[Plugin] CleanUp
Re: [Plugin] Cleanup (1.1.2) — 23 October 2009
Postby thomthom » Tue Feb 09, 2010 9:58 am
Thanks Sean.
So you're still using SU? I thought you'd gone all Max now?
PluginStore Author
PluginStore Author
Postby free agent » Tue Feb 09, 2010 10:21 am
yup still using SU, some things are still way quicker with a face modeler than a solid modeler, i doubt it will ever be out of my workflow, i wish u were writing max script, there are alot of sketchup like actions i would like to see available in max... but i have to work with what i have i guess :) thanx again for this script :thumb:
free agent
Postby thomthom » Tue Feb 09, 2010 10:26 am
Well, the office is making more and more Revit models. And importing them into SU is a workflow nightmare. So I'm very tempted to get Max into my office toolkit. ...so who knows... ;)
Btw, got any new renders to show off?
PluginStore Author
PluginStore Author
Postby free agent » Tue Feb 09, 2010 11:35 am
please contact me when u take the plunge into maxscript, im sure its easier, definitly a bigger user base, do it do it do it!!!
i got a couple, should i email? :P
free agent
Postby thomthom » Tue Feb 09, 2010 12:14 pm
email or make a post in the gallery. I'm always curious to see what you produce.
PluginStore Author
PluginStore Author
Postby Gaieus » Wed Mar 17, 2010 2:21 pm
Hi Thom,
There is an "unwanted" feature in this plugin (I do not necessarily want to call it a "bug"); it erases coplanar edges also when that edge divides faces where the same material applied but positioned differently. See screenshots attached.
Could there be at least a setting that prevents this? I was making an arched surface for this vault when I first discovered this - it simply erased all the dividing edges and of course screwed up the arch big time.
Thanks for looking into this issue - this is the best ever cleanup script I have ever encountered. aybe abother wish - could there be a feature/setting to clean up only whatever is in context (like inside a goup) and/or in a certain selection?
Or maybe I missed something?
Postby thomthom » Wed Mar 17, 2010 2:42 pm
Gaieus wrote:There is an "unwanted" feature in this plugin (I do not necessarily want to call it a "bug"); it erases coplanar edges also when that edge divides faces where the same material applied but positioned differently. See screenshots attached.
hmm... Yes - I see how this can be an issue. Will need to ponder on how to avoid this though.
Gaieus wrote:Thanks for looking into this issue - this is the best ever cleanup script I have ever encountered. aybe abother wish - could there be a feature/setting to clean up only whatever is in context (like inside a goup) and/or in a certain selection?
Yea - the UI is horrible.
PluginStore Author
PluginStore Author
Postby Gaieus » Wed Mar 17, 2010 2:54 pm
Hm. Can I have another (older?) version?
Postby thomthom » Wed Mar 17, 2010 3:27 pm
No - I seem to have extra menu items from working on v1.2.0 oopsie
PluginStore Author
PluginStore Author
Postby Gaieus » Thu Mar 18, 2010 10:03 am
:lol:
_______
I tried to lock such faces with positioned materials but the script erases lines in locked groups, too! :o
Postby thomthom » Thu Mar 18, 2010 10:46 am
Gaieus wrote:I tried to lock such faces with positioned materials but the script erases lines in locked groups, too! :o
That's interesting. Another thing to note down.
PluginStore Author
PluginStore Author
Re: [Plugin] Cleanup (1.2.0) — 23 April 2010
Postby thomthom » Fri Apr 23, 2010 10:41 pm
Armed with more info from Simone Nicolo I now have a better method for detecting coplanar faces - the same method Sketchup use. I think it's 100% reliable. No more messing about with tolerances. :berserk:
Highly recommended update!
PluginStore Author
PluginStore Author
Postby thomthom » Fri Apr 23, 2010 10:57 pm
thomthom wrote:Armed with more info from Simone Nicolo I now have a better method for detecting coplanar faces - the same method Sketchup use. I think it's 100% reliable. No more messing about with tolerances. :berserk:
:( Turns out it's not 100%. In one of my test model it still left some edges that could be erased.
Updated with some minor UI fixes.
PluginStore Author
PluginStore Author
Re: [Plugin] Cleanup (1.2.1) — 23 April 2010
Postby EscapeArtist » Fri Apr 23, 2010 10:58 pm
"The selected attachment does not exist anymore"
Error when clicking for download.
EscapeArtist
Top SketchUcator
Postby thomthom » Fri Apr 23, 2010 11:06 pm
EscapeArtist wrote:"The selected attachment does not exist anymore"
You probably tried to download just as I uploaded a quick patch. :oops:
PluginStore Author
PluginStore Author
Postby CadFather » Fri Apr 23, 2010 11:09 pm
Thanks Thom, this is good.
