[Plugin] CleanUp
Re: [Plugin] CleanUp
Postby mariocha » Mon Dec 04, 2017 4:31 pm
I like localizing plugins. Helps me learn ruby. I found this one well written and thus a good teacher.
So it is now localized with LanguageHandler. And french strings. v 3.4.3
Should I get it signed before posting it here, or send it to you, or what ?
Cookies to you.
p.s.: I had to change the tooltips heredocs to strings, of course.
oh, also, no progressbar or status on Mac.
Mario C.
Certified SketchUp Trainer, QC CA.
Every rule has exceptions, but some.
mariocha
Premium Member
Premium Member
Postby ataman811 » Thu Apr 26, 2018 8:59 am
Hi!
How can I translate your plugin into Russian?
ataman811
Postby Oxer » Thu Apr 26, 2018 2:16 pm
I translated the plugin to Spanish language a long time ago for my own use but I made it translating the strings in the .rb files directly.
mariocha, can you share the strings file to translate it to Spanish? what did you do to give support to the .rb files to translate the plugin?
http://www.oxervision.blogspot.com/
Oxer
Postby thomthom » Thu Apr 26, 2018 4:27 pm
CleanUp doesn't support translation right now.
If you want to translate, add a comment in the issue tracker; https://bitbucket.org/thomthom/cleanup/ ... 6/localize
Mention what language you can contribute with.
PluginStore Author
PluginStore Author
Postby Oxer » Thu Apr 26, 2018 7:42 pm
thomthom wrote:CleanUp doesn't support translation right now.
Done!!
P.S.: Thom, have you see your private messages, I sent you a message a week ago about UVToolKit plugin.
Oxer
Postby highlander » Tue Feb 05, 2019 9:15 am
Hello,
Can someone tell me why this menu does not work anymore??
Sander Hoogland
SketchUp 2018 pro - Vray
Beeld3d
highlander
Premium Member
Premium Member
Postby TIG » Tue Feb 05, 2019 1:38 pm
Try clearing the computer's Internet Explorer cache and restarting SketchUp to see if that helps...
Global Moderator
Postby pbacot » Thu Mar 07, 2019 6:54 pm
Does anyone have some alternative plugins to this tool? It's pretty much useless in v.2019 except in the smallest drawings. Cleanup just takes too long now.
I'd like another plugin that can remove lines without a face and coplanar lines. One that handles lonely vertices fast too would be great, but could be a separate tool (Fredo's tool works but I like the way CleanUp did it).
Used to be the greatest tool in earlier SketchUp versions.
Top SketchUcator
Re: [Plugin] CleanUp3
Postby Mochanic » Thu Apr 11, 2019 9:40 am
As I was saying on Youtube, I get a blank menu like the one in the attachment. What am I doing wrong?
Also can you recommend an easy fix for all the holes that are created (like the ones in the 2nd attachment) when I import an STL file. It takes me HOURS to manually fix all the holes!
Thanks for your help!
Mochanic
Postby Mochanic » Fri Apr 12, 2019 3:52 am
highlander wrote:Hello,
I have the exact same problem! It's been like this for over a year now. I wish someone could tell me how to fix it...
Mochanic
Postby pbacot » Thu Jun 06, 2019 12:38 am
Hasn't anyone else had problems with this tool in v. 2019? It has slowed considerably as to be mostly useless (i.e. you can do the cleanup faster yourself). It seems to be related to file size though you are only working on a selection. The larger the file, the slower it is.
It's too bad. It was one of the greatest tools!
Top SketchUcator
Postby Dave R » Sat Jun 08, 2019 12:08 am
Which version of CleanUp are you using? I'm using CleanUp3 and it works as fast in v2019 as in any other version.
Global Moderator
Postby jkoll66 » Wed Jul 17, 2019 7:18 pm
Unchecking "Validate Results" and "Erase Duplicate Faces" in the settings menu speeds things up immensely on larger models. If I want to erase duplicate faces later, I usually set it to go at the end of the day.
pbacot wrote:Hasn't anyone else had problems with this tool in v. 2019? It has slowed considerably as to be mostly useless (i.e. you can do the cleanup faster yourself). It seems to be related to file size though you are only working on a selection. The larger the file, the slower it is.
jkoll66
Postby pohlr1 » Tue Jul 30, 2019 10:50 pm
Can anyone try to clean this up real quick to make sure its not my computer or version or what not. Super simple.
