[Plugin] Cyma Curve Tool
Re: [Plugin] Cyma Curve Tool
Postby Dave R » Thu Mar 24, 2011 1:28 pm
I just tried it with the same settings, V8 on XP and had no problems with it.
Global Moderator
Postby Bob James » Fri Mar 25, 2011 8:36 am
TIG wrote:Here's an explanation of the the 2 types of Cyma Curve...
I tried to use this to make pipe transitions: bend the pipe x-inches and continue in the original direction.
A ratio of 1.414 does not result in vertical for me (both ends do not extend parallel)
Also, a "follow-me" circle most often results in a long tapering cone off of the opposite end! :o
Bob James
Premium Member
Premium Member
Postby TIG » Fri Mar 25, 2011 10:35 am
Bob
A Cyma Curve is really for making moldings and profiles, and not for 'followme' pipe bends...
A ratio of 1.414 won't give exactly parallel start/ends as it's not exactly sqrt(2) - To enter the more 'exact' value type sqrt(2) - it's easier that typing 1.414213562373095050 etc...
However even that will give slightly 'off vertical' ends, as the tolerances in the Maths etc...
For some reason the Cyma Curve will not always make a good 'followme' path with PipeAlongPath - but with 'vanilla' FollowMe it's better...
If you add short horizontal bits on the ends of the Cyma Curve and use the three as the path it should then give vertical terminations, like this...
You can then move the end circles horizontally to change the 'leg' length as desired...
Global Moderator
Postby Bob James » Fri Mar 25, 2011 6:23 pm
Thanks, TIG.
I realize using this tool for pipes (actually it's more often for electrical conduits) is a little "out of the box", but it was the first thing that popped into my mind when I saw it. Besides, even with adding short segments it's faster than drawing arcs or using bezier curves.
Neat tool :thumb:
P.S. I was using the vanilla follow-me tool (but, yes, in the "real world" I would use Pipe-Along Path). Sometimes, however, SU does not recognize it as a legitimate path.
Bob James
Premium Member
Premium Member
Postby gonashvili » Mon Jan 28, 2013 7:24 am
Can you please explain the formula 2*Y/sqrt(X*X+Y*Y), particulrly the /sqrt part, i'm not familiar with the american way of math writing. Thank you!
Also, I thought the two parts of the curve were supposed to be different, based on Chord proportion [to make them undulate in such beautiful manner :)]?
Even if X and Y are different, the radius is the same, but I might got this all wrong :knockout:
gonashvili
Postby TIG » Mon Jan 28, 2013 11:15 am
2*Y/sqrt(X*X+Y*Y)
The X and Y are the curve's enclosing rectangle's sizes.
The '*' is 'multiply by' [×] - so that in this case it is 2 times the Y value [2*Y].
The '/' is 'divide by' [÷].
The 'sqrt' is the standard abbreviation for 'square-root'.
You can also use 'sqrt(nn)' in the ;input;, substituting 'nn' with the required numerical value - it will then find the square-root for you: you can only add a number, not a formula...
The '()' are used to show that you do the calculations inside them before taking the square-root. Also the '*' parts within them are done before the '+'. Note that the part to the right of the '/' is basic 'Pythagoras' stuff...
The default tool makes 'perfect' aesthetic curves according to the ancient rules explained in the help-text, but quite often these proportions are adjusted for other reasons, hence the opportunity to customize the values...
Global Moderator
Postby function » Tue Oct 15, 2013 10:51 pm
I still get the weird glitch at the bottom of the cymas with all different settings, new windows 7 build, new sketchup installs, and downloading the newest version here... maybe its a plugin conflict???
after exploding, deleting the extra piece and then welding again, the dimensions are still what was input in the dialogue
function
Postby TIG » Thu Dec 12, 2013 10:36 pm
Here's a new future-proofed update.
viewtopic.php?p=230584#p230584
Global Moderator
Postby TIG » Tue Mar 04, 2014 1:48 pm
Here an up date http://sketchucation.com/pluginstore?pln=CymaCurve
Tweaks to lingvo files for v2014 compatibility.
Global Moderator
Previous
Return to Plugins
Users browsing this forum: ferarag, JieBu , Maxsumko, oten kasep, rswenger and 9 guests
