[Plugin] Edge ToolsRe: [Plugin] Edge Tools (2.0.2) — 06 February 2011Thom, just finished a project where the Edge Tools came in so handy. What a time saver you've created. Thanks again.
I was wondering if it would be possible to create an additional tool that acts like the Divide Face tool, but does it simultaneously on two opposing faces connected by a shared (corner) edge. I do a lot of corner trim and siding details that require this and do it manually at the moment. It would also be handy for subdividing purposes. Something simple that does like in the image in a single click with a distance input. I guess you could say it's an "offset corner". I figured I'd ask you first as it seems like a logical addition to this toolset. 3D Artist at Clearstory 3D Imaging
Guide Tool at Winning With Sketchup Content Creator at Skapeup
Re: [Plugin] Edge Tools (2.0.2) — 06 February 2011Lately I've not had as much time as I used to. So I don't feel I can commit to anything right now. Sorry.
![]() Thomas Thomassen — SketchUp Monkey & Coding addict
Well, this feature would be nice to be added to Artisan! ![]() ![]() DESIGNER AND ARTIST DEREI.UK
Re: [Plugin] Edge Tools (2.0.2) — 06 February 2011No worries bro. Just a thought for the next update whenever you get around to it.
Re: [Plugin] Edge Tools (2.0.2) — 06 February 2011Just wanted to say thanks! Comes in very handy!
Great work you're doing, man ![]() still sketchin'
Re: [Plugin] Edge Tools (2.0.2) — 06 February 2011wow!!!
![]() ![]() ![]() Re: [Plugin] Edge Tools (2.0.2) — 06 February 2011Thom,
when using 'split faces into multiple' then inputting an array only *# works (not #*). Not a major thing but thought you'd like to know. It's the same for #/ There's a frontroom and a backroom....reverse faces
hmm... never knew that was a input format. That shouldn't be too hard to add. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Edge Tools (2.0.2) — 06 February 2011Strange thing is I never knew the other method of input until I used this tool.
Anyway it's no biggie as I'm sure you're up to your eyes as it is. There's a frontroom and a backroom....reverse faces
Re: [Plugin] Edge Tools (2.0.2) — 06 February 2011I've had an update lingering for this anyway (small compatibility fix). So I need to get it out anyway.
Re: [Plugin] Edge Tools (2.0.2) — 06 February 2011THANK A LOT - I WAS LOOKING FOR YOUR PLUGINS- THIS IS MUST HAVE IN ALL SKP.
EVERY BODY SHOULD TRY Re: [Plugin] Edge Tools (2.0.3) — 17 June 2011
Requires TT_Lib 2.5.4 Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Edge Tools (2.0.3) — 17 June 2011![]() Thanks Thom There's a frontroom and a backroom....reverse faces
Re: [Plugin] Edge Tools (2.0.3) — 17 June 2011That one was for you Rich!
Re: [Plugin] Edge Tools (2.0.3) — 17 June 2011You've moved up in my favourite person list. Your now 82nd
![]() There's a frontroom and a backroom....reverse faces
Re: [Plugin] Edge Tools (2.0.3) — 17 June 2011thom,
I have run into a small problem: when I hover over the icons on the toolbar I get no feedback as to what each icon refers to. to be more precise, the name of the tools do not appear. I am on mac. do you have a fix for that? or, is there any place where I could find what each icon in the toolbar means?
Re: [Plugin] Edge Tools (2.0.3) — 17 June 2011hmm... no tooltips...? how odd...
and you get it on other plugins`? I don't see why there should be a difference for OSX on this... ![]() Thomas Thomassen — SketchUp Monkey & Coding addict
I do not get it with any other plugin, including your own. all the others work fine. edge tools is the only one in which the problem appears.
I noticed on my Mac if Edge tools toolbar is horizontal there was no feedback yet works fine vertical. "To read between the lines was easier than to follow the text."OSX 10.11.6 _ _ _ _ _ SU 8 pro
not so in mine. no feedback either way.
position the toolbar vertically then quit sketchup.. relaunch and the tooltips should work. dotdotdot
eh? Is this a know OSX issue? what an bizzare one... ![]() ![]() Thomas Thomassen — SketchUp Monkey & Coding addict
bizarre indeed! the tooltips are working now! and what a useful plugin this is! ![]()
it's hard to say since sketchup is the only app i use that allows you to drag a toolbar to the top of the screen and it will switch to horizontal orientation. it's very weird toolbar behavior in OSX world so i doubt it's a known issue since no apps do it. i just stumbled upon it one day when i tried 1001bit toolbar across the top of my screen. (bonzai has a few horizontal toolbars but their tooltips (vert&horizontal) aren't standard so they've done something to modify the icons/tooltips) dotdotdot
Re: [Plugin] Edge Tools (2.0.3) — 17 June 2011Thom, Thanks a lot. This should be a must on all sketchup user. A very useful plug. It makes work easier and faster.
Re: [Plugin] Edge Tools (2.0.4) — 11 July 20112.0.4 - 11.07.2011
Re: [Plugin] Edge Tools (2.0.4) — 11 July 2011Nice update. Thanks Thomthom!!
![]() 3D Artist at Clearstory 3D Imaging
Re: [Plugin] Edge Tools (2.0.4) — 11 July 2011Hi, ThomThom:
Thank you again for this excellent tool. And thank you for the 2.0.4 update. Will you be inserting info on the update in the first post? I take the slow, deliberate approach in my aimless wandering.
Re: [Plugin] Edge Tools (2.0.4) — 11 July 2011hm.. was just a minor update, really needed?
Users browsing this forum: kerlan, worayut062 and 16 guests
