[Plugin] Make Fur v.2.1.0(20140323)Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)Go to the very first post of the thread and scroll down a bit the page. Is there.
Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)What can I do to make this more precise so it wont place anything outside the selected face??
Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)Plugin is great but I have a problem. I use previously modeled component as fur instance. What happens is that each component that fur drops is inverted. How can I make sure this does not happen?
You could use offset tool to make the area smaller. If the component is proprely centered on origin then measure the horizontal distance from origin to the farthest point of component geometry. Use that value to offset the boundary. If you have surface use offset on surface tool. Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)Hi,Davor.
I guess that problem.... Fur brade may up to Z aixis in the component. so I think your component is filpped for Z axis. or Your selected face for making fur is flipped. The Selected Face must directed to upward for you want. or The value of Force(Z) is too strong. Is your case there? Hi,Latetzki. I think like as Davor's,too. Fur is created on the points of selected face. But,The blade of fur has width. offset the face if you want more precise inside. Thanks. -----------
by TAK2HATA
Re: [Plugin] Make Fur (Updated - v.2.0.1 Jun 02, 2013)Hi,All.
I update to version2.0.1 in 2013.06.02. UI is improved. Hi,zieios. The icon is pretty cool! ![]() Fur will be grown thick on sketchup! Thanks. -----------
by TAK2HATA
Re: [Plugin] Make Fur (Updated - v.2.0.1 Jun 02, 2013)Amazing plugin!!!
I just got a hair cut, and didn't know how to fullfill my hair. But, now I found a way Thank you ![]()
Re: [Plugin] Make Fur (Updated - v.2.0.1 Jun 02, 2013)Thanks for update, there is a czech translation.
Re: [Plugin] Make Fur (Updated - v.2.0.3 Jun 02, 2013)Hi,All.
Now I place the new language files in language folder. fur_lang_farsi.txt:Persian translation by Majid.Thanks! fur_lang_cz.txt:Czech translation by Pepa.Thanks! Hi,Anton! Nice hair! I wish if I had hair like him. It will need too much hair spray. Thanks! -----------
by TAK2HATA
Re: [Plugin] Make Fur (Updated - v.2.0.4 Jun 02, 2013)Thank you for update and new interface
![]() ![]() My perspective shortcuts book: https://bit.ly/30Tdbce
Re: [Plugin] Make Fur (Updated - v.2.0.4 Jun 02, 2013)Thanks for the update, I have done a new translation for Spanish Language, I add new strings to the file.
Spanish Language v2.0.4
Re: [Plugin] Make Fur (Updated - v.2.0.4 Jun 02, 2013)thanks for the update, great plugin I use it regularly.
erikB Re: [Plugin] Make Fur (Updated - v.2.0.4 Jun 02, 2013)Thanks Hebeijianke and Oxer for uploading the translation files.
Now I'm busy ,so I will update plugin including these translation files in the end of this week. Thank you very much! -----------
by TAK2HATA
Re: [Plugin] Make Fur (Updated - v.2.0.5 Jun 08, 2013)Hi,All.
I update to v2.0.5. Include new language file for Spanish and Chinese. Thanks Oxer and Hebeijianke! Enjoy! -----------
by TAK2HATA
Re: [Plugin] Make Fur (Updated - v.2.0.5 Jun 08, 2013)Preview shows fur on the selected face but after clicking make fur, quite a number of it go off the selected face. The ones on the face are also scattered unevenly unlike the preview.
Is this what should happen or am i doing something wrong ? Ok, sketchup just crashed. I tried it again and it seems to be fine now. Fur stays on the faces. I stil don't know what happened before and the cause. Re: [Plugin] Make Fur (Updated - v.2.0.5 Jun 08, 2013)Hi,meoa.
I need more information for your problem. I can not know what happened, too. Please upload your model and the picture of the fur setting and selected face. Thanks. -----------
by TAK2HATA
Sorry tak2hata, it was my mistake. I deleted geometry in a component and for some reason it did not rescale or i may have moved the axes by mistake so the component size was far larger than the content(space when you edit the component). Thus, the make fur moved the components further away than the size of the content which explains why they were off the face. Re: [Plugin] Make Fur (Updated - v.2.0.5 Jun 08, 2013)
Hi,meoa. This problem is solved by yourself. Thanks! -----------
by TAK2HATA
Re: [Plugin] Make Fur (Updated - v.2.0.5 Jun 08, 2013)Hello there,
First thanks tak2hata for the wonderful plugin. I'm trying long time now to use this for create a nice Olive tree. While the plugin work perfectly for create the single element. I can not in any way create the proper effect randomizing the element using the "leaf" mode. any suggestion? thanks Re: [Plugin] Make Fur (Updated - v.2.0.5 Jun 08, 2013)Wonderful plugin. Here is Serbian translation. Just to feel the excitement of taking part in an international project
![]() www.saurus.rs
Re: [Plugin] Make Fur (Updated - v.2.0.6 Jun 12, 2013)Hi,
I upload to v2.0.6. Include the language file for Serbian by SRX.Thanks! Hi,menes. I try it! Component for leaves lay along to X-Axis(RED) with litte slope. And place it with large Z value of "direction" and "force" in fur dialog. It make like this placement. Thanks. -----------
by TAK2HATA
Re: [Plugin] Make Fur (Updated - v.2.0.6 Jun 12, 2013)i loved this plugin already, and now it´s even better! Arigato Gozaimasu Tak2Hata
Re: [Plugin] Make Fur (Updated - v.2.0.6 Jun 12, 2013)![]() Thank you very much indeed! TAK2HATA Will try and let you know Re: [Plugin] Make Fur (Updated - v.2.0.6 Jun 12, 2013)Thanks TAK2HATA
You put me in the right way ![]() My values were different Main Detail type : leaf top jitter :8 Density: 60.000 width jitter: 19 Max n. :60.000 stiffness jitter : 50 length :1 valid distance: 0,000 rootwidth : 0,200 direction (x): 0,000 stiffness : 1 direction (y): 0,000 divide :2 direction (z): 1 force (x):0 force (y):0,000 force (z):-30 now the only thing to try ,it's to avoid many leaves at the bottom of the branches and have more on the top. Re: [Plugin] Make Fur (Updated - v.2.0.6 Jun 12, 2013)Hi,
Thanks for the plugin! But I have a problem. It seems that I can't get v2.0.6 to work on the new Sketchup 2013. Am i doing something wrong? As usual I've placed the plugin in C:\Program Files (x86)\SketchUp\SketchUp 2013\Plugins. Re: [Plugin] Make Fur (Updated - v.2.0.6 Jun 12, 2013)Great plugin
![]() 2011 iMac
SU 2015 Pro, 2017 Make V2 Twilight macOS Sierra 10.12.5
Users browsing this forum: ambarogli, Bradds205, marian_27_97, meril, michael850805, Tolik and 16 guests
