Plugin for 5D animations in Sketchup
Postby engineeringtheworld » Tue Apr 06, 2010 8:15 pm
Hey all
For the last couple of months I have been developing a program, that let's you run 4D or 5D animations of building process using Google Sketchup and OnTime project scheduling tool (found on: http://www.tdteam.com/ontime/).
This tool connect the 3D elements in Google Sketchup to tasks in a project schedule. When all elements are connected the animation can be started, which will animate building process according to the data inputted in the schedule.
You can download the rbs script that you have to place in your plugins folder on the web address below:
http://www.tdteam.com/ontime5d/skp/ontime5d.rbs (ruby plugin file)
http://www.tdteam.com/ontime5d/skp/bridge.skp (model of a bridge that is ready for animation)
http://www.tdteam.com/ontime5d/skp/skp.zip
(PLEASE TRY THIS ONE, SEVERAL PEOPLE REPORTED PROBLEMS DOWNLOADING FROM 2 LINKS ABOVE)
Just to be transparent: Zip file contains ontime5d.rbs and bridge.skp
If you cannot download the file from the links above, try visiting:
http://engineeringtheworld.wordpress.co ... animation/
and try downloading from links provided. There are some vague instructions listed on the blog post, more instructions to be made in days to come.
Any feedback will be highly valuable for me. Thanx
Ladislav Klinc
Last edited by engineeringtheworld on Wed Apr 07, 2010 4:39 pm, edited 1 time in total.
engineeringtheworld
Re: Plugin for 5D animations in Sketchup
Postby majid » Wed Apr 07, 2010 9:34 am
dear mate, it sounds good, but I was not able to download it, would you plz repair the links?
My V-Ray book for architects: https://goo.gl/cz1oRc
majid
Top SketchUcator
Postby engineeringtheworld » Wed Apr 07, 2010 4:38 pm
Hey,
please try this one:
Please let me know if you were able to get it and unzipp it...
Thanx
engineeringtheworld
Postby indian22 » Thu Apr 08, 2010 1:02 pm
This are the instruction found http://engineeringtheworld.wordpress.co ... animation/
..."For a quick look at what this plugin can do, download the Bridge model, that is listed above. All you have to do next (after you have copied the plugin to your plugin Sketchup folder) is open Sketchup, open Bridge file. Go to Plugins toolbar and select OnTime5D. This will open up a webdialog, where you can login with provided credentials and select Alfred Zampa Memorial Bridge project. Then you can skip the 1 step (where you have to bind the Sketchup model and schedule), click Next Step and you can leave animation running default 30 seconds and once again click Next Step.
On the last step you are greeted with a Play/Pause button and below with a chart of expenses (shown only if there is any money data inputted into the schedule). And still further below is the list of all the tasks that are currently under way in the animation. "
..when i click "Play", appear "error did not get layers"....??????
indian22
Postby engineeringtheworld » Mon Apr 12, 2010 7:21 pm
Please let me know which Operating System you are using and which version of Sketchup you have so I can test it. This error occurres when there is a problem in communication between Sketchup and webDialog (in this case UI of OnTime app).
Thanx
engineeringtheworld
Postby engineeringtheworld » Tue Apr 13, 2010 6:40 am
Hey
Could you please let me know which Operating System you are using and which version of Sketchup. I would like to test your configuration and see what went wrong.
The fact that you get that error means, that there was problem in comunication between Sketchup and webDialog (application UI).
Thanx
Ladislav
engineeringtheworld
Postby indian22 » Tue Apr 13, 2010 4:19 pm
I am using Windows Xp Professional 32 bit and Sketchup version 7.0.8657
bye
indian22
Postby engineeringtheworld » Wed Apr 14, 2010 11:32 am
Hey
Fixed issue, now everything should be working, there was a bug in my app that was only happening on Flash Player on Windows. Now it is fixed and animation should work. Please do try it and let me know:
Program is now tested on:
(1) Mac OS X 10.5.8, with Sketchup 7.1
(2) Windows XP Pro, with Sketchup 7.1
If anyone has either Windows 7 or Windows Vista, please do let me know if program worked.
engineeringtheworld
Postby engineeringtheworld » Mon Apr 26, 2010 8:36 am
Plugin also tested on Windows 7 and it is working.
So OS's tested are:
(1) Mac OS X 10.5.8
(2) Windows XP Pro
(3) Windows 7
I uploaded a quick tutorial, that shows how to operate this plugin:
http://www.youtube.com/watch?v=5_XpB2e-ZDw&fmt=22
Enjoy
engineeringtheworld
Return to Plugins
Users browsing this forum: armandinho0 and 11 guests
