[Plugin] CleanUp
Re: [Plugin] CleanUp
Postby Box » Mon Dec 09, 2013 1:26 pm
Dave R wrote:There's a Download button in the first post of this thread. Click that and then the red Download button on the next page. Change the file's extension to .ZIP, extract the contents of the zip file and place them in the Plugins folder making sure you maintain the file structure. Make sure you also get the TT_Lib support files as indicated in the first post.
Is the red text not what you were after? A very clear indication of where to download the file you wanted. So I don't believe Dave needs to improve his reading skills.
Postby cotty » Mon Dec 09, 2013 2:10 pm
Maybe 4 answers by global moderators, 2 from the plugin author and 1 of a Top Sketchucator are not enough help... we have to work harder!
cotty
Top SketchUcator
Postby gbu » Mon Dec 09, 2013 2:59 pm
massimo wrote:
gbu wrote:
tt_su wrote:
gbu wrote:
Sarcastic comments not necessary Massimo- all I was looking for was the download link. And Dave R- you obviously didn't read my post properly.
Sarcastic comment? That was neither sarcastic nor a comment. That simply was a question (I asked because there was everything you needed to know in the previous posts) and a couple of tips trying to help... :-?
apologies, should read:
Sarcastic comments not necessary Dave R.- all I was looking for was the download link. And Massimo- you obviously didn't read my post properly.
Massimo I didn't ask for advice on how to unzip and install- I'd already clarified that in a previous post.
All I asked was for the download link.
Thank you.
-1
gbu
Postby gbu » Mon Dec 09, 2013 3:04 pm
Where in the first post is the download button? Explain with a screenshot if necessary.
gbu
Postby gbu » Mon Dec 09, 2013 3:06 pm
cotty wrote:Maybe 4 answers by global moderators, 2 from the plugin author and 1 of a Top Sketchucator are not enough help... we have to work harder!
Another sarcastic comment- its really not necessary. The author of the plugin answered my query with no fuss at all.
Thanks for the insight.
-1
gbu
Postby Dave R » Mon Dec 09, 2013 3:06 pm
Sheesh!
Global Moderator
Postby Box » Mon Dec 09, 2013 3:08 pm
Here,
Postby gbu » Mon Dec 09, 2013 3:12 pm
Dave R wrote:
Sheesh!
didn't see that- must be going blind- apologies.
...or working too hard! ok, fine people of sketchucation, thank you for your help.
gbu
Postby tt_su » Mon Dec 09, 2013 3:25 pm
If you install the PluginStore you can search and install all the SCF hosted plugins from within SketchUp. And it'd be a uniform UI so you'd always find the Download button in the same place instead of the random positioning and presentation of the forum threads.
tt_su
SketchUp Team
SketchUp Team
Postby gbu » Mon Dec 09, 2013 3:31 pm
tt_su wrote:If you install the PluginStore you can search and install all the SCF hosted plugins from within SketchUp. And it'd be a uniform UI so you'd always find the Download button in the same place instead of the random positioning and presentation of the forum threads.
Thanks, but as I said previously the PluginStore says only for version 8. I have version 7. If that is not the case I'd appreciate a note on how to download version 7 plugins from within Sketchup.
edit: message says: Parts of this process only work with Sketchup >= v8M2.
gbu
Postby tt_su » Mon Dec 09, 2013 3:38 pm
Oh right - it uses the RBZ install feature. Yea - then you have to do it the ol' manual way.
tt_su
SketchUp Team
SketchUp Team
Postby Box » Mon Dec 09, 2013 3:43 pm
Just to be clear, the Sketucation store plugin is saying only certain features work with SU8, not the plugin itself.
The auto install part of the store doesn't work with SU7.
Postby gbu » Mon Dec 09, 2013 3:46 pm
tt_su wrote:Oh right - it uses the RBZ install feature. Yea - then you have to do it the ol' manual way.
ok, thanks for confirming- guess its time to upgrade soon. Used this the first iterations of sketchup intensively back in 2000/2001 for a few years, then concentrated on 3dmax.
But for quick and easy nothing beats it.
gbu
Postby gbu » Mon Dec 09, 2013 3:47 pm
Box wrote:Just to be clear, the Sketucation store plugin is saying only certain features work with SU8, not the plugin itself.
righto, thanks
gbu
Postby blauga » Fri Jan 31, 2014 9:07 am
Hi Thomas. I use Cleanup with Sketchup 2013. I noticed that occasionally, some faces disappear. I have uploaded a sample model (actually an extract of a sofa model). It contains to cushions. The one with holes has been treated with cleanup, resulting in missing faces. The other one has not been treated yet.
