SketchUcation Premium Membership
[Plugin] ExtrudeTools - Full Set 20130520a
Re: [Plugin] ExtrudeTools - Zipped Set 20110529
Postby TIG » Sun May 29, 2011 11:36 am
Here's an updated set viewtopic.php?p=217663#p217663
The tool now makes the Extrusion Tools toolbar/submenu even if the various .rb files are not located in the standard ../Plugins/ folder and are loaded from elsewhere [it now uses File.dirname(__FILE__) rather than the .find_support_file() which is limited to a standard set of folders]. It just requires that all of the files [including those in the ../TIGtools/ submenu] are kept in the same relative locations rather than the previous absolute ../Plugins/ location...
It also includes the latest Chinese lingvo files, thanks to 'hebeijianke'...
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby TIG » Sun May 29, 2011 11:37 am
Jim wrote:I made these mods to make it portable:
starting @ ~ line 50
Code: Select all
    eePlugins.each{|plugin|
   path = File.join(File.dirname(__FILE__), plugin+".rb")
   #if Sketchup.find_support_file(plugin+".rb","Plugins/")
   if File.exists?(path)
       gotPlugin=true
       break
   end#if
I had just made very similar changes - you posted as I uploaded it - see updated set... :roll:
Global Moderator
SketchUp version: 8
License type: Pro
Postby Jim » Sun May 29, 2011 11:40 am
Frequent updates are another advantage of using a shared Plugins folder! :lol:
Thanks again.
Jim
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby TIG » Sun May 29, 2011 11:41 am
Jim wrote:Frequent updates are another advantage of using a shared Plugins folder! :lol:
I think I'm done for a while on updating this tool... :roll:
Global Moderator
SketchUp version: 8
License type: Pro
Postby unclex » Sun May 29, 2011 12:51 pm
Sorry , my mistake
the reason is another Plugins
Thanx for ur replied
unclex
Postby manson666 » Fri Jun 03, 2011 2:29 pm
I'm new Sketchup user
now learning it
I founded out sketchup plug in is strong tool
thx share
manson666
Postby openhatch » Fri Jun 03, 2011 10:47 pm
If I haven't said this before, awesome tools, thx. :thumb:
This doesn't play well with SketchyPhysics; this newest version won't extrude edges by rails successfully if SketchyPhysics is installed. So I keep the two installed in different versions of Sketchup. :(
openhatch
Postby TIG » Sat Jun 04, 2011 9:24 am
openhatch wrote:If I haven't said this before, awesome tools, thx. :thumb:
I know about the SketchyPhysics issue - it can also affect other tools... viewtopic.php?p=300111#p300111
The fix is relatively simple BUT it means recoding a few lines in one of the SketchyPhysics rubies...
viewtopic.php?p=300105#p300105
Global Moderator
SketchUp version: 8
License type: Pro
Postby Destors » Sun Jun 05, 2011 7:37 am
How i need to make these things, help me please :)
Destors
Postby openhatch » Sun Jun 05, 2011 7:43 am
TIG wrote:I know about the SketchyPhysics issue - it can also affect other tools...
Okay, I knew you knew; I guess I might have clarified I was wondering if it's an outstanding problem (I hadn't read those posts you link to here). But the fix you link to will do (assuming it works, as I haven't tried it yet), thanks!
openhatch
Postby billychaics » Tue Jun 07, 2011 12:36 pm
Thanks guys this is extremely good plugin that i was looking for so long
billychaics
Postby doraemon79 » Wed Jun 29, 2011 10:47 am
Wonderful tool....
doraemon79
Postby rock1 » Mon Aug 08, 2011 9:30 am
this toolset is a bit complicated for usage for a novice like me. I'm getting some unexpected results. Are there any video tutorials :roll:
Signature removed by SCF Admin
rock1
Postby majid » Mon Aug 08, 2011 6:41 pm
ow... it jumps out of Sketchup with no error message!!! (almost half of tools!!!! eebe , eebf,eebfs, EEbR)
درصورتيكه به مساله اي برخورديد(مثل وارد نشدن به سايت، فراموش كردن پسورد و غیره با ما تماس بگیریدhttp://sketchucation.com/contact
majid
Top SketchUcator
SketchUp version: 8
License type: Free
Postby TIG » Mon Aug 08, 2011 7:32 pm
Majid
Have you installed any new Plugins lately?
Try disabling them temporarily and see if that helps.
Do you get any error messages in the Ruby Console before the 'crash'?
If you do find the culprit let use know asap.
Have you tried repair/reinstall Sketchup and/or reinstalling the Extrusion tools again...
This is weird :?
Global Moderator
SketchUp version: 8
License type: Pro
Postby Dave R » Mon Aug 08, 2011 9:47 pm
rock1 wrote:this toolset is a bit complicated for usage for a novice like me. I'm getting some unexpected results. Are there any video tutorials :roll:
You might find it helpful to learn the basic tool set first. And then search through the forum because there's lots of information on using TIG's Extrude Tools. He did instructions for all of the tools in individual threads.
Inspecting mirrors is a job I could easily see myself doing.
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: woodworking
Postby rock1 » Fri Aug 26, 2011 8:28 am
I'm unable to have the first button, don't know why.
