by calvin200001 » Sun Dec 15, 2013 9:30 pm
does this work for mac? I get an error:
Error Loading File /Users/****/Library/Application Support/SketchUp 2013/SketchUp/Plugins/TT_EdgeTools/core.rb no such file to load -- TT_Lib2/core.rb Error Loading File tt_edgetools.rb no such file to load -- TT_Lib2/core.rb
calvin200001
- Name: josh
- Operating system: Mac
- SketchUp version: 2013
- License type: Free/Make
- SketchUp use: product design
- Level of SketchUp: Beginner
by TIG » Sun Dec 15, 2013 10:12 pm
calvin200001 wrote:does this work for mac? I get an error:
Have you installed the latest version of the TT_Lib2 and restarted SketchUp ? http://sketchucation.com/resources/plug ... pln=TT_Lib
- Global Moderator
- Name: TIG
- Operating system: Windows
- SketchUp version: 2021
- License type: Pro
- SketchUp use: architecture
- Level of SketchUp: Advanced
by calvin200001 » Sun Dec 15, 2013 10:53 pm
SO sorry, I didnt see that. Works amazingly now.
calvin200001
- Name: josh
by halroach » Wed Jun 11, 2014 12:19 pm
Hi Thomthom,
I've been using edge tools for a long time. It's great!
A little idea that could be a great time saver. It would be nice if you could add to the 'Inspect & Close' function, an option of dragging the mouse over a bunch of edges to have them all fixed at once.
(... Like when there is a long staircase imported from dwg where all of the steps aren't connecting... drag a selection all around them... and viola - all taken care of).
halroach
- Name: Yoni Frandzel
- SketchUp version: 2018
- License type: Pro
by pbacot » Wed Jun 03, 2015 9:40 pm
I find that with "Split faces into multiple pieces" the "X" key is not recognized to create more multiple edges. The * key on the 10-key pad is recognized however. This is on a Mac. Is that intended?
- Top SketchUcator
- Name: pbacot
- SketchUp version: 2016
- License type: Pro
by JQL » Wed Jun 03, 2015 9:52 pm
pbacot wrote:I find that with "Split faces into multiple pieces" the "X" key is not recognized to create more multiple edges. The * key on the 10-key pad is recognized however. This is on a Mac. Is that intended?
Duh! I didn't know one could do that. It works (though my "X" is assigned to other function and I always use "*" for that sort of stuff)
JQL
- Premium Member
- Name: JQL
- SketchUp version: 2017
- License type: Pro
by pbacot » Wed Jun 03, 2015 11:08 pm
did you know you could place the line on many other faces in context, not just the contingent face? I am not sure what decides which faces apply, but probably has something to do with having an edge that is a parallel to the contingent face. I just found that out today.
- Top SketchUcator
- Name: pbacot
- License type: Pro
by cotty » Thu Jun 04, 2015 8:44 am
I would like to get a line at the next vertex (see animation) and not only in between the vertices, is it possible? edgeatvertex.gif
cotty
- Top SketchUcator
- Name: Carsten
- SketchUp version: 2020
- License type: Pro
- SketchUp use: hobby
by JQL » Thu Jun 04, 2015 10:08 am
pbacot wrote:did you know you could place the line on many other faces in context, not just the contingent face? I am not sure what decides which faces apply, but probably has something to do with having an edge that is a parallel to the contingent face. I just found that out today.
Yes that I knew already! We are tied! The only thing needed is coplanar faces... cotty wrote:I would like to get a line at the next vertex (see animation) and not only in between the vertices, is it possible?
That only happens when the edge hits two simultaneous vertexes. I never split faces but sometimes that happens if I use split faces around a box. I can split 3 faces but the last only works if I draw a line. I used to think it had something to do with that final edge generating a face but it has to do with joining two END vertexes. split box.jpeg It can split if the vertexes are in the middle. split middle vertexes.jpg
JQL
- Premium Member
- Name: JQL
- License type: Pro
by pbacot » Thu Jun 04, 2015 4:05 pm
Yep, The faces don't need to be coplanar. They can be parallel faces and perpendicular but parallel to edge, plus more--but I haven't figured out what and probably cannot
- Top SketchUcator
- Name: pbacot
- License type: Pro
by alamin » Mon May 09, 2016 5:31 pm
any pdf tutorial ?
alamin
- Name: alamin
- SketchUp version: 2014
- License type: Pro
by AMena » Thu May 11, 2017 12:23 pm
@thomhom
Hi, i installed Edge tools² in my sketchup pro 2017, but i'm not able to find it in the menu "View » Toolbars » Edge Tools²" or in "Tools » Edge Tools²" , i've tried to reinstal it, but it did't work.
Pd: i already installed the TT_Lib² — 2.7.0 before instal the Edge tools²
Thanks for the help
AMena
- Name: Andrea Mena
- License type: Pro
- SketchUp use: education
by TIG » Fri May 12, 2017 11:43 am
Assuming you installed it from its RBZ using the Install Extension tool... Check under the Extension Manager dialog that it is activated - if it's not, then no menu items or toolbars will appear...
