[Plugin] Extrude Edges by Loft
Re: [Plugin] Extrude Edges by Loft
Postby altap » Wed Mar 10, 2010 7:10 pm
:shock: This is really GREAT TIG... and BTW, I want to thank every ruby scripts developpers here again, you're making people happy :thumb: .
On another side while it may be irrelevant in sketchup ?! , what if it was a live loft sort of modifing the profiles( on which the loft volume is created ) and sketchup regenerate automatically the lofted volume. maybe it is too much asked as i'm already very glad to have a loft tool in Sketchup
altap
Postby DIEGO-RODRIGUEZ » Wed Mar 10, 2010 10:01 pm
thanks tig. excellent plugins. actually this set of tools for extrusion is increasingly complete. and further expand the potential of modeling sketchup.
a small observation.
when you select a curve, changes color.
but generates a rare color "Dashedlines" between blue and another color
a question
You can set the number of Segments per Section: independently?
or number of Segments per Section: General.
osea
number of segments between the first and last section selected
Spanish translation:
Small Correction
DIEGO-RODRIGUEZ
Banned
Postby TIG » Wed Mar 10, 2010 11:31 pm
The color 'dashing' is interference between the drawn color and the model's edges - it's pretty much unavoidable - the coloring is only intended to help you remember which curves you you have picked in what order - as ROYGBIV are the rainbow's colors...
You can't currently have different segment-numbers in each section, it's based on the one value you give [which initially defaults as the most segmented curve's edge-count]...
It would be possible to have varying segment counts - I suppose that the dialog could have a section-number entry for each segment defaulting to the maximum number of edges in the pair of curves bounding that section of mesh ? OR it could be a maximum count apportioned across the mesh based on some other factor like the numbers of edges in the curve-pairs...
If users would like that I can come up with something ?
Feedback first please...
Thanks, I'll look at your ES lingvo for a future update...
:geek:
Global Moderator
Postby pilou » Thu Mar 11, 2010 1:15 am
Coloft :)
Speedy Galerie
Top SketchUcator
Postby jonorman » Thu Mar 11, 2010 12:11 pm
A little render testing loft. Thnx for a great plugin. (edit: the blue silke cloth :oops: )
jonorman
Premium Member
Premium Member
Postby teuf » Thu Mar 11, 2010 3:06 pm
jonorman wrote:A little render testing loft. Thnx for a great plugin.
Did you model this car with loft plugin ? :shock:
teuf
Postby hebeijianke » Thu Mar 11, 2010 8:42 pm
TIG: Here's the Chinese lingvo file
extrudeEdgesByLoftZH-CN.rar
hebeijianke
Postby TIG » Thu Mar 11, 2010 8:43 pm
Thanks, the new lingvo will be zipped in with the next update... :)
Global Moderator
Postby sketch13 » Sun Mar 14, 2010 1:08 am
fantastic thanks
sketch13
Postby hsjzyangbin » Wed Mar 17, 2010 12:28 pm
TIG wrote:
is there any plugins forums that control the start/end point of line?
hsjzyangbin
Postby mitcorb » Wed Mar 24, 2010 10:42 pm
Hi, TIG:
Attached is a clumsy half carcass of a fish.
Tailfin done with EExR, I believe.
Main body done with EExR too, but with some corrective restretching and knitting.
Head section begun with progressive modeling by copying the curve and Fredoscaling it into place, and then knitting the faces closed.
Last section done with EExLoft. This section shows the distortion/ drift away from the intended ground curve, even though the ground curve was not part of the selection. You might note the lofted mesh sort of makes a shallow sine wave shape above and below the ground face.
Just wondering how you are progressing on the adjustments you are making.
mitcorb
Top SketchUcator
Postby TIG » Wed Mar 24, 2010 10:47 pm
One of the reasons I think you are getting problems is that many faces of the mesh might be getting too small - try modeling the fish x10 real size and scaling the results down later.
SUp has a limit to how small a face it can make but scaling downwards they stay OK...
EEbyLoft does make a bezier transition curve. To control the form better use EEbyRail ?
Global Moderator
Postby mitcorb » Wed Mar 24, 2010 11:07 pm
Thanks, TIG:
As you can easily verify, each long dimension of the faces in the main body is about 30cm. I had the impression that this was sufficient size threshold, considering that the fish it is based on is in reality ~60cm total length. Thank goodness, he is stuffed! Otherwise, measuring him would just add to my misery of this proportional scaling ritual. I couldn't swim that fast, especially with a tape measure in my hand. :mrgreen:
mitcorb
Top SketchUcator
Postby TIG » Thu Mar 25, 2010 9:59 am
But something ~300mm divides up into many smaller mesh facets and some of these could approach the critical size limit (~1mm) and thereby not get faces etc... :?:
Global Moderator
Postby magnato » Wed Mar 31, 2010 10:31 pm
Thanks for amazing new plugins TIG! I have been playing with them for some days now.
Lately I have been trying Extrude Edges by loft, and I thought I did not get the same result every time. I made an experiment: I did the same procedure 12 times in a row using the plugin. I drew one circle along the red axes and copied the circle copying&dragging it upwards the blue axes 3time the radius. Then I used the Extrude Edges by Loft plugin, clicking on the circles in the same order every time. I chose no to all the questions and took every shape as it.
