SketchUcation Plugin Store
[Plugin] UVTools 0.2 Pro (Beta) (Updated for SU6)
Re: [Plugin] UVTools 0.2 Pro (Beta) (Updated for SU6)
Postby snowdogg » Thu Oct 13, 2011 7:07 pm
24DIADOME.skp
Rich O'Brien wrote:Try it on a Dome with 50 edges to see if it's the edge count. Or share it here so we can all play.
Opps, forgot to attach it. Yes, I would appreciate if you can see if there are any problems. I am just trying to add the tile roof texture (in Sketchup)on the top side only.
snowdogg
Postby snowdogg » Wed Oct 19, 2011 3:18 pm
snowdogg wrote:
24DIADOME.skp
Anyone had any thoughts/solutions about this? Still having problems. Thanks!
snowdogg
Postby martinvz » Fri Oct 21, 2011 9:53 pm
Great plugin.
Im not sure if the author still updates the plugin, but I found out it did not import in blender.
This is because of a small typo in the plugin file at line 374.
Fix the typo and blender will import without a problem.
martinvz
Postby snowdogg » Tue Oct 25, 2011 3:06 pm
Quick question. Does this plug-in conflict with other plug ins? I think I found out why I was bug splatting because I have a version of SketchUp (version 8) without many plug ins (my other versions have no conflicts amongst themselves, and are up to date). If someone knows, please advise me. I really like this plug in and I would like to use it on 7.
snowdogg
Postby Rich O Brien » Tue Oct 25, 2011 3:54 pm
Firstly, here's your dome mapped without any problems happening. Sorry for late response.
Secondly, this is the first reported issue with UV Tools Pro so I imagine the conflict lies elsewhere.
Try removing all plugins except this and test to see if it happens.
:::Blog:::
I'm a Trimbler now!
Rich O Brien
Administrator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: engineering and mechanical design
Level of SketchUp: Advanced
Postby TIG » Tue Oct 25, 2011 3:59 pm
Another issue is you modeled the dome completely inside out with all back-faces outwards.
Reverse one and Orient to correct it before trying complex UV mapping tricks - which are intended for front face materials...
Global Moderator
SketchUp version: 2013
License type: Pro
SketchUp use: architecture
Postby snowdogg » Tue Oct 25, 2011 4:28 pm
Rich O'Brien wrote:Firstly, here's your dome mapped without any problems happening. Sorry for late response.
Thanks so much! Yes, I am going through the plugins now and now, I think I know the problem. Not purging through LIBFREDO6 purge feature. And also, not deleting the older versions! I probably got sidetracked at the time, and I didn't follow through the instructions. I am glad I can now use this plugin, its so darn helpful!
snowdogg
Postby Rich O Brien » Tue Oct 25, 2011 4:32 pm
Good.
From experience, I know installing all these glorious plugins is a must but if when reorganizing you say 'I don't use THAT often' then it needs to go.
It's easier troubleshoot and also it has a calming influence.
:::Blog:::
I'm a Trimbler now!
Rich O Brien
Administrator
SketchUp version: 8
License type: Pro
Postby martinvz » Fri Nov 04, 2011 12:06 pm
I Guess Whaat does not update this plugin anymore.
So here is a fixed version, this will solve the problem with Blender.
Tested with blender 8, LithUnwrap and Blender.
UVtools.rb
martinvz
Postby dereeei » Fri Nov 04, 2011 12:21 pm
martinvz wrote:I Guess Whaat does not update this plugin anymore.
UVtools.rb
What exactly is fixed?
dereeei
Postby Rich O Brien » Fri Nov 04, 2011 12:24 pm
dereeei wrote:What exactly is fixed?
viewtopic.php?p=361512#p361512
:::Blog:::
I'm a Trimbler now!
Rich O Brien
Administrator
SketchUp version: 8
License type: Pro
Postby dereeei » Fri Nov 04, 2011 12:26 pm
LOL ! i was looking around about "the glitch that needed fix", the page before, two pages before...but somehow I missed that :mrgreen:
dereeei
Postby thomthom » Fri Nov 04, 2011 12:54 pm
UVtools.rb
Did you get permission to redistribute the plugin?
Global Moderator
Name: Thomas Thomassen
License type: Pro
Postby Gaieus » Fri Nov 04, 2011 1:11 pm
UVtools.rb
Pleae, read the plugin posting guidelines here:
viewtopic.php?p=204973#p204973
Whaat is alive and active so he may consider incorporating some changes into his plugin but re-posting verions is not good.
