by josephkim626 » Fri Nov 13, 2015 10:51 pm
Beautiful TIG! I will try it out as soon as I can! I thought you were gonna sleep on it
josephkim626
- Name: Joseph
- Operating system: Windows
- SketchUp version: 2015
- License type: Pro
- SketchUp use: architecture
- Level of SketchUp: Advanced
by TIG » Fri Nov 13, 2015 11:06 pm
Going to sleep now !
- Global Moderator
- Name: TIG
- SketchUp version: 2021
- License type: Pro
by TIG » Tue Dec 29, 2015 5:38 pm
Here's v7.1 Download There are several minor coding tweaks to try and work around a reported MAC issue [with my LayerWatcher!]... Feedback appreciated...
- Global Moderator
- Name: TIG
- License type: Pro
by TIG » Tue Dec 29, 2015 5:59 pm
Here's v7.2 Download There are several more coding typo fixes to try and work around a reported MAC issue [with my LayerWatcher!]... Feedback appreciated...
- Global Moderator
- Name: TIG
- License type: Pro
by TIG » Wed Dec 30, 2015 12:17 am
Here's v7.3 Download The tool that used to set up the main tools' commands has been recast as a simple class instance, to avoid issues with MACs caused by having a tool activated as SketchUp initially loads...
- Global Moderator
- Name: TIG
- License type: Pro
by ivreich » Mon Jan 18, 2016 11:30 pm
Hi TIG
I've found a new bug with v7.3 of this plugin when running SU 2016...
When creating 2D fillets , the resultant geometry no longer shows as pure arcs, but exploded edges. Have attached a screenshot.
There are no ruby console error messages, and it works fine in SU 2015.
Cheers!
Joel
ivreich
- Name: Joel Lee
- SketchUp version: 2014
- License type: Pro
by TIG » Tue Jan 19, 2016 1:54 pm
The 2d fillet's creation was changed to avoid problems with the new Observer regime in v2016. This is the first reported issue. I just retested it [v7.3 with v2016] very extensively and I got a perfect arc for the fillet every time... But obviously that change looks like the probable cause of your glitch... Does it occur every time for you ? Do you have many other plugins loaded which might have skewed entities observers etc ? Can you please post a simple SKP, with before and after examples of what you are seeing...
- Global Moderator
- Name: TIG
- License type: Pro
by ivreich » Wed Jan 20, 2016 6:26 am
Hi TIG
I'm not sure how to check if my other plugins conflict with 2D tools, but I've attached a SU 2016 file showing what I get when I try to fillet 2 edges with the plugin. It occurs every time with SU 2016, but works fine with SU 2015 (for me).
Hope this helps!
Cheers, Joel
ivreich
- Name: Joel Lee
- License type: Pro
by Dave R » Wed Jan 20, 2016 11:08 am
Very weird. I just opened your SKP file and selected the fillet. It's not exploded and reports as an arc with a radius which it wouldn't do if it was or had been exploded. Fillet.gif Click on the picture. Edit: Even weirder is that I get the same exploded arc when I run the 2D Fillet tool on the other corner. And notice one segment remains highlighted when I click on the others with Select. No modifier key was being held. Entity Info reports edges selected not an arc. Fillet2.gif Click.
- Global Moderator
- Name: Dave R
- License type: Pro
- SketchUp use: woodworking
by ivreich » Wed Jan 20, 2016 1:49 pm
Yup that is very weird. But the second image you described is exactly what happens whenever I try to run the fillet tool on SU 2016...one edge remains consistently highlighted and the curve reports as a series of edges...not an arc.
Cheers J
ivreich
- Name: Joel Lee
- License type: Pro
by TIG » Wed Jan 20, 2016 3:49 pm
OK I can see it happening too It the two picked Edges form a Face, then the Fillet is an Arc. It those Edges have no Face then the Arc is getting exploded into weird bits ! All my tests were on faced-edges - which is supposedly the more awkward process ! I'll investigate - I'll announce the update as soon as I find the problem - and fix it...
