[Plugin] Make Fur v.2.1.0(20140323)
Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)
Postby cas_123 » Sun Jan 27, 2013 8:30 pm
Thank you, I downloaded it via IE. I put this unwrapped folder 'fur_en15a' in folder 'Plugins' in SketchUp files but it doesn't work. What should I do?
cas_123
Postby Ineshtine » Sun Jan 27, 2013 9:00 pm
cas_123 wrote:Thank you, I downloaded it via IE. I put this unwrapped folder 'fur_en15a' in folder 'Plugins' in SketchUp files but it doesn't work. What should I do?
You must unzip it to that folder.
What? you haven't tried Raylectron yet?
Ineshtine
Postby cas_123 » Sun Jan 27, 2013 9:04 pm
I did but it doesn't work :/
cas_123
Postby Ineshtine » Sun Jan 27, 2013 9:46 pm
cas_123 wrote:I did but it doesn't work :/
Make sure that the fur_en folder and the fur_en.rb file is in your ..Sketchup\Plugins\ folder and re-start Sketchup if it was already opened.
if that doesn't work still, then let me ask.. what doesn't work? The fur plugin? or it's not in your Plugin menu? Give me some clues.
Ineshtine
Postby cas_123 » Sun Jan 27, 2013 10:10 pm
Thank you very much, the problem was that I had it all in fur_en15a folder (not.zip), instead of having it autonomously in Plugins folder, now it works, thanks a lot and sorry for keeping on at you.
cas_123
Postby Zacchia » Fri Feb 01, 2013 2:58 pm
Thanks for this very helpful plugin! I will use it for carpets.
Is it possilbe to delete a preset I saved ? How?
Zacchia
Postby slapfoot » Fri Feb 08, 2013 8:29 pm
Ineshtine wrote:Yes, indeed. But this is not the problem. The real problem is, the grass generation is not evenly distributed (sometimes). There is more grass on some areas (looks like big triangles). It does this with the green dots, and also when making the fur.
I have a suggestion. Can you implement clipping for the crowd? If we use a wide object instead of a tall object (like people), they go over the face edges. It would be nice if they clip, or moves inside so they don't go over the edges.
BTW, Thanks for this fantastic plugin, I love it.
Anyone have a solution to this problem? I've encountered the same issue. Even just drawing a simple rectangle and generating the grass - the fur is concentrated in these triangle shapes.
slapfoot
Postby slapfoot » Fri Feb 08, 2013 8:38 pm
"The real problem is, the grass generation is not evenly distributed (sometimes). There is more grass on some areas (looks like big triangles). It does this with the green dots, and also when making the fur."
Any solution to this issue yet? I'm experiencing the same problem (using SK8 if that helps). Even when generating fur on a simple rectangular face - the fur distributes unevenly into these weird triangles. So i'll be left with fur concentrated triangles and then more sparse regions. Any help would be most appreciated!
- slapfoot
slapfoot
Postby tak2hata » Sun Feb 10, 2013 8:38 am
slapfoot wrote:"The real problem is, the grass generation is not evenly distributed (sometimes). There is more grass on some areas (looks like big triangles). It does this with the green dots, and also when making the fur."
- slapfoot
Hi,slapfoot.
The generating method was not improved.
Please set the large value to "MaxNumber(/Face) :".
But too many furs will make the model file size too large.
Please notice about this.
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Postby cricrichan1984 » Thu Mar 14, 2013 9:08 pm
Thank you!! :)
That a sweet plugin
cricrichan1984
Postby jujepoy » Tue Mar 19, 2013 8:35 am
where to download?
jujepoy
Postby thomthom » Tue Mar 19, 2013 9:39 am
jujepoy wrote:where to download?
In the first post on the first page of this thread.
PluginStore Author
PluginStore Author
Postby cucumuda » Mon Apr 01, 2013 2:37 pm
how to i get the plugin?
can u tell me how to download the plugin.... :)
the plugin very nice....
cucumuda
Postby pilou » Mon Apr 01, 2013 5:21 pm
Click on this link ;)
it's the same than the current version that you can find on the first post of this thread!
