[Plugin] ExtrudeTools - Full Set
Re: [Plugin] ExtrudeTools - Zipped Set
Postby Landie » Mon Apr 26, 2010 5:47 pm
Thankyou for sharing. :ecstatic:
Landie
Postby TIG » Wed Apr 28, 2010 2:01 pm
New updated set available here... viewtopic.php?p=217663#p217663
Brand new tool ExtrudeEdgesByRailsToLattice added.
[It has basic EN-US/FR/ES lingvo files...] viewtopic.php?p=242239#p242239
Replacement ES lingvo files for all tools included [from Defisto]; and some new FA lingvo files for some tools added [through Majid] - Thanks to them! :D
Minor adjustments:
EEbyEdges tool now exits gracefully.
A few scripts have had the missing "require 'deBableizer.rb'" added.
RickW's 'offset.rb' method-only script is now included in the set - because it's needed by EEbyRailsToLattice...
:geek:
Global Moderator
Postby mitcorb » Wed Apr 28, 2010 2:45 pm
Again, TIG:
Thank you for your talents and contributions.
mitcorb
Top SketchUcator
Postby watkins » Wed Apr 28, 2010 7:24 pm
Dear TIG,
You appear to be using version 1.0 of offset.rb. There is a later version, V2.1 (see the attached). Is it okay to use the later version with your scripts?
Regards,
Bob
watkins
Postby TIG » Wed Apr 28, 2010 8:38 pm
watkins wrote:Dear TIG,
Regards,
Bob
Don't know how I'm still using that old one !
Finger on the pulse, and all that.... :roll:
Anyway... it doesn't matter, v1 or v2.1 both work fine when I've tested...
I'll package the new version with any future updates...
Meanwhile, if users already have the newer version then I recommend that they don't overwrite it with the older zipped one until the zipped update catches up...
Sorry for any confusion...
Global Moderator
Postby TIG » Thu Apr 29, 2010 10:28 am
Here's a new version viewtopic.php?p=217663#p217663
EEbyRailsToLattice has been updated with the latest version of 'offset.rb' and trapped to rescue its 'fails', also some glitches with display of selected curves etc is fixed...
:geek:
Global Moderator
Postby TIG » Thu Apr 29, 2010 12:24 pm
I have reissued a new version again today viewtopic.php?p=217663#p217663
The single change is a temporarily fixed offset.rb [awaiting its author's input, RickW ]...
After I updated from offset.rb v1 to v2.1 in my zipped set earlier today, I discovered that it had then broken RickW's own Windowizer4.rb :roll: .
None of this affects my tools - they only need the Face::offset() method !
In this tweaked version I have included the older Array::offset() AND the newer Array::offsetPoints() methods found in offset.rb v1 AND v2.1 respectively; and so it should now work with Windowizer4.rb and also any tools that might rely on the newer version...
Global Moderator
Postby TIG » Thu Apr 29, 2010 9:33 pm
Here's another version viewtopic.php?p=217663#p217663
An updated FR lingvo for EEbyRailsToLattice - a compilation of Pilou and Didier's suggestions/corrections
[note that "accents" are not used in text within the inputbox dialogs to avoid problems...]
Thanks...
Global Moderator
Postby doy » Thu Apr 29, 2010 10:58 pm
thumbs up....this is hot...thanks a lot for sharing
doy
Postby TIG » Fri Apr 30, 2010 9:35 am
Here is today's update viewtopic.php?p=217663#p217663
EEbyRailsToLattice has some new /updated lingvo files, minor text corrections and flat faces at z=0 are now auto-reversed. See it's thread for more info...
:geek:
Global Moderator
Postby TIG » Tue May 04, 2010 2:21 pm
Here is an updated zipped set viewtopic.php?p=217663#p217663
EEbyRailsToLattice is updated to give back faces of panes the color too and the panes' 'face.offset' method no longer relies on 3rd party offset.rb - it has been incorporated into the class-methods and made more robust.
Global Moderator
Postby pilou » Tue May 04, 2010 2:34 pm
Works fine now :thumb:
Speedy Galerie
Top SketchUcator
Postby gavvy » Wed May 05, 2010 1:37 am
:shock: TO Tig ,I can't say anymore :thumb:
gavvy
PluginStore Author
PluginStore Author
Postby TIG » Thu May 06, 2010 11:04 am
Here is an updated set.
EEbyRailsToLattice now also has a 'Diagonals' option for the Lines...
