by goWentgone » Thu Nov 25, 2010 1:42 pm
Hi, I've got SketchUP 8 pro, although it seems really easy to use this plugin, I don't get any fur... I know which settings I should have, but when I click on assign to material, nothing happens... any step by step explanation would be great! thanks in advance.
goWentgone
by nektares » Fri Nov 26, 2010 7:09 pm
Thanks! since i saw this one it instantly became one of my top plugins!
nektares
by fuzzion » Mon Dec 06, 2010 4:09 pm
Fur used to work for me. I didnt use fur for a while.Since then, i installed various plugins including the tgi3d amorph plugin. Now it does not work. It installed fine. It shows up in my tool bar I select face and click make fur with default settings but nothing happens. Even preview doesn't work. I tried it on SU8 where i have only installed the TGi3d plugin, and it does not work. This is an important plugin so any help is greatly appreciated PS. Every other plugin works fine.
"Only the dead have seen the end of war" - Plato
fuzzion
- Name: Josh
- Operating system: Windows
- SketchUp version: 8
- License type: Free/Make
- SketchUp use: hobby
- Level of SketchUp: Advanced
by cupko » Mon Dec 06, 2010 6:53 pm
In rollout menu Make by Component select No instead fur_instance.
cupko
by fuzzion » Thu Dec 09, 2010 5:16 am
cupko wrote:In rollout menu Make by Component select No instead fur_instance.
I tried that on both SU8 and 7.1 but it still does not work. I can click the 'make fur' button a million times but nothing happens
fuzzion
- Name: Josh
by tak2hata » Sun Dec 12, 2010 7:56 am
fuzzion wrote:cupko wrote:In rollout menu Make by Component select No instead fur_instance.
Hi fuzzion. now ,I couldn't find the solution for this problem. I want to see the dialog of the "fur" on your computer. and show "ruby console" before clicking the "make fur" button. (showing "ruby console" is in "windows" in the menubar) if it shows some error message when clicking make fur button, I want to see it. Thanks.
----------- by TAK2HATA
tak2hata
- Name: tak2hata
- License type: Pro
- SketchUp use: architecture
by gr8fzy1 » Mon Dec 13, 2010 9:39 pm
I had an older version that was working for me in SketchUp 7, can't remember what version it was, but I recently downloaded the newest version for my SketchUp 8 Pro (fur_en_15, I think it was called) and it's not functioning right. I get green dots instead of grass or fur. I'll post some screenshots for you. Older fur maker in SKUP 7: http://i44.photobucket.com/albums/f42/g ... nSKUP7.pngFur_en_15 in SKUP 8 Pro: http://i44.photobucket.com/albums/f42/g ... sSKUP8.pngIn the meantime, I've copy/pasted the older furmaker into SKUP 8 and THAT is working, it's just growing the grass upside down.
gr8fzy1
- Name: Christophe Morone
by rombout » Tue Dec 14, 2010 2:35 am
whatever i try icant seem to make anything.... im trying to make simple grass like the example on page one, but im using a component. the mesh only gets rotated just a bit. Also when i try it with plain geometry nothing really happens. im using su6 on mac osx 10.5.6
rombout
- Name: rombout
by fuzzion » Tue Dec 14, 2010 3:01 am
tak2hata wrote:fuzzion wrote:cupko wrote:In rollout menu Make by Component select No instead fur_instance.
First I want to say thank you for making this plugin  Regarding Ruby console, nothing shows up at all. Only green dots appear on the selected plane. Should I install an older version of Fur? I have tried re-installing plugin into folders, but that did not help. Should i re-install Sketchup? Do you think another plugin is causing the problem? PS. Is it possible for future releases to include make Hair with gravity ? Like create cylinderical shape with taper at the end. Below is the screenshot . screenshot_1.jpg
Please, register (free) to access all the attachments on the forums. "Only the dead have seen the end of war" - Plato
fuzzion
- Name: Josh
by kalu » Mon Dec 20, 2010 7:16 pm
I have the same results in Sketchup 8 Pro, they make some kind of dots that's it...
The old version works but I wish the new version works in S8. Thank you for your hard work.
the Plugins is awesome...
THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
kalu
- Name: Gonzalo Arteche
- Operating system: Mac
- License type: Pro
by kalu » Wed Dec 22, 2010 8:25 pm
Hi: Can you fix the problem with Sketchu 8 and works with other plugins or we need to keepp using the older version?....
kalu
- License type: Pro
by Jim » Wed Dec 22, 2010 8:46 pm
After you see the green dots, press the ENTER key.
Jim
- Global Moderator
- Name: Jim
- License type: Pro
- SketchUp use: other
by fuzzion » Thu Dec 23, 2010 4:03 am
Jim wrote:After you see the green dots, press the ENTER key.
