[Plugin] Repeat Copy UPDATED 2-24-2010
Re: [Plugin] Repeat Copy UPDATED 2-23-2010
Postby Chris Fullmer » Wed Feb 24, 2010 10:30 pm
I wanted to mention that there is yet another new version of the plugin updated to smustard, allowing the UI to be moved around and reset. Here is a quick video that shows this capability:
Have fun,
Chris
All my Plugins I've written
SketchUp Team
SketchUp Team
Re: [Plugin] Repeat Copy UPDATED 2-24-2010
Postby utiler » Thu Feb 25, 2010 12:41 am
That's nuts, Chris!!!!!! :sketchstatic: :sketchstatic:
utiler
Top SketchUcator
Postby JClements » Thu Feb 25, 2010 4:09 am
Chris, is there a way to add a "Pause" button which allow the user to pick a different set of components, them by clicking on it a again, it would resume with copying using the current parameters but with the new selection set.
John
JClements
Premium Member
Premium Member
Postby Chris Fullmer » Thu Feb 25, 2010 4:45 am
I like the idea John, but it is a bit more complex to manage. With different sets of scale and randomness. Its hard to visualize. But it could be powerful for sure.
SketchUp Team
SketchUp Team
Postby JClements » Fri Feb 26, 2010 3:20 am
Hi Chris, not sure if I conveyed my suggestion clearly. My thought was that the "Pause Button" would replicate the process of closing the script, making a new selection, and then re-initiating the script.
John
JClements
Premium Member
Premium Member
Postby Chris Fullmer » Fri Feb 26, 2010 3:38 am
Oh gotcha, I did think you were suggesting something a little more complicated.
Yes, that had crossed my mind - the ability to add or remove components from the selection set would be nice. I could see that feature being added to this script for sure.
How about just holding down shift activates this? Or I could make a button to toggle into selection mode.
Chris
SketchUp Team
SketchUp Team
Postby JClements » Sun Feb 28, 2010 12:47 am
Whatever is the easiest. Like to see key combo's close to SU's selection keys if possible; Ctrl-click to add to current selection, maybe Shift-Click to remove one at a time, and Alt-Click to start over.
JClements
Premium Member
Premium Member
Postby Panga » Fri Mar 19, 2010 3:47 pm
Just bought it...very usefull Chris !! Thanks.
Panga
Premium Member
Premium Member
Postby brookefox » Sat May 08, 2010 8:09 pm
Yes, yes, most useful and thank you, but I must respectfully insist: where do those nice face-me trees come from which are in the page 1 tutorial? Your private collection seems not searchable from here, and a nice woods they would make should I need some place to inhabit.
~ Brooke
brookefox
Postby Chris Fullmer » Mon May 10, 2010 5:37 am
Hey Brooke, I almost forgot to respond! The trees are just random trees I found on the 3d warehouse. I just tried to look for them again and no luck. The 3dwarehouse is really lame like that.
Chris
SketchUp Team
SketchUp Team
Postby brookefox » Mon May 10, 2010 6:23 pm
You are very kind, and yes it seems to be.
I will keep mine peeled.
Thank you much.
~ Brooke
brookefox
Postby Pherim » Sun Aug 01, 2010 10:43 am
What about this suggestion from the first page of this thread? Will this be included someday? I really love this plugin, but that would make me like it even more. ;)
DIEGO-RODRIGUEZ wrote:thought. perhaps an option would be good to insert groups or components of two ways -
position> onto face
position> as the original
perhaps, following start of the tool. pressing Ctrl ( switch between insert original and ontoface)
Pherim
Postby Chris Fullmer » Mon Aug 02, 2010 6:57 am
Oh yeah, I do like that idea. I think I can implement it easy enough. I've got a few other things I am working on that I really need to get done before I update this unfortunately. I'd like to tidy up a bunch of these kinds of projects here soon though. I've got a bit of things outside of SU I'd like to get working on too.
I'll see what I can do, but don't expect anything very soon.
