[Plugin] ExtrudeTools - Full Set 20130520aRe: [Plugin] ExtrudeTools - Zipped Set 20101102All right-click context-menu items are also available at the end of the Edit Menu...
Sorry -- I'm a Newbie and this is my first attempt to install a Ruby Plugin. Followed the instructions and I can add the Toolbar, however, it is missing the icons. If you roll your mouse over it, the little squares will light up but there are no icons on it to tell what you are using! So, what did I do wrong? Also, I assume the Lingvo files are Help files? How do I access them? Lin SketchUp Pro 8 Windows7 Please, register (free) to access all the attachments on the forums.
Re: [Plugin] ExtrudeTools - Zipped Set 20101102I suspect that you have made a similar mistake to the one you've quoted.
I suggest that you remove all of the files that you have just put into the ../Plugins/ folder; to see a list of these read the contents of the zip file and its subfolders. Files that should be in the ../Plugins/TIGtools/ subfolder should never be put into the main folder... Now... extract the contents of that zip file into a temporary folder somewhere - e.g. ../Desktop/ExtrusionTools/ keeping all of the files that are already in a subfolder in those subfolders - the main subfolder is called 'TIGtools'. Now move all of these extracted files and subfolders keeping the files within them [i.e. /TIGtools/] into the ../Plugins/ folder. Now it should work with a restart... You will find that many complex tools have a subfolder with support files in it. Often there will be one or two .rb files to go into ../Plugins/ that kick off the tool, and the rest of the files are in a subfolder or perhaps even subfolders within a subfolder! In the case of the ExtrusionTools, because they are a compilation over time, there are several tools with .rb tool-files and a 'loader' .rb file in ../Plugins/. The 'deBabelizer.rb' tool is required to do language translations: the .lingvo files are the translations it uses [and these must be inside ../Plugins/TIGtools/]. The .png files inside the TIGtools folder are the image-files used for the toolbar button-icons [that's why I 'know' they are not in the right folder - otherwise you wouldn't have this problem!!] Please let me know how you fare and if you need any more help please post here... Please, register (free) to access all the attachments on the forums. TIG
Re: [Plugin] ExtrudeTools - Zipped Set 20101102Finally -- problem solved! Followed your directions and it still wasn't quite right - then I noticed that my Unarchive was putting everything into one big folder without your TIGtools subfolder. Used a different program to Unzip and now it all works!
thanks! Lin
Aha! ALWAYS ensure the files stay inside their subfolders when you install ANY Plugin.; clearly there needs to be a .rb or .rbs file to use those BUT also note that some support files [like Fredo's LIBs all stay inside their supplied folder. TIG
Re: [Plugin] ExtrudeTools - Zipped Set 20101102TIG, I know this might sound silly
Eternity is very long, especially towards the end. Woody Allen
Re: [Plugin] ExtrudeTools - Zipped Set 20101102Fredo's tools are quite a lot newer than mine.
Some of the tools are very similar, like EEbyRails and EEbyLoft - BUT there are several in the Extrusion toolset that are NOT - like 'EEby.. Lathe, Vector, Lattice, Face etc... I have both toolsets and I use mine more, simply because I am used to it... Fredo's do have a prettier UI and there are extra options to dynamically adjust the mesh etc, and they can work better in some circumstances - like with lofting closed-loop profiles, they might make complex messes a little faster too... So use what you find works best for you in each instance... TIG
Re: [Plugin] ExtrudeTools - Zipped Set 20101102Hi,
The plugin doesn't appears in tools menu. I put .rb in the plugin folder but it doesn't work. Can somebody help me ? Thanks
Re: [Plugin] ExtrudeTools - Zipped Set 20101102You should have several .rb files in the ../Plugins/ folder and several extra files in the ../Plugins/TIGtools/ subfolder ?? This is a screen-grab of what the contents of the zip file look like. The new files/subfolder+files should be replicated exactly as this after you've extracted everything... When you restart Sketchup there should be a drop-down submenu early in the 'Plugins' menu [Note that it's NOT in the 'Tools' menu Please, register (free) to access all the attachments on the forums. TIG
Re: [Plugin] ExtrudeTools - Zipped Set 20110524Here's a new version viewtopic.php?p=217663#p217663
It has an additional tool ExtrudeEdgesByVectorToObject... see here for more details of the new tool... viewtopic.php?p=331059#p331059 TIG
Re: [Plugin] ExtrudeTools - Zipped Set 20110524oh nice! that's a great addition.
[it also shows hints of a sweet trim tool plugin - sort of like solid booleans without the solids part.. in rhino, it works like: select cutting object(s) then pick the parts of the intersecting geometry you'd like to delete.. in eeVO, it automatically picks the side to delete on the opposite side of the cutting object of where the vector extrusion started.. in this hypothetical trim tool, you would be able to pick which side to delete... i dunno, just ideas in case you get bored one day dotdotdot
Re: [Plugin] ExtrudeTools - Zipped Set 20110524just wanted to say thank you for your amazing efforts.
