SketchUcation Plugin Store
[Plugin Beta] Curviloft 1.2d - 13 Apr 12 (Loft & Skinning)
Re: [Plugin Beta] Curviloft 1.0a (Loft by Spline)
Postby Daniel S » Mon Jun 14, 2010 2:11 pm
Thank you Fredo!!! :ecstatic: :ecstatic: :ecstatic:
The loft tool works very well. All seems very user friendly... and that is very difficult in tools like this ones. The use of your hoverselect tool in the manual selection makes it very simple too.
In the release note you say that there are some limitations and unfinished work.
Modify vertex matching by selecting a vertex and dragging it to a new position inside the floating palette is a limitation or a unfinished feature?. That would be awesome.
And is possible to allow SketchUp remember the last position of the floating palette? In the default position I have to move it always because there I have all the SU tools there.
Daniel S
PS. Can´t wait for the other tools :bounce: :bounce: Hope that you can realease more beta versions before the "official release".
Daniel S
Postby Fredo6 » Mon Jun 14, 2010 7:27 pm
cmeed wrote:A seat i recently designed needed an end that curved round and formed the back rest. I've just played for 20mins on the beta and i'm struggling. can curviloft help?
cheers
chris
I think you need to draw first the rails that give the shape of the junction, making sure that each surface would be closed by 4 or 3 curves. Then you can apply the Skinning function.
Fredo
Fredo6
Top SketchUcator
Postby Fredo6 » Mon Jun 14, 2010 7:30 pm
Daniel S wrote:In the release note you say that there are some limitations and unfinished work.
This is rather an unfinished feature. Actually, this is why you have a preview zone in the floating palette, because editing on the model, with faces hiding vertices may be less convenient.
Daniel S wrote:And is possible to allow SketchUp remember the last position of the floating palette? In the default position I have to move it always because there I have all the SU tools there.
Daniel S
Also an unfinished feature
Daniel S wrote:PS. Can´t wait for the other tools :bounce: :bounce: Hope that you can realease more beta versions before the "official release".
The other tools work but may have more issues and unfinished features.
Fredo
Fredo6
Top SketchUcator
Postby vidy » Tue Jun 15, 2010 5:10 am
Hai Fredo, thanks for this pre release ver, im really excited with this capability, thanks againn :ecstatic:
regards,
still so much to learn..
vidy
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Beginner
Postby cmeed » Tue Jun 15, 2010 9:23 am
Fredo[/quote]
Thanks but i couldn't get the rails working with this. I don't understand it completely yet. i need to wait till the documentation comes out as i seem to find myself with alot of colourful lines with 7,8,9 written on them.
But on the up side i worked the path method see pics YES!
cmeed
Postby charly2008 » Tue Jun 15, 2010 1:29 pm
This is a new milestone. I find this tool opens up new design possibilities. The loft tool works very well and easy to understand. Especially because the geometry of the forms can be calculated in advance. Thanks for this wonderful tool.
The last image below is an almost perfect Moebius band. Unfortunately, the last segment is not closed.
More dangerous than ignorance is the illusion of knowledge
charly2008
SketchUp version: 7
License type: Pro
SketchUp use: historical reconstruction
Level of SketchUp: Advanced
Postby TIG » Tue Jun 15, 2010 4:24 pm
Fredo
This is already too impressive :knockout:
Global Moderator
SketchUp version: 8
License type: Pro
Postby Fredo6 » Tue Jun 15, 2010 5:01 pm
Here is the Moebius ribbon with closure
Fredo
Fredo6
Top SketchUcator
Postby hgdn » Wed Jun 16, 2010 1:23 am
Fredo, :berserk:
Great impact for SU users in creating 3d models. With yours I am not afraid of creating 3d models from now on..still new!!! Easy and powerful plugins eventhough you give bug warnings but I have not seen any thing so far!!
Genius and generous Fredo :)
hgdn
Postby lapx » Wed Jun 16, 2010 5:06 am
I've tried it as well. Thanks Fredo for such a wonderful tool. Can you get it to maintain a sharp edge? I noticed it round the corners. Would be nice to have this as an option if available.
lapx
Postby Ruturaj » Wed Jun 16, 2010 1:17 pm
Thank you Fredo Sir,
you are great
Many Many Many THANK you.
I'm shocked man :shock:
This plugin is very helpful thank you.
:ecstatic: :thumb: :) ;)
Thanks,
RuturaJ
Ruturaj
Postby TIG » Wed Jun 16, 2010 1:30 pm
lapx wrote:I've tried it as well. Thanks Fredo for such a wonderful. Can you get it to maintain a sharp edge? I noticed it round the corners. Would be nice to have this as an option if available.