Quarr-IT - SketchUp Training from the Master.. http://quarr-it.com/
CadFather
PluginStore Author
PluginStore Author
Postby EscapeArtist » Sat Apr 24, 2010 4:00 am
thomthom wrote:You probably tried to download just as I uploaded a quick patch. :oops:
Ah, timing is everything. Works just fine. Thanks!
EscapeArtist
Top SketchUcator
Postby MtnTrails » Sat Apr 24, 2010 6:46 am
:thumb: Thank you, Thom! Works just like I'd hoped. What a great time saver! :sketchstatic:
-Brian
Keep doing what you're doing and you'll keep getting what you're getting.
MtnTrails
Postby Gaieus » Sat Apr 24, 2010 8:52 am
Hi Thom,
Thanks for the update. I'll definitely try it out (I managed to forget about two coplanar faces with differently positioned but the same texture again and screwed up my model - no big hassle though just a "doh" moment again...)
:D
Postby thomthom » Sat Apr 24, 2010 10:57 am
Gaieus wrote:Hi Thom,
:D
Ah yes - I'm still not sure how to account for that. But it is possible ... somehow...
PluginStore Author
PluginStore Author
Postby Rich O Brien » Sat Apr 24, 2010 11:03 am
Hi Thom,
Thanks for the update, one of my favourite plugins.
Doesnt say much about my modelling ability!
Rich O Brien
Administrator
Re: [Plugin] Cleanup (1.2.2) — 24 April 2010
Postby thomthom » Sat Apr 24, 2010 4:10 pm
Important update in 1.2.2
Sorry for all these updates recently.
I think I found the root of why the last update wasn't 100%.
It now erases edges as they are processes, instead of in bulk later. This is because each face's plane equations must be re-evaluated after it's been merged. This might lead to slightly longer processing time - but I now hope that it truly is 100% watertight.
PluginStore Author
PluginStore Author
Postby EarthMover » Sat Apr 24, 2010 7:39 pm
Thanks for the update. I use this puppy all the time! :thumb:
Content Creator at Skapeup
EarthMover
Premium Member
Premium Member
Postby Jim » Sun Apr 25, 2010 3:07 pm
Thanks - it is doing better job of removing edges. I am willing to trade a little extra time for a cleaner model.
I did get a reference to a deleted Edge error on this model (.stl import.) I haven't investigated the cause, but I've attached it in case you're curious.
Error: #<TypeError: reference to deleted Edge>
C:\Program Files\Google\Google SketchUp 7\Plugins\tt_cleanup.rb:283:in `faces'
My fix:
283: next unless e.valid? and e.is_a?(Sketchup::Edge)
But is doesn't explain the cause.
Jim
Global Moderator
Postby thomthom » Sun Apr 25, 2010 4:09 pm
hm.. that is odd. I wonder why that happens. thanks for posting the model.
PluginStore Author
PluginStore Author
Re: [Plugin] Cleanup (1.2.3) — 25 April 2010
Postby thomthom » Sun Apr 25, 2010 6:14 pm
Updated to account for the issue reported by Jim.
Though I still don't understand why I ever get a reference to a deleted edge...
PluginStore Author
PluginStore Author
Postby TIG » Sun Apr 25, 2010 9:14 pm
Trap unexpected deleted edges with edge.erase! if edge.valid? type of code ?
Global Moderator
Postby thomthom » Sun Apr 25, 2010 9:55 pm
Yes - but what puzzles me is why the code comes across deleted references at all. After reviewing my code I can't work out why. I am iterating an array copy of the entities collection. And I only iterate the array once.
PluginStore Author
PluginStore Author
Re: [Plugin] Cleanup (1.3.0) — 26 April 2010
Postby thomthom » Mon Apr 26, 2010 10:51 pm
Gaieus: This update is for you. Made it investigate the UV's before merging.
Not that it is very strict, the UV values for either vertex of the edge has to be identical for each face connected to it before it merges. This means there might be cases where it visually looks like they should merge, but doesn't. They should merge is you position a material on one face and use the dropper to paint other adjacent faces.
To turn of this feature just enable the Ignore UV's.
Note that this is pretty fresh code that hasn't been tested well. (Only very quickly.) So please investigate the model after using the tool and report any unexpected behaviour. (Please most sample model as that will make debugging much easier.)
PluginStore Author
PluginStore Author
Postby Ern » Tue Apr 27, 2010 2:30 am
Very handy,
Ern
PreviousNext
Return to Plugins
Users browsing this forum: medeek, pangymyly, panman and 12 guests