Administrator
License type: Pro
SketchUp use: historical reconstruction
Postby Whaat » Fri Nov 04, 2011 4:12 pm
UVtools.rb
I apologize for not updated this plugin. You should be asking permission before you redistribute any plugins. However, I have decided to include your version in the top post of this thread (hmmmm...I guess I'm now redistributing your plugin... :P :lol: ) if you don't mind.
Thanks for providing a fix. I had tested the plugin with Blender before and I thought it worked fine but I guess I was wrong.
Whaat
SketchUp version: 8
License type: Pro
Postby Gaieus » Fri Nov 04, 2011 4:23 pm
:thumb:
Administrator
License type: Pro
Postby martinvz » Fri Nov 04, 2011 5:10 pm
My appoligies, I did not alter anything in the plugin except the fix. (wanted to help the people out that did not know how to fix the plugin)
Because the plugin did not get any update I thought the author did not update the plugin anymore. (last update was a long long time ago)
Next time I will pm the author first.
martinvz
Postby Lianam » Sat Jan 07, 2012 1:55 am
Thanks for the plugin...Just found it. I am using sketch-up 8 and trying to learn Blender also. I want to be able to texture in blender what I can not in sketch-up the way I want to or that is my main hope. :) I will give it a try soon.
Lianam
Lianam
Uv tools to UV layout help
Postby paolo » Tue Jul 17, 2012 12:08 pm
Hi everyone, sorry for the silly question but I'm learning using UV tools by Whaat (thanks a lot to him) with Headus UVlayout although is for Architectural purpose (simple geometry) I wonder if using this method will reduce the file size comparing to editing textures to Photoshop in Sketchup? any way I have a problem when loading the geometry in UVlayout cause some openings do not appear, please see the pictures.
Thanks a lot for any help.
paolo
Re: Uv tools to UV layout help
Postby Whaat » Tue Jul 17, 2012 4:30 pm
paolo wrote:Hi everyone, sorry for the silly question but I'm learning using UV tools by Whaat (thanks a lot to him) with Headus UVlayout although is for Architectural purpose (simple geometry) I wonder if using this method will reduce the file size comparing to editing textures to Photoshop in Sketchup? any way I have a problem when loading the geometry in UVlayout cause some openings do not appear, please see the pictures.
I think there might be a bug with the OBJ export for faces with more than four vertices. Try manually dividing faces into quads before exporting and see what happens?
Whaat
SketchUp version: 8
License type: Pro
Postby paolo » Wed Jul 18, 2012 10:21 am
:o Whaat thanks for your quick reply, it works manually dividing face into quads although is a bit of a pain... I wonder if your SketchUV plugin will do the job 'automatically'.
paolo
Postby Whaat » Wed Jul 18, 2012 4:05 pm
paolo wrote::o Whaat thanks for your quick reply, it works manually dividing face into quads although is a bit of a pain... I wonder if your SketchUV plugin will do the job 'automatically'.
Sorry, although SketchUV has a nice triangulation feature that will split all faces into triangles, it has a bit of trouble with faces that have 'holes'
Whaat
SketchUp version: 8
License type: Pro
Postby weblogin » Wed Mar 06, 2013 10:21 am
Thanks, lets try it!
weblogin
SketchUp version: pre-6
License type: Pro
Level of SketchUp: Beginner
Postby eeum8244 » Sun Apr 07, 2013 5:58 am
thank you
eeum8244
Postby Leonard96 » Sun Apr 21, 2013 7:28 pm
Gaieus wrote:
zunkian wrote:...I then right click on the model, selected the UV tools plugin and selected spherical map...
This is the wrong topic then. That's UVTools 1:
http://forums.sketchucation.com/viewtopic.php?t=10404
And yes, sometimes that plugin does not work perfectly. Can you attach the model?
Hy Gav! I need help!!! SketchUP 8 crashes because of UV tool 1 when I want to mapp a texture(I want to model planet Jupiter).Sometimes works sometimes crashes, but now...it crashes! :x :x Hope to find a solution!Here is my model!
Untitled.skp
Here are my models on 3D warehouse:http://sketchup.google.com/3dwarehouse/cldetails?mid=ded937a45a821f58178b53c3b6bafa41
Leonard96
Name: Vlad Miha-Leonard
SketchUp version: 8
License type: Pro
SketchUp use: game and/or sci-fi modelling
Vertex Tools for SketchUp. Take control over each vertex with this vertex editor for SketchUp.
PreviousNext
Return to Plugins
Users browsing this forum: cal717, Google Feedfetcher, keahi, TheGetGo and 14 guests