These tools do work very well.... :mrgreen:
The form is auto-smoothed ? You can always select the resultant group and right-click > soften, and set sliders to 0 and all edges will un-smooth/un-soften etc...
or view > hidden_geometry toggle to 'on' and use erase+ctrl+shift to un-soften wiped edges [also remember that erase+ctrl softens wiped edges and erase+shift hides wiped edges - but you must select hidden lines to unhide them using entity info, as there is not erase >> unhide equivalent key-combo...]
Global Moderator
SketchUp version: 8
License type: Pro
Postby massimo » Wed Jun 16, 2010 3:46 pm
Already a must-have plugin. Thank you Fredo. :thumb:
massimo
Global Moderator
SketchUp version: 7
License type: Pro
SketchUp use: other
Postby charly2008 » Wed Jun 16, 2010 4:15 pm
Some ideas with Grow and Curviloft
charly2008
SketchUp version: 7
License type: Pro
Postby charly2008 » Wed Jun 16, 2010 5:05 pm
In some forms it comes to interesting but not unanticipated results.
charly2008
SketchUp version: 7
License type: Pro
Postby Fredo6 » Wed Jun 16, 2010 7:19 pm
charly2008 wrote:In some forms it comes to interesting but not unanticipated results.
Charly,
There are still missing features in Loft along Path, in particular about spiral specific treatments.
But if you can post your model, I can have a look and see if this can be handled.
Fredo
Fredo6
Top SketchUcator
Postby charly2008 » Wed Jun 16, 2010 7:48 pm
Hi Fredo,
attached you wil have a similar model because the first one i have deleted. I selected each segment separately. Thanks again for your plugin, thanks for your efforts.
Karl (Charly)
charly2008
SketchUp version: 7
License type: Pro
Postby charly2008 » Wed Jun 16, 2010 8:09 pm
The same shape with small modifications
charly2008
SketchUp version: 7
License type: Pro
Postby lapx » Thu Jun 17, 2010 3:42 am
Thanks Tig! I'll try it out :bounce:
lapx
Postby Didier Bur » Thu Jun 17, 2010 3:23 pm
Hi Fredo,
I get a bugsplat EVERYTIME I try to "loft by spline", no matter the method used. Any possible conflict with other plugins ?
F: J'ai un bugsplat directement après avoir cliqué l'icône, quelle que soit la méthode de sélection que j'utilise pour les faces, contours, chemins, etc. Est-ce qu'il y a à ta connaissance un conflit possible avec un autre plugin (ceux de TIG par exemple, qui font un job similaire ?).
Je suis scotché, là...
Didier Bur (Bytes Farmer)
Ecole Nationale Supérieure d'Architecture de Nancy (F)
http://rld.crai.archi.fr/rubylibrarydepot/
Didier Bur
SketchUp version: 8
License type: Pro
Postby Fredo6 » Thu Jun 17, 2010 3:38 pm
Didier Bur wrote:Hi Fredo,
At what step do you get the bug splat: selection, preview, generation of geometry?
Is it with any model?
I don't think there are conflicts with other plugins, and anyway not TIG's ones, because I have them in active my environment.
Fredo
Fredo6
Top SketchUcator
Postby Didier Bur » Thu Jun 17, 2010 8:29 pm
@Fredo6: at any time, either in a blank new model, or in a model with geometry in it.
The bugsplat occurs as soon as I click on the icon, once I have selected contours or faces and the path (no problem with selection. :shock:
I'm considering to start with an empty Plugins folder (except curviloft of course :D ) to see what happens.
Didier Bur
SketchUp version: 8
License type: Pro
Postby urgen » Thu Jun 17, 2010 9:24 pm
...Oh, Fredo,thank you very much! :thumb:
--pupil forever...------
urgen
Postby djorkaeff » Thu Jun 17, 2010 9:56 pm
Very good and promising plugin. Thank you for your effort and generosity!
djorkaeff
Postby JClements » Fri Jun 18, 2010 12:22 am
Hi Fredo:
Is there anyway, once the surface group is created, that it could store the Curviloft parameters used? That way the user, if they had not completed all the surfacing, could verify and reuse those settings at a later time.
Perhaps there could be an eyedropper that could "suck up" the values of an existing surface-group and paste them into the Curviloft dialog?
I have been doing a bit of testing using contours from CAD and comparing the results with the Sandbox tool. I was not able to reduce the total curviloft surfaces (triangles and quadrangles) between contour elevations compared to the triangulated surfaces sandbox creates BUT Curviloft places its surfaces where they SHOULD BE unlike Sandbox which places surfaces that "bridge" across vertices of the same elevation ...that is a big time saver.
John
Illustrator
Beaverton, Oregon
JClements
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: illustration, cartoons
Postby pep75 » Fri Jun 18, 2010 8:19 am
This is a brilliant Plug-In...Super. Fredo fantastic!!! This is just what SU needed, just that little extra spline modelling tool. And for free! Better then the Booltools where you'll have to pay for and works 25% of the time...
