[Plugin] CameraControls
• Page 1 of 2 • 1, 2
Re: [Plugin] CameraControlsThank you very much for the tool! I loved.
A thing that could be implemented would be the possibility to arise or to go down the camera, to change the zoom, or to alter the vision field, or Pan by slide.
Re: [Plugin] CameraControlsThanks for the suggestions. I'll see what might work.
RickW
www.smustard.com
Ah, sorry about that. I'll see about embedding a YouTube video instead. RickW
www.smustard.com
Re: [Plugin] CameraControlsNice job Rick!
I discovered a few things, not sure if they are bugs or not. See attached file. Could you have vertical lines (or tick marks) at degree intervals (ie., 45, 90, 130, 180, -45, -90, etc.) in the dialog background so you can align the sliders to them (or perhaps snap to them?)? _________________________________________________________________ Could you have a Camera Dialog devoted solely for "Dolley" movements (moving camera along a striaght path) which would perform the following: 1- Move along each of the colored axis (including user defined axis if possible) similar to the script you had for doing tutorials that jumb to "Iso snap-shots" from Scene to Scene. 2- Move left to right [Truck] and top [Pedestol]to bottom across the screen. The user could input distance values for the DOLLEYs. [UPDATE: Pardon me if I am not using the correct terminolgy here; it seems like there are mixed terminologies between applications (SU Pan tool does what I'm describing here, and SU's Look Around is similar to the PAN in your dialog). Please, register (free) to access all the attachments on the forums.
John
Illustrator Beaverton, Oregon
Re: [Plugin] CameraControlsJohn,
The 90-degree issue is (I think) an internal SU thing due to the desire of the camera to not look straight down - you can see this when manually orbiting, and I suspect it carries over to dynamically moving the camera in Ruby. Either that, or it's a by-product of my (necessary) assumption that when looking straight down, the positive y-axis is zero roll. Not sure. As for the second issue you described in your model, I don't quite understand the issue - I didn't have any problem getting 90 degrees for the magenta(?) and green boxes. I'll try to get with you later to get more input. RickW
www.smustard.com
Re: [Plugin] CameraControlsI cant get it to work.
I get a window with three sliders but nothing happens when I drag them. Should there be more things visible in that window? If not I suggest you make it a lot smaller. It takes up a great deal of space IMHO.
Re: [Plugin] CameraControlsAhh yes, agreed. The window initialy starts quite large for just the three sliders.
Jan, is it giving errors to the webconsole? I had a problem described earlier in the thread where the atan function needed to be specified as Math::atan on line 153. Did you already fix that one Rick? Chris
Re: [Plugin] CameraControlsOk. I added the Math::atan and now it works. Still the window is huge!
I really like the way it works in realtime but please make the window much more compact. It would also be nice with a small reset button for each slider. Also would it be possible to have these as well: Truck (left/right) Pedestal (up/down) Dolly (in/out) For these maybe some logarithmic/non linear curve for the slider so when sliding a little it would be small values and when sliding towards the extremes it would be larger/faster movement. Just a thought.
Re: [Plugin] CameraControlsInteresting, on my work computer, the window was HUGE also. But on my home computer, it was tiny tiny. Resized as absolutely small as possible, I almost didn't see it because it just shows the red x, minimize and maximize buttons.
You can manually resize it though, which works fine. And for me it remembers its size and location between SU sessions. So try to resize it and see if SU rememeber's its size. Chris
Good suggestion, Pixero. Moving sliders with the mouse with any accuracy has often been an issue for me (ie., in Goggle Earth dialogs). Perhaps Arrow keys could be active. Shift-Arrow = large movement, Ctrl-Arrow small movement, and what I have available in a 2D app for closeup work, Alt-Arrow = One Pixel no matter what the zoom level is. Getting a bit complicated isn't it. John
I like the idea, and if is possible to store some values, is fantastic.
Re: [Plugin] CameraControlsPixero: Not sure when you downloaded, but the current download has the corrected script (though I see you did get yours fixed).
John: Yes, I was using more "conventional" (as far as I could find) terminology for camera motion, rather than corresponding SU terminology. Also, I added text entry so you don't have to rely solely on slider accuracy - if you get it close and find the approximate angle, you can type the one you want. All: I can add a preset size for the window to get it a bit smaller at startup, though as noted above, it can be resized and should remember that size in the future. Also, I'm noting the requests, and will see what can be added. RickW
www.smustard.com
Re: [Plugin] CameraControlsThanks for the reply, Rick.
One thing. I did notice that you can NOT "swipe" the values in the dialog; you have to click and use the Delete Key or Backspace Key first, then type in new values. Any chance to allow "swiping"? Last edited by JClements on Wed Aug 12, 2009 4:22 pm, edited 1 time in total.
John
Re: [Plugin] CameraControlsThere are some challenges there with JavaScript/HTML in where I allow selection. I'll try to clean that up if possible.
RickW
www.smustard.com
Re: [Plugin] CameraControlsThank you RickW!
Works fine here!
Re: [Plugin] CameraControlsPlease, register (free) to access all the attachments on the forums.
Re: [Plugin] CameraControlsNice Plugin Rick,
Its really helpful when aligning the camera to a face in parallel projection and then rotating so the view is "upright". One problem I found is that in parallel projection the camera zooms out to the extents when adjusting the values. I had a look at the code and the simple solution is to store and maintain the camera.height value for non-perspective views, ie: maintaining:
storing:
Re: [Plugin] CameraControlsIv downloaded the files directly into plugins folder, but nothing appears in camera tab relating to the plugin, have i done something wrong, help please
Re: [Plugin] CameraControlslol i got it, its in my plugin tab and not the camera tab
SketchUcation One-Liner AdvertsArtisan Organic Toolset - a set of powerful organic modeling tools.
