SketchUcation Premium Membership
[Plugin] Component Stringer UPDATED Nov. 16, 2009
Re: [Plugin] Component Stringer UPDATED Nov. 16, 2009
Postby thomthom » Sun Sep 05, 2010 9:43 am
EscapeArtist wrote:Anyone tried this with SU8 yet? I seem to be having difficulty with component orientation and scaling.
Screenshots? Would help with more specific information.
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby Chris Fullmer » Mon Sep 06, 2010 7:51 am
Yeah, screenshot please :) I have not gotten around to testing my plugins with version 8. I'm sure there might be some problems. But problems with scaling and orientation were not on my list of things I was expecting to break - so I'm not exactly sure what might be wrong. But screenshots might help, thanks!
Chris
All my Plugins I've written
SketchUp Team
SketchUp version: 8
License type: Pro
SketchUp use: landscape architecture
Postby sklu » Mon Sep 06, 2010 10:05 am
Component Stringer Loading Problem
I loaded the RB into sketchup folder..but when trying to activate, it doesn't work.
Ruby Console showing:
Error: #<ArgumentError: Cannot convert argument to Sketchup::Point3d>
C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_component_stringer.rb:79:in `add_text'
C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_component_stringer.rb:79:in `curve_labeler'
C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_component_stringer.rb:70:in `curve_ordering'
C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_component_stringer.rb:105:in `main'
C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_component_stringer.rb:190
Any help, Chris?
sklu
Postby Chris Fullmer » Mon Sep 06, 2010 10:42 am
Hmm, its past my bedtime right now, I'll check it out tomorrow. But what version of SU are you trying it on?
Chris
SketchUp Team
SketchUp version: 8
License type: Pro
Postby sklu » Mon Sep 06, 2010 11:10 am
SU 7 Pro...tried a few different windows..same error occurs..many thanks
sklu
Postby olishea » Tue Sep 07, 2010 10:49 am
Great plugin :thumb:
oli
olishea
Premium Member
Premium Member
Postby EscapeArtist » Mon Sep 13, 2010 10:32 pm
I found the bug, it was on this side of my computer screen.
EscapeArtist
Top SketchUcator
SketchUp version: 8
License type: Pro
SketchUp use: hobby
Postby voxdei_999 » Tue Sep 14, 2010 4:48 pm
thanks Chris very useful to me
voxdei_999
Postby Chris Fullmer » Tue Sep 14, 2010 9:44 pm
Great Beto, glad you like it!
Chris
SketchUp Team
SketchUp version: 8
License type: Pro
Postby fabiorossi » Thu Jan 13, 2011 3:22 pm
sklu wrote:Component Stringer Loading Problem
Any help, Chris?
This is just the same error message that I see on my ruby console; I've got su7Pro and this message appears also on SU6;I've tried many times to download "Component Stringer"script but ther is not any changement...............what's the problem??
fabiorossi
Postby Chris Fullmer » Thu Jan 13, 2011 8:47 pm
Hmm, does it fail everytime you try it? Can you upload a small test file here for me?
Are you using the Itallian Language of SketchUp and is your computer set to Itallian?
Upload a test model, I'll start by looking at that.
Chris
SketchUp Team
SketchUp version: 8
License type: Pro
Postby bentleykfrog » Sat Jan 29, 2011 1:41 pm
Nice plugin Chris, would love to see an option to use the tangent of the two edges at the node rather than perpendicular to one edge
bentleykfrog
Postby raffy » Wed Mar 30, 2011 3:30 pm
thank you so much for your help....
raffy
Name: rafael sison jr
Postby solo » Fri May 13, 2011 2:38 pm
I'm getting this:
Code: Select all
Error: #<NoMethodError: undefined method `definition' for nil:NilClass>
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb:103:in `main'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb:190
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb:103:in `call'
Nothing happens, no dialogue box.
My site
Quod gratis asseritur, gratis negatur.
solo
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby TIG » Fri May 13, 2011 8:58 pm
solo wrote:I'm getting this:
Code: Select all
The relevant code is this [ending line #103
Code: Select all
        sel = model.selection
      comp = []
      $arc_labels = []
      comp_height = []
      sel.each do |e|
        comp << e if e.is_a? Sketchup::ComponentInstance
        edges << e if e.is_a? Sketchup::Edge
      comp_height = comp[0].definition.bounds.depth
So the error is saying that the selection [sel] doesn't contain a component-instance ?
Since 'nil' has no 'definition'...
It could be better trapped to stop if the selection contains no instances but...
