It's funny these tools sort of started with my request for a way for my boss (who is learning SU) to draw in 2d.
[Plugin] 2D ToolsRe: [Plugin] 2D Tools v2.6Wow, I really like the trim extend functionality.
It's funny these tools sort of started with my request for a way for my boss (who is learning SU) to draw in 2d. ![]() Re: [Plugin] 2D Tools v2.6TIG excellent, had not noticed this tool to expand.
If you could achieve to work with arc that would be excellent.
Re: [Plugin] 2D Tools v2.6Tig, thanks for your so fast and explicit reply!
I know what fillet tool can do (and I didn't entirely read your the help file ![]() Truth is that I never tried to extend an arc... but I think that's a SU limitation, knowing that they are approximated by segments. But what I forgot to add to my previous post is that ArchiCAD "adjust" tool can be applied to more that one 2D entity: one can select as many lines or arcs, etc. at once and they will trim or extend all together and, if boundary line doesn't exist, one can draw an imaginary one. I hope this make sense. Actually, a set of real 2D Tools are something I was "officially" asking each time I was in the beta tester team, from @Last to Google, and yours are a major step forward. Re: [Plugin] 2D Tools v2.6What you are asking for is an Trim/Extend like CAD where you select the Line(s) etc to Trim/Extend to and then the ones to be edited. The first set doesn't change (unless it's also in the second set !), the second set is adjusted as expected - extending/trimming to the projection of a selected line if appropriate...
In CAD many users use Fillet as a Trim/Extend Tools by setting the value=0 and working on just 2 picked Edges. The separate Trim/Extend works as outlined above... I'll think about a separate Tool... ![]() TIG
Re: [Plugin] 2D Tools v2.7Here's v2.7 viewtopic.php?p=185760#p185760
![]() New 2D Polygon Tool added. Similar to 2D Circle BUT can specify number of Sides NNs, length of a Side NNNx OR Radius NNN etc... 2D Circle tool alignment to second-picked point corrected. Help files updated. New tool's Icons added - also CADfather's alternative set updated temporarily until he adds his own... TIG
Re: [Plugin] 2D Tools v2.8Here's v2.8 viewtopic.php?p=185760#p185760
2D Circle and 2D Polygon adjusted - Rotation of 'ghost' ngon/circle drawn as you look to pick the second-point now matches the final one - with vertex at second-point picked... TIG
Indeed, it's a CAD-like tool. I use it in ArchiCAD very often, as I said, and I think it would expand SU poor native 2D possibilities even further. Thanks for updating and for your hard work, generally! Last edited by Dan on Thu Sep 24, 2009 1:24 pm, edited 1 time in total.
Re: [Plugin] 2D Tools v2.8When snapping to midpoint and click, the cursor jumps to the midpoint of the resulting segment
http://www.youtube.com/watch?v=IstNF3U73n0 Re: [Plugin] 2D Tools v2.8
This is a mystery ! I recently added the line inferencing stuff. It seems to work for all other snaps, but as you make multiple segment lines it needs to make a 'leapfrog', making ipoint1 ipoint2, clear ipoint2 etc. For some reason I haven't fathomed if the last snap was the midpoint of an edge then the copy! of the ipoint1 knows it's the mid-point of that edge BUT since that edge has been 'halved' it moves to the edge's new mid-point ... I think I have a fix... TIG
Re: [Plugin] 2D Tools v2.9I can't wait for 2D Tools v3.0
![]() This is the most updated plugin. And the shortest time betwen versions. Google Team could learn something from here... Thank you TIG! ![]() Re: [Plugin] 2D Tools v2.9ZOMG. WOW. ZOMG.
Amazing. I can't keep up! But I will, because this is probably the best plugin ever. I've been searching for these functionalities in SU since day one. Which was Sketchup 2, I think. Wonderful work TIG. Thank you! Re: [Plugin] 2D Tools v2.9TIG
K Tools/geometry/make L with radius set to [0] will do the Cad clean/join thing for 2d work. I set a keystoke [K] (surprise)just enter and select the lines to be cleaned and 'that's all folks'. Check it out. Thanks again and again for all your "good works". dtr
is it ever fast, if you look at the first post 2.9 came out before 2.8 . ![]() “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
http://www.Twilightrender.com try it! Re: [Plugin] 2D Tools v2.9TIG, Hope this wasn't asked before, but if I open 2d#.rb and see:
### TIG (c) 2009 ### loads 2D tools... ### v2 Reworked 20090909 require 'sketchup.rb' load '2Dtools/2D#loader.rb' ### And, I want to check which version is installed, will 200909(09) tell me that this is v2.9 ? Thanks.
