Note that I recently changed the old typo in the main script 'require ./delauney2.rb' to 'require 'delaunay2.rb'
The required file has been renamed 'delaunay2.rb'
Regards,
[Plugin] Drape Cpoints
• Page 2 of 2 • 1, 2
Re: [Plugin] Drape CpointsHi,
Note that I recently changed the old typo in the main script 'require ./delauney2.rb' to 'require 'delaunay2.rb' The required file has been renamed 'delaunay2.rb' Regards, Didier Bur (Bytes Farmer)
Ecole Nationale Supérieure d'Architecture de Nancy (F) http://rld.crai.archi.fr/rubylibrarydepot/
hi, could you please make step by step tut for creating your wonderful "5-minute bedspread" for those, who´re in the process of learning, just a bit far behind you (youtube is fine too)thanks ! SU8 Pro + VRay 1.49.90 on Win7 x64
Re: [Plugin] Drape CpointsTibet, here is a quick tutorial on the bedsheet.
Reason: Embedded Video into post A designer is an emerging synthesis of artist, inventor, mechanic, objective economist and evolutionary strategist. - R. Buckminster Fuller
Some of my 3D crap
Re: [Plugin] Drape CpointsNice tut!
Re: [Plugin] Drape CpointsWow Adam that is a cool tutorial.
visit my blog: http://www.nomeradona.blogspot.com
Re: [Plugin] Drape CpointsThanks guys..glad it was helpful. Here's a few tests of the method on different shapes. It's not as good as a physics based cloth simulation, but the results are fairly convincing. For table cloths, you just need to make sure you have a ground shape object that is slightly larger than the table and in the same group, so that the Cpoints will drape down and onto the ground. The same method can be used to make water in a stream bed or snow on a rooftop.
Please, register (free) to access all the attachments on the forums. A designer is an emerging synthesis of artist, inventor, mechanic, objective economist and evolutionary strategist. - R. Buckminster Fuller
Some of my 3D crap
Re: [Plugin] Drape Cpointshi earthmover,
thanks for your valuable time and desire to share your knowledge among sketchup fans/learners. it´s pretty cool, well done! cheers! SU8 Pro + VRay 1.49.90 on Win7 x64
"and a related delauney3" can't find this? “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
The delauney3.rb is a modified version I wrote to use with my version of The Triangulate-Points tool here viewtopic.php?p=301274#p301274 = the .rb is in the zip file with the tool's .rb... It in no way replaces or affects other tools using earlier 'delauney' scripts - however the earlier scripts can clash with so other tools so that is why I rewrote the modularized versions of them... TIG
Re: [Plugin] Drape CpointsHi TIG - First off - Amazing Plugin! Currently trying to model a leather headboard and will be using it to get nice uneven edges for a more realistic look. This may have already been flagged up so please ignore if that's the case, but I can't seem to get the plugin to work in Sketchup 8. 6 is fine so its not causing me any hassle but I just thought it could be worth a mention. Again - thank you very much. I'll try to post the results when I get there.
Re: [Plugin] Drape CpointsIt should work fine in v8.
Do you have the latest v8M3 installed ? Do you get any error messages in the pre-opened Ruby Console when you run this tool ? Do you have a 'rogue' script auto-loading that can cause issues by messing with the base-classes or making ill-formed observers ? Examples are SketchyPhysics, Matchbox, DrivingDimensions and an old SolarStudy tool [I forget its exact name]... If so, try moving them out of the Plugins folder and retry the tool... TIG
SketchUcation One-Liner AdvertsVertex Tools for SketchUp. Take control over each vertex with this vertex editor for SketchUp.
