[Plugin] 2D Tools
Re: [Plugin] 2D Tools v4.6
Postby thomthom » Fri Sep 10, 2010 6:10 pm
His error indicate a syntax error.
Sketchup::set_status_text ("Length"), SB_VCB_LABEL instead which Ruby 1.8.6 throws an error at now that it's stricter than previous version.
Possible he has used different tools than you?
@Wyatt: exactly when you do get these errors? What tools/operations are you doing?
PluginStore Author
PluginStore Author
Postby Dave R » Fri Sep 10, 2010 6:21 pm
I don't know, Thomas. I've gone through all of the 2D tools just now and didn't get any errors.
Global Moderator
Postby wyatt » Fri Sep 10, 2010 7:23 pm
Ok, figured it out. The 2D tools that don't work for me are these:
viewtopic.php?t=21445
v4.6 works fine. Are the plugins on the other thread an earlier build?
wyatt
Postby TIG » Fri Sep 10, 2010 7:36 pm
As Thomthom says v8 is more unforgiving of having only part of the arguments parenthesized - I will check my code and reissue to suit... B U T . . .
However, there is no occurrence of the text Sketchup::set_status_text ("Length"), SB_VCB_LABEL ANYWHERE in the current 2DlineTool.rb - it's always the correctly syntaxed Sketchup::set_status_text((db"Length"),SB_VCB_LABEL) ??? :?
So I am a bit mystified - do you have the correct version downloaded from the main page zip file...
Global Moderator
Postby thomthom » Fri Sep 10, 2010 7:57 pm
o_O
Peculiar. Though, I did find the syntax alien to be TIG's...
PluginStore Author
PluginStore Author
Postby TIG » Fri Sep 10, 2010 8:55 pm
thomthom wrote:o_O
It was 'wrong' in some older versions.... BUT not in the more recent ones - and they coincidentally suits v8 too............
Global Moderator
Postby Fredquentin » Tue Sep 14, 2010 2:48 pm
Thank's a lot
Reg@rds Fred
Fredquentin
Re: [Plugin] 2D Tools v4.7
Postby TIG » Thu Sep 23, 2010 9:52 am
Here's v4.7 viewtopic.php?p=185760#p185760
The MAC TAB-key press glitch is trapped using key-up check instead of key-down in 2DlineTool.
MAC 'help' openURL glitch fixed.
Global Moderator
Postby ken » Thu Sep 23, 2010 11:44 am
Some how I don't think this is what you wanted.
And thanks.
Ken
ken
Premium Member
Premium Member
Postby TIG » Thu Sep 23, 2010 11:49 am
Ken wrote:TIG
And thanks.
Ken
Ken - somehow the zip got messed up! :oops:
I'll post v4.7 again!
Global Moderator
Postby TIG » Thu Sep 23, 2010 12:09 pm
:oops: v4.7 zip was messed up!
It's now fixed viewtopic.php?p=185760#p185760 - please re-download...
I know that it has been downloaded a few times in the corrupted form.
If you have it then either don't install it or if you already have done so, then please remove all of the 'wrong' files from the Plugins folder...
Otherwise you'll get multiple toolbar-buttons etc...
In the Plugins folder you should only have just two related files - deBableizer.rb and 2D#.rb - AND also a 2DTools folder containing lots of things.
Everything else with '2d' is their name [files (~22nr) and folders (2nr)] is wrong and needs removing.
The CadFathersIcons.zip file is also wrongly located and needs removing to tidy up.
Also there will be a folder called Icons that unfortunately might have merged with other tools' folder of the same name - it does no harm to have the extra image files in there... BUT to tidy up remove any files in it with '2D' in their name - if that empties the folder then you can also delete that.
Similarly the Hatching folder has been misplaced - it's unlikely to have merged - but check if it only contains image files starting with 'PATT' and a ReadMe.txt file - if so the whole folder can go...
Sorry for this mess up... :oops:
Global Moderator
Postby jeff hammond » Thu Sep 23, 2010 4:44 pm
confirmed, tab now works on mac.
i didn't know that's what tab was supposed to do. ha
that makes 2D tools even more awesome :enlight:
thank you
dotdotdot
jeff hammond
Global Moderator
Postby Brett McAllister » Thu Sep 23, 2010 8:53 pm
Hi Tig
I noticed the edit 2d text function no longer works in version 8.
The option to edit the text shows up in the context menu but doesn't pop up a dialog box.
This is the error I got.
Error: #<NameError: undefined local variable or method `db' for TextTool2D:Class>
2DtextTool.rb:379:in `edit'
Running windows xp sp2
Cheers
Brett
Brett McAllister
Postby dedmin » Thu Sep 23, 2010 9:44 pm
When trying to use Edit 2D text I got this:
Code: Select all
Error: #<NoMethodError: undefined method `db' for TextTool2D:Class>
C:/Program Files/Google/Google SketchUp 8/Plugins/2Dtools/2DtextTool.rb:379:in `edit'
C:/Program Files/Google/Google SketchUp 8/Plugins/2Dtools/2D#loader.rb:186:in `activate'
C:/Program Files/Google/Google SketchUp 8/Plugins/SectionCutFace.rb:437:in `call'
WinXP SP3
dedmin
Postby TIG » Thu Sep 23, 2010 10:11 pm
Brett McAllister wrote:Hi Tig
Cheers
Brett
You should have deBabelizer.rb in the Plugins folder. It's in the main zip file?