Good idea - from now on I'll put the latest version/date into '2d#.rb'... TIG
Re: [Plugin] 2D Tools v2.9Dear TIG,
Perhaps you could just put your edit history (cut and paste) at the front of the script, as you usually do. Kind regards, Bob Re: [Plugin] 2D Tools v2.9Master Tig
I cannot express how much I appreciate your 2d drawing plugin. The arc and circle tools are very useful additions. So much so, could they be made to work in 3d? My arc tool still does not read the angle in the VCB, not sure why, a minor inconvenience. In addition, just another thought, could the 2D Set Z-Plane set the drawing to the top view, turn off model axes, move the origin to the lower left hand corner and make a set of construction lines for the X and Y axes. Again thanks for all work and time Ken Fight like your the third monkey on Noah's Ark gangway.
Re: [Plugin] 2D Tools v2.9I'm wondering if the "Set Z Plane" tool allow the user to physically manipulate a "ghost" plane of some kind to set the drawing plane.
For example, you click on the Set Z plane button and a Ghost Plane appears. The user can then manipulate the plane with the move and rotate tools. You could move the plane up by 10' and rotate the plane 45 degrees, right click and choose accept as drawing plane, the ghost plane disappears and all the tools would then be locked to that plane at that angle. This would be beneficial for using the 2D tools in a 3D world. If you could snap a ghost plane somewhere on your 3D model and lock the tools at that height and angle, it would allow you to draw freely using CAD style tools, without the annoyance of snapping and inferencing while trying to draw flat. Just a thought. 3D Artist at Clearstory 3D Imaging
Guide Tool at Winning With Sketchup Content Creator at Skapeup
Re: [Plugin] 2D Tools v2.9thax again dear master TIG ...for all you are doing for us...
but 2d hatch never worked for me ,at any version... what do you guess? also it is a while that I've lost "search panel" beside my explorer, does it depends on?
Please start the 2D Hatching Tool with the Ruby Console open and send us the messages that appear there - if any. Also report what it says on the Bottom of the Screen 'VCB' bar... We will fix it... ![]() TIG
Re: [Plugin] 2D Tools v3.0Version 3.0 is now available here...
viewtopic.php?p=185760#p185760 There has been a general re-write to improve robustness. The 'Help' section is now in htm format and suits all platforms, A brand new tool 'Adjust' has been added - this allows you to Select a set of Target-Lines and then 'Adjust' [Trim/Extend] Picked Lines to them [Target-Lines can also be Adjusted]. It is quick, intuitive and easy to use - with simple mouse-click-to-pick or mouse-drag-with-button-down-to-multi-select, then double-clicking to toggle between target-select and line-adjust [or exit], there is easy add/remove to targets-set by toggle-key <shift>, clear VCB prompting, and informative color changes to targets-set and the cursor [orange during stage1=select-targets, cyan during stage2=adjust-lines] etc... Feedback please... TIG
Re: [Plugin] 2D Tools v3.0TIG, thank you again for the incredible tools.
Like Majid, the hatching tool has never worked. Here is what I get with Ruby Console open: "Cancelled 2D Hatching. Error: #<NoMethodError: undefined method `display_name' for nil:NilClass> C:/Program Files/Google/Google SketchUp 6/Plugins/2Dtools/2DhatchingTool.rb:134:in `onMouseMove' C:/Program Files/Google/Google SketchUp 6/Plugins/2Dtools/2DhatchingTool.rb:134 Error: #<NoMethodError: undefined method `display_name' for nil:NilClass>" Then this message keeps repeating as I move the mouse. Ben Re: [Plugin] 2D Tools v3.1I think I've fixed this '2D Hatching' glitch that some of you were experiencing - I had to try very hard to make it fail on my PC at all, but now I know what the message is it's a bit clearer !
![]() Here's v3.1 viewtopic.php?p=185760#p185760 Please try it and see how it goes... ![]() TIG
Re: [Plugin] 2D Tools v3.1Thanks TIG. I never did have a problem with the hatching but I appreciate your continued attention to detail.
BTW, immediately above the link for the ZIP file it says that the file is no longer available. I'm guessing that just needs to be edited? Etaoin Shrdlu
% (THERE'S NO PLACE LIKE) G28 X0.0 Y0.0 Z0.0 M30 %
This Hatching glitch needs you to do a sequence of things when you first run the tool, that then mess it up subsequently ! Took me ages to work out what, as like you I had no problems with it at all... I think (hope) that's now trapped... I've also edited that initial 'typo' in the post ! TIG
I appreciate how quickly you fix things TIG, however, I still can't get the hatching to work with v3.1. It cancels out right away and I don't even get a chance to see anything in the VCB. Thanks again for this great script. Ben |
