Rombout,
You can change materials while keeping the same UV with Fredo Tool's Thrupaint. There's an Icon with a multicolor brush there that does that. That doesn't do it automatically, but you can paint without being inside the group wich is handy.
[Plugin] Material Replacer
• Page 3 of 3 • 1, 2, 3
Re: [Plugin] Material ReplacerTT:
Wow! Thanks very much. Great tool that does what it names says. Rare these days. Ron
Re: [Plugin] Material Replacer]I think it would be great to be able to consolidate materials by selecting in the material palette. I've seen the script that isolates objects by material (material selector), but it doesn't seem to work in my model. Besides, I'm trying to take a hundred-ish materials and reduce them to a more manageable figure.
I've run your material consolidator, but the materials aren't *exactly* the same. As you can see... if I could select a couple dozen similar grays and tell them to be one... life would be much better. Re: [Plugin] Material ReplacerI'm using this plug in a lot. Changing materials all the time in my work. It would be good to have an option to change materials in a group or component only and not in all model. Would that be difficult to integrate?
thanks! Re: [Plugin] Material Replacer
It should work in v2019. Are you having issues ? If so, then what are they ?? Note: because it hasn't been updated for many years it is not 'signed' for full compatibility with all Extension Loading Policies in the newer SketchUp versions - BUT this doesn't matter provided that you have your newer SketchUp's Extension Manager's Loading Policy set to 'Unrestricted'... TIG
Re: [Plugin] Material ReplacerI use a very old plugin Material_Maintenance that still works up to SU 2018 Pro.
Really super for material replace and edit. Author Akira Yamada and not to be found anywhere. His web listed as http://www.KeepingMyHandIn.com but a dead end. It is free to edit and distribute I have folder in the SU plugins and the Material_Maintenance.rb copied to same. Works for me and check it out and see if it can be configured properly as an rbz Help from the Masters needed. dtrarch
Re: [Plugin] Material ReplacerIt's nice this works in the model. It would be nice too if one could do the material replacement in the browser.
Another nice thing is how the material replacer can give you the name of a material immediately. This is a slow, painful process on the Mac. Why? MacOSX Mojave High Sierra SketchUp Pro v19 Twilight v2 Thea v2 PowerCADD
Users browsing this forum: uilana and 17 guests