Global Moderator
Postby TIG » Thu Sep 23, 2010 10:12 pm
dedmin wrote:When trying to use Edit 2D text I got this:
Code: Select all
WinXP SP3
Not sure about the SectionCut error ???
Global Moderator
Postby TIG » Thu Sep 23, 2010 10:16 pm
v4,7 error... However, I have now managed to reproduce the glitch :roll: with v8 ... and v4.8 will be issued shortly :roll: ...
Global Moderator
Postby dedmin » Thu Sep 23, 2010 10:42 pm
Code: Select all
WinXP SP3
Reinstalled the 4.7 and now the error is this:
Code: Select all
dedmin
Re: [Plugin] 2D Tools v4.8
Postby TIG » Thu Sep 23, 2010 11:05 pm
I've now got these new v8 errors trapped in '2D Text' and '2D Line Style' "edit" modes - see v4.8 viewtopic.php?p=185760#p185760
Double checking that no other methods are rubbished by the less forgiving PC-Ruby in v8... :roll:
EDIT: There shouldn't be any others - but that's not to say you lot won't find something that's broken... keep looking :?
Global Moderator
Postby dedmin » Fri Sep 24, 2010 12:38 am
Thanks,TIG! :thumb: :thumb:
dedmin
Postby Didier Bur » Fri Sep 24, 2010 9:31 pm
Hi TIG,
I'm always having this error too, even with the latest version. When setting the Z plane altitude for instance:
Code: Select all
C:/Program Files/Google/Google SketchUp 7/Plugins/2Dtools/2DzplaneTool.rb:59:in `onMouseMove'
Error: #<NoMethodError: undefined method `db' for #<Zplane2D:0x1285ba60>>
Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F)
Didier Bur
Re: [Plugin] 2D Tools v4.9
Postby TIG » Fri Sep 24, 2010 10:37 pm
Thanks Didier...
I just knew that someone would have another problem!
It was a stupid typo on my part that hadn't been reported before... :oops:
Here's v4.9 that fixes the 'db' glitch in the 'Set Z-Plane' tool.! :geek:
Global Moderator
Postby Didier Bur » Fri Sep 24, 2010 10:45 pm
Cool !
So reactive ;)
Didier Bur
Didier Bur
Postby CadFather » Sat Sep 25, 2010 10:34 pm
icons updated as well (thanks TIG)
Icons.zip
CadFather
PluginStore Author
PluginStore Author
Postby TIG » Sat Sep 25, 2010 10:48 pm
Thanks - I'll include them for the next update - meanwhile anyone who wants them now... please replace the original Icons with these...
Global Moderator
Re: [Plugin] 2D Tools v5.0
Postby TIG » Mon Sep 27, 2010 11:23 pm
Here's v5.0 viewtopic.php?p=185760#p185760
The db arguments etc are parenthesized in (). Various minor glitches in text etc have been addressed. The ES lingvo & help files have also been updated etc - many thanks to Defisto for his nit-picking that goaded me into the update! CadFather's new toolbar button icon set is also include if you want to swap over to that...
Global Moderator
Re: [Plugin] 2D Tools v2.2
Postby define » Tue Sep 28, 2010 4:44 pm
TIG wrote:Already updated with some minor fixes ! viewtopic.php?p=185760#p185760
:ugeek:
hello TIG, thx for your 2d-toolset...I'm using it all the time and would'nt know how to get along without it.
But I have to second ThomThom with his question, if one 'sotospeak' could make the 2dtools work with
your 'work-planes' too? This would make it into something even more versatile.
You answered ThomThom with a link - I can't however figure out what you are pointing at.
If there's already a means to switch the 2dtools z-axis to any 'temporarily active one' please
give me a hint.
thx a lot for the 2dtools and the 'workplane-plug' and all the other plugs as well
define
Postby Ben Ritter » Tue Sep 28, 2010 5:39 pm
I can use the hatching option only once, thereafter, I the hatch selection window doesn't open. Tried it with SU7 and SU8, same issue.
Any suggestions?
Ben Ritter
Postby Ben Ritter » Tue Sep 28, 2010 6:17 pm
Sorry for the bother. I'm short on memory and lazy. Just looked at some previous posts and found the answer.
Ben Ritter
Postby EarthMover » Tue Sep 28, 2010 6:24 pm
define wrote:if one 'sotospeak' could make the 2dtools work with
This would in fact be quite redundant. The work planes are used in a similar manner to the 2D tools, as they create a "shield" to prevent the inferencing of the native tools to the geometry on the opposite side of the plane. You can draw directly on it as it's a locked group and delete it at will. The 2D tools do much the same except they are restricted to the X,Y axis for 2D drawing, but still allow you set the Z, which creates an invisble 2D work plane on that height. The work plane plugin allows similar restriction, only it's not restricted to X,Y only and it works with the native toolset. You could technically set a work plan on the x,y axis at a Z height and use the native tools to draw in restricted 2D. Using the 2D tools to go the other direction would negate them from being 2D at all.
Content Creator at Skapeup
EarthMover
Premium Member
Premium Member
PreviousNext
Return to Plugins
Users browsing this forum: gahner, hady_s2021 and 15 guests