SO - question: does the selection contain a component-instance when you run the tool ??
Global Moderator
SketchUp version: 8
License type: Pro
Postby jorge2011 » Sat Jun 11, 2011 3:02 am
hi sr Chris Fullmer.
This plugin is generating the following error
Error: #<NoMethodError: undefined method `edges' for nil:NilClass>
C:/Archivos de programa/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb:59:in `curve_ordering'
C:/Archivos de programa/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb:56:in `times'
C:/Archivos de programa/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb:56:in `curve_ordering'
C:/Archivos de programa/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb:105:in `main'
C:/Archivos de programa/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb:190
I use sketchup8 pro
It is possible to fix?
Thank you very much
jorge2011
SketchUp version: 7
License type: Pro
Postby Chris Fullmer » Sat Jun 11, 2011 7:43 am
Can you supply the model or a part of the model you are working on? Is it repeatedable on all models for you?
SketchUp Team
SketchUp version: 8
License type: Pro
Postby jorge2011 » Thu Jun 30, 2011 12:11 pm
that error can not play Mr. Chris, but the plugin works well in general.
thanks
jorge2011
SketchUp version: 7
License type: Pro
Postby Chris Fullmer » Fri Jul 01, 2011 5:30 pm
ok, I hope it keeps working for you,
Chris
SketchUp Team
SketchUp version: 8
License type: Pro
Postby Lobster » Wed Jul 06, 2011 2:35 am
Hi chris,
Great plugin, however i have this on a model.
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_component_stringer.rb:80:in `add_text'
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_component_stringer.rb:80:in `curve_labeler'
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_component_stringer.rb:70:in `curve_ordering'
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_component_stringer.rb:105:in `main'
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_component_stringer.rb:190
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_component_stringer.rb:80:in `call'
Here is a link for it http://www.mediafire.com/?aesv4fd1ccv1cvn
It does not get to the reverse option. The plugin works fine on a simple box and a curve.
SU8, OSX 10.6.7
It seems to write 'start' but not 'end'.
I hope it is useful, if you have time to have a quick look.
Regards
Sam
Lobster
Operating system: Mac
SketchUp version: 8
License type: Free
SketchUp use: other
Postby raineysky » Tue Jan 10, 2012 6:35 pm
I am trying to make a chain like in the video in the first post. Must be doing something wrong because I'm getting what's in the picture below when I set the component rotation to 90°. Any advice? SU8 Free M2
Thank You
raineysky
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby Chris Fullmer » Thu Jan 12, 2012 2:50 am
It all has to do with where the component axis is set. It looks like its oriented correctly, its just not centered right. Then once the chain is made, you need to edit the component and extend one end of it so that it overlaps into the other components, which I think I did in the video.
But first, spend some time figuring out how to center the component axis better.
Chris
SketchUp Team
SketchUp version: 8
License type: Pro
Postby raineysky » Fri Jan 13, 2012 1:03 am
OK. Thank You very much Chris. I'll let you know how it turns out this weekend. Thanks again for your help and for the plugin.
raineysky
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby raineysky » Sun Jan 15, 2012 10:43 am
I did it!!! Centered the axis like in the picture below and it works like a charm. Thank You very much Chris for your help and for a wonderful plugin.
raineysky
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby panpanndundu » Sat Feb 25, 2012 8:30 am
Awesome tool, thank you chris fullmer ... :berserk:
panpanndundu
Name: pandu pebruanto
SketchUp version: 8
License type: Free
Postby thegoodguy » Tue May 22, 2012 12:10 pm
Brilliant plugin :-) Just what I need. Thanks.
thegoodguy
Postby ivreich » Fri Jul 20, 2012 5:26 am
Any chance there could be a "stretch" modifier (like the stretch tool in FredoScale) when stringing components? Although i guess this would destroy the component definitions.
joel
ivreich
SketchUp version: 8
License type: Pro
Postby kingsi » Sat Jan 05, 2013 1:58 pm
Many thanks for the excellent pluggin
Noobtastic
kingsi
Postby kingsi » Mon Jan 07, 2013 1:03 pm
Wonderful plugin. Many Thanks Chris
Noobtastic
kingsi
Postby Chris Fullmer » Mon Jan 07, 2013 1:09 pm
You're welcome and you're welcome!
SketchUp Team
SketchUp version: 8
License type: Pro
Need SketchUp Books, Models, Styles or Textures? Check out our One Stop Shop for SketchUp.
PreviousNext
Return to Plugins
Users browsing this forum: bugmenot123, Daniel S, Hutton, meocram and 14 guests
