by DareDevil » Wed May 19, 2010 11:29 pm
TIG wrote:Try substituting the comma (,) as the list separator with a semi-colon (;)... so in UK/US 1,2.3,4.5 >> 1;2,3;4,5 in FR.
I tried, but dont work  Or change you regional settings !
Nooooooooo, pleeeeaaaaase  thomthom wrote:I use Norwegian locale, we also use comma as decimal separator. But using period in this plugin works for me.
Can you use the period in the SU standard value input ? I cant ! I must use the comma and the semi-colon as separator (i.e. 10,5;22,4 for a rectangle). I noted something in what you said though: (0.0cm,0.0cm,5.0cm) Did you enter cm into the direction and force vectors? They should not have length indications. Vectors are just direction indicators.
No, cm is in the default setting. If it's 0cm it's ok, but if it's 0 cm (with space) it dont work. OK, I know why I have the unit after value, because it's a SU setting in the Model info : "Display units format". Uncheck it, disable the cm. ... And if I set the Precision (in Model info -> Units) to 0 instead 0,0 all it's ok in the Fur setting windows, I have 0,0,5 (but setting 0cm for Precision or mm for Units in it's not ok for my way of work  )
DareDevil
- Name: Didier D
by tak2hata » Thu May 20, 2010 1:33 am
Frederik wrote:Would it be possible to add an option, where you can select that components don't intersect with each other...??
That's very difficult for me.I will challenge future.Please wait without expecting it. daredevil wrote:I'm french and use SU on a french vista system. In french we use the comma (,) for decimal separation If it's 0cm it's ok, but if it's 0 cm (with space) it dont work.
Indeed,I learnt it for the first time. I will think about some measures for that problem. Thomas wrote:could you keep the filename free from the version number? That way it's easier to update by just dragging the file into the plugins folder overriding the old.
Thanks.That's right! I will keep the filename.
----------- by TAK2HATA
tak2hata
- Name: tak2hata
- Operating system: Windows
- SketchUp version: 8
- License type: Pro
- SketchUp use: architecture
by Frederik » Thu May 20, 2010 7:03 am
tak2hata wrote:That's very difficult for me.I will challenge future.Please wait without expecting it.
I'll keep my fingers crossed...  This plug-in is so much fun to work with... You have my deepest respect...
Frederik
- Top SketchUcator
- Name: Kim Frederik
- License type: Pro
- SketchUp use: engineering and mechanical design
- Level of SketchUp: Advanced
by thomthom » Thu May 20, 2010 8:34 am
daredevil wrote:Can you use the period in the SU standard value input ? I cant ! I must use the comma and the semi-colon as separator (i.e. 10,5;22,4 for a rectangle).
Not in the SU VCB area, no. But this plugin doesn't use this, does it? What I was referring to was the webdialog (metric) for this plugin. The screenshot I showed last time. daredevil wrote:No, cm is in the default setting. If it's 0cm it's ok, but if it's 0 cm (with space) it dont work. OK, I know why I have the unit after value, because it's a SU setting in the Model info : "Display units format". Uncheck it, disable the cm. ... And if I set the Precision (in Model info -> Units) to 0 instead 0,0 all it's ok in the Fur setting windows, I have 0,0,5 (but setting 0cm for Precision or mm for Units in it's not ok for my way of work  )
Are you seeing "cm" in the webdialog for this plugin? I'm confused... Or are you talking about SU in general?
- Global Moderator
- Name: thomthom
- License type: Pro
by tak2hata » Thu May 20, 2010 10:39 am
Hi,All. I update fur plugin. Now it's version 1_3d. this fileName will keep to "fur_en.rb" for future. When you use this version ,you must remove older version fur plugin file from sketchup plugins folder.
Thanks.
tak2hata
- Name: tak2hata
- License type: Pro
by thomthom » Thu May 20, 2010 10:52 am
Good stuff! Very nice plugin this. Shaping up good. Another remark: menu names, can you also avoid version number in the menu names? Keep them static? Because when the menu name changes between updates the shortcuts assigned to them doesn't work any more.
