the small size of your geometry. SketchUp won't create the faces needed at the size of your model. Try scaling it up before running Curviloft. You can scale up and back down or use the method shown by Box here.
Global Moderator
Skinning problem
Postby Einstein » Tue Dec 12, 2017 7:49 pm
Hi! I'm having some problems with Skin Contours:
I am trying to interpolate a face with Skin Contours but the tool didn’t detect the edges perfectly. Changing Vertex Matching or Simplify didn’t help. Usually when I click on created surface, there appears additional floating window showing the connections and I can add some forced pairs. But sometimes, like in this case, I cannot change the geometry.
(the upper screen)
Another issue with adding forced pairs is that sometimes when I succeed with adding but I don’t like the result, I want to “Redo last change” and that change doesn’t redo.
(the lower screen)
So the problem is actually double, within Skin Contours. In the first case I’d like to do exactly what I’m doing in the second one. Is it possible to fix this?
Einstein
Postby jgb » Tue Dec 12, 2017 9:43 pm
Part of your problem, and one that is difficult to control, is the number of segments in the top to bottom and left to right curves are not equal. Curviloft will create extra vertices on opposing curves to line up with vertices on the other side. Therefore you get extra segments on both sides.
You can minimize the problem if both opposing sides are true curves, not segmented lines, by making both curves contain the same number of segments. Select each curve and use Entity Info to adjust the number of segments.
But be aware, 3 sided perimeters will not loft smoothly to adjacent 4 side curves.
Your top drawing has a 3 sided perimeter (on the left) adjacent to a 4 sided perimeter, the way Curviloft will see it.
Even after I do this, I still usually have a lot of cleaning up to do by pulling intersection end points in the mesh to adjacent intersections to reduce the close spaced curves and other errors that creep in.
But Curviloft does 95++% of the work. :thumb: :thumb: :thumb: Can't live without it.
__________________
jgb
jgb
Postby Einstein » Fri Dec 15, 2017 1:46 pm
Yes, tkanks, I'm aware that the numbers of segments should match. But actually my problem is different. I still don't know why I cannot UNDO (in the second case) and why I cannot MATCH VERTICES (in the first case). Looks like something's missing in the plugin's core, with all the respect to Fredo.
Einstein
Postby fredo6 » Sat Dec 16, 2017 1:08 pm
Could you post your model so that I have a look.
As far as I remember, I did not implement an UNDO for manual vertex matching.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Einstein » Wed Dec 20, 2017 8:22 pm
Looks like you did but it doesn't always work ;) Because usually when I add a forced pair I can Undo last action. In some cases I cannot. Also, after cancelling all changes some of them don't cancel. All I do is adding forced pairs, nothing more. I cannot distinguish when I perform an operation which is impossible to undo.
SU file attached in the next post
Einstein
Postby Einstein » Wed Dec 20, 2017 8:25 pm
The model showing the problem
Einstein
Postby sketchartist023 » Tue Jan 02, 2018 9:41 pm
This plugin is ESSENTIAL for me :) THank you much. I will donate as long as I can get my idea to work :P. May I have assistance? I will post up anything you need to know.
Basic Concept: Taking a letter on a plane (non-3D) and forming it around an arc into a poly(preferably a simple rectangle).
I have yet to do this successfully without overlapping and issues with turning it into a solid for 3d printing using this plugin plus a paid version of SUSolid :/
sketchartist023
Postby pbacot » Tue Jan 02, 2018 10:23 pm
sketchartist023 wrote:This plugin is ESSENTIAL for me :) THank you much. I will donate as long as I can get my idea to work :P. May I have assistance? I will post up anything you need to know.
Maybe you can start a post with your specific task. An image of the result you want and a model of what you are starting with --and the result you have so far. Also Curviloft has a lot of features: What process are you using and what seems to be failing?
It could also be that another approach is suggested, not involving Curviloft.
Top SketchUcator
Generate the juntions as SU curves
Postby Einstein » Sun Jan 07, 2018 2:37 pm
"Generate the juntions as SU curves" in Skinning (the icon of blue horizontal line and 3 vertical lines) - what does it do?
Einstein
Problem with contour order in Loft by Spline
Postby Einstein » Sun Jan 07, 2018 9:22 pm
I have another problem with this plugin.
I'm trying to perform Loft by Spline based on 3 curves. I went Contour Selection and I dictated contour order: 1st, 2nd, 3rd. Proceeded to loft. And it didn't apply my choice. Did I do something wrong?
Einstein
Re: Problem with contour order in Loft by Spline
Postby fredo6 » Sun Jan 07, 2018 10:16 pm
Einstein wrote:I have another problem with this plugin.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Einstein » Mon Jan 08, 2018 12:40 am
Is it possible to generate real quads with this tool?
I mean, not to smooth newly-created edges "perpendicular" and "parallel" to given path and only smooth/ soften diagonals?
Einstein
Postby Einstein » Mon Jan 08, 2018 1:26 am
Fredo
I already worked out that I should have first picked the tool, only then choose contours. Now it works fine ;) Thank you.
Einstein
Postby fredo6 » Mon Jan 08, 2018 10:12 am
Einstein wrote:Is it possible to generate real quads with this tool?