This has been a problem since a long time. I have got now windows 7 ultimate but the problem is still there. I did a fresh download of this set, overwrote the old extrude tools files but the problem is still there. :?
rock1
Postby TIG » Fri Aug 26, 2011 9:29 am
There are only ever 11 buttons - there are only 11 extrudeEdgesBy...rb files!!!
I suspect that you have put one of the files into two auto-loading locations or have two copies with slightly different names in Plugins - so something is loading twice but the 1st time its icon files are not found - SO... what is the first button ? See its Tooltip etc or look in the Plugins>ExtrusionTools... for a submenu duplicate.
Temporarily move all of the 11 'good' extrudeEdgesBy...rb files into another folder and restart SUp [leave the #extrusionToolbar.rb in placeso the toolbar MIGHT get made]. Then you can track down the culprit - perhaps something like 2x extrudeEdgesByEdges.rb ??
Let us know when you've fixed it.
Global Moderator
SketchUp version: 8
License type: Pro
Postby rock1 » Fri Aug 26, 2011 10:36 am
TIG wrote:There are only ever 11 buttons - there are only 11 extrudeEdgesBy...rb files!!!
Whoa what a shot TIG!, bingo, its' the one extrude edgesbyedges, WTH it's duplicated :lol: !!!. :o I'll try to solve. i'm getting a duplicate in plugins menu man!! :shock:
rock1
Postby rock1 » Fri Aug 26, 2011 10:45 am
i am unable to solve this problem. what should i do :?:
rock1
Postby TIG » Fri Aug 26, 2011 10:58 am
Have you got two brain-cells to rub together :roll:
You have got two files with similar names loading, that then add the same tool twice.
So simply look through the contents of Plugins.
Find these two files and open/read them both with Notepad.exe
The one called "extrudeEdgesByEdges.rb" is the one to keep - it's from the zipped set [it says 'Version 3.0' in its notes]
The other one that's maybe 'older' and/or just has 'another similar name' needs removing.
There are several files in Plugins with similar names but only two of the 11 [in your case 12!] are the ones you need to worry on...
I can't do this for you - you must help yourself here - be resilient...
Global Moderator
SketchUp version: 8
License type: Pro
Re: [Plugin] ExtrudeTools - Zipped Set 20111003
Postby TIG » Mon Oct 03, 2011 11:45 am
Here's an update
Two tools now have 'Quad Face' options to complement thomthom's new Quad-Tool
ExtrudeEdgesByRails viewtopic.php?p=201286#p201286
ExtrudeEdgesByLoft viewtopic.php?p=231016#p231016
The lingvo files have also been updated to suit.
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Mon Oct 03, 2011 11:55 am
Sweet! More quad tools! :D
Global Moderator
SketchUp version: 8
License type: Pro
Re: [Plugin] ExtrudeTools - Zipped Set 20111004
Postby Rich O Brien » Tue Oct 04, 2011 10:37 pm
Error on startup...
Code: Select all
Error Loading File extrudeEdgesByRails.rb
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/extrudeEdgesByRails.rb:163: syntax error, unexpected '='
:::Blog:::
I'm a Trimbler now!
Rich O Brien
Administrator
SketchUp version: 8
License type: Pro
SketchUp use: engineering and mechanical design
Postby TIG » Tue Oct 04, 2011 11:01 pm
Rich O'Brien wrote:Error on startup...
Code: Select all
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/extrudeEdgesByRails.rb:[b]163[/b]: syntax error, unexpected '='
:roll: I somehow managed to duplicate a line below '=end' in the guidance notes as I saved the file...
Here's the updated version viewtopic.php?p=217663#p217663
Sorry :oops: ... but the 8 of you who downloaded it so far do need to do it again :shock:
More haste, less speed... as the English proverb goes...
Global Moderator
SketchUp version: 8
License type: Pro
Re: [Plugin] ExtrudeTools - Zipped Set 20111020
Postby TIG » Thu Oct 20, 2011 8:03 pm
Here's a maintenance update which includes new ES lingvo files by deFisto with minor idiom corrections etc, and a minor 'db' correction to EEbyLathe to include the start_operation name...
Global Moderator
SketchUp version: 8
License type: Pro
Postby Rich O Brien » Thu Oct 20, 2011 8:12 pm
thank you :thumb:
:::Blog:::
I'm a Trimbler now!
Rich O Brien
Administrator
SketchUp version: 8
License type: Pro
Re: [Plugin] ExtrudeTools - Zipped Set 20111023
Postby TIG » Sun Oct 23, 2011 11:57 am
Here's another update...
It now only smooths mesh edges with more than one face in EEbyLathe/..Faces/..Loft and ..Rail
Global Moderator
SketchUp version: 8
License type: Pro
Postby srx » Mon Oct 24, 2011 10:36 am
Thanks! Nice to see you working as a team :) :thumb:
srx
SketchUp version: 7
License type: Free
Re: [Plugin] ExtrudeTools - Zipped Set 20111102
Postby TIG » Wed Nov 02, 2011 11:50 am
Here's an update viewtopic.php?p=217663#p217663
EEbyLathe v3.5 Fixed Picked-Angle's messy undo; Smoothed-edges now stop @90º.
Global Moderator
SketchUp version: 8
License type: Pro
Keyframe Animation plugin - animate your SketchUp model by adding movement to any object.
PreviousNext
Return to Plugins
Users browsing this forum: arqcyn35, Bing [Bot], salleex, tafort, topcon and 14 guests