- Global Moderator
- Name: thomthom
- License type: Pro
by thomthom » Thu May 20, 2010 11:30 am
hmmm... I now see the problem daredevil talked about. tak2hata: When the user's locale is decimal you can't use the comma to get the various components of the vectors. 2010-05-20 12h02_47.png "0,400mm,0mm,0mm" is interpreted as x=0, y=400, z=0The problem is this: - Code: Select all
def fur_dialog_ini @fur_units_metric = false @fur_units_metric = true if ( 0.to_l.to_s )["m"] @delim = "," @delim = ";" if Sketchup.get_locale.upcase == "FR" end
This code only checks for FR Sketchup locale. But there are many more that uses , comma as decimal delimiter. Norwegian for instance. But, Sketchup.get_locale does not return the locale of the system. It returns the language code of Sketchup. For instance, I use Norwegian locales, but use English SU. Sketchup.get_locale returns en-USI've been recently struggling with this myself. And the hack I ended up using to find the user's comma decimal separator was this: @decimal_separator ||= 1.2.to_l.to_s.match(/\d(\D)\d/)[1]See viewtopic.php?f=180&t=28346 for more info. Now, this only gives you what the comma separator is. I've not found a way to find the list separator. Just I think you can catch most cases by assuming locales with comma as decimal separator uses ; as list separator. So to revise your code: - Code: Select all
def fur_dialog_ini @fur_units_metric = false @fur_units_metric = true if ( 0.to_l.to_s )["m"] decimal_sep = 1.2.to_l.to_s.match(/\d(\D)\d/)[1] @delim = ";" if decimal_sep == ',' end
Then there is the other part of that method: @fur_units_metric = false @fur_units_metric = true if ( 0.to_l.to_s )["m"]Use model.options to get the user units. http://code.google.com/apis/sketchup/do ... ml#optionsIt returns an OptionManager that gives you access to some OptionsProvider classes. http://code.google.com/apis/sketchup/do ... nager.htmlhttp://code.google.com/apis/sketchup/do ... vider.htmlTo inspect the available options, use this snippet: Sketchup.active_model.options.keys.each {|key| p key; Sketchup.active_model.options[key].each {|k,v| puts "> #{k} - #{v}"} }Using that you can see that model.options["UnitsOptions"] gives you all the info you need about the model units. model.options["UnitsOptions"]["LengthUnit"] gives you the unit type. The unit types are: // LENGTH_FORMAT: 0 = Decimal, 1 = Arcitectural, 2 = Engineering // LENGTH_UNITS: 0 = Inches, 1 = Feet, 2 = Millimeters 3 = centimeters, 4 = Meters // LENGTH_PRECISION: number of decimal places to show(Found this in the Google SketchUp 7\Resources\en-US\i18n.dat file)
- Global Moderator
- Name: thomthom
- License type: Pro
by Gaieus » Thu May 20, 2010 1:05 pm
Frederik wrote:...Only in UK in Europe (and I believe on Cypres too) they drive in the left side...
And Ireland, too.
- Administrator
- Name: Csaba Pozsárkó
- SketchUp version: 2013
- License type: Pro
- SketchUp use: historical reconstruction
by watkins » Thu May 20, 2010 1:18 pm
watkins
by solo » Thu May 20, 2010 1:29 pm
Countries that drive on the left
Looks like a British commonwealth map.
My site Quod gratis asseritur, gratis negatur.
solo
- Global Moderator
- Name: Pete Stoppel
- License type: Pro
- SketchUp use: other
by Gaieus » Thu May 20, 2010 1:59 pm
Yeah. Though already a minority of the countries, still "the sun never sets over the countries that drive on the left".
- Administrator
- License type: Pro
by Pilou » Thu May 20, 2010 2:15 pm
And when French user uses directly FR Locale "." (modified) whith English SU version seems there is no problem?  wind.jpg
Pilou
- Top SketchUcator
- SketchUp version: 6
- License type: Free/Make
- SketchUp use: hobby
by tak2hata » Thu May 20, 2010 3:00 pm
Hi, All. I update this to v1.3e. Thomas,Thank you very very much! At last, I also understood. I use your code "decimal_sep = 1.2.to_l.to_s.match(/\d(\D)\d/)[1]". and model.options["UnitsOptions"]["LengthUnit"] >= 2 then unit is metric. It not depend to Sketchup locale.
I think that this is perhaps no problem. please reply when there is a problem.
tak2hata
- Name: tak2hata
- License type: Pro
by thomthom » Thu May 20, 2010 3:11 pm
tak2hata wrote:I use your code "decimal_sep = 1.2.to_l.to_s.match(/\d(\D)\d/)[1]". and model.options["UnitsOptions"]["LengthUnit"] >= 2 then unit is metric. It not depend to Sketchup locale.
I think that should work.
- Global Moderator
- Name: thomthom
- License type: Pro
Oh - you posted update already! I see. I'll try it out then.
- Global Moderator
- Name: thomthom
- License type: Pro
by thomthom » Thu May 20, 2010 3:13 pm
 1.3e not working for me. Error: #<NoMethodError: undefined method `[]' for nil:NilClass> C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/fur_en.rb:734:in `fur_dialog_ini' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/fur_en.rb:741:in `fur_webdialog' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/fur_en.rb:1414 C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/fur_en.rb:1413:in `call'
- Global Moderator
- Name: thomthom
- License type: Pro
by TIG » Thu May 20, 2010 3:34 pm
With 1.3e I get Error: #<TypeError: no implicit conversion to float from nil> C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:1326:in `initialize' C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:1326:in `new' C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:1326:in `s_to_vec' C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:713:in `show_webdialog' C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:658:in `call' with the 'web-dialog' accept button. You must be passing an empty argument to a defn ?
- Global Moderator
- Name: TIG
- License type: Pro
by tak2hata » Thu May 20, 2010 4:28 pm
thomthom wrote::( 1.3e not working for me.
