SketchUcation Plugin Store
[Plugin] Extrude Edges by Rails to Lattice
Re: [Plugin] Extrude Edges by Rails to Lattice
Postby TIG » Fri May 07, 2010 6:46 pm
There's a new version of EEbyRailsToLattice in the zipped set.
The change is to the way the Line only versions are Grouped...
viewtopic.php?p=242239#p242239
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby numerobis » Fri May 07, 2010 8:12 pm
AWESOME!!! Thank You very much for ANOTHER very helpful tool!!! :berserk:
numerobis
SketchUp version: 8
License type: Pro
Postby simon le bon » Fri May 07, 2010 9:09 pm
robert111 wrote:simn le bon , very nice job , how did you do to have this form plz
can you make tutto ?
Thank you Robert,
very simple.
RE: take care to carefully place the component axis (the blue axis is going to follow the curves)
Then You will need Component Stringer from (our wellknown very nice fellow) Chris Fullmer
It is recommended to apply a shortcut to this plugin :_ Window/ Preferences/ Shortcuts: for example Alt+c
Because we have now to apply it one by one to each diagonal curve.
that's it!
;) simon
simon le bon
Postby Pilou » Fri May 07, 2010 11:49 pm
Have you some easy trick for make faces with the 2 diagonals lattices?
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby TIG » Sat May 08, 2010 8:55 am
If the profiles and rails are parallel [copied etc] the diagonal lines are not needed for face forming - hence the prompt to remove them.
BUT if you make a lattice of the two sets of diagonals [regrouped and exploded], then they do not make coplanar quads and so they can't take faces - of course by adding a diagonal to a quad it will face, but then you have then gone 'full circle' and might as well have used plain EEbyRails in the first place !
So diagonal 'diamond' lattices won't take faces.
This is about as near as you can get - make a quarter using EEbyRails, copy the mesh to one side, Scale -1 to mirror the diagonals and overlay the two so the 'diamonds' form, then manually erase the unneeded orthogonal lines to get the diagonal lattice - note it must have some horizontals to let it 'bend' over. Rotate-Copy x3 to form the whole. Now use Windowizer to add the frames/panes ?
Global Moderator
SketchUp version: 8
License type: Pro
Postby eddy » Sat May 08, 2010 12:13 pm
cool plugin :berserk: :berserk:
thanks, thanks,thanks. :thumb: :thumb:
@ ++ Eddy
eddy
Postby Pilou » Sat May 08, 2010 6:00 pm
@TIG : THX for the precision! 8-)
But for this sort of thing prefer this maybe more easy ;)
I have used Windowiser by Rick Wilson and this little useful plug of Multiple face Offset by Remus, Selection Toy by Thomthom and of course your Inverse Selection! :thumb:
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby TIG » Mon May 17, 2010 10:08 am
There's an updated zipped set available viewtopic.php?p=242239#p242239
All lingvo files have been updated.
Global Moderator
SketchUp version: 8
License type: Pro
Postby maximas » Wed Jun 09, 2010 12:35 pm
please i would like to cretae an effect like this on my facade how can i do this.??
can u do an small tutorial of the use of the plugin??? thanks
maximas
Postby goldenma » Wed Jun 16, 2010 11:31 pm
Thanks TIG, truly marvelous tool!!
one question, though - is there a function to generate 3d geometries on the diagonals? the same effect of "extrude edges by rail by face" but for diagonals.
right now i can get the diagonal lines using "extrude---to lattice", but i'll have to "follow me" each line with a profile.
thanks a lot!
goldenma
Postby TIG » Thu Jun 17, 2010 12:17 am
Use the EEby lattice tool to make a mesh of only the diagonals as lines - one of the options [no 3D yet].
Now you have a set of grouped curves == the diagonals.
You might want to do a bit of un-grouping/regrouping now...
We'll now use EEbyFace...
Draw a face as a profile on the 'flat', in the same entities set as these curves [remember the face's Y=up when extruded].
Use the preselected face and curves with EEbyFace - you should get the face used to form an extrusion with each of the diagonal curve's as a path, in turn...
Global Moderator
SketchUp version: 8
License type: Pro
Postby goldenma » Thu Jun 17, 2010 5:42 pm
Thanks TIG! that's a great tool that i overlooked. it's a lot better than doing follow me on every curve. :ecstatic:
goldenma
Postby Crevard » Fri Aug 27, 2010 10:58 pm
i was just wondering how i could make a lattice dome with this plugin :roll: and btw thx for these awesome plugins !!!!!!
Crevard
Postby TIG » Sat Aug 28, 2010 9:37 am
Crevard wrote:i was just wondering how i could make a lattice dome with this plugin :roll: and btw thx for these awesome plugins !!!!!!
Make a quarter of the dome and then Polar-Array Copy it with Rotate+Ctrl, explode the 4 groups and regroup as 1 etc... See this quick example:
Global Moderator
SketchUp version: 8
License type: Pro
Postby Crevard » Sat Aug 28, 2010 5:42 pm
yes ! this will be really handy in future with my studies ! :D that's really cool now i begin to understand the concept , thanks to you ( RESPEEEECT !!!! )
Crevard
Postby Dem0s » Wed Apr 13, 2011 11:25 pm
i cant work this plugin out, how do i start, when i start extrude edges by edges, i t asks me to select the profile and then the path, but the cursosr gets blocked, i cant select anything.
i' running sketchup 8
Dem0s
Postby TIG » Thu Apr 14, 2011 10:06 am
Dem0s wrote:i cant work this plugin out, how do i start, when i start extrude edges by edges, i t asks me to select the profile and then the path, but the cursosr gets blocked, i cant select anything.
