[Plugin] Make Fur v.2.1.0(20140323)
Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)
Postby brokenstaral » Fri Aug 26, 2011 4:10 am
awsome!!
so simple and easy to operate!!
This is by far one of the best and most useful plugins I have ever seen !!!!!
brokenstaral
Postby uzairazam » Sun Aug 28, 2011 11:48 am
i am unable to create furs....when i click make fur....nothing happens....what is wrong with it plz help?
uzairazam
Postby mazureac » Wed Oct 12, 2011 4:45 pm
Thanks for a super plugin!
mazureac
Postby torring » Fri Oct 14, 2011 8:40 am
Great plugin!
torring
Postby stef52 » Sat Nov 12, 2011 11:08 pm
Hello!
i have a little problem with a piece of a terrain shaped with the sand box; what can i do to have a regular surface of grass instead of this triangulated one?
stef52
Postby tak2hata » Sun Nov 13, 2011 4:28 pm
Hi,stef52.
stef52 wrote:Hello!
I think inputing larger number to "MaxNumber(/Face)" in dialog will improve the problem.
How is it?
Please reply if it does not improve the problem.
Thanks.
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Postby eidam655 » Mon Nov 14, 2011 10:54 pm
hello,
thanks for the plugin, grass making is now really easy (and by using component grass, it's also super fast as well!) :)
however, i have a question (a feature request): would it be possible to implement distributing by a B&W texture, or with an exponential fall-off (especially useful with the Valid Distance option)
thanks for answers and i wish you good luck :)
I'm using SketchUp 2017, V-Ray 3.4
eidam655
Postby db9black » Mon Nov 28, 2011 8:39 am
hi tak2hata
i just discoverd this plugin. this plugin is awesome!!! it's a great relief for all SU users. thank you very much! domo arigato gozaimashita!!!!
db9black
Postby mitcorb » Mon Nov 28, 2011 1:51 pm
@steph52:
Viewing your example suggested that you may need to set up a more regular mesh on that slope instead of stretched triangles. More like a fishnet grid. I may have misinterpreted the image, however.
mitcorb
Top SketchUcator
Postby tak2hata » Mon Nov 28, 2011 4:48 pm
Hi,eidam655 and db9black and mitcorb.
Thanks for your replys. :D
eidam655...
Your request is difficult for me.
I did not try processing from a picture yet.
I will search the method for that solution.
Please wait (without Expectation...Sorry.)
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Postby azp136 » Wed Dec 07, 2011 4:34 pm
fur、txt、Oh, thank you
azp136
Postby peter_shaw » Tue Dec 13, 2011 2:46 pm
just found this plugin, it's awesome!
peter_shaw
Postby tak2hata » Tue Dec 13, 2011 4:28 pm
Hi ,peter_shaw.
very nice! :ecstatic:
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Postby eidam655 » Wed Dec 14, 2011 1:05 pm
hi,
here's what i thought of:
current algorithm distributes fur to the whole face/polygon according to a function with multiple parameters, density being one of them. i would suggest something like:
request min and max density from user
request/load the density map from user (file)
stretch image on the face (300x300 px image onto a 1m x 1m face for example)
go through every pixel in image //yeah, this sucks while 1. there's no getPixelColor method in sketchup's sdk as far as i can see, and 2. this is a loop in a loop and takes ages to complete :D
color value divided by white (100%) is the percentage
therefore current density for this area is minDensity+percentage*(maxDensity-minDensity)
...and so on.
yes, there are probably more effective ways to do this.
no, i'm not a computer scientist.
no, i don't know ruby or sketchup's sdk.
no, i'm not sure how this should have helped you.
eidam655
Postby ssw » Sat Dec 24, 2011 12:11 am
CREATING GRASS with HIDDEN EDGES in model with visible edges?
Any way to use the create grass function to do this? Can do this in the create crowd function, but it doesn't have the controls of the blade shape.