- Global Moderator
- Name: TIG
- License type: Pro
by filatelik » Mon Sep 18, 2017 10:57 am
Hi Thomthom, first of all many thanks for this useful plugin.
Just would like to ask you if exist or you plan to make its equivalent for newer versions of Sketchup? I mean *.rbz suffix of file. Many thanks in advance for your answer.
Filip
filatelik
- Name: filatelik
by Dave R » Tue Sep 19, 2017 12:08 pm
filatelik wrote:Just would like to ask you if exist or you plan to make its equivalent for newer versions of Sketchup? I mean *.rbz suffix of file. Many thanks in advance for your answer.
Filip
The rbz file is already available and has been for a long time. Look in the PluginStore by clicking on the button at the top of this page. Or better, install the Sketchucation Extension Store tool (look under Resources at the top of this page.) and use it to install Edge Tools. Don't forget to also install the current TT_Lib as well.
- Global Moderator
- Name: Dave R
- License type: Pro
- SketchUp use: woodworking
by Einstein » Thu Feb 15, 2018 1:31 pm
Very handy tool, thank you  I'd have a little upgrade suggestion - the first tool "Split faces into multiple pieces" could remember the last distance used and snap cursor to it
Einstein
- Name: Michal P
- License type: Pro
by Einstein » Tue May 29, 2018 3:16 pm
Hi! I use these tools a lot but unfortunately I cannot set a key shortcut for any of them because thery're not listed in SketchUp's tools list in Preferences > Shortcuts. Please, if you could, make some upgrade that would include them into the list.
Also remembering last distance in the first tool: "Split faces into multiple pieces" would be a great feature. With these two things Edge Tools would be not only cool and handy, but also very fast to use.
Einstein
- Name: Michal P
- License type: Pro
by Box » Tue May 29, 2018 3:33 pm
Look for them under Tools/edge...
- Name: Box
- License type: Pro
- SketchUp use: other
by Dave R » Tue May 29, 2018 3:49 pm
Einstein wrote:Hi! I use these tools a lot but unfortunately I cannot set a key shortcut for any of them because thery're not listed in SketchUp's tools list in Preferences > Shortcuts. Please, if you could, make some upgrade that would include them into the list.
C'mon Einstein. As Box wrote... Screenshot - 5_29_2018 , 10_04_18 AM.png Filter for 'edge' to shorten the list.
- Global Moderator
- Name: Dave R
- License type: Pro
by Einstein » Tue May 29, 2018 9:26 pm
Thank you.
I was confused because the tool called "Split faces into multiple pieces" stood in the list as "Divide faces" and I firstly didn't come up it's the same thing.
Einstein
- Name: Michal P
- License type: Pro
by maszka » Tue Aug 13, 2019 9:02 am
THe plugin Egde and Lib are installed properly but I cannot find anything in tools/ view toolbars to swich on. I cannot find this pludins in interface of sketchup anywhere.
Anybody could help me?
maszka
- Name: maszka
- SketchUp version: 8
by Dave R » Tue Aug 13, 2019 6:35 pm
maszka wrote:THe plugin Egde and Lib are installed properly
Are you still using SketchUp 8 as indicated in your profile? How exactly did you install them?
- Global Moderator
- Name: Dave R
- License type: Pro
by asder » Mon May 04, 2020 2:36 am
thank
asder
- Name: asder
by ct103stu0 » Sat Jun 06, 2020 8:02 pm
When I use "Find all edge gaps", I see the circles. And I can click each one and repair. But, due the large number, I then use "Close all edge gaps", and none of the gaps are closed. Should "Close all edge gaps" close all gaps identified by the "Find all edge gaps"?
ct103stu0
- Name: Claire Z.
by maheswari19 » Wed Jun 17, 2020 1:45 pm
Hey thomthom! I am currently using sketchup 2020. I installed edge tools plugin but it does not show up on my palette. And i checked on my extension manager it shows enabled but is does not shop up. Please help me.
maheswari19
- Name: Maheswari D
- License type: Pro
by Dave R » Thu Jun 18, 2020 12:08 pm
maheswari19 wrote:I installed edge tools plugin but it does not show up on my palette.
Did you also install the current version of tt_lib2? It is required for Edge Tools to work. And did you install SketchUp 2020 correctly by right clicking on the downloaded installer exe file and selecting Run as administrator from the context menu?
- Global Moderator
- Name: Dave R
- License type: Pro
by Einstein » Thu Sep 10, 2020 10:18 am
It would be cool to have the same tool names in the toolbar and Preferences. For example: a tool called "Split faces into multiple pieces" lives in the Prefs hotkey list as "Divide faces" and I couldn't figure out it's the same thing. It is very confusing.
Einstein
- Name: Michal P
- License type: Pro
- Robot
Return to Plugins
