[Plugin] 2 Faces + Path ver. 1.5.
• Page 3 of 3 • 1, 2, 3
Re: [Plugin] 2 Faces + Path ver. 1.5.I am having some difficulty with this shape. It is a spiral with a shape, and it tapers as it it travels down the spiral.
I thought this plug would work but I am getting odd results. Any ideas? Thank you for all, Re: [Plugin] 2 Faces + Path ver. 1.5.Use the Perpendicular face tool by Chris Fullmer for put your 2 faces at the extremities of the curve!
Don't take care of their positions explode the groups select all and launch 2 faces + path ![]()
Re: [Plugin] 2 Faces + Path ver. 1.5.Hi Frenchy,
I used that when I set up the model. Also tried flipping the normals on the shaped ends, various options in the dialog box, its not behaving like I thought. Driving me crazy Re: [Plugin] 2 Faces + Path ver. 1.5.Maybe it's your curve! I have drawn a new one
![]() With spiral 1.3
Re: [Plugin] 2 Faces + Path ver. 1.5.I was guessing it may be that the spiral was precisely formed.
I'm trying but I still can't get it. Re: [Plugin] 2 Faces + Path ver. 1.5.I got it!
![]() Used Shape Bender instead! Re: [Plugin] 2 Faces + Path ver. 1.5.Thank you much, Kirill.
I'm trying to get up to speed. Not being a ruby cooker, I am ignorant of why a straight 'curve' is needed rather than an edge, multi- segmented or not, though you clearly state that a curve path is what is required. I wish error messages could be generated to help users, say if they make selection errors. Or perhaps that the plug be made to work with edge paths, so slow-witted users wouldn't need error messages.... So much. ~ Brooke
You may try new version of 'LSS Toolbar' instead of '2 Faces + Path' plugin. New version of 'LSS Toolbar' is still under construction, but fortunately '2 faces + path' tool is already implemented and work even more stable, than '2 Faces + Path ver. 1.5' stand-alone plugin. You may take a look at demonstration video at https://sites.google.com/site/lssoft201 ... ss-toolbar
Re: [Plugin] 2 Faces + Path ver. 1.5.Interesting, Kirill. The first try gave me this result. I would expect a smoother transition from the circle to the lozenge shape. Any suggestions on a way to make the transition correctly?
% (THERE'S NO PLACE LIKE) G28 X0.0 Y0.0 Z0.0 M30 %
Yes you can use 2 command buttons within '2 Faces + Path' section of web-dialog: - Flip face normal - Rotate face to dock vertices with other face It is also possible to fix the situation after 'pathface entity' generation: you can rotate any of two faces manually and refresh 'pathface entity'. I promise, that I'll write some manuals after 'LSS Toolbar' functionality update completion.
Re: [Plugin] 2 Faces + Path ver. 1.5.looks and sounds good.
been waiting for the new LSS Toolbar. thank you kirill.
Users browsing this forum: Jonatan_Hernandez, ryleywalker3 and 11 guests