- Global Moderator
- Name: TIG
- License type: Pro
by TIG » Thu Jan 21, 2016 7:28 pm
Here's v7.4 Download The Fillet tool is changed for compatibility with all + >= v2016 [important when its fillets are NOT applied onto a faced area] Also the Fillet tool now helpfully highlights selected lines etc.
- Global Moderator
- Name: TIG
- License type: Pro
by ivreich » Fri Jan 22, 2016 12:22 am
Brilliant, Thanks TIG
Cheers, J
ivreich
- Name: Joel Lee
- License type: Pro
by JQL » Mon Mar 14, 2016 8:21 pm
I noticed I cannot change linetype. It says right click for options but right click shows a context menu without any 2D tool entries.
JQL
- Premium Member
- Name: JQL
- SketchUp version: 2017
- License type: Pro
by TIG » Mon Mar 14, 2016 8:33 pm
JQL wrote:I noticed I cannot change linetype. It says right click for options but right click shows a context menu without any 2D tool entries.
To [re]set the Line-Style you have to right-click in 'open space', otherwise the right-click activates the default context-menu...
- Global Moderator
- Name: TIG
- License type: Pro
by JQL » Tue Mar 15, 2016 10:53 am
Does it count if you are inside a group/component, with hide rest of model turned on and click on empty space there.
The first entry actually says "close group" and then I have some context menu options as you say.
JQL
- Premium Member
- Name: JQL
- License type: Pro
by TIG » Tue Mar 15, 2016 11:33 am
@JQL
You're right - after all of these years ! There is no context-menu when right-clicking in empty space in the model entities context, but there is when inside an edit mode... You can of course set the 2dLineStyle when in the model entities context and that will be used in the edit context. Or use the default 2dLineStyle on one piece and then select it and edit its 2dLineStyle, resetting the selected's 2dLineStyle that way...
It also occurs in the '2dHatch' tool, when trying to reset the 'PATT' !
This is clearly quite unsatisfactory - so I'll look at how I might fix it...
- Global Moderator
- Name: TIG
- License type: Pro
by JQL » Tue Mar 15, 2016 12:51 pm
TIG wrote:@JQL
LOL it's all your fault! I was working inside sectioncutface group! After your release of the latest SectionCutFace, where XY axis are parallel to section planes (I only requested it, it's your fault you developed it  ), I've been rethinking my workflow for doing more stuff in sketchup than in LO. This includes linework of course and your dashed lines came to mind. I knew they were there but hadn't used them before... As you're diving into this again, have you ever tought of drawing a sequence of lines for your dashed lines instead of faces? That would allow us to use styles to control thickness instead of having a fixed face width, and it would allow us a bit more control on scenes displayed at multiple scales inside LO. (I would personally have a hard time with it as I'm using profiles to control width but...)
JQL
- Premium Member
- Name: JQL
- License type: Pro
by TIG » Tue Mar 15, 2016 1:04 pm
Here's v7.5 Download Unlike when used within the Model entities-context, when editing a Group/Component the "right-click_in_open_space" was failing to open the 2dLineStyle-Settings or the 2dHatching-PATT-selector dialog: this has now been addressed - so that if used within an edit situation the short context-menu that appears has an appropriate command added onto it, which will then open that particular 2dTool's dialog.
- Global Moderator
- Name: TIG
- License type: Pro
by JQL » Tue Mar 15, 2016 4:17 pm
Thanks Tig!
JQL
- Premium Member
- Name: JQL
- License type: Pro
by function » Wed Mar 16, 2016 3:43 pm
newest version is messing with select tool I think. say i do control g to group something - usually it lets me select things again immediately. this plugin is conflicting and makes it so i have to hit the select tool again to select things. hope that makes sense
function
- Name: shredd
by TIG » Wed Mar 16, 2016 8:21 pm
function wrote:newest version is messing with select tool I think. say i do control g to group something - usually it lets me select things again immediately. this plugin is conflicting and makes it so i have to hit the select tool again to select things. hope that makes sense
This might be because of the tool-pop/push needed to add the context-menu... I've investigated... Here's v7.6 Download The context-menu for changing the 2dLineStyle & 2dHatching settings, when opened on a right-click from inside an edit situation, are now set up so that they do not interfere with other tools...
