SketchUcation Plugin Store
[Plugin] Edge Tools (2.0.4) — 11 July 2011
Re: [Plugin] Edge Tools (1.1.0) — 05 May 2010
Postby Pilou » Tue May 11, 2010 9:56 am
"Outside" is not given by face's sign of a normal?
Speedy Galerie
Pilou
Top SketchUcator
Operating system: Windows
SketchUp version: 6
License type: Free
SketchUp use: hobby
Level of SketchUp: Advanced
Postby arjunmax09 » Sun May 23, 2010 12:52 pm
Awesome!!! Awesome!!!Awesome!!!Awesome!!!Awesome!!! Thomthom you rock...that's why a rocking cake for you :D btw..do you listen to u2??
when you fail at something....you haven't really failed...you've found one way the thing will not work out
arjunmax09
Banned
Postby mitcorb » Sun May 23, 2010 2:35 pm
Sketchup would have to decide what is outside, what is inside. What if it would have something to do with faces facing camera? Or, if the model is a closed volume somehow Sketchup would check for this and assumes all outside faces should be white, all inside faces should be grey. But what would it decide on an almost closed volume?
mitcorb
Top SketchUcator
SketchUp version: 8
License type: Free
SketchUp use: architecture
Postby TIG » Mon May 24, 2010 10:36 am
That is why with some of my tools - like EEbyRails - it makes the mesh and asks if you want to reverse the faces - it tries to double-guess which is inside and which is out, BUT only you know which way round you'd like it...
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Mon May 24, 2010 11:19 am
Problem arise when you have meshes with internal faces.
Global Moderator
SketchUp version: 8
License type: Pro
Postby TIG » Mon May 24, 2010 11:34 am
If an edge has more than two faces it is impossible to have all of those faces oriented the same way.
A simple fact of geometry - therefore trying to orient meshes with 'internal' faces is futile...
Global Moderator
SketchUp version: 8
License type: Pro
Postby mitcorb » Mon May 24, 2010 12:30 pm
This must be due to Sketchup being a surface modeler?.
I'm not sure what Blender is classified as, but it has ways to deal with face orientation, internals and duplicates. I wonder if some analogous form of these concepts could still be applied to Sketchup?-- that is, short of exporting to Blender and back.
mitcorb
Top SketchUcator
SketchUp version: 8
License type: Free
Postby thomthom » Fri May 28, 2010 1:38 pm
Update 1.1.1
Important bug fix in my Ramer-Douglas-Peucker implementation of the curve simplification.
Global Moderator
SketchUp version: 8
License type: Pro
Re: [Plugin] Edge Tools (1.1.1) — 28 May 2010
Postby Ben Ritter » Fri May 28, 2010 4:32 pm
Thom thom, thank you for the great plugin. I don't seem to understand how to get the colinear function. I see the rest but not this one.
Ben
Ben Ritter
Postby notareal » Fri May 28, 2010 4:36 pm
Nice!
notareal
Thea Render
Postby thomthom » Tue Jun 01, 2010 7:01 pm
Sorry about replacing the Divide Face video is a poorer quality YouTube video, but I ran out of bandwidth on Screencast and I did not have the original video.
Global Moderator
SketchUp version: 8
License type: Pro
Postby pilger » Mon Jun 28, 2010 5:13 pm
Hey thom!
I wonder if the simplify curve bit work with closed curves or even surfaces. I find myself in a position in which i imported geometry from a DWG and it left me with some insanely segmented edges. I'm trying to find a method to simplify this thing which complies with the Human Rights.
I've uploaded a small sample to make it clearer.
Thanks in advance.
EDIT:
Found a neat SimplifyCountours.rb script right on the SketchUp repository (http://sketchup.google.com/download/rubyscripts.html). Silly me.
I figured i should post it here in order to help whoever has a similar issue, since it's somehow related to the plugin subject.
I'll be keeping your plugin though, thom. It's pure juice. Keep it up!
pilger
Postby thomthom » Mon Jun 28, 2010 6:17 pm
I realised last week that it did not work for closed curves. But this I should be able to make work.
However, it will not work with faces attached.
Global Moderator
SketchUp version: 8
License type: Pro
Postby pilger » Mon Jun 28, 2010 6:27 pm
That wouldn't be much of a problem. There's a pretty good Make Face plugin around (i don't remember who wrote it, though).
I'm having some difficulties in using that Simplify thingy i've found as it uses angles to do the dirty job and not the neat Rammer-Douglas_Peucker algorhithm. :\
pilger
Postby thomthom » Mon Jun 28, 2010 6:35 pm
Yea - it's why I was looking for a different algorithm as I found that Simplify didn't preserve the overall shape as well.
From your screenshot it looks as though you have a lot of criss-crossing curves. That leads to problems with any curve simplification algorithms.
