[Plugin] Edge Tools
Re: [Plugin] Edge Tools (2.0.1) — 06 February 2011
Postby jokewalker » Thu Sep 20, 2012 5:08 pm
dedmin wrote:
Hey all,
Just installed 2.0.4 and am seeing this pop up again. Any simple fixes to make this go away?
jokewalker
Re: [Plugin] Edge Tools (2.0.4) — 11 July 2011
Postby TIG » Thu Sep 20, 2012 5:17 pm
Did you get-and-install the TT Lib that was linked on the download page ?
Global Moderator
Postby jokewalker » Thu Sep 20, 2012 6:06 pm
TIG,
I did have a version of TT_Lib2 in the Plugins folder already, but went ahead and re-downloaded/installed per your suggestion. Seems to be working now. Thanks!
jokewalker
Postby sarkarshomit » Mon Sep 24, 2012 6:09 am
Thanks ...very useful for me....
Shomit,
India
sarkarshomit
Postby thomthom » Mon Sep 24, 2012 8:51 am
jokewalker wrote:
dedmin wrote:
Hey all,
Sounds like you extracted the content of TT_Lib directly in the plugins folder istead of preserving the TT_Lib2 that contains them.
PluginStore Author
PluginStore Author
Postby Mra » Thu Nov 29, 2012 4:11 am
thomthom, sweet script. However i'm having problems with one of your tools.
The "Split faces into multiple pieces" doesn't seem to work properly on this face;
I can't give you the full scene though (NDA) and when I just paste this piece into a new sketchup scene your tool works. Any ideas? :)
Exploding object doesn't work either. The axis is at default place in the world at 0,0,0.
Mra
Postby thomthom » Thu Nov 29, 2012 9:42 am
mra wrote:I can't give you the full scene though (NDA) and when I just paste this piece into a new sketchup scene your tool works. Any ideas? :)
Can you save a copy of the model - erasing everything else - purge the model, then send it to me?
PluginStore Author
PluginStore Author
Postby Mra » Thu Nov 29, 2012 11:46 pm
Hi Thomthom, today is another day, so after I turn on the computer again, it seems there is no problem on the same piece of mesh anymore. Something must've been corrected when restarting SketchUp. Perhaps I ran into a bug by somehow? But anyway, thanks for your offer to take a look. If it ever happens again, I will try and get some reproducible steps.
Mra
Postby thomthom » Fri Nov 30, 2012 12:02 am
Ghost in the box. :)
PluginStore Author
PluginStore Author
Postby ErikLiu0801 » Tue Dec 11, 2012 6:42 pm
thanks a lot.
i'm not good at english but i still want to say thanks for your sharing.
ErikLiu0801
Postby bobpineo » Mon Dec 17, 2012 4:44 pm
Thomthom,
Using this plugin again today on another very large autocad import, can't tell you how grateful I am for your plugin!
Bob Pineo, Design Develop LLC http://www.designdevelop.org.
bobpineo
Premium Member
Premium Member
Postby thomthom » Mon Dec 17, 2012 4:45 pm
PluginStore Author
PluginStore Author
Postby gina » Thu Jan 31, 2013 1:40 pm
HELP !
It doesnt work for me. i'm using su 8, and at the beginning of load screen a message box appear saying that theres an error from loading the edges tool plugins.
gina
Postby Dave R » Thu Jan 31, 2013 2:10 pm
What is the exact error message?
Global Moderator
Postby thomthom » Fri Feb 01, 2013 9:50 am
As Dave said, without knowing the error it's impossible to determine what the problem is.
If I'd hazard a guess, did you install the required TT_Lib2? Linked under Requirements right above the Download button?
PluginStore Author
PluginStore Author
Postby onzki » Wed Apr 10, 2013 7:36 am
This is an amazing tool. Thanks so much it's very useful. I like the concept of curve simplification.. However, forgive my out of the world request, is it also possible to have a way to make curves smoother- meaning an option to add segments rather than reduce. I know it sounds crazy but there are times when most of my CAD import are roughly segmented like the one shown on screenshot.
Thanks!
[/hr]Dell Precision T5600. SKU 2018 Pro. AutoCAD 2013. Landscape design firm. Hong Kong
onzki
Postby thomthom » Wed Apr 10, 2013 12:39 pm
Problem here is that they are part of complex geometry. Adding more segments to that isn't easy for a computer operation to do.