- Global Moderator
- Name: TIG
- License type: Pro
by LDHall » Wed Mar 30, 2016 6:47 am
2D Fillet / Chamfer tool does not work.
LDHall
- Premium Member
- Name: Lawrence Hall
- SketchUp version: 2016
- License type: Free/Make
- SketchUp use: hobby
- Level of SketchUp: Beginner
by TIG » Wed Mar 30, 2016 11:32 am
There was an issue reported with 2dFillet sometimes failing - this January - but the latest versions, since v7.4, have addressed this. The Fillet tool was changed for compatibility with all versions + >= v2016. This update was important when its fillets are NOT applied onto a faced area. Also the 2dFillet tool now helpfully highlights the two hovered/selected lines etc [as DaveR's gif illustrated very well]. Please get/install the latest RBZ - now v7.6 [which also include some fixes for 2dLineStyle and 2dHatching dialogs right-click opening when inside non-model contexts]... http://sketchucation.com/pluginstore?pln=2DtoolsTest and report back...
- Global Moderator
- Name: TIG
- License type: Pro
by josephkim626 » Wed Apr 06, 2016 4:12 pm
Thanks for the great work TIG!
josephkim626
- Name: Joseph
- License type: Pro
by Clayton49 » Mon Jul 31, 2017 6:36 pm
Hi all,
Is anyone using TIG'S-2D-TOOLS on version SU-PRO-2017, as I see it's not validated yet for this version ?
Thanks, Over & out, CJT54
Over & out, Clayton.
Trotman & Taylor Architectural Consultants
Clayton49
- Name: Clayton
- License type: Pro
by Dave R » Mon Jul 31, 2017 7:12 pm
I already replied in the other thread. This extension works just fine in SU2017. Leave the loading policy set to unrestricted.
- Global Moderator
- Name: Dave R
- License type: Pro
by Clayton49 » Tue Aug 01, 2017 9:41 am
Dave R wrote:I already replied in the other thread. This extension works just fine in SU2017. Leave the loading policy set to unrestricted.
Hi Dave-R, Thanks for confirming this, it's best this was aired on this 2D-tools page for others, tenuous links & all that. I see on my very old posts about subject, DASHED-LINES, I did in fact download & install this plugin, I now remember using it, but lost & forgot all about it, it must have been around the time I had a PC HD melt down...grrrr. I wonder why it's not been badged o.k. for SU-PRO-2017 on the download page... ? it sure is a great tool from what I remember, I can't wait to plug-it-in again. SU I feel has missed out on not providing 2D-CAD type tools, not everything needs to be modeled in 3D, adding the odd extra detail with 2D lines on saved model sections for building plans/sections makes this tool invaluable. I prefer doing it this way, rather than SU-LAYOUT, as all fixed & tied into the model. Besides that, I failed miserably in measuring off the model in SU-LAYOUT when trying to place/trace extra line details off the model in the view port at precise known distances. I think measuring was influenced by the scale of the view port window, anyway seemed tedious from what I recall. Not too sure why this is, as dimensions know what scale your using ? SU-LAYOUT is great for other items.
Clayton49
- Name: Clayton
- License type: Pro
by facer » Tue Aug 01, 2017 10:24 am
Draftsight (Free)https://www.3ds.com/products-services/d ... -software/If you are looking for 2D drafting tool to complement your Sketchup work Draftsight offers the following advantages:1. Free 2. Continually upgraded, allowing reading of current Revit or Autocad drawings in dwg or dxf 3. Supported by Dassault Systemes 3DS - a large French company.
facer
- Premium Member
by juju » Tue Aug 01, 2017 10:44 am
facer wrote:Draftsight (Free)https://www.3ds.com/products-services/d ... -software/If you are looking for 2D drafting tool to complement your Sketchup work Draftsight offers the following advantages:1. Free 2. Continually upgraded, allowing reading of current Revit or Autocad drawings in dwg or dxf 3. Supported by Dassault Systemes 3DS - a large French company.
I second this suggestion, I use it for viewing and conversion purposes.
juju
- Premium Member
- Name: Juju
- License type: Pro
- Robot
Return to Plugins