I think this is the option "generate Pseudoquads" in the Geometry section of the palette.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Einstein » Mon Jan 08, 2018 12:02 pm
Fredo
Almost, because it softens every edge ;)
Referring to a problem I had earlier:
I discovered that Skin Contours doesn't allow to add forced pairs when input contours embrace a flat surface. I quite often use Curviloft for interpolating flat areas and making organic mesh out of them, like in the screenshot. Normally we can manually match vertices only when output mesh is not planar.
So I'd politely make an improvement idea - to enable manual vertex matching for planar input-output.
Einstein
Postby rv1974 » Wed Jan 17, 2018 1:32 pm
Is there a way to set a new default value
1 for #Seg for example?
rv1974
Postby fredo6 » Wed Jan 17, 2018 2:15 pm
rv1974 wrote:Is there a way to set a new default value
Not really from what I remember.
What can be done however is that Curviloft keeps the latest values of the parameters across sessions. I do this in other plugins.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby rv1974 » Wed Jan 17, 2018 7:17 pm
No, it always returns to 5
rv1974
Postby Einstein » Tue Jan 30, 2018 2:40 pm
Fredo, if you plan to make another update to Curviloft, could you please increase max. values of these parameters: Simplify from 0.15 to 0.8 or something (0.15 is very little, in some cases I'd need much more), Sampling and Interpolation from 40 to 100? With previous releases I would have done it by myself by simply editing CurviloftPalette.rb in Notepad but now these codes are encrypted.
And secondly, there's this bug that when I use the tool, close it and open again, it doesn't bring that menu bar on viewport's top to adjust options but goes straight to generating junction. And I can't come back and set connection options. Have to open a new model and copy my geometry to it. I think it was already discussed somewhere so I'm just bringing it "in the board".
Einstein
Curviloft 1.6a Spline loft - 3+ profiles
Postby L0_Inhabit » Tue Feb 20, 2018 10:45 pm
Hi, I just installed LibFredo and the latest Curviloft plugin. It works fine when I have 3 or fewer profiles, but I'm trying to connect at least 5. How can I accomplish this? All the profiles are simply copies of the same thing, but it won't work when I try to connect more than 3. I am using an imac on High Sierra 10.13.3, Sketchup Pro 2018, and Curviloft 1.6a. The profiles were first drawn in AutoCAD as polylines and the dwg was imported into Sketchup. They are closed line shapes with no surface in between. I have a screen recording, but it's too large to upload. Is there another way I can send? All advice, tips, observations are welcome!!
-Lola
L0_Inhabit
Re: Curviloft 1.6a Spline loft - 3+ profiles
Postby fredo6 » Wed Feb 21, 2018 9:52 am
L0_Inhabit wrote:Hi, I just installed LibFredo and the latest Curviloft plugin. It works fine when I have 3 or fewer profiles, but I'm trying to connect at least 5. How can I accomplish this? All the profiles are simply copies of the same thing, but it won't work when I try to connect more than 3. I am using an imac on High Sierra 10.13.3, Sketchup Pro 2018, and Curviloft 1.6a. The profiles were first drawn in AutoCAD as polylines and the dwg was imported into Sketchup. They are closed line shapes with no surface in between. I have a screen recording, but it's too large to upload. Is there another way I can send? All advice, tips, observations are welcome!!
-Lola
I think it's best to post the model (or an extract of the model with the 5 profiles).
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby fredo6 » Wed Feb 21, 2018 10:08 am
Einstein wrote:Fredo, if you plan to make another update to Curviloft, could you please increase max. values of these parameters: Simplify from 0.15 to 0.8 or something (0.15 is very little, in some cases I'd need much more), Sampling and Interpolation from 40 to 100? With previous releases I would have done it by myself by simply editing CurviloftPalette.rb in Notepad but now these codes are encrypted.
will go in next version
Einstein wrote:And secondly, there's this bug that when I use the tool, close it and open again, it doesn't bring that menu bar on viewport's top to adjust options but goes straight to generating junction. And I can't come back and set connection options. Have to open a new model and copy my geometry to it. I think it was already discussed somewhere so I'm just bringing it "in the board".
Not sure I understand. Curviloft never goes directly to generate Sketchup geometry. It ony goes to Preview mode when you have an initial selection.
Could you clarify and illustrate your case.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby L0_Inhabit » Wed Feb 21, 2018 4:47 pm
-Lola
Fredo
Sorry, fairly new to this, but thanks for the quick reply. All I have are screenshots, couldn't get the screen recording small enough to upload. The 5 profiles change color after I hit the green checkmark, but never actually form a plane..See attached images! I just started a new post under the same name with my sketchup model attached. Also attaching here..Let me know if that helps!
L0_Inhabit
Postby fredo6 » Wed Feb 21, 2018 7:16 pm
@LO_Inhabit
Very simple. Your model is at a very small scale, with a lot of tiny edges in the profiles (<0.1mm). Sketchup does not like this, and Curviloft neither.
Just scale the whole model by x50, and Curviloft will make the tube without problem.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby L0_Inhabit » Wed Feb 21, 2018 7:20 pm
Aha! I knew it had to be simple!! Thank you so much, Fredo!
L0_Inhabit
PreviousNext
Return to Plugins
Users browsing this forum: Ezia91, jonorman, Josh16, nima78, tmakdlf94 and 10 guests
