[Plugin] Component Stringer UPDATED May 23, 2013
• Page 5 of 5 • 1, 2, 3, 4, 5
Re: [Plugin] Component Stringer UPDATED Nov. 16, 2009hi sr Chris Fullmer.
This plugin is generating the following error Error: #<NoMethodError: undefined method `edges' for nil:NilClass> C:/Archivos de programa/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb:59:in `curve_ordering' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb:56:in `times' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb:56:in `curve_ordering' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb:105:in `main' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb:190 I use sketchup8 pro It is possible to fix? Thank you very much
Re: [Plugin] Component Stringer UPDATED Nov. 16, 2009Can you supply the model or a part of the model you are working on? Is it repeatedable on all models for you?
Re: [Plugin] Component Stringer UPDATED Nov. 16, 2009that error can not play Mr. Chris, but the plugin works well in general.
thanks
Re: [Plugin] Component Stringer UPDATED Nov. 16, 2009ok, I hope it keeps working for you,
Chris
Re: [Plugin] Component Stringer UPDATED Nov. 16, 2009Hi chris,
Great plugin, however i have this on a model. Error: #<ArgumentError: Cannot convert argument to Sketchup::Point3d> /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_component_stringer.rb:80:in `add_text' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_component_stringer.rb:80:in `curve_labeler' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_component_stringer.rb:70:in `curve_ordering' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_component_stringer.rb:105:in `main' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_component_stringer.rb:190 /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_component_stringer.rb:80:in `call' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_component_stringer.rb:80 Here is a link for it http://www.mediafire.com/?aesv4fd1ccv1cvn It does not get to the reverse option. The plugin works fine on a simple box and a curve. SU8, OSX 10.6.7 It seems to write 'start' but not 'end'. I hope it is useful, if you have time to have a quick look. Regards Sam
Re: [Plugin] Component Stringer UPDATED Nov. 16, 2009I am trying to make a chain like in the video in the first post. Must be doing something wrong because I'm getting what's in the picture below when I set the component rotation to 90°. Any advice? SU8 Free M2
Thank You Please, register (free) to access all the attachments on the forums.
Re: [Plugin] Component Stringer UPDATED Nov. 16, 2009It all has to do with where the component axis is set. It looks like its oriented correctly, its just not centered right. Then once the chain is made, you need to edit the component and extend one end of it so that it overlaps into the other components, which I think I did in the video.
But first, spend some time figuring out how to center the component axis better. Chris
Re: [Plugin] Component Stringer UPDATED Nov. 16, 2009OK. Thank You very much Chris. I'll let you know how it turns out this weekend. Thanks again for your help and for the plugin.
Re: [Plugin] Component Stringer UPDATED Nov. 16, 2009I did it!!! Centered the axis like in the picture below and it works like a charm. Thank You very much Chris for your help and for a wonderful plugin.
Re: [Plugin] Component Stringer UPDATED Nov. 16, 2009Awesome tool, thank you chris fullmer ...
Re: [Plugin] Component Stringer UPDATED Nov. 16, 2009Brilliant plugin
Re: [Plugin] Component Stringer UPDATED Nov. 16, 2009Any chance there could be a "stretch" modifier (like the stretch tool in FredoScale) when stringing components? Although i guess this would destroy the component definitions.
joel
Re: [Plugin] Component Stringer UPDATED Nov. 16, 2009Many thanks for the excellent pluggin
Noobtastic
Re: [Plugin] Component Stringer UPDATED Nov. 16, 2009Wonderful plugin. Many Thanks Chris
Noobtastic
Re: [Plugin] Component Stringer UPDATED Nov. 16, 2009You're welcome and you're welcome!
Re: [Plugin] Component Stringer UPDATED Nov. 16, 2009Chris,
I've been trying to use this amazing tool to place a Tree component along some streets, but can't them to be separated as I need them to be(distance between each component). Do you have any ideas to fix this? I would really appreciated it! Ana
Re: [Plugin] Component Stringer UPDATED May 23, 2013Great Plugin I was searching for it.
I moved the plugin in my plugins folder but I cant find it in sketchup.
Re: [Plugin] Component Stringer UPDATED May 23, 2013i cant install this plugin:( windows 8, sketchup 8
Re: [Plugin] Component Stringer UPDATED May 23, 2013You'll need to give us a bit of help here Help us to help you. Fill in your User-Profile details so we can immediately know your OS, SketchUp version etc without having to read a post that might be several steps earlier by the time we resolve this issue... This kind of problem has almost certainly been covered endlessly in other posts at SCF... Here are a few ideas... Do you install, and then always run SketchUp as an admin? [properties>compatibility check-box setting] Do you have FULL permissions to the Plugins folder? [properties>security>edit] It should be set to FULL for everyone. Do you have a 'Compatibility Files' button/link on the Plugins folder's Windows Explorer window upper bars? This suggests a VirtualStore issue resulting from you having limited permissions when trying to install files into a folder. Do you understand how to install a plugin from an RBZ archive? Do you have the current version of v8? [you need >= v8M2] You need that to get the 'Install...' button in the Preferences > Extensions dialog. This allows you to auto-install files/subfolders of helper from an RBZ archive. Do you understand that if you don't want to upgrade your earlier version then you can add .ZIP to the end of the .RBZ archive and extract its contents; then manually install the file[s] and subfolder[s] of files 'intact' into the Plugins folder... If in doubt about manually installing plugins then please read the help/tutorial section at SCF... I assume you are getting the tool's RBZ file from the PluginStore? http://sketchucation.com/resources/pluginstore ? If you have a suitable version v8 or v2013 that allows 'auto-install' then can I suggest you get and install the 'SketchUcation Plugin Store' tool which then allows you to browse all of the SCF plugins and Auto-Install them immediately, with no manual download etc on your side... http://sketchucation.com/resources/plug ... e-download Hopefully one [or more] of the above will start you off in the right direction. If you are still flummoxed ask again. TIG
SketchUcation One-Liner AdvertsNeed Authorised SketchUp Training by experts in various disciplines? Check out our Training details.
