[Plugin] Make Fur v.2.1.0(20140323)Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)Would anyone like to share their presets file? There used to be one with a few settings and I just unstalled the latest and now its empty!
Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)Dude Thanks alot! this is a kick ass plug in
![]() ![]() ![]() Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)Great plugin, thanks!!
Which do you think is the best way to create grass along a very large surface? I tried various methods but my model keeps crashing, i suppose due to the large number of polygons ![]() Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)When I try to download it the zip file only has 5 png. files within it nothing else..., is there somewhere else I can download this from??
The zip is fine! There's a .rb file and a folder containing the png file. The .rb file goes into your Plugins folder, as does the folder containing the png files... ![]() TIG
Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)Thanks TIG!!
I didn't have the .rb file. It's working now! Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)Thank A LOT!!!
The very best plug-in for SU. Works wonders! Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)i downloaded the folder only contains the icon png files, does the grass need anything else other than .rg and the icon png files? because i am not getting any grasses on my surface.
Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)Hi Billy,
There are two ways to build the grass:
Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)Thanks man i get it right, i guess i just need to press enter haha
Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)Any tutorial or explanatory PDF, please?
I can't understand all those parameters. What I understand (or I think I do): Type - the shape of the "fur" Density - how much fur on square meter Max number/ Face - overrides "Density" and limit the number of fur/face (not dependent of face area) Length - how long the fur is RootWidth - width at base (if not rectangular) Divide - segments-define curvature smoothness direction x,y,z - how the fur is oriented Units - what units to use (metriv / US) _________________________________________________ This is what I understand, with the explanation that I think it is... the other settings I have no idea what they do. Please explain them to me. I want to make a "furry carpet", but what I get is or all fur oriented in same direction, or many of them, pointing downwards, trough my floor. How to make randomly oriented fur? Thank you. Please help me. DESIGNER AND ARTIST DEREI.UK
Thanks one thousand times! ![]() DESIGNER AND ARTIST DEREI.UK
Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)There are also two buttons: Assign to Material and Get from Material. They seem to do nothing, but I'm sure that they do. I just don't know how to use them.
How to apply texture on created faces? That buttons are related to this? Don't tell me that I must apply texture on every shape created ![]() Thanks. DESIGNER AND ARTIST DEREI.UK
Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)First of all i would like to say thanks to the person who is responsible for this magnificent peace of art.
The tool works wonderful, but i'm facing some errors. Hopefully someone will be able to help me out. Problem 1: The grass or fur is always facing downwards, in other words: upside down. It doesnt matter what i do, its always this way. Problem 2: Somehow, the color is black and white. I was hoping to see the grass turning green. Thanks!! Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)Hi Boestin,
In case 1: is the surface you want to run the plugin on a back face or a front face? Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)Hello Gaieus,
Thank you for you reply. I dont know how I can check that, I am almost sure that it is the top side because when I draw a rectangle, select it and generate fur on this I am in the Top view camera. Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)When you draw a rectangle on the red/green plane, its back face (blue colour) is showing up by default. Right click and reverse faces to change that and now the front face (white) will show upwards.
I am not sure this is the problem but I can imagine. Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)Thanks Gaieus!! That was the problem
![]() You made my day!! Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)Very useful indeed. There must be a variable not shown in settings dialog which controls rotation on a specified axis. (The default effect is visible in the road signs image). It would be a great benefit to have that variable available, and a "jitter" control. But the author has done a fantastic job. Re: [Plugin] Make Fur (Updated - v.1.3d May 20, 2010 6:39 pm
And of course the land of the rising sun drives on the left. Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)I downloaded the plugin and extracted it to my plugins folder (SU 8) and now get a runtime error anytime I open SU. Anyone else have this issue or have a solution?
-Brodie steelblue http://www.steelbluellc.com
Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)I ran into small problem. What can I do to lose that ... problem?
Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)goodmorning!! i need your help!
How can i download this plugin? Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)Hi Sesil,
It is posted as an attachment at the bottom of the first post. Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)
Hi Gaieus, i found the zip file but it doesn't contains any runfile for installation. Sorry for my English,i'm from Greece. Nevertheless, thank you very much. Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)SketchUp plugins are 8mostly) simple text files with an rb (for "ruby") extension. All you need to do is to extract all the content and then copy everything into the plugins folder of SketchUp which is by default (on a 32 bit windows) here:
C:\Program Files\Google\Google SketchUp 8\Plugins\ Also, here is a sticky post about the installation of zipped plugins: viewtopic.php?f=323&t=35746 Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)It's work!!! Thank you very very much. I use some other plugins like omnigrid plugin and it was necessary to make an installation. I think that i'm comfused about the programms and the plugins!!!!
