[Plugin] CleanUpRe: [Plugin] CleanUpThanks TIG, spoke with Rich and that was he suggestion too. So i run edge inspector in each component of the model and ended up fixing thousands of tiny gaps/edges. After the whole process (didn't take as long as I was imagining) all fixed and no more crashes! Thanks again for all your tips and great plugins.
Re: [Plugin] CleanUpHi
I imported an STL file into sketchup 2014 and I am trying to clean the faces with cleanup and it appears to cause some problems. CEdge (15569) and CEdge (1510) connect the same 2 vertices - fixed CEdge (14024) and CEdge (1479) connect the same 2 vertices - fixed CEdge (1268) and CEdge (15568) connect the same 2 vertices - fixed The plane equation for CFace (15570) is not valid - fixed The plane equation for CFace (15576) is not valid - fixed The plane equation for CFace (15588) is not valid - fixed The plane equation for CFace (15637) is not valid - fixed The plane equation for CFace (15643) is not valid - fixed The plane equation for CFace (15655) is not valid - fixed The plane equation for CFace (15606) is not valid - fixed The plane equation for CFace (15662) is not valid - fixed The plane equation for CFace (15675) is not valid - fixed The plane equation for CFace (15829) is not valid - fixed The plane equation for CFace (15822) is not valid - fixed The plane equation for CFace (15781) is not valid - fixed The plane equation for CFace (15795) is not valid - fixed The plane equation for CFace (15802) is not valid - fixed The plane equation for CFace (15815) is not valid - fixed The plane equation for CFace (15755) is not valid - fixed The plane equation for CFace (15767) is not valid - fixed The plane equation for CFace (15774) is not valid - fixed I am using SuSolid to check whether the model is watertight. Directly after i import, the SuSolid shows no problem with the model. However after i ran cleanup, some issues appear. I am using Sketchup 2014. Re: [Plugin] CleanUpzhenning:
I have used MeshLab to decimate models and found it is best to limit the number of actions taken to one at a time and the sequence can also affect the out come. I have not used ThomThom's plugin but, trying to limit the number of corrections to few at a time may help you keep it a solid. In addition using Tig's solid solver has quite often helped after cleanup. What analyzer are you using one of the 3d printers?
The cleanup seems to delete wrong faces? The coplanar error appears only after the cleanup plugin is used to clean the model. Re: [Plugin] CleanUpAttached is the file:
https://www.dropbox.com/s/5y5lve896tpqklb/base.skp?dl=0 After some trials, the errors happens when i tried merge faces ![]() Re: [Plugin] CleanUpInitial application of cleanup does a good job of fixing errors, then running TIG's solid solver had problems to the point of destroying model. That just haapens some times.
After cleanup suggest you save the file as a stl you can then use one of the free apps some 3 d printers have and attempt to fix the model. The attached jpg shows my results using NetFab more work need to be done. Shapeway had a free service where they would run your model thru there app and possibly fix model. Sadly I have lost link and will have to look for it. Here is info I have And the link on use of the app. It free version so does not give full capability
Re: [Plugin] CleanUpFound 1 link http://www.shapeways.com/tutorials/how_ ... nd_netfabb.
Since Su has a STL export plugin you do not need to use MESHLAB
Re: [Plugin] CleanUpFound the cause of it. Actually its from the stl
![]() ![]() Re: [Plugin] CleanUpIs Cleanup working in SKU 2015? Doesn't seem to be appearing in the extensions tab at all?
Edit: Sorry it is working! (I thought I had restarted ketchup but I hadn't) Last edited by Lersince1991 on Wed Nov 19, 2014 2:23 pm, edited 1 time in total.
Re: [Plugin] CleanUpDid you also install the latest Lib for thomthom's tools ? He updated everything to suit v2015 a few weeks ago... TIG
Edited:
Sorry for alerting you! I'm now using the sketchucation extension manager which is a god send for keeping everything up to date and installing quickly! Re: [Plugin] CleanUpI use SU 2015 x64 Portable. First starting SU was correct with plugins. Next start SU appear errors loading cleanup. TT Lib (latest version) had already installed with extension manager but SU says that it not install. Screenshot below. What is it? Why CleanUp is not loading.
Re: [Plugin] CleanUpWhat is "Portable" SketchUp? Where did you get it? Whatever it is, it is not a supported installation.
It is the same as "usually" SketchUp is, but does not require standart installation. It very easy if you are often re-install windows OS.
It gave me my friend.
Why? The way of file system is the same as SketchUp standard installation ones. Other plugins successfully loading into portable version. Re: [Plugin] CleanUpThom Thom et. all,
I recently got a new computer (Mac running 10.9) and Sketchup 2015 and I am experiencing some odd issues. When I click Clean and run through the dialog box, many coplanar faces are not removed). When I then just click on the Merge Faces button, they are picked up. It seems to be fairly erratic though. Your help would be greatly appreciated, as CleanUp has been extremely useful over the years and is one of my most used plug-ins (and a large tool in my workflow). Thanks so much for all your awesome work! Re: [Plugin] CleanUpDo you have a sample model to reproduce this?
Re: [Plugin] CleanUphey mate i added the EX but i cant find it in my sketchup dont know what to do ?
Re: [Plugin] CleanUpAssuming you mean EXtension, how did you 'add it'. Did you install it from the RBZ archive ? Did you also install the 'TT_Lib' RBZ required by thomthom's tools ? Both available in the PluhginStore... http://sketchucation.com/pluginstore?pln=TT_Lib http://sketchucation.com/pluginstore?pln=tt_cleanup Did you restart SketchUp ? Did you read the tool's instructions ? viewtopic.php?p=193587#p193587 Is its Extension activated in the relevant section of the 'Preferences' dialog ? Did you look under the 'Plugins' menu submenu for its items [remember that this is now renamed 'Extensions' in v2015 !] TIG
Re: [Plugin] CleanUpFortunately for me, unfortunately for debugging, I can't seem to reproduce my previous issues.
In trying, I triple checked my cleaning settings, so perhaps I was just boneheaded and it was all user error. (I thought I went through and checked-unchecked the different settings, but maybe not). Anyhow, thanks for the response, if it happens again, I will be sure to attach the offending sample of model. Thanks again for all your awesome work! Re: [Plugin] CleanUpWhy this is not cleaning!
![]() Works by hand line by line!
Re: [Plugin] CleanUpIt seems it can´t UN-SMOOTH the models?
I have this model with a ridiculous amount of groups and subgroups. And it's all softened, although it should not be softned at all. It´s impossible to unsoften by hand because of the amount of groups, and I also don´t want to ungroup them all (because I might have to move the groups around) But setting the SOFTEN to 0 degrees does not unsoften the groups and subgroups, unlike the Soften Edges Panel... Re: [Plugin] CleanUpThat would be nice. I notice a group can be unsoftened /softened but not a nested group (without first opening the parent group). That's with the Soften/Smooth dialog.
Re: [Plugin] CleanUpUse with care !
Copy+Paste into the Ruby Console + <enter>.
To process a selection...
Re: [Plugin] CleanUpThanks a million Thomthom, though i was going to throw my computer away, downloaded CleanUp its magic.
Scenes that took minutes to open now not even time to say "thank you Thomthom..."and the scene is open. Made my day or actually my late night ! |