Trying to delete the coplaner faces and get rid of all the extra lines.
pohlr1
Premium Member
Premium Member
Postby Dave R » Tue Jul 30, 2019 11:28 pm
Running CleanUp3 on the bottom plate won't delete the coplanar edges because you've got different materials applied to the faces. Instead, those edges will be hidden.
On the top plate there are no coplanar edges to remove because there are holes above each stud.
The extension works fine. There just isn't anything for it to do.
Global Moderator
Postby Mochanic » Fri Sep 06, 2019 7:30 pm
WHAT IS WRONG?
I have uninstalled Cleanup3 and TT Lib, deleted the folders, cleaned the cache, downloaded and reinstalled both from scratch and I STILL get a blank menu!
Yesterday I even installed SU2019 and still nothing but a blank gray menu like my attachment above.
Somebody please help!
Mochanic
Postby Dave R » Fri Sep 06, 2019 7:44 pm
Did you install SketchUp correctly? That is, did you right click on the downloaded installer file and select Run as administrator?
Global Moderator
Postby Mochanic » Sun Sep 08, 2019 5:55 am
No I did not before, but I just completely uninstalled it and started fresh with 19.2 that just released and this time I installed with admin privelages.
So after getting it all back up and running before installing any other extensions I tried Cleanup3 and yet again, just a blank gray menu! I don't understand it... It's the ONLY extension I have any issues with.
Mochanic
Postby Dave R » Sun Sep 08, 2019 11:44 am
...and this time I installed with admin privelages.
What exactly do you mean by this? Does that mean you logged into windows as your normal user, find the installer, right click on it and choose Run as administrator? Or did you log into Windows as the administrator and install SketchUp?
Global Moderator
Postby Mochanic » Sun Sep 15, 2019 4:28 am
Right clicked on setup and chose Run as administrator. (and my windows automatically starts as admin)
Mochanic
Postby TIG » Sun Sep 15, 2019 1:51 pm
For the avoidance of doubt...
Here's the only correct way to install [or repair] SketchUp on a PC.
Login to your PC using your normal users Windows-account - if that user has admin-powers it is unimportant.
Do not login as the separate 'administrator' account.
Ensure SketchUp is closed.
Find the SketchUp installer's exe file - probably in your Downloads folder.
Select its icon, right-click > context-menu > "Run as administrator"
When prompted choose "Repair".
[Alternatively, if it's a brand new installation choose "Install"]
When it completes restart SketchUp and see what happens...
Running the installer in any other way - e.g. by double-clicking its icon - will result in unpredictable issues, often around file/folder permissions and saved preferences etc...
If you have installed Plugins etc these should be unaffected by a "Repair".
A few Extensions, like Fredo's Lib, might have created a subfolder/files to save preferences with bad permissions in an earlier incorrect SketchUp setup. This is fixed by deleting the faulty folder.
In the case of Fredo's Lib...
Close SketchUp.
Find your 'Local' folder %LocalAppData% and find its subfolder named LIBFREDO6_DATA_Dir - delete it and its contents.
It is hidden by default, but it should be directly accessible when you use that %...% path in a Windows Explorer window...
When you restart SketchUp that preferences folder and its contents should get recreated, this time with good permissions...
Also note that some older and backwardly compatible Extensions use Internet Explorer on a PC, to create complex dialogs.
This is irrespective of the browser you my use day to day.
Sometimes the IE cache gets cross-threaded and causes issues.
Open IE and clear the entire cache.
See if that helps with flaky dialogs...
Global Moderator
Postby Mochanic » Tue Sep 17, 2019 6:11 am
I appreciate your advice, but I do not have any other issues with Sketchup or extensions ONLY Cleanup 3 and a blank gray menu no matter what. And as I stated earlier, this is a brand new fresh install with admin privileges, so I'm pretty sure there is nothing wrong with the .exe file.
