[Plugin] 2D ToolsRe: [Plugin] 2D Tools v4.6Dear dedmin,
Thanks for the quick reply. I work at a university in the UK, and so I am entitled to an academic copy, which should make the transition cost effective. Are you UK based? Kind regards, Bob Re: [Plugin] 2D Tools v4.6
Yes - very cost effective - http://www.novedge.com/products/3148 ![]() Be warned that this piece is like SketchUP - You always come back to it! ![]() Re: [Plugin] 2D Tools v4.3
Hello TIG Thanks very much for all your stuff it's awesome. I've been using the 2D for a while no major issues. SIncidently though I have the same problem with the help file on Mac, Did the extraction many times, tools work mostly (except toggles, more below) but help doesn't. File (2Dtoolshelp.htm)can be opened separately (the one in the plugins, I use the EN one) Pluging your command into the ruby console gives me EN-US More troubleshooting info: clicking the help button doesn't do anything, no info in the help console. The button highlights but doesn't turn grey and any other button (tool) remains active. Now another very minor issue I have is that the CTRL toggle doesn't work (it's a MAC that's why). For example for the arc tool: I can't get anything to change but select 1st pt, 2nd pt and then circle circumference. Command and option (alt equivalent) do nothing as expected, and control doesn't toggle. Control does this: If you start with an arc (no other object) and keep it pressed it prevents you from clicking point until you release it, then it does nothing. As toggle it doesn't work either. If you have already an object (a line for example) and clicking on it, it brings up a contextual menu (the entity info menu, same as right click) Alt toggle works fine on other tools. The undo button does weird things too on entities. It erases the first one or few and then either it adds points or it just stop erasing. Also incidentally, no menu access, only the tool bar. ( I don't know if there is supposed to be a menu access, just in case I mention it) All these are minor issues, as I"m really happy with everything as it is, so it's just for feedback. Re: [Plugin] 2D Tools v4.6I know why the MAC Help doesn't open.
If you put this attached file into the ../Plugins/2Dtools/ folder in place of the earlier one it should open Help on a Mac... I've also temporarily added this updated file to the first item in this thread... 2D Tools sub-menu is to be found under the Draw menu... TIG
It works like a charm, thank you Sir! Sorry for the submenu, I can't believe I didn't find it before, I always used he toolbar so never looked for it, it's only until you mentionned whether help could be accessed from the submenu that I tried to find it. Re: [Plugin] 2D Tools v4.6OK I've solved the problem of the control key on Macs. Into the ruby programs that correspond to tools that have a ctrl modifier, I changed all tests for VK_CONTROL into VK_COMMAND, I changed the display to cmd too.
I don't have stuff to zip but I'll gladly send you the modified files through email or whatever you'd like. Thanks TIG Re: [Plugin] 2D Tools v4.6So are you saying id I change the '..==VK_CONTROL' tests to '..==VK_CONTROL or ..==VK_COMMAND' it'll work on both PC AND MAC?
Please post or PM the files I need to prepare an update... ![]() TIG
Re: [Plugin] 2D Tools v4.6TIG:
Use none of them. Use the constants listed in the Tool class' description. http://code.google.com/apis/sketchup/do ... /tool.html
Well here is the thing, the control command on MAC should work but it didn't and I don't know why, sometimes it is said and written that the control function on PC is the command function on MAC, it didn't work in this case either. So I just substituted the Command key to the control key and left the ALT alone (which is option on MAC). I'm not sure what the VK_COMMAND corresponding key is on PC if any (maybe the window icon key). For the sake of information here is some I found: http://www.roughlydrafted.com/2007/08/1 ... ained-one/ So the "or" line may work but may introduce a second key on PC which may not be desirable. As for the generic commands that Thomthom listed they will work but beware. I thought about using those too, but in my particular case I work on a laptop and I don't have a "menu" key AFAIK, so again it's not as universal as they'd like. Copy_modifier_mask and Alt_modifier_mask would work fine here it seems but they reverse the use (ctrl and alt) As you saw from the story above the control key is really the command key on mac keyboard so I found it just simpler and more intuitive to modify all (text and variables), where option/alt remains such and command becomes the more global modifier. Much more logical and clean as the text match too. Files coming later tonight. On the 2D line, alt could be a 3 way toggle too but that's more work. The link that Thomthom posted has all the variables mentioned (VK_COMMAND, etc..) lower in the text. They claim it to be universal Mac/PC but I'm not sure. VK-ALT for sure (Option/Alt key on my keyboard) Re: [Plugin] 2D Tools v4.6I can set a test for a PC or Mac OS and then use the appropiate VK_...
![]() TIG
"Menu" is the "Alt" key - I don't know why the manual says "Menu". I have that small wireless keyboard for my Mac, and I have all the keys required. And I expect you have an Alt key available. Those generic keys are the least work as they avoid having to test for Windows or Mac. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] 2D Tools v4.6But since Alt and Ctrl are effectively swapped over from PC to Mac using this method you'd need to test to change prompts and Help files, as Alt on the Mac is not Alt on the PC.