I was hoping to get at straight shape sooner or later and the 12.th time I got the shape I was looking for. Now, is there any type of random function at work here? Is there a way to get the same straight shape every time by modifing the plugin somehow, or even decide how much the shape should twist every time you use the plugin. That would be an awsome feature!
Tx,
Magnar
magnato
Postby TIG » Wed Mar 31, 2010 10:47 pm
If you add a small piece of edge off one of the nodes of each of the two the 'circles' then that should 'split' the curves to force a 'start/end' to the two of them - then the EEbyLoft 'twist' will become predictable as it will be made 'End to End'... :?:
Global Moderator
Postby magnato » Fri Apr 02, 2010 10:03 am
Like this, a simple line between the two circles. Yes, thats works very nice! Thanks a lot!
Magnar
magnato
Postby TIG » Fri Apr 02, 2010 10:29 am
Or... if you 'angle' the line then the extrusion should 'twist' to match ?
It could also be two separate lines splitting the two loops...
:geek:
Global Moderator
Postby tomot » Fri Apr 02, 2010 7:14 pm
WOW... :bounce: a thing of beauty! ...Nice job TIG
I was wondering if its possible to include a Straight line in the "Extrude Edges by Rails" ruby. I have been faking it by drawing a curve with very little radius up to now. Cheers!
tomot
PluginStore Author
PluginStore Author
Postby magnato » Fri Apr 02, 2010 9:54 pm
I made some other exaples with five curves. Also in this example it seems to be a good idea to add a line to split the curves to force a 'start/end'. By spliting the curves with a line I found it possible to control the outcome every time. Intersecting the curves with a plane did not have any effect, I had to use a line to get the desired effect. Without splitting the curves the outcome seems to be unpredictabe. Is there a way to add anything to the script of the plugin to split the the curves ?
magnato
Postby TIG » Sat Apr 03, 2010 10:24 am
tomot wrote:WOW... :bounce: a thing of beauty! ...Nice job TIG
Draw a straight line to desired length and add an extra line on the end [at an angle so you can see the node easier later].
To make a single line curve for use with the EEby... tools...
Use RickW's weld ruby script tool to weld the two lines into a curve of two segments.
Draw a short line coming off that one node in the curve to split the curve into two pieces.
The curve is split into two pieces - each a straight line but still a curve.
Erase the unwanted piece of curve and the temporary splitter-line.
Don't erase the splitter-line first because the curve might re-heal back into a two segment one !
Global Moderator
Postby magaledon » Thu Apr 08, 2010 7:47 pm
Hello! Where can I download this plugin??
THanks!!
magaledon
Postby TIG » Fri Apr 09, 2010 12:08 pm
magaledon wrote:Hello! Where can I download this plugin??
THanks!!
With most plugins the first post in its topic has the files linked for download - in this case because it's part of a comprehensive zipped set of extrusion tools, there is a link at the end of the first post in this topic which takes you to another page that has the link to download them all in one go...
Global Moderator
Postby EscapeArtist » Fri Apr 09, 2010 1:49 pm
If it wasn't for guys like you making these great plugins I would've quit using SU a long time ago. Awesome addition to the plugin family. Thanks!
EscapeArtist
Top SketchUcator
Postby Ben Ritter » Fri Apr 09, 2010 4:20 pm
TIG, I keep getting bug splats. Trying to do 2 meshes on 3 circles. Each circle has a line attached to it.
Ben Ritter
Postby TIG » Fri Apr 09, 2010 7:37 pm
Ben Ritter wrote:TIG, I keep getting bug splats. Trying to do 2 meshes on 3 circles. Each circle has a line attached to it.
Can you post an example image or skp...
Global Moderator
Postby xrok1 » Sat Apr 10, 2010 6:34 pm
Tomot after you draw a curve then use the move tool to move the center of the arc back into line with the ends. :D
“There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
xrok1
Postby forest19901211 » Mon Apr 12, 2010 3:53 pm
fantanstic
forest19901211
Postby szastoupil » Wed Apr 14, 2010 8:27 pm
Hi. I'm having trouble getting the plugin to work with my model. I have a set of curves I want to join, but I'm not able to select the curves. I tested the install using the arc tool with success. In my model I created the "arcs" by stretching/scaling a circle. I believe I exploded the shape along the way. There must be something fundamental that I missing that is required for the plugin to work. Any thoughts? My file is attached.
szastoupil
Postby Rich O Brien » Wed Apr 14, 2010 9:33 pm
There was a few small errors in your model that prevented using this tool successfully.
First your :arc: 's were exploded, which prevented being able to select them as profiles. If in the future you need to turn exploded curves back to curves use this plugin to 'weld' them back together.
Also some of your :arc: 's didn't touch your 'rails' which would give you an unnecessary twist in your mesh.
I used Fredo's Bezier Tool to create the profiles that matched those in your reference drawing. Make sure you read all of the first post in Fredo's thread for instruction in how to install.
See the attached file, in it I used TIG's EEbyR tool to create the mesh, it probably doesn't suit but it may help? If you've further queries please post back.
aphrodite.skp
Rich O Brien
Administrator
PreviousNext
Return to Plugins
Users browsing this forum: leznah0811, yurry and 12 guests