SketchUp Team
SketchUp Team
Postby utiler » Mon Aug 02, 2010 7:44 am
IsWon't your component on face plugin do that, Chris?
utiler
Top SketchUcator
Postby xrok1 » Mon Aug 02, 2010 7:03 pm
utiler wrote:IsWon't your component on face plugin do that, Chris?
yes.
“There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
xrok1
Postby Chris Fullmer » Mon Aug 02, 2010 8:10 pm
Yes its true. I can try to add that function to this script. Make it even a little more useful.
SketchUp Team
SketchUp Team
Postby utiler » Mon Aug 02, 2010 11:40 pm
How bad is my spelling????? I need to spellcheck before I send..... :oops:
utiler
Top SketchUcator
Postby bjornkn » Sun Jun 05, 2011 10:47 am
Looks useful :)
Will it allow you to scale/rotate randomly on individual axes?
For placing non-faceme trees it would be very useful to be able to set different rotation values for red/green/blue axes.
And for scale it would be nice to have a master min/max scale setting as well as individual (smaller) red/green/blue variations min/max values?
bjornkn
Postby Chris Fullmer » Tue Jun 07, 2011 4:51 am
I believe what it does is rotates on the Z axis of the model space. So it would rotate a tree the way you would want. It does scale with min/max parameter, but it is an overall scale factor. It does not let you scale randomly per axis.
I do have a plugin called Scale and Rotate multiple:
viewtopic.php?f=323&t=17507&hilit=plugin
It gives you lots of control over scaling and rotating lots of components. So you could use the two in conjunction if you really wanted. But in general, the purpose of repeat copy was just to make it fast to randomly place a selected group of components into the model. The scaling and rotating features are very basic.
SketchUp Team
SketchUp Team
Postby rv1974 » Wed Jun 15, 2011 9:27 am
Chris this is the owesome one. Way better than any other scattering competitor. Very laconic and bug free (meanwhile)
Thank you.
rv1974
Postby sicksickisck » Mon Jan 14, 2013 11:53 pm
this is still good idea 8-)
[/quote][/quote]
sicksickisck
Postby Chris Fullmer » Tue Jan 15, 2013 4:36 am
Yeah, that really is a good idea. I have not updated any of my public plugins for a loooong time. I think it might be time to get doing that here eventually.
SketchUp Team
SketchUp Team
Postby sicksickisck » Tue Jan 15, 2013 11:04 am
:ecstatic: for real
sicksickisck
Postby pilou » Tue Jan 15, 2013 1:14 pm
If you have time between bottle-feeding ;)
(the axes of the Component Sringer also :geek:
Speedy Galerie
Top SketchUcator
Postby Pherim » Fri Sep 27, 2013 9:19 am
Just noticed there is a new version on Smustard (1.7.1). What is new in this version? Is the suggestion from above included?
Pherim
Postby Chris Fullmer » Fri Sep 27, 2013 3:14 pm
No, the new version was just to make it compliant with the extension warehouse. I might have thrown in one or two code changes to speed things up, but typically its not the kind of speed change you'd notice unless you were doing a LOT of stringing.
SketchUp Team
SketchUp Team
Postby djohnson.nz » Mon Mar 17, 2014 6:27 am
Hi Chris,
Have you updated your plugin REPEAT COPY for sketchup 2014.
Very handy script thanks.
David
nO fiKst ideas
djohnson.nz
Postby Chris Fullmer » Mon Mar 17, 2014 8:19 pm
I just updated it today. It should be 2014 compatible now.
Chris
SketchUp Team
SketchUp Team
Postby TIG » Mon Mar 17, 2014 11:41 pm
Chris Fullmer wrote:I just updated it today. It should be 2014 compatible now.
Will it get into the PluginStore ?
Global Moderator
Postby djohnson.nz » Wed Mar 19, 2014 10:54 pm
Thanks so much Chris...
nO fiKst ideas
djohnson.nz
PreviousNext
Return to Plugins
Users browsing this forum: ewan1977, jadetsiyu, suyanto567 and 17 guests
