SketchUcation Premium Membership
[Plugin] Cleanup (3.1.10) — 18 March 2013
Re: [Plugin] Cleanup (3.1.9) — 12 January 2012
Postby TIG » Mon Feb 06, 2012 3:40 pm
The last update on the 12 January was some days ago; it's now 6 February 2012 ?
Jan, are you in a parallel dimension ?
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby Dave R » Mon Feb 06, 2012 3:47 pm
I think Sweden's clocks run about 390 days behind the rest of the world. :lol:
Inspecting mirrors is a job I could easily see myself doing.
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: woodworking
Postby thomthom » Mon Feb 06, 2012 3:49 pm
Sshhhhh! Let's impress him with all the amazing technology he haven't seen yet!
Global Moderator
SketchUp version: 8
License type: Pro
Postby TIG » Mon Feb 06, 2012 3:54 pm
It's the long dark winter nights... but hang on... thomthom is up near the Arctic Circle :shock:
Global Moderator
SketchUp version: 8
License type: Pro
Postby Pixero » Mon Feb 06, 2012 7:49 pm
:oops:
Pixero
Premium Member
Premium Member
Name: Jan Sandström
SketchUp version: 8
License type: Pro
Postby yanakhokho » Wed Feb 08, 2012 12:57 pm
I'm new here, please: help. I copy the downloaded file (tt_cleanup.rb) to plugin. When i get inti Scetch up (8 pro) a window pops up ERROR LOADING.
yanakhokho
Postby Gaieus » Wed Feb 08, 2012 1:25 pm
Does it also say what the error is? I mean error loading what?
Have you also installed the TT_Lib library as it says in the instructions?
Administrator
SketchUp version: 8
License type: Pro
SketchUp use: historical reconstruction
Postby yanakhokho » Thu Feb 09, 2012 9:44 am
Yes, I TT_Lib libraries properly installed, but after that I lost the button Plugins from the control panel(including V-ray). After that, I have properly installed other plugins for sketch up, they have successfully copied to the Plugins folder, but when I run the program do not appear (and yes, I restarted the program)))))
http://www.imagebar.net/out.php/t105394_1.jpg
EDITED: link TIG... still unreadable !
yanakhokho
Postby thomthom » Thu Feb 09, 2012 12:52 pm
That image is unreadable. You can upload image directly to the forum.
yanakhokho wrote:but after that I lost the button Plugins from the control panel
I'm sorry, but I don't understand what you mean by this. "button Plugins" ? What do you mean by "control panel" in SketchUp"?
yanakhokho wrote:I have properly installed other plugins for sketch up, they have successfully copied to the Plugins folder, but when I run the program do not appear (and yes, I restarted the program)))))
This confused me. Have you installed any plugins that has worked? Or does everyone fail?
Maybe you can post a screenshot of your Plugins folder?
Here are some general instructions for installing plugins for SketchUp: http://www.thomthom.net/thoughts/2012/0 ... -sketchup/
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Thu Feb 09, 2012 1:40 pm
@Marek: You're on OSX Lion, right? And do y ou have the latest update to SketchUp? Maintenance Release 2?
Global Moderator
SketchUp version: 8
License type: Pro
Postby yanakhokho » Thu Feb 09, 2012 1:57 pm
sorry for my bad english :)
my problem is that - after the installation tt_library at startup i see a screen with an error(print screen in the attached files). an installed other plugins just not displayed. problem can be solved only after a complete reinstall the program.
yanakhokho
Postby yanakhokho » Thu Feb 09, 2012 2:01 pm
i can see all my pligins.
yanakhokho
Postby thomthom » Thu Feb 09, 2012 2:06 pm
yanakhokho wrote:sorry for my bad english :)
I suspect you placed the content of the TT_Lib2 folder directly into your plugins folder.
See the footprint:
Notice the TT_Lib2 folder.
I recommend you remove the files from TT_Lib2 and install using my Simple Plugin Installer utility. (Assuming you have the latest update to SketchUp 8)
Global Moderator
SketchUp version: 8
License type: Pro
Postby TIG » Thu Feb 09, 2012 2:13 pm
It looks like your Plugins folder might NOT be where it should be in the Sketchup folder - otherwise there would be at least a menu and one or two plugins listed in it ??
Where is your Plugins folder?
Can you post the full Windows [text] path to it please...
You can find this also by copy/paste this into the Ruby Console + <enter>
Sketchup.find_support_file("Plugins")
It should be something like
C:/Program Files/Google/Google SketchUp 8/Plugins
Errors Report:
Is that the very start of the error messages ?
Does it start with #extrusionToolbar.rb ?
If so that error [at least] results from there being files missing in the installation or they are not found.
So are the files there?
Have you extracted all of the files that come with this toolset in the correct way - putting some files in the Plugins folder BUT others must remain inside their subfolder as supplied in the ZIP file...
If they appear to be there, then do you have 'full permissions' to read/write/etc to the Plugins folder and it's subfolders ? Otherwise Windows might have placed some files or folder in side-folders to protect you - but it still looks like they are there; if there's a button in the top bars of the Plugins folder window saying something like 'Compatibility Files' that is a sign, click on it.
Another thought... I'm guessing that your locale is somewhat exotic, if you have any non-ASCII characters in file-paths used by Ruby this can cause issues...