“Whatever the mind of man can conceive and believe, it can achieve.” -W.Clement Stone (American best selling Author and Founder of Combined Insurance Co (now a part of Aon Corp.), 1902-2002)
Re: [Plugin] ExtrudeTools - Zipped Set 20110524you are really great!!! fantastic work, thank you
Re: [Plugin] ExtrudeTools - Zipped Set 20110525Here's an updated set viewtopic.php?p=217663#p217663
A new tool 'ExtrudeEdgesByOffset' has been added. Its details are found here viewtopic.php?p=331303#p331303 TIG
Re: [Plugin] ExtrudeTools - Zipped Set 20110525Wow, TIG, a tool a day?
"There is a man in the world who will never be turned down... he is the man who delivers the goods."
Re: [Plugin] ExtrudeTools - Zipped Set 20110528Here's an updated set viewtopic.php?p=217663#p217663
The 'Extrude Edges By Vector To Object' tool has been improved considerably:- A new algorithm has been added for the intersecting with objects: now walls extend to soffits with additional apex vertices and so on so it extrudes fully to the faces/edges. 'Ghost' extrusions now show intersections as red dots. The original selection is kept, unless the is group exploded. Some ES lingvos updated by Defisto [thanks]. TIG
Re: [Plugin] ExtrudeTools - Zipped Set 20110528aHere's another update viewtopic.php?p=217663#p217663
The 'Extrude Edges By Vector To Object' tool has additional traps added for rare glitches when a faced edge-selection was used. TIG
Re: [Plugin] ExtrudeTools - Zipped Set 20110528bHere's yet another update viewtopic.php?p=217663#p217663
The 'Extrude Edges By Vector To Object' tool has had a glitch fixed with 'undo' if you'd reversed faces etc... TIG
Re: [Plugin] ExtrudeTools - Zipped Set 20110528cHere's yet another update viewtopic.php?p=217663#p217663
The 'Extrude Edges By Vector To Object' tool has had glitches fixed with 'commit' and extruding faces inside groups to objects outside... TIG
Re: [Plugin] ExtrudeTools - Zipped Set 20110528c DUUUDE! Exactly what I was talking about!Here's a few tests: I have a couple more tiny requests to ask, but now i don't have time! Please, register (free) to access all the attachments on the forums. Eternity is very long, especially towards the end. Woody Allen
Re: [Plugin] ExtrudeTools - Zipped Set 20110528c[Plugin] ExtrudeTools - Zipped Set 20110525 Installed
[Plugin] Shape Bender Beta v0.55 Can't work... Need Help !!! ThanX
I translate All the plugins in ExtrudeTools into chinese This is the translation file Please, register (free) to access all the attachments on the forums.
I [and many others] have both toolsets installed without any interconnected problems Can you explain the nature of the problem a bit more ? Are there any error messages [either at startup or when it's run with the Ruby Console open]? if so please post them here, or perhaps more logically in the ShapeBender thread, as that's the broken tool. Nothing has changed between recent versions of the EEby... tools that I could think might affect ShapeBender in any way. that tool itself has been around for some time... Please check you have progressbar.rb installed in the Plugins folder [available free from Smustard.com] - this is a frequent cause of tools failing that need it [it's not needed for any of the EEby... tools though!] TIG
Thanks I'll include them with the next update of the toolset. Meanwhile Chinese locale users can install them into the TIGtools folder and feedback... TIG
Re: [Plugin] ExtrudeTools - Zipped Set 20110528cHi TIG,
Shouldn't there be a Toolbar? I don't see it. I have all the EEb Tools in the Plugins menu, but no Extrusion* in Toolbars. Please, register (free) to access all the attachments on the forums.
Re: [Plugin] ExtrudeTools - Zipped Set 20110528cThere should be a file in ../Plugins/ #extrusionToolbar.rb makes the Toolbar/Sub-Menu.
It starts with a '#' so it loads first - it then checks to see if any of the possible EEby...rb files exist and if so it adds the 'Extrusion Tools' toolbar referenced as '$extrusionToolbar' and an 'Extrusion Tools' submenu referenced as '$extrusionToolsSubmenu'. As each of the EEby...rb files loads it checks for these $ references and if they don't exist then there is no toolbar/button and the tool's menu item is added direct to Plugins-menu rather than into a subfolder... Your screen-shot suggests that #extrusionToolbar.rb is missing as there's no 'Extrusion Tools' submenu ?? Note that the EEby... tools also 'require' deBabelizer.rb ? TIG
Ah, I renamed it without the #. Guess I can't do that.
Re: [Plugin] ExtrudeTools - Zipped Set 20110528cNO! It needs to load before the other tools so they find the toolbar/submenu ready-made... The existence of the EEby...rb tools are checked by it 'by name' so renaming all of those would also stop the toolbar/submenu getting created... Its filename doesn't have to start with a #, it just needs to list somewhere before the other tools in alphanumeric order... I use a leading # on the name of for my tools if I want it to load early - like the '#HolePunchTool.rb', as I want its items high up on the context-menu listings... TIG
Re: [Plugin] ExtrudeTools - Zipped Set 20110528cAnd I use C:\Plugins rather than the default so I can share plugins between versions. EEbX isn't portable in that way either.
Thanks.
Re: [Plugin] ExtrudeTools - Zipped Set 20110529I made these mods to make it portable:
starting @ ~ line 50
SketchUcation One-Liner AdvertsNeed Authorised SketchUp Training by experts in various disciplines? Check out our Training details.