Sketchup has so many bugs its beyond ridiculous! I'm one of many people that has this same issue. I can't understand why they haven't fixed the multiple faces bug that has been known about for years. I have had up to 15 faces on top of each other by drawing 1 single line!
Mochanic
Postby Lia_M » Sun Dec 22, 2019 8:27 pm
I've installed cleanup³ and TT_Lib2, but it still doesn't show up in extensions bar
Lia_M
Postby Dave R » Mon Dec 23, 2019 1:15 pm
Lia_M wrote:but it still doesn't show up in extensions bar
Do you mean the Extensions menu?
Did you try restarting SketchUp after installation of these extensions?
When you installed SketchUp, did you do so correctly? That is did you right click on the downloaded installed and choose Run as administrator from the context menu?
Global Moderator
Postby bsfranza » Wed Dec 25, 2019 11:05 am
Hi there,
@ Thomthom, i have two small feature requests/ ideas that i was hoping you could think about... :)
Problem description; i use the cleanup features delete coplanar, repair edge and delete lines not connected to any other geometry regularly via shortcuts... which is super and really helpful, however, there are two limiting facts to it.. first the shortcuts should only work in the active context or there should be at least be a warning message asking the user if he really wants to apply the command “model wide” ... second, it would be nice if we could set the commands for the shortcutted features it would be nice if we could set parameters for these “shortcutted” commands seperately from the main plugin window because for the shortcuts i may want other fixed settings than when im running The whole plugin via the UI
Thanks for considering it!
Have a nice Xmas everyone!
bsfranza
Postby rv1974 » Wed Dec 25, 2019 12:54 pm
all these commands already exist as separate commands (from several authors: Fredo,TT, TIG, Smustard etc).
Search tt edge tools for instance.
rv1974
Postby a_w » Tue Jan 21, 2020 12:10 pm
Loved that tool, since a few hours ago. Somehow, after cleaning up one model increased in size! how is that possible and how can I fix the problem?
a_w
Postby pbacot » Sat Jul 18, 2020 6:55 pm
a_w wrote:Loved that tool, since a few hours ago. Somehow, after cleaning up one model increased in size! how is that possible and how can I fix the problem?
I've never seen this, but in changes to either SketchUp or OS this great plugin is too slow on all but the simplest models, when you are only cleaning up an operation on a single component. Could it be Mojave? I'll check on a different OS.
Top SketchUcator
Postby bionic58 » Mon Aug 10, 2020 2:37 am
I wanted a toolbar icon to run "Clean with last settings" without having to go to navigate down the plugins menu, so I added the following code to core.rb under the ### MENU & TOOLBARS ### section:
Code: Select all
toolbar = UI::Toolbar.new(PLUGIN_NAME)
cmd = UI::Command.new("Cleanup"){ Sketchup.active_model.select_tool(self.cleanup_last) }
cmd.small_icon = "broom-24.png"
cmd.large_icon = "broom-48.png"
cmd.tooltip = "Cleanup"
cmd.status_bar_text = "Clean your model using current settings"
cmd.menu_text = "Cleanup"
toolbar = toolbar.add_item(cmd)
if toolbar.get_last_state==TB_NEVER_SHOWN
  toolbar.show
elsif toolbar.get_last_state==TB_VISIBLE
  toolbar.restore
I have attached the icons I used. They need to be placed in the same folder as core.rb
bionic58
Postby lordnimon » Sat Aug 29, 2020 7:12 pm
Sometimes when I run CleanUp on a model, it will say that it reduced some edges (e.g. "Edges Reduced: 10"). But then I run CleanUp again, without touching or changing anything, and it will say the same exact thing -- "Edges Reduced: 10". It appears that CleanUp is notices something that needs to be fixed, but it doesn't actually fix it.
What causes this to happen?
lordnimon
PreviousNext
Return to Plugins
Users browsing this forum: fredo6, hj10mm, jeraldinejimenez, maxtar65, nachan, sozuneri116 and 13 guests