Any idea ?
blauga
Premium Member
Premium Member
Postby tt_su » Fri Jan 31, 2014 12:23 pm
What settings did you use? I just ran it with default settings on a fresh installation of SU and no faces were lost.
tt_su
SketchUp Team
SketchUp Team
Postby expresso405 » Thu Feb 27, 2014 1:37 pm
@TT;
I have a file that generates lots of errors. (probably down to my sloppy drawing practices). :oops: ...
Do you still want example files that generate errors sent to you?
Thanks for a great plugin! :-)
expresso405
Postby thomthom » Fri Feb 28, 2014 4:21 pm
Depends on the errors. Does the model have lots of small faces/edges?
PluginStore Author
PluginStore Author
Postby saucerful » Mon Mar 17, 2014 7:54 pm
Hi Thom, thanks for this excellent tool.
I was hoping you could help me get it working in Linux under wine. I saw the discussion many pages back about wine but that was a different error. I am using SketchUp 8 and the latest TT_Lib 2.9.8 and Cleanup 3.2.1
After installing TT_Lib and restarting I am getting a dialog saying
Code: Select all
Error Loading File C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb
uninitialized constant TT::GUI::ToolWindowError Loading File TT_Lib2.rb
uninitialized constant TT::GUI::ToolWindowError Loading File C:/Program Files/Google/Google SketchUp 8/Plugins/tt_cleanup/core.rb
uninitialized constant TT::GUI::ToolWindowError Loading File tt_cleanup.rb
Meanwhile in the terminal I see
Code: Select all
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2.rb:19: warning: already initialized constant PLUGIN_ID
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2.rb:20: warning: already initialized constant PLUGIN_NAME
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2.rb:21: warning: already initialized constant PLUGIN_VERSION
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:27: warning: already initialized constant BB_LEFT_FRONT_BOTTOM
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:28: warning: already initialized constant BB_RIGHT_FRONT_BOTTOM
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:29: warning: already initialized constant BB_LEFT_BACK_BOTTOM
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:30: warning: already initialized constant BB_RIGHT_BACK_BOTTOM
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:31: warning: already initialized constant BB_LEFT_FRONT_TOP
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:32: warning: already initialized constant BB_RIGHT_FRONT_TOP
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:33: warning: already initialized constant BB_LEFT_BACK_TOP
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:34: warning: already initialized constant BB_RIGHT_BACK_TOP
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:36: warning: already initialized constant BB_CENTER_FRONT_BOTTOM
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:37: warning: already initialized constant BB_CENTER_BACK_BOTTOM
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:38: warning: already initialized constant BB_CENTER_FRONT_TOP
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:39: warning: already initialized constant BB_CENTER_BACK_TOP
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:41: warning: already initialized constant BB_LEFT_CENTER_BOTTOM
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:42: warning: already initialized constant BB_LEFT_CENTER_TOP
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:43: warning: already initialized constant BB_RIGHT_CENTER_BOTTOM
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:44: warning: already initialized constant BB_RIGHT_CENTER_TOP
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:46: warning: already initialized constant BB_LEFT_FRONT_CENTER
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:47: warning: already initialized constant BB_RIGHT_FRONT_CENTER
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:48: warning: already initialized constant BB_LEFT_BACK_CENTER
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:49: warning: already initialized constant BB_RIGHT_BACK_CENTER
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:51: warning: already initialized constant BB_LEFT_CENTER_CENTER
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:52: warning: already initialized constant BB_RIGHT_CENTER_CENTER
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:53: warning: already initialized constant BB_CENTER_FRONT_CENTER
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:54: warning: already initialized constant BB_CENTER_BACK_CENTER
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:55: warning: already initialized constant BB_CENTER_CENTER_TOP
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:56: warning: already initialized constant BB_CENTER_CENTER_BOTTOM
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:58: warning: already initialized constant BB_CENTER_CENTER_CENTER
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:59: warning: already initialized constant BB_CENTER
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:64: warning: already initialized constant MB_ICONHAND
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:65: warning: already initialized constant MB_ICONSTOP
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:66: warning: already initialized constant MB_ICONERROR
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:67: warning: already initialized constant MB_ICONQUESTION
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:68: warning: already initialized constant MB_ICONEXCLAMATION
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:69: warning: already initialized constant MB_ICONWARNING
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:70: warning: already initialized constant MB_ICONASTERISK