Download it Unzip and put it on the Plugins folder!
Speedy Galerie
Top SketchUcator
Postby jujepoy » Mon Apr 08, 2013 3:03 am
pls help me where to download this plug.in
jujepoy
Postby massimo » Mon Apr 08, 2013 7:14 am
Go to the very first post of the thread and scroll down a bit the page. Is there.
massimo
Postby ATBP » Mon Apr 08, 2013 4:36 pm
Very nice. :sketchstatic:
ATBP
Postby Latetzki » Sun May 05, 2013 1:38 pm
What can I do to make this more precise so it wont place anything outside the selected face??
Latetzki
Postby DavorP » Sun May 05, 2013 3:23 pm
Plugin is great but I have a problem. I use previously modeled component as fur instance. What happens is that each component that fur drops is inverted. How can I make sure this does not happen?
DavorP
Postby DavorP » Sun May 05, 2013 7:01 pm
Latetzki wrote:What can I do to make this more precise so it wont place anything outside the selected face??
You could use offset tool to make the area smaller. If the component is proprely centered on origin then measure the horizontal distance from origin to the farthest point of component geometry. Use that value to offset the boundary. If you have surface use offset on surface tool.
DavorP
Postby tak2hata » Mon May 06, 2013 6:27 am
Hi,Davor.
I guess that problem....
Fur brade may up to Z aixis in the component.
so I think your component is filpped for Z axis.
or Your selected face for making fur is flipped.
The Selected Face must directed to upward for you want.
or The value of Force(Z) is too strong.
Is your case there?
Hi,Latetzki.
I think like as Davor's,too.
Fur is created on the points of selected face.
But,The blade of fur has width.
offset the face if you want more precise inside.
Thanks.
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Re: [Plugin] Make Fur (Updated - v.2.0.1 Jun 02, 2013)
Postby tak2hata » Sun Jun 02, 2013 5:27 am
Hi,All.
I update to version2.0.1 in 2013.06.02.
UI is improved.
Hi,zieios.
The icon is pretty cool! :ecstatic:
Fur will be grown thick on sketchup!
Thanks.
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Postby Anton_S » Sun Jun 02, 2013 6:51 am
Amazing plugin!!!
I just got a hair cut, and didn't know how to fullfill my hair.
But, now I found a way
Thank you :fro:
Anton_S
PluginStore Author
PluginStore Author
Postby pepa » Sun Jun 02, 2013 12:56 pm
Thanks for update, there is a czech translation.
pepa
Re: [Plugin] Make Fur (Updated - v.2.0.3 Jun 02, 2013)
Postby tak2hata » Sun Jun 02, 2013 1:14 pm
Hi,All.
Now I place the new language files in language folder.
fur_lang_farsi.txt:Persian translation by Majid.Thanks!
fur_lang_cz.txt:Czech translation by Pepa.Thanks!
Hi,Anton!
Nice hair!
I wish if I had hair like him.
It will need too much hair spray.
Thanks!
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Re: [Plugin] Make Fur (Updated - v.2.0.4 Jun 02, 2013)
Postby majid » Mon Jun 03, 2013 4:23 am
Thank you for update and new interface :ecstatic: :thumb:
majid
Top SketchUcator
Postby macmac12 » Mon Jun 03, 2013 1:34 pm
thanks for the update :)
macmac12
Postby Oxer » Mon Jun 03, 2013 1:36 pm
Thanks for the update, I have done a new translation for Spanish Language, I add new strings to the file.
Spanish Language v2.0.4
fur_lang_esv2.0.4.txt
http://www.oxervision.blogspot.com/
Oxer
Postby hebeijianke » Mon Jun 03, 2013 3:53 pm
Chinese translation new
hebeijianke
Postby olishea » Mon Jun 03, 2013 4:08 pm
thanks for the update. great plugin :thumb:
oli
olishea
Premium Member
Premium Member
PreviousNext
Return to Plugins
cron
Users browsing this forum: Antikgilang and 6 guests