Reverse the order of picking the rails to swap the diagonals' direction.
Make two diagonal groups overlaid to get a 'diamond mesh' etc...
The lingvo files have be updated to match.
Global Moderator
Postby TIG » Fri May 07, 2010 6:45 pm
Here's a new zipped set viewtopic.php?p=217663#p217663
EEbyRailsToLattice has been updated to fix glitches with the Line work lattices' grouping - which affected all types, but was only noticed when the 'diagonal' option was added...
Global Moderator
Postby watkins » Fri May 07, 2010 8:39 pm
Dear TIG,
Does one still need offset.rb? I notice that it is missing from the zipped folder.
Regards,
Bob
watkins
Postby TIG » Fri May 07, 2010 8:46 pm
Bob
No, as was explained in earlier release notes, to avoid the problems with newer versions of offset's incompatibility with Windowizer etc I changed the way EEbyRailsToLattice makes its lattice offsets by building the method into the code in a slightly different way...
You can use any version of offset.rb you want - it is no longer needed by my tools... :)
Global Moderator
Postby leixing » Sat May 08, 2010 4:34 am
Thanks TIG.
great work
leixing
Postby watkins » Sat May 08, 2010 10:25 am
Dear TIG,
I understand from what you wrote that windowizer.rb has problems with offset.rb V2.1. Is that correct? I have overwritten my copy of V1.0 and I have windowizer.rb installed. Could you post a copy of V1.0 please?
Thanks,
Bob
watkins
Postby watkins » Sat May 08, 2010 11:02 am
Dear TIG,
Forget that last request. I've just checked and I have V3.0 of windowizer.rb. I downloaded it again and it had offset.rb V1.0 in the folder, so no worries.
Regards,
Bob
watkins
Postby TIG » Mon May 17, 2010 10:06 am
Here's an updated zipped set - viewtopic.php?p=217663#p217663
All of the EEbyRailsToLattice and EEbyEdges lingvo files have been updated [incorrect/missing strings fixed], their ES versions were also updated by Defisto.
Global Moderator
Postby Keksschredder » Tue May 18, 2010 1:31 pm
Outstanding Tools. Thanks for the good work Tig.
Keksschredder
Postby dolphin » Wed May 19, 2010 5:41 pm
<<Pontugues>>
Por favor.
Não encontro o link para baixar o ExtrudeTools. Onde está?
<<English>>
Please.
I can not find the link to download the ExtrudeTools. Where is it?
dolphin
Postby Gaieus » Thu May 20, 2010 10:35 am
Hi Dolphin (and welcome to SCF).
Plugins are usually attached to the bottom line of the very first post in the topic.
Postby TIG » Thu May 20, 2010 10:56 am
It's here viewtopic.php?p=217663#p217663
The clue is in the 'note' ;)
or there are links in any of my posts announcing an update...
Global Moderator
Postby Daniel S » Thu May 20, 2010 1:47 pm
TIG wrote:It's here viewtopic.php?p=217663#p217663
Hi TIG
Great Idea!!! What about if you click in the image and that makes a direct download of the plugin?
Something like:
CLICK on the image for download!!
The code I Use:
Code: Select all
[url=http://forums.sketchucation.com/download/file.php?id=48174][attachment=0]Screenshot_1.jpg[/attachment][/url]
Daniel S
Daniel S
Postby TIG » Thu May 20, 2010 2:11 pm
I'd prefer the users read the post... then download... although I know a lot will scroll past everything anyway but if the image were to link to the download they'd even have no need to do that - you'd be amazed how many PMs we scripters get about problems with installing the files, simply because most new users never read the notes and open a zip file and then drag'n'drop everything into their Plugins folder; when these days a lot of stuff goes into sub-folders to try and keep things a little 'ordered'...
Global Moderator
Postby liangljz » Thu May 20, 2010 8:16 pm
i am looking for it. thank you
liangljz
Postby toldo39 » Sun May 23, 2010 9:22 pm
thnx
toldo39
Postby stefx » Thu Jun 03, 2010 3:33 pm
Hi TIG,
the plugin set is amazing!
I would like to know if there is a chance to create the extrude-edge-by-rails but for faces, something like "extrude faces by rails".
stefx
PreviousNext
Return to Plugins
Users browsing this forum: ashot_var, harrycahyono, Kasha Basha, Mastergeoar01 and 16 guests