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:71: warning: already initialized constant MB_ICONINFORMATION
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:72: warning: already initialized constant MB_ICON_NONE
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:74: warning: already initialized constant MB_DEFBUTTON1
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:75: warning: already initialized constant MB_DEFBUTTON2
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:76: warning: already initialized constant MB_DEFBUTTON3
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:77: warning: already initialized constant MB_DEFBUTTON4
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:82: warning: already initialized constant MESH_SHARP
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:83: warning: already initialized constant MESH_SOFT
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:84: warning: already initialized constant MESH_SMOOTH
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:85: warning: already initialized constant MESH_SOFT_SMOOTH
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:90: warning: already initialized constant POINT_OPEN_SQUARE
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:91: warning: already initialized constant POINT_FILLED_SQUARE
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:92: warning: already initialized constant POINT_CROSS
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:93: warning: already initialized constant POINT_X
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:94: warning: already initialized constant POINT_STAR
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:95: warning: already initialized constant POINT_OPEN_TRIANGLE
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:96: warning: already initialized constant POINT_FILLED_TRIANGLE
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:114: warning: already initialized constant VERSION
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:118: warning: already initialized constant PREF_KEY
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:121: warning: already initialized constant PATH
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:122: warning: already initialized constant PATH_LIBS
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:125: warning: already initialized constant PATH_LIBS_CEXT
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/sketchup.rb:21: warning: already initialized constant COLOR_GL_POLYGON
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/sketchup.rb:25: warning: already initialized constant COLOR_ALPHA
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/sketchup.rb:29: warning: already initialized constant RAYTEST_WYSIWYG
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/system.rb:16: warning: already initialized constant PLATFORM_IS_OSX
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/system.rb:19: warning: already initialized constant PLATFORM_IS_WINDOWS
C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/system.rb:22: warning: already initialized constant TEMP_PATH
I am expecting a Cleanup item in the Plugins menu but do not see it. Let me know if I can help debug! Thanks again.
saucerful
Postby thomthom » Mon Mar 17, 2014 10:15 pm
What version of Linux and Wine are you using?
How did you install the extensions?
PluginStore Author
PluginStore Author
Postby saucerful » Tue Mar 18, 2014 5:34 am
Thanks for the quick reply! Linux is Debian stable (wheezy) with wine from the repository, version 1.4.1.
Extensions installed via SketchUp GUI.
saucerful
Postby tetrochuan » Tue Mar 18, 2014 10:42 am
hi there,
it would be cool if we could access the delete coplanar feature with respect to the materials via a shortcut =) would save me a thousand clicks...
there is a plugin from smustard that does exactly that but since smustart is neither in the extension warehouse nor on scetchucation it would be nice to have it from tt=)
greetings
tetrochuan
Postby tt_su » Tue Mar 18, 2014 11:22 am
tetrochuan wrote:it would be cool if we could access the delete coplanar feature with respect to the materials via a shortcut =) would save me a thousand clicks...
If you set up the dialog to merge only by material you can use the Clean With Last Settings by shortcut. It's a workaround, but it currently works.
tt_su
SketchUp Team
SketchUp Team
Postby saucerful » Tue Mar 18, 2014 4:24 pm
By the way, I tried installing SketchUp 2013 and got the same output in console and dialog. Let me know if I can help debug. Thanks!
saucerful
Postby tt_su » Tue Mar 18, 2014 5:29 pm
Can you install this RBZ and go Plugins > SketchUp Diagnostics Tools > Collect Data ?
Now, it should put a txt file on your Desktop... though I'm not sure how this works when you are running Linux+Wine... :s
tt_su
SketchUp Team
SketchUp Team
Postby saucerful » Tue Mar 18, 2014 9:17 pm
Diagnostic ouptut is attached.
saucerful
Postby tt_su » Wed Mar 19, 2014 10:24 am
Given that file I don't see CleanUp as being installed - only TT_Lib2...
tt_su
SketchUp Team
SketchUp Team
Postby saucerful » Wed Mar 19, 2014 4:29 pm
Whoops, I removed Cleanup to check whether I would get errors with just TT_Lib. And I did.
I reinstalled CleanUp and attached the diagnostic. Thanks for your patience.
saucerful
Postby tt_su » Wed Mar 19, 2014 5:11 pm
Ah, right!
And the error message you posted here: viewtopic.php?f=323&t=22920&view=unread&sid=3c5780a432a36ee6c62eb305f16f5390#p516006
Was that with or without CleanUp installed?
tt_su
SketchUp Team
SketchUp Team
Postby saucerful » Wed Mar 19, 2014 5:43 pm
With. Without I get just the first half:
Code: Select all
saucerful
PreviousNext
Return to Plugins
Users browsing this forum: arqgaby, medeek, whs11111 and 9 guests
