SketchUcation Premium Membership
[Plugin] Manifold v2.2
Re: [Plugin] Manifold v1.6
Postby TIG » Sat Jan 30, 2010 5:07 pm
Here's v1.6 viewtopic.php?p=218691#p218691
Face making error fixed, 3-edge faces removal improved.
Sub-groups/Instances now within Group removed & reported.
Error reporting improved.
Global Moderator
Operating system: Windows
SketchUp version: 2013
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby driven » Sat Jan 30, 2010 6:47 pm
Hi TIG,
I think it's working really nicely now, lot faster, plenty of info, it still passes inner faces that don't necessarily break the 1 edge, 2 face rule.
There are only two '4-faced' edges in the original drawing and if a BoolTool, VWS, or a manual delete is done first, (as it should be) than manifold does a speedy and detailed correction, orientation and triangulation. I'm wondering if a simple pre-flight check that states, "I'm not doing this-there are inner faces highlighted that you need to remove first" or something less long winded, might not be in order. I'll PM you some other screen shot's as well.
Am I the only one testing this????
driven
Top SketchUcator
Operating system: Mac
License type: Pro
SketchUp use: engineering and mechanical design
Re: [Plugin] Manifold v1.7
Postby TIG » Sun Jan 31, 2010 3:05 pm
Here's v1.7 viewtopic.php?p=218691#p218691
It now does a quick initial 'Health-Check' on the group and a dialog reports - it also temporarily shows any probable 'internal faces' in Magenta and faces adjoining probable 'holes' in Cyan etc...
If it's a lot of errors you can answer 'No' to not continue and then attempt to fix them manually, before trying again - or answer Yes to continue if there are no problems identified, or answer Yes anyway to try and auto-fix any problems [with a final error report and red/green/.../-.- highlighting in an "error-group"]...
:geek:
Global Moderator
License type: Pro
Postby driven » Sun Jan 31, 2010 3:16 pm
TIG....do you sleep???
driven
Top SketchUcator
License type: Pro
Postby OTB Designworks » Sun Jan 31, 2010 3:18 pm
any chance this can be adjusted to not triangulate all faces? It is very useful for me to be able to clean up a model that I have carefully constructed so that I have consistent quads everywhere, which is what I need for sending into ZBrush for further detail modeling.
I know that Cheetah, too, triangulates everything when performing boolean functions, which I also find annoying. It is this, more than anything, that keeps me away from automated solutions for ensuring manifold meshes.
Cheers, Chuck
Cheers, Chuck
MY BLOG
Become a fan of OTB Designworks on Facebook, we'd love to have you!
3.2ghz 8 core Mac Pro. 10 gig RAM, 8800 GT GPU, dual monitors
OTB Designworks
Postby TIG » Sun Jan 31, 2010 3:31 pm
OTB Designworks wrote:any chance this can be adjusted to not triangulate all faces? It is very useful for me to be able to clean up a model that I have carefully constructed so that I have consistent quads everywhere, which is what I need for sending into ZBrush for further detail modeling.
Cheers, Chuck
I'll add triangulation as a closing option ? :geek:
Global Moderator
License type: Pro
Postby OTB Designworks » Sun Jan 31, 2010 3:38 pm
That would be quite useful, for me.
Now, how about a plug-in that cuts a model up into beautifully perfect quads? I'd pay cold hard cash for that one, too.
Thanks TIG!
Cheers, Chuck
MY BLOG
OTB Designworks
Re: [Plugin] Manifold v1.8
Postby TIG » Sun Jan 31, 2010 3:41 pm
Here's v1.8 viewtopic.php?p=218691#p218691
Triangulation is now an option near the end - Answer Yes to do it... :geek:
Global Moderator
License type: Pro
Postby driven » Sun Jan 31, 2010 3:47 pm
TIG,
slight problem, when choosing Yes to continue after an 'initial health check' pass, it zapps everything even unselected groups.... both on badly grouped and clean booled groups, I'll do some more and send pics.
I'll see if it still happening in 1.8
driven
Top SketchUcator
License type: Pro
Postby TIG » Sun Jan 31, 2010 4:03 pm
driven wrote:TIG,
Odd - I can't get it to error at all... :? Please 'feedback'.............
Global Moderator
License type: Pro
Postby driven » Sun Jan 31, 2010 4:18 pm
TIG wrote:Odd - I can't get it to error at all... :? Please 'feedback'.............
been trying to up load pics, site is slow, pics to follow
it's on both machines, 1.7 and 1.8
3 groups from Draw Shapes Menu, grouped, manifold_1.7and8, both give a pass
Yes to continue....zapppp
Same 3 groups, exploded then regrouped is running as predicted on other mac at the moment, this site is slow from this machine....
driven
Top SketchUcator
License type: Pro
Postby driven » Sun Jan 31, 2010 4:26 pm
driven
Top SketchUcator
License type: Pro
Postby driven » Sun Jan 31, 2010 4:28 pm
something screwy going on with uploads, sorry it makes thing disjointed
driven
Top SketchUcator
License type: Pro
Postby TIG » Sun Jan 31, 2010 4:33 pm
I get no problems... but can you PM me that model asap, so that I have exactly the same starting point... :?
The 'no problems found' report is on any geometry that hasn't already be relegated to 'red'... looks like everything is removed BEFORE we do the health check - it's not a group inside a group is it ?