I think this is LengthFormat or LengthPrecision problem. So I will change code.. - Code: Select all
def fur_dialog_ini unitoptions = Hash.new Sketchup.active_model.options["UnitsOptions"].each{|key ,val| unitoptions[key] = val } Sketchup.active_model.options["UnitsOptions"]["LengthFormat"] = 0 if unitoptions["LengthFormat"] != 0 Sketchup.active_model.options["UnitsOptions"]["LengthPrecision"] = 1 if unitoptions["LengthPrecision"] == 0 @fur_units_metric = false lunit = unitoptions["LengthUnit"] @fur_units_metric = true if lunit >= 2 lprec = Sketchup.active_model.options["UnitsOptions"]["LengthPrecision"] @decimal_sep = 1.2.to_l.to_s.match(/\d(\D)\d/)[1] @delim = "," @delim = ";" if @decimal_sep == ',' unitoptions.each{|key ,val| Sketchup.active_model.options["UnitsOptions"][key] = val } end
TIG wrote:With 1.3e I get Error: #<TypeError: no implicit conversion to float from nil> C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:1326:in `initialize' C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:1326:in `new' C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:1326:in `s_to_vec' C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:713:in `show_webdialog' C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:658:in `call' with the 'web-dialog' accept button. You must be passing an empty argument to a defn ?
Sorry,I will change the code.
tak2hata
- Name: tak2hata
- License type: Pro
by thomthom » Thu May 20, 2010 4:59 pm
Why are you doing this?
You're changing the model settings.
- Global Moderator
- Name: thomthom
- License type: Pro
by thomthom » Thu May 20, 2010 5:02 pm
This whole thing makes no sense... - Code: Select all
You create an hash to store model UnitOptions, then change them and then restore the original values...?
- Global Moderator
- Name: thomthom
- License type: Pro
by thomthom » Thu May 20, 2010 5:08 pm
From what I could understand, that method could be condensed to: - Code: Select all
def fur_dialog_ini units = Sketchup.active_model.options["UnitsOptions"]["LengthUnit"] @fur_units_metric = (units >= 2) # true if units are 2 or greater @decimal_sep = 1.2.to_l.to_s.match(/\d(\D)\d/)[1] @delim = (@decimal_sep == ',') ? ";" : "," end
- Global Moderator
- Name: thomthom
- License type: Pro
by tak2hata » Thu May 20, 2010 5:47 pm
Hmmm, When LengthFormat is Architectural or LengthPrecision = 0, "1.2.to_l.to_s.match(/\d(\D)\d/)[1]" return error.
Is that problem excluding this?
tak2hata
- Name: tak2hata
- License type: Pro
by thomthom » Thu May 20, 2010 5:58 pm
Ah, yes. I see the problem. ..hm... this needs some more thinking...
- Global Moderator
- Name: thomthom
- License type: Pro
by thomthom » Thu May 20, 2010 6:14 pm
Ok - turns out that you can't trust the SU methods to extract the decimal separator as model settings affects the length to string formatting. (Should have thought of that.  ) Looking at there seems to mostly be just comma or period as decimal separator. At least if you make that assumption it will cover most. So here is an alternative: - Code: Select all
def get_decimal_separator # If this raises an error the decimal separator is not '.' '1.2'.to_l return '.' rescue return ',' end
def fur_dialog_ini @decimal_sep ||= get_decimal_separator @delim ||= (@decimal_sep == ',') ? ";" : "," end
This snippet makes some assumptions: Only comma or period as decimal separator. If the separator is a period then comma is used as list separator. If the separator is a comma then ; is used as list separator. The method is working out the decimal separator is by trial and error.
- Global Moderator
- Name: thomthom
- License type: Pro
by jchau2007 » Thu May 20, 2010 9:40 pm
wow... keep it coming. Thanks.
jchau2007
- Name: James
by AcesHigh » Thu May 20, 2010 9:44 pm
I thought of a very cool thing to do with this plugin... those xmas stuff that you put on Xmas trees, you know?? Well, actually this plugin also makes it easy to do the Xmas tree itself. I am talking about this thing that goes around the tree
AcesHigh
by Rich O Brien » Thu May 20, 2010 10:12 pm
Is v1.3e working for others?
Nothing happens when i select it?
Rich O Brien
- Administrator
- Name: Rich O'Brien
- License type: Pro
by EscapeArtist » Thu May 20, 2010 10:16 pm
I did have some issues as well, didn't check the console though. I had a model I'd saved using the previous "make fur" revision and was attempting to use the plugin, nothing happened - dialogue wouldn't open. I opened a "new" scene (File > New) and then the plugin worked.
EscapeArtist
- Top SketchUcator
- Name: Jeff
- License type: Pro
by tak2hata » Fri May 21, 2010 8:11 am
I update to version 1.3g. Vector parameter split to 3 parameter each. and I change preset file. I think this vesion has problem yet.
For the time being, It going on my sketchup. But very difficult for me to convert units. and so tired.
Thanks.
tak2hata
- Name: tak2hata
- License type: Pro
by thomthom » Fri May 21, 2010 8:24 am
I appears to work. I'll see if I can get some time to have a better look at your script and see if I can help with the units.
- Global Moderator
- Name: thomthom
- License type: Pro
Return to Plugins