A wonderful plug-in that really helps create lush landscaping.
ssw
Postby jdcamc » Tue Jan 24, 2012 2:30 pm
Help! I'm doing something wrong. Here is my setup:
and my render:
As you can see, the grass is just little green dots and the rendering shows nothing at all. What am I doing wrong? :?:
jdcamc
Postby Gaieus » Tue Jan 24, 2012 2:31 pm
Those green dots are the preview only. Did you also press the Make fur button?
Postby jdcamc » Tue Jan 24, 2012 3:24 pm
Well, I thought I did. Let me try it again just to make sure.
Thanks.
jdcamc
Postby jdcamc » Tue Jan 24, 2012 3:47 pm
yippee!! grass and everything - now I guess I'l have to start mowing....
:berserk: :ecstatic:
jdcamc
Postby negiaf » Mon Apr 02, 2012 8:54 pm
thanks alot
its amazing :berserk:
negiaf
Postby asmendong » Wed May 02, 2012 4:32 pm
IVE DOWNLOADED THE MAKE FUR, BUT NO .EXE FILE, ONLY FUR_EN, NOT AND INSTALLER, ONLY IMAGES. ANY HELP PLSSS??
asmendong
Postby TIG » Wed May 02, 2012 11:30 pm
asmendong wrote:IVE DOWNLOADED THE MAKE FUR, BUT NO .EXE FILE, ONLY FUR_EN, NOT AND INSTALLER, ONLY IMAGES. ANY HELP PLSSS??
Arman
Follow the installation instructions on the download page.
There is no 'exe' file or an 'installer' etc. :?
Various files/subfolder in the downloaded 'archive' file will need extracting into the Sketchup Plugins folder... Before you restart Sketchup to get the expected menus/toolbars/etc...
It sounds like you are a complete installation newbie ??? :roll:
There are many posts explaining how to do this in some detail... do a search on the SCF forums...
Please [re]read these and the tools download page guidance notes - if you still can't install it come back to us...
PS: Please don't post using ALL CAPS - it looks like you are shouting at us, it is also harder to read... AND it is generally regarded as bad manners on almost all forums... :(
Global Moderator
Postby pogogt » Sat Jun 09, 2012 9:20 pm
THHAAAAAAAAAAAANNNNKKKKK YOU!!!! this will be very helpfull with my models : )
pogogt
Postby Arrakis10 » Fri Jun 15, 2012 11:44 am
hello this plug in is marvellous.
Just a silly question.
I finally manage to create some grass but it makes me a white model. I dont manage to change the color. It seems to be not a component (herb) so i have to change the color of every single blade of grass?
Arrakis10
Postby FGomes » Sat Jul 14, 2012 8:43 pm
First of all, I would like to confratulate on this excelente plugin.
Im having a little problem with this plugin... When I make "grass", the plugin does not cover all the face.
Could any one help please?
Thanks a lot
FGomes
Postby eidam655 » Sat Jul 14, 2012 9:21 pm
does subdividing the face into smaller regions help?
eidam655
Postby tak2hata » Sun Jul 15, 2012 8:39 am
eidam655 wrote:does subdividing the face into smaller regions help?
Hi,eudam655.
The face Your saying is blade of grass?
Subdivide of blade setting is "DIVIDE".
The blade will be generated more divides when you set it Large number.
Thanks.
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Postby FGomes » Sun Jul 15, 2012 3:38 pm
No. dividing the area does not help. The problem still occurs.
This is very strange... for example, I made a flat rectangle, anda making fur preview, half the side as more "fur" than the other... I tried dividing the area in smaller areas but the problem persists...
FGomes
Postby eidam655 » Sun Jul 15, 2012 3:59 pm
you're wrong, dividing the are will help, you just have so many particles there that it hits some kind of ceiling.
either that or the 30000 maximum per face is too little. how big is the face?
eidam655
Postby FGomes » Sun Jul 15, 2012 4:10 pm
I tried dividing and its the same thing. See the examples and I increased the number to 900000 and it distributes less...
FGomes
PreviousNext
Return to Plugins
Users browsing this forum: enionarimatsu, lokito226 and 13 guests