In my DP implementation I pre-process the selection to locate curve segments. A curve segment is only valid if it doesn't have faces connected or forks. Anything that doesn't fit the requirements is silently ignored.
Global Moderator
SketchUp version: 8
License type: Pro
Postby pilger » Mon Jun 28, 2010 6:45 pm
Indeed, i realise the crossing is a bit of a problem. However, i separated them all in groups (which is basically double clic and group, being a fairly easy task) so i guess that wouldn't get much in the way.
pilger
Postby thomthom » Mon Jun 28, 2010 6:59 pm
hm... I guess it could be made into an option to consider a curve segment to be between forks...
Adding to Experiment list.
Global Moderator
SketchUp version: 8
License type: Pro
Re: [Plugin] Edge Tools (1.1.2) — 29 August 2010
Postby thomthom » Thu Aug 26, 2010 9:29 am
Version 1.1.2
Important Bug Fix!
Fixed incorrect lengths for Divide Face tool.
Global Moderator
SketchUp version: 8
License type: Pro
Postby Pilou » Thu Aug 26, 2010 9:36 am
Perfection is not for this world ;)
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby keyston » Fri Dec 03, 2010 12:29 am
Hi Thomtom,
First, thanks for your hours spent making all these plugins. its a wonder google dont take some onboard for future su releases.
I not very technically inclined when it comes to 3d terminology, just want to ask about importing terrain from google earth (get current view ), If I get a few views all slightly overlapping,then explode and toggle terrain, I get holes and overlaps and mess.
Which one of your scripts is best to clean this up? Edge tools or cleanup rb?
Also in su 8 get current view is no longer in the google toolbar?
keyston
SketchUp version: 8
License type: Free
SketchUp use: product design
Postby shoeb_cars » Mon Dec 06, 2010 1:27 pm
RESPECT ++
u saved my life again...TQ very much :sketchstatic:
shoeb_cars
Re: [Plugin] Edge Tools (1.1.3) — 20 November 2010
Postby thomthom » Mon Dec 20, 2010 11:10 am
Version 1.1.3
Important Update! Now handles curves the forms loops.
Global Moderator
SketchUp version: 8
License type: Pro
Postby rv1974 » Tue Dec 21, 2010 10:02 am
Damn how could I miss it? Excellent! With this set of tools you came very close to the one of the biggest hemorrhoids in my workflow- the acad generated arcs\polylines\curves. They typically overlap, cut each other, have different segment length and stray ends etc. If only you could make something in this direction ;)
rv1974
SketchUp version: 8
License type: Pro
Postby thomthom » Tue Dec 21, 2010 10:23 am
Overlapping curves that intersect each other is troublesome. It's something that should be corrected in Autocad before importing as it'd be difficult to separate them afterwars. ("Garbage in garbage out")
As for the curve segments - Fredo's Bezier Curve tool let you convert curves into parametric curves you can adjust - can be used to interpolate I think. Maybe his plugin could be automated to process a set of curves?
Global Moderator
SketchUp version: 8
License type: Pro
Re: [Plugin] Edge Tools (1.1.3) — 20 December 2010
Postby bentleykfrog » Sat Feb 05, 2011 11:54 am
Awesome toolset, would be nice if divide faces preserved the edges soft, smooth and hidden properties though.
thanks thomthom
bentleykfrog
Postby thomthom » Sat Feb 05, 2011 3:40 pm
bentleykfrog wrote:Awesome toolset, would be nice if divide faces preserved the edges soft, smooth and hidden properties though.
thanks thomthom
Good idea. I have an update coming up very shortly. Though it won't make it for that, but I'll be on my todo list. :thumb:
Global Moderator
SketchUp version: 8
License type: Pro
Re: [Plugin] Edge Tools (2.0.0) — 05 February 2011
Postby thomthom » Sat Feb 05, 2011 9:08 pm
Version 2.0.0
  • Bug fixes
  • Toolbar
  • Close Gaps
  • Erase Stray Curves
Global Moderator
SketchUp version: 8
License type: Pro
Postby srx » Sun Feb 06, 2011 10:38 am
Thank you, thank you, thankyou...
srx
SketchUp version: 7
License type: Free
Re: [Plugin] Edge Tools (2.0.1) — 06 February 2011
Postby thomthom » Sun Feb 06, 2011 11:16 am
Version 2.0.1
  • Fixed minor issue where the plugin might throw an error if another plugin hadn't already loaded TT_Lib2.
Global Moderator
SketchUp version: 8
License type: Pro
Postby dedmin » Sun Feb 06, 2011 11:35 am
dedmin
Are you a Premium Member? Get your freebies here. Are you not a Premium Member yet? Upgrade your account to grab these freebies instantly.
PreviousNext
Return to Plugins
Users browsing this forum: fperruchot, MarOmir and 7 guests