PluginStore Author
PluginStore Author
Postby rv1974 » Sun May 19, 2013 12:40 pm
Thomthom, would it be hard to refine 'divide face' to make it offset '0' from stray line laying on the face (AB in the attachment)?
Another thing: Could there be 'magneto' or double click feature (like in standard move and offset) that'd glue to the last numeric input?
Thank you.
rv1974
Postby thomthom » Mon May 20, 2013 10:31 am
rv1974 wrote:Thomthom, would it be hard to refine 'divide face' to make it offset '0' from stray line laying on the face (AB in the attachment)?
Offset zero? I'm afraid I don't understand the request. What is the expected result?
rv1974 wrote:Another thing: Could there be 'magneto' or double click feature (like in standard move and offset) that'd glue to the last numeric input?
Thank you.
That would be nice indeed.
PluginStore Author
PluginStore Author
Postby rv1974 » Mon May 20, 2013 12:36 pm
thomthom wrote:Offset zero? I'm afraid I don't understand the request. What is the expected result?
Activate 'divide face' tool, put cursor above AB line segment and try to cut the face via AB. Currently you won't make it,- there's kind of bug.
rv1974
Postby thomthom » Mon May 20, 2013 12:49 pm
Ah! Gotcha! So it's be an extend edge kindof feature?
PluginStore Author
PluginStore Author
Postby rv1974 » Mon May 20, 2013 1:31 pm
exactly
rv1974
Postby Dave R » Mon May 20, 2013 1:38 pm
There are already plugins that extend lines.
Global Moderator
Postby TIG » Mon May 20, 2013 4:04 pm
Not sure I understand why it can't be done by hand...
Make a guide-line through the line AB.
Ensure nothing is selected.
Activate the Move tool.
Pick the start of the line AB and snap it to the guide's intersections with the face's edge.
Repeat for the end of the line AB.
Now line AB has extended to meet the two face-edges...
Erase the superfluous guide-line.
Alternatively draw a new line across the face from the intersections of the guide and the face's edges... erase the guide.
Global Moderator
Postby thomthom » Mon May 20, 2013 4:14 pm
TIG wrote:Not sure I understand why it can't be done by hand...
Because one click is nicer than many. ;)
When cleaning up plans there's often a lot of edges that need extending - and the less clicks the better.
I've been meaning to find the time to allow the Close Edge tool in Edge Tools to do this. So when it highlights an open end edge you can just click on it and have it extend - even though it would be outside the radius.
PluginStore Author
PluginStore Author
Postby TIG » Mon May 20, 2013 4:16 pm
There's already my 2dTools Adjust ?
Works in any plane...
Wipe the two types of edges and - objects/targets and they adjust by extending or trimming...
Global Moderator
Postby rv1974 » Mon May 20, 2013 5:48 pm
It should be a permanent headline in the ruby sub-forum.
rv1974
Postby JQL » Wed Oct 09, 2013 4:52 pm
Thomthom,
Since Sketchup 2013 the inspect tool in Edgetools2 has been very unstable.
Split faces is working fine, erase stray edges is perfect as ever and I can also use align vertices. However most of the time I try the inspect tool Sketchup crashes sometimes it's only when I press the circles, but it also happens just for executing the tool. The strange thing is that it actually inspects correctly but then SU stops responding.This is happening with both complex and simple models.
I have the most recent version installed and also TT Library. I erased both folders and reinstalled from Sketchucation Plugin Store.
As I don't see anyone saying the same thing I suppose it might be my problem, but would you have some kind of guidelines for figuring out what I can do?
Thanks and best regards,
EDIT: I just isolated both TTLib and Edgetools and removed every other plugin from plugins folder and it crashed again...
JQL
JQL
Premium Member
Premium Member
Postby tetrochuan » Wed Oct 09, 2013 6:01 pm
i second the instability issues with the find edge command... :L
tetrochuan
Postby halroach » Tue Oct 22, 2013 11:15 am
I've got an idea for a nice feature that could make this plugin even more powerful.
Having the option to limit the "edge gap closing" to points that are on the same Z. Any chance for that?
halroach
PreviousNext
Return to Plugins
Users browsing this forum: jcscsig and 12 guests