An error loading one script can affect other scripts loading, BUT it might well be that you have multiple errors overlaid here... we can but see...
The 'TTerror' looks like an issue loading one of thomthom's libraries ?
Global Moderator
SketchUp version: 8
License type: Pro
Postby yanakhokho » Thu Feb 09, 2012 2:17 pm
Thank you very much! You are doing an excellent job!
and a special thank you for your patience and quick responses! I will try next time do not be silly!
yanakhokho
Postby thomthom » Thu Feb 09, 2012 2:20 pm
yanakhokho wrote:Thank you very much! You are doing an excellent job!
It is working now?
Global Moderator
SketchUp version: 8
License type: Pro
Postby Alainbo » Tue Feb 14, 2012 11:16 am
Hello,
When I export my model with LumenRT, it fails because it finds a zero length vector !?!
It seems Cleanup cannot find such problem.
How to find it?
Is it possible to improve cleanUp to take it in account?
Alain
Alainbo
SketchUp version: 8
License type: Pro
Postby thomthom » Tue Feb 14, 2012 11:59 am
Alainbo wrote:Hello,
How to find it?
Alain
Can you provide a sample model?
This zero length vector - is that from an error you get? Can you post the whole error?
It could be that it is a bug in LumenRT's exporter - and not a model problem.
Global Moderator
SketchUp version: 8
License type: Pro
Postby Alainbo » Tue Feb 14, 2012 1:40 pm
I found the problem, not precisely but it was related to a scene and not to the model.
I did't really understand what caused the bug but it's sure it's not a geometry issue.
Thanks a lot.
Alainbo
SketchUp version: 8
License type: Pro
Postby tspco » Thu Feb 16, 2012 1:35 am
What did I do wrong? I just downloaded and installed cleanup 3.1.9 and latest ttlib 2.6 I open the model and run the plugin, The screen goes gray, and a long gray box appears with no options to select from. The ttlib file goes into the compatibility files folder, I think that is the problem. I cannot move in back into the regular plugins folder
tspco
Postby tspco » Thu Feb 16, 2012 2:25 am
I read back a few pages and found the issue, I now have the tt simple installer, and all "appears" as it was.
tspco
Postby TIG » Thu Feb 16, 2012 11:29 am
Ensure that you have 'full access rights' to the Plugins folder [select its icon Properties > Security ...].
Also do the same for Components, Materials and Styles...
This will stop 'Compatibility Files' issues - where Vista stops you moving files/folders into certain 'program' folders to protect you from yourself if you have limited access rights... With full-rights it should behave...
Global Moderator
SketchUp version: 8
License type: Pro
Postby tspco » Thu Feb 16, 2012 1:01 pm
I apparently already set permissions for everyone but the creator owner will not change, I am sure it is a windows thing I really don't need to know.
tspco
Postby TIG » Thu Feb 16, 2012 1:03 pm
Why mess with that just give yourself 'full-permissions'...
Global Moderator
SketchUp version: 8
License type: Pro
Postby genma saotome » Fri Mar 16, 2012 1:48 am
Dunno if this has been mentioned before (40 pages is a lot to go thru) but the statistics presented afterwards are off. I'll run cleanup and be told it cleaned out quantities a, b, and c of types x, y, and z... do nothing, run cleanup again and be told it cleaned out quantities a, b, and c of types x, y, and z... and... rinse and repeat forever. Version 3.1.9.
I like the results... but I do wish it would tell the the straight story when it was done.
genma saotome
Postby thomthom » Fri Mar 16, 2012 9:25 am
It's because SU some times doesn't heal broken edges after all - probably some accuracy issue. To rework it to be 100% accurate might slow it down significantly. I figured that the stats being in the ball park would be good enough.
Global Moderator
SketchUp version: 8
License type: Pro
Postby genma saotome » Sat Mar 17, 2012 9:10 pm
Edges... that was one... ok, I understand. One of the others I recall now was a count of deleted components. Would delete 13, then another 13, etc., etc.
In truth, the numbers are a nice thing but not essential. I figure if you're aware and later happen to notice something the two might click and something gets fixed. Otherwise, oh well.
genma saotome
Postby thomthom » Sat Mar 17, 2012 11:46 pm
genma saotome wrote:Would delete 13, then another 13, etc., etc.
?!? Got a sample model for that?
Global Moderator
SketchUp version: 8
License type: Pro
Postby john2 » Mon Mar 26, 2012 11:11 am
how can i make cleanup not delete coplanar lines (like imported drawings from cad) which are locked?
Google SketchUp Pro 8, Vray 1.49, Windows 7 – 32 bit
john2
Postby thomthom » Mon Mar 26, 2012 12:06 pm
john2 wrote:how can i make cleanup not delete coplanar lines (like imported drawings from cad) which are locked?
I have that in the list of bugs: https://bitbucket.org/thomthom/cleanup/ ... cleaned-up
Global Moderator
SketchUp version: 8
License type: Pro
Vertex Tools for SketchUp. Take control over each vertex with this vertex editor for SketchUp.
PreviousNext
Return to Plugins
Users browsing this forum: Bruno Teles, faizoso, nkutty, radiacor and 8 guests