DemOs
I am confused.
You post in the EEbyRailsToLattice thread BUT then write about EEbyEdges which is a different tool ?
However, the tool's request for a profile and path [?] suggest a 'rails' based tool, because EEbyEdges needs two preselected groups and no 'profile' etc.
Can you clarify which tool it is you are having difficulties with - there are several variants.
If it's an EEbyRailsxxxxx type you need to have premade curves [either arcs of lines 'welded' into a curve using weld.rb, an indispensable utility available free from Smustard.com].
You are first asked to pick the Profile curve [the curves highlight in different colors as you pick them]
Then Rail 1 curve [which can't be the Profile again]
Then Rail 2 curve [which can't be the Profile again, BUT could be Rail 1 if a 'parallel' railed mesh is desired - usually it's another curve]
Then the Melding-Profile [which can't be Rail1 or Rail2, BUT could be the Profile if you don't want any morphing along the rails]
The mesh is made [and you are prompted about various aspects of the lattice etc depending on the specific tool type]...
Can you run the tool with the Ruby Console open and report any error messages etc...
Note that an alternative to EEbyRailsToLattice is to use EEbyRails first to make a mesh surface and then post process it with my 'LatticeMaker' tool which gives similar results, BUT this route allows you to tweak the mesh [with View > Hidden Geometry > 'on'] before making the Lattices from it...
Global Moderator
SketchUp version: 8
License type: Pro
Postby Dem0s » Thu Apr 14, 2011 8:38 pm
i am using EEbyEdges, and when i try to use it, i cant select anything at all.
can u explain me every step that i should do.
Should i select the profile etc before i run the plugin?
Dem0s
Postby Pilou » Thu Apr 14, 2011 10:00 pm
Draw your curves
then call the plug
then click your Profil, Rail 1, Rail 2, melding profil (depending of what Extrude Edges tools you use and number of curves)
that all ;)
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby TIG » Thu Apr 14, 2011 10:19 pm
IF you are trying to use 'EEbyEdges' why are you posting in the 'EEbyRailsByLattice' thread ? :roll:
Anyway... :evil:
IF you read the instructions for EEbyEdges you will see that it is somewhat different from the other tools...
For this tool you must make two separate groups containing the sets of edges you want to use.
These need not be 'curves' or even 'connected' edges - just some 'edges' [aka 'lines'].
With those two groups selected you then run the tool EEbyEdges...
After the extrusions are made there are questions about orienting faces, reversing faces etc etc...
Done. :?
Global Moderator
SketchUp version: 8
License type: Pro
Postby Dem0s » Fri Apr 15, 2011 3:43 pm
:oops: sorry i'm getting a bit confused by the names of the diffrent plugins , anyway problem is solved.
thank you very much, and congrats for the tool, its amazing
Dem0s
Postby nvrdunwandering » Sat Apr 16, 2011 4:06 am
Thanks for an absolutely amazing plugin. I've just started using it and am in awe.
I am having one problem though... I'm trying to create a rather complex shape and have found that the only way to do this is by using EEby RailsByLattice bit by bit to create the shape (a kind of circular undulating canopy, if that makes any sense). My Profile is a straight line divided into 14 equal pieces and combined into a polyline. My rails are both polylines with 5 equal sized segments in a curve (they are not identical, one rail is shorter and creates a taper for the circular shape). The melding profile is another straight line, 14 equal segments and combined into a polyline. At first I had no problems. Then making the third one my computer made it through the entire process with no problems and then SketchUp crashed immediately after clicking "no" to "erase original curves." No biggie, I save often. Problem is that it is happening more and more. I've made 10 of these shapes (though no two are identical) and now it crashes multiple times for each one that I do. Always at the same point. I'm afraid to click "no." :? Do I have too many faces for SketchUp, or am I doing something wrong?
Any help on this would be great. Thanks! :D
nvrdunwandering
Postby TIG » Sat Apr 16, 2011 12:00 pm
Try making it in an empty SKP.
If it's likely to try and make faces <1mm across OpenGL and Sketchup might have issues.
If so scale up x10 do the EEby... and then scale back x0.1 - small faces can 'exist', it's just making them that proves problematical!
If you can't resolve it try posting the SKP here and let us have a look at it...
Global Moderator
SketchUp version: 8
License type: Pro
Postby nvrdunwandering » Sat Apr 16, 2011 9:08 pm
Thanks, I'll give that a go as I have another set of these to create. For the one I was working on I did create another SketchUp file and as I made the pieces I copied them into the original drawing and deleted them from the one I was using to create the pieces. This was much more stable. :ecstatic: I'm sure that there are some small spaces that are causing the issue. Thanks again! This tool is amazing!
nvrdunwandering
Postby architorture » Fri Dec 09, 2011 3:41 am
WOWW!! this would mean parametrix design via sketchup limitless. can't wait to try it. thanks broo.. :berserk:
architorture
Postby gherkin » Tue Jul 03, 2012 10:59 pm
You can use the 'weld' plugin ( http://www.smustard.com/script/Weld ) to join arcs together, infinitely, before using this plugin; helping to create very complex shapes in the same number of clicks (4 base curves still apply!):
gherkin
Are you a Premium Member? Get your freebies here. Are you not a Premium Member yet? Upgrade your account to grab these freebies instantly.
PreviousNext
Return to Plugins
Users browsing this forum: arkiyore, chri, dayot, HAL, iwazz, OlfLab, onzki, unearthed and 13 guests