Global Moderator
License type: Pro
Postby driven » Sun Jan 31, 2010 4:51 pm
TIG,
they were groups inside a group, and got a pass, (they are all manifold) it only zaps them if you say YES,
the same thing happened after I BoolTool'd all 3 groups into 1 group, initial pass (as it should), but zapped if you choose YES, I only got the RED on that one drawing, I'll re run the first set-up and post the if no red is shown again.
I have just set a Bool'd group run that Passed initial and didn't blitz the drawing when I hit YES
It's on a pair of torus + geodasic sphere bool group, and it is running.
original set ungrouped, but not booled
driven
Top SketchUcator
License type: Pro
Re: [Plugin] Manifold v1.9
Postby TIG » Sun Jan 31, 2010 4:59 pm
Here's v1.9 viewtopic.php?p=218691#p218691
It now traps for 'No Geometry' inside the Group... :geek:
Global Moderator
License type: Pro
Postby driven » Sun Jan 31, 2010 5:28 pm
NO Zapping with 1.9... is it possible for the health check to report 'NO geometry to Check because the selection contains sub-groups'?
I'll try some other breakers I've been working on...
cheers john
driven
Top SketchUcator
License type: Pro
Postby driven » Sun Jan 31, 2010 5:48 pm
TIG,
I've got a couple of test on the go, I'll report on them when they're cooked.
some additional ?'s
which should be faster for manifold, simply continuing after fail or a manual repair than re-test continue
would it be possible to choose bothquad's and tri's as two separate groups, if you have two different post destinations for the object?
or would EraseCoplanar on a copy of a Tri'd group give identical mesh results?
driven
Top SketchUcator
License type: Pro
Postby TIG » Sun Jan 31, 2010 6:52 pm
driven wrote:TIG,
some additional ?'s
Manual fix versus Auto-fix depends on what needs fixing - making it right in the first place is the best bet ;)
If you choose NOT to triangulate but then want a triangulated version then copy it and simply select all faces and run my [+tt's] tool triangulate_faces and you'll have the same result - uses the same code... :geek:
Global Moderator
License type: Pro
Postby driven » Sun Jan 31, 2010 7:12 pm
TIG- found the problem with the Bool'd groups -BT can create a group inside a group when bool-ing more than two groups, which I should have spotted in Outliner.
When manifold highlighted RED and said 'NO' I simply exploded the extra group and answered my earlier ?, it was much faster on the bool'd group and I assume would be the similar on a manually repaired group.
Note for users: The manual option also gives more control over the mesh shape at the torus/box intersection.
Basically TIG you've done a fantastic job on this, thank you
I'm convinced you, Chuck, and I won't be the only end-user's for this, it has soo many uses.
for now I'll keep putting up images that help or hinder, and get back to some bent text testing....
do you think it's ready for a wider audience yet, I'm planing on trying to do a tutorial when your happy?
ADD: it's what I thought re: tri/quads, just thought I'd ask
driven
Top SketchUcator
License type: Pro
Postby driven » Sun Jan 31, 2010 7:21 pm
Even Likes Curves, but they will slow it down.
driven
Top SketchUcator
License type: Pro
Re: [Plugin] Manifold v2.0
Postby TIG » Mon Feb 01, 2010 7:37 pm
Here's v2.0 viewtopic.php?p=218691#p218691
Glitch in health-check if very small edges in faces fixed...
Global Moderator
License type: Pro
Postby thomthom » Tue Feb 02, 2010 12:23 pm
v2 ? is this a major or minor update?
Global Moderator
Name: Thomas Thomassen
License type: Pro
Postby TIG » Tue Feb 02, 2010 12:25 pm
thomthom wrote:v2 ? is this a major or minor update?
The tweaks were relatively minor - BUT as I am unlikely to make many more changes in the short-term I thought I'd mark it with '2.0'... ;)
Global Moderator
License type: Pro
Postby Pilou » Tue Feb 09, 2010 9:16 am
I have missed this new true gem! :oops:
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free/Make
SketchUp use: hobby
Postby Pilou » Tue Feb 09, 2010 11:40 am
When I use Manifold I obtain that ok
But When I kill or move the group red repair
I have the original copy with killed internal faces Yes ok :enlight: , but always segments on the faces! :o
Does it normal? A simple box with 6 faces must be result ? No clean selection?
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
SketchUp use: hobby
Postby TIG » Tue Feb 09, 2010 1:03 pm
Pilou wrote:When I use Manifold I obtain that ok
This is correct.
The internal faces are removed by any edges they has forming part of the external envelope are kept.
If you want rid of then use one of the tools that removes coplanar edges...
It could seek to remove coplanar edges too ?
Global Moderator
License type: Pro
Re: [Plugin] Manifold v2.1
Postby TIG » Tue Feb 09, 2010 1:25 pm
Here's v2.1
It now has the option to remove coplanar edges before triangulation, this will minimize the number of faces -useful if for example internal faces have been removed and their old edges are not needed to keep the external 'manifold' skin intact...
Global Moderator
License type: Pro
Postby Pilou » Tue Feb 09, 2010 1:39 pm
Cool now we have possibility or not to "clean" the model in the same time ;)
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
SketchUp use: hobby
Postby Pilou » Wed Feb 10, 2010 2:35 am
2 volumes
copy move
for each selected (2 volumes) Intersect Selected
Group
for each "group" apply Manifold
with same answers : Yes for the first question (of course)
and No for the others questions
Curious result is not the same! :o
Is that normal?
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
SketchUp use: hobby
Artisan Organic Toolset - a set of powerful organic modeling tools.
PreviousNext
Return to Plugins
Users browsing this forum: Bing [Bot], boxzero, Maccaneel, maneazul, MattC, smallb18 and 8 guests