That works  ...You are a legend mate
fuzzion
- Name: Josh
by lapx » Thu Dec 23, 2010 6:31 pm
Can the settings be saved to the harddrive in a file to be shared with others?
lapx
by tak2hata » Mon Dec 27, 2010 5:02 am
Hi fuzzion,gr8fzy1,kalu and Jim. I'm sorry about not visitting here recently. Thank you very much for this solution.
In Webdialog, "Preview fur" makes only green points for examining density. "Make fur" makes furs.
In Inputbox, "OK" button makes preview points everytime. after that ,press Enter key to make fur. or press ESC key to return Inputbox.
Hi,rombout. Perhaps this is not solution,I think now.
The First Idea: Make fur is only makes on faces.(and mesh) When the mesh is in group or component and selecting group,MakeFur doesn't work. Open the group and select faces or meshes.
The Second Idea: That is bug. I didn't solve the problem about webdialog in mac os ,yet. If it does not make fur by using inputbox too,this problem is bug in recent version. So I will upload older versions.
Thanks.
tak2hata
- Name: tak2hata
- License type: Pro
by JClements » Mon Dec 27, 2010 4:48 pm
? Wondering if anyone familiar with the various settings could produce a PDF (or some other document type) that would explain and diagram each of the parameters. ?
John Illustrator Beaverton, Oregon
JClements
- Premium Member
- Name: JClements
- License type: Pro
- SketchUp use: illustration, cartoons
by Fletch » Sat Jan 01, 2011 1:43 am
JC, Does THIS help at all?
Fletch
- Twilight Render
by JClements » Sun Jan 02, 2011 1:56 pm
Hi Fletch:
Yes it does. What a nice Christmas present.
Regards, John
JClements
- Premium Member
- Name: JClements
- License type: Pro
by rsalgadojf » Wed Jan 05, 2011 3:41 am
It´s very good but the file came from 27mb to 100mb! So difficulty
rsalgadojf
- Name: Raphael
by Richard » Thu Jan 06, 2011 3:39 am
Hey Fletch thanks mate for posting that reference, will help most people a BUNDLE!
Richard
- Name: Richard
- License type: Pro
by keanuar » Mon Jan 10, 2011 5:01 am
this plug-in is SICK!!! save me tones of time when rendering in vray. no need to constantly tweaking the bump & displacement again. good job buddy!
keanuar
by JavaKom09088 » Tue Jan 18, 2011 7:34 am
xrok1 wrote:8-) this is greaaaat!
hi, may i know what is ur setting for this? i just cant create such natural look of the grass distribute on the ground... thank you
JavaKom09088
by plot-paris » Sun Jan 23, 2011 8:01 pm
hey Fletch, really great reference card. if plugin creators were able to add information to the instructor window in SketchUp, it should be this reference card...
plot-paris
- Name: plot-paris
- License type: Pro
by AcesHigh » Wed Feb 02, 2011 4:12 pm
its a great tool, but I never use it because file size gets so big and the scene so heavy.
AcesHigh
by ramdelgp » Tue Feb 08, 2011 8:43 am
Veryy nice plugin...very usefull  now saving more time on modeling exteriors
ramdelgp
- Name: Ramdel Guerrero
by gospodja » Mon Feb 14, 2011 10:57 pm
Hi, can someone help me.. Ive downloaded the plug in, extracted the files in the same folder as my other plugins for sketchup but still it doesnt appear within the plugin menu when I restart Sketchup.. any ideas? Thanks
gospodja
- Name: gospodja
by TIG » Tue Feb 15, 2011 1:12 am
gospodja wrote:Hi, can someone help me.. Ive downloaded the plug in, extracted the files in the same folder as my other plugins for sketchup but still it doesnt appear within the plugin menu when I restart Sketchup.. any ideas? Thanks
There is only ONE file [.rb] and that goes into the Plugins folder; the remaining files stay inside their sub-folder [fur] that goes into Plugins... If you have misplaced files please tidy up... You should then get a 'menu item' under Plugins ?
- Global Moderator
- Name: TIG
- SketchUp version: 2013
- License type: Pro
by tspco » Tue Mar 01, 2011 5:48 am
Got a question, how do I grow grass on a large scale? Just copy and paste?
tspco
- Name: Ryan
by Comitre » Tue Mar 08, 2011 6:40 am
Hi, is my first time here, i would like to say thanx to everyone that are always running for help who needs... like me. So... i am trying to install the make fur plugin right now. Thank you all. Be blessed by the Force! (Sorry about my poor english)(Talking from Brasil) Bye.
Comitre
- Name: Comitre
by bizmen » Sat Mar 12, 2011 1:04 pm
tspco wrote:Got a question, how do I grow grass on a large scale? Just copy and paste?
hi just back read only you will get fletch reference link. Cheers
bizmen
- Name: Bizmen
Need Authorised SketchUp Training by experts in various disciplines? Check out our Training details.
- Robot
Return to Plugins