Fredo you're my hero!
pep75
Postby TIG » Fri Jun 18, 2010 11:20 am
pep75 wrote:This is a brilliant Plug-In... And for free! ...
Please remember that although many of the scripters, like Fredo, do publish their tools freely, there is often a PayPal 'Donation' available - so you can give Fredo a little something, if you think he's worth it [which he is!] - I'm sure he won't object... ;)
Global Moderator
SketchUp version: 8
License type: Pro
Postby autarchos » Fri Jun 18, 2010 2:52 pm
Hi Fredo -
I am having the same problem as Didier with bugsplats. I am able to make geometry selections, but the moment I attempt a loft by spline, SU crashes.
This occurs only on PC for me - the plugin works fine on Mac (both platforms have the latest version of SU)
autarchos
Postby baz » Fri Jun 18, 2010 4:01 pm
had a good play with loft by spline today...
...no probs.
its looking abfab. thanks fredo.
ba
win7, (for my sins :( ). pent4. 3ghz. 3gb ram. nvidea 6600
"What do we want?...Time travel... When do we want it?... Irrelevant"
Thanks to Funny Pics
baz
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby Didier Bur » Fri Jun 18, 2010 4:33 pm
Hi Fredo6,
I finally got it to start without a bugsplat. Select edges, spline, and here is the error message:
Error: #<NoMethodError: undefined method `-' for nil:NilClass>
C:/Program Files/Google/Google SketchUp 7/Plugins/CURVILOFT_Dir_10/CurviloftSpline.rb:953:in `spline_matrix_match_point'
C:/Program Files/Google/Google SketchUp 7/Plugins/CURVILOFT_Dir_10/CurviloftSpline.rb:930:in `spline_matrix_column'
C:/Program Files/Google/Google SketchUp 7/Plugins/CURVILOFT_Dir_10/CurviloftSpline.rb:927:in `each'
C:/Program Files/Google/Google SketchUp 7/Plugins/CURVILOFT_Dir_10/CurviloftSpline.rb:927:in `spline_matrix_column'
C:/Program Files/Google/Google SketchUp 7/Plugins/CURVILOFT_Dir_10/CurviloftSpline.rb:646:in `spline_matrix_analyze'
C:/Program Files/Google/Google SketchUp 7/Plugins/CURVILOFT_Dir_10/CurviloftSpline.rb:645:in `each'
C:/Program Files/Google/Google SketchUp 7/Plugins/CURVILOFT_Dir_10/CurviloftSpline.rb:645:in `spline_matrix_analyze'
C:/Program Files/Google/Google SketchUp 7/Plugins/CURVILOFT_Dir_10/CurviloftSpline.rb:234:in `spline_junction_construct'
C:/Program Files/Google/Google SketchUp 7/Plugins/CURVILOFT_Dir_10/CurviloftAlgo.rb:1371:in `junction_construct'
C:/Program Files/Google/Google SketchUp 7/Plugins/CURVILOFT_Dir_10/CurviloftAlgo.rb:415:in `link_construct_all'
C:/Program Files/Google/Google SketchUp 7/Plugins/CURVILOFT_Dir_10/CurviloftAlgo.rb:415:in `each'
C:/Program Files/Google/Google SketchUp 7/Plugins/CURVILOFT_Dir_10/CurviloftAlgo.rb:404:in `link_calculate_all'
C:/Program Files/Google/Google SketchUp 7/Plugins/CURVILOFT_Dir_10/CurviloftAlgo.rb:377:in `prepare_all'
C:/Program Files/Google/Google SketchUp 7/Plugins/CURVILOFT_Dir_10/CurviloftAlgo.rb:368:in `proceed'
C:/Program Files/Google/Google SketchUp 7/Plugins/CURVILOFT_Dir_10/CurviloftTool.rb:590:in `transition_to_loft'
C:/Program Files/Google/Google SketchUp 7/Plugins/CURVILOFT_Dir_10/CurviloftTool.rb:575:in `notify_edge_picked'
C:/Program Files/Google/Google SketchUp 7/Plugins/LIBFREDO6_Dir_35/Lib6EdgePicker.rb:356:in `call'
C:/Program Files/Google/Google SketchUp 7/Plugins/LIBFREDO6_Dir_35/Lib6EdgePicker.rb:356:in `notify_action'
C:/Program Files/Google/Google SketchUp 7/Plugins/LIBFREDO6_Dir_35/Lib6EdgePicker.rb:1214:in `click_outside'
Hope this helps you to debug somewhat
Didier Bur
SketchUp version: 8
License type: Pro
Are you a Premium Member? Get your freebies here. Are you not a Premium Member yet? Upgrade your account to grab these freebies instantly.
PreviousNext
Return to Plugins
Users browsing this forum: Archistudent, Google Feedfetcher, memille7memille7, Olivier, percy92, snnazzz, Stefan_FVT and 9 guests