PC Ctrl = Mac Cmd - = VK_CONTROL or = VK_COMMAND for PC/Mac respectively. PC Alt = Mac Opt - both = VK_ALT PC Shift = Mac Shift - both = VK_SHIFT In 2Dtools it's a simple fix to test for both key presses ? If a PC user presses 'command' [whatever that is?] then it's the same as pressing 'ctrl' anyway, as the 'command' key is not used otherwise on PC and there's no 'ctrl' key on a Mac to muddle us? The 2Dlinetool uses TAB to set Z value option, but it looks for two possible key press codes because TAB varies on the PC and Mac... if key == 9 or key == 15 ### 9 for PC and 15 for MAC... TIG
Re: [Plugin] 2D Tools v4.6No, this is exactly why COPY_MODIFIER_MASK is for "Alt on Mac, Ctrl on PC"
The *_MODIFIER_KEY and *_MODIFIER_MASK let you check for the various modifiers in a cross platform method. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] 2D Tools v4.6The PC user presses Alt - a Mac user usually thinks of Mac's Opt == PC's Alt - so a Mac user should press Opt......... As I see it this suggested method is contra-logical......
Re: [Plugin] 2D Tools v4.6Yea - names are confusing, mainly the ALT_* constants, but using these constants will match up the modifier key behaviour of native SketchUp. And I guess it matches common behaviour of the platform?
Since OSX has 4 modifier keys and Windows has 3 - things aren't mapped 1 to 1. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] 2D Tools v4.6tig
is it posible to get these 2d tools working in the layout portion of sketchup? they would be a great help when preparing documentation drawings regards grim
Sorry, but SUp's .rb isn't transferable to LO - there are lots of useful tools inside LO though ?? TIG
On the 2D Text tool would it be possible to limit the color selection to just 8 colors. Right now the end of the list is off screen's bottom and this makes it impossible to select yellow or any other color that is be at the bottom. Again thanks for the plugin. Ken Fight like your the third monkey on Noah's Ark gangway.
You CAN select off any list that goes off the screen... Select that list option... Type the first letter of the color you want - say W for 'White' The list jumps to 'Wheat' - because it's the first item starting with W... Now use the down-arrow key to scroll through the list until you have 'White' selected If you wanted 'Violet' use the up-arrow key to scroll up to that etc... In your example pressing 'Y' would jump to 'Yellow' directly as that is the first item it finds... The clunky 'inputbox' methods are not great but you can work through them... A web-dialog based interface with proper-scrolling is on the to-do-list... ![]() TIG
Thanks. That works for me. I was unaware of this feature. Again, thanks for your plugins. Onto another note, will you be at 3D Basecamp? Ken Fight like your the third monkey on Noah's Ark gangway.
Unfortunately, it's a no. Google arranged 3D Basecamp a very bad time... I have a sick relative coming to live with us around then... AND I have to get things ready [like finish the new ground-floor bedroom/bathroom etc]... AND also it's aloooong way... AND it's a lot of money for a few days' junket AND... it starts on my wife's birthday AND it ends on our wedding-anniversary ![]() So all in all a resounding 'no' - though I would have loved to have gone ![]() TIG
Excuses, excuses, TIG.... ![]() purpose/expression/purpose/....
Re: [Plugin] 2D Tools v4.6does this plugin only work for SU porfessional, or will it work with the free version.
i cant get it to load up. Thanks Glenn Re: [Plugin] 2D Tools v4.6It works on SU Free. Have you extracted the zipped folder into your plugins directory? Making sure to keep the folder/file structure intact.
Re: [Plugin] 2D Tools v4.6Glenn, it works with both pro and free versions of SU. Perhaps you could be a little more specific about what you've done and what's happening.
% (THERE'S NO PLACE LIKE) G28 X0.0 Y0.0 Z0.0 M30 %
Re: [Plugin] 2D Tools v4.6Also it's not to be found in the Plugins Menu... See Menu > Draw > 2D Tools > sub-menu items... AND you will need to activate the 2D Tools toolbar from Views > Toolbar > 2D Tools to see that too...
Please read the instructions in the Help file... TIG
Re: [Plugin] 2D Tools v4.6i feel like such an idiot, yes, they have been there all along.
sorry, i had been so engrossed in trying to get them to appear in the plugins section. thanks for the info Glenn Re: [Plugin] 2D Tools v4.6TIG,
The 2D tools don't seem to work in v8. I get the following error (3 pages actually - just copying one as they are all similar). Error Loading File 2D#.rb C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/2DlineTool.rb:33: syntax error, unexpected ',', expecting kEND Sketchup::set_status_text ("Length"), SB_VCB_LABEL I don't have an urgent need for this plug-in right now but I thought you'd like to know that it may need to be updated. Thanks! Wyatt Re: [Plugin] 2D Tools v4.6Wyatt, I don't want to speak for TIG but I'm not having any problem with the 2D Tools on either my Mac or my PC. In fact I just used it a few minutes ago on my PC here at work. Could it be an install problem?
