by danylight » Sat Apr 28, 2012 2:18 am
why is sketchup closing when I use the section cut face ?? does anyone experience the same issue ? I used to work with this great plugin, I reinstalled sketchup ( same version as before, 8.0.3161 ) and now it doesn't work anymore...
I work with OS X 10.6
danylight
by TIG » Sat Apr 28, 2012 9:50 am
No known issues like this Have you tried disabling recently installed scripts to see if they are messing with some base class/methods used by this tool - e.g. some scripts have malfunctioning observers, or even ill-advisedly mess with Sketchup 'group.copy' methods etc and can cause such issues...
- Global Moderator
- Name: TIG
- Operating system: Windows
- SketchUp version: 8
- License type: Pro
- SketchUp use: architecture
- Level of SketchUp: Advanced
by humbertoanastasia » Tue May 15, 2012 6:53 pm
Hi. First of all, thank you! I've always used this plugin, and it's just wonderful! Since last update, though, everytime i try to use it my SketchUp crashes. I don't know what to do... Any suggestions?
Thanks!
humbertoanastasia
by TIG » Tue May 15, 2012 8:10 pm
humbertoanastasia wrote:Hi. First of all, thank you! I've always used this plugin, and it's just wonderful! Since last update, though, everytime i try to use it my SketchUp crashes. I don't know what to do... Any suggestions?
Thanks!
See the post just before yours viewtopic.php?p=401294#p401294 You must have installed something making rogue changes to base-classes/methods...
- Global Moderator
- Name: TIG
- License type: Pro
by mwm5053 » Sun May 20, 2012 4:13 pm
I like this plugin great job TIG I have a small question. When applying section cut face it fills in faces where no faces should be, still can't figure what I'm doing wrong
mwm5053
- Premium Member
- Name: Walt M
- Operating system: Mac
- License type: Pro
- SketchUp use: hobby
by bmike » Sun May 20, 2012 4:30 pm
mwm5053 wrote:I like this plugin great job TIG I have a small question. When applying section cut face it fills in faces where no faces should be, still can't figure what I'm doing wrong
it will sometimes do that depending on how complicated the geometry it has to cut. it happens to me 10% of the time when doing full building sections with framing, floors, timber, steel, etc. edit the group, and select the major area that needs to be removed. it will usually take a few clicks to clean it up.
bmike
by TIG » Sun May 20, 2012 6:04 pm
If your section cut is through non-solid objects or overlapping ones, its algorithm isn't clairvoyant - it makes a best guess at what is what. If you choose to keep unfaced edges it makes a manual repair quick and easy. A simple example is to make two cube groups and overlap them in 3d and cut a section through them... How is any tool going to double-guess what you expect to be filled in solid and what to leave as a void if your objects are no pure separated solids? This one very simple version of two overlapping cubes has eight or more possibilities - here are a few [adding more intersecting objects simply exacerbates the complexities and permutations...
Please, register (free) to access all the attachments on the forums. TIG
- Global Moderator
- Name: TIG
- License type: Pro
by mwm5053 » Sun May 20, 2012 6:59 pm
That makes total sense
Thanks TIG
mwm5053
- Premium Member
- Name: Walt M
- License type: Pro
by kai350191439 » Mon Jun 11, 2012 2:42 pm
Thank you so so much !!!!
kai350191439
- Name: Yankai wang
by juanchiarq » Thu Jul 05, 2012 2:55 am
Hey guys, I'm trying to use this plugin but I'm not getting any result, when I move/copy the object after making adding Section-CutFace I get the same one complete without the Section I've made, can anyone help me with this??, thanks.
juanchiarq
by Dave R » Thu Jul 05, 2012 11:56 am
I think you're expecting something this plugin doesn't do nor is it intend to do. This plugin doesn't modify the existing entity it just creates a new one which is the face on the section plane. If you expect to end up with the entity actually cut, you need Zorro instead.
Inspecting mirrors is a job I could easily see myself doing.
- Global Moderator
- License type: Pro
- SketchUp use: woodworking
by juanchiarq » Thu Jul 05, 2012 4:13 pm
Dave R wrote:I think you're expecting something this plugin doesn't do nor is it intend to do. This plugin doesn't modify the existing entity it just creates a new one which is the face on the section plane. If you expect to end up with the entity actually cut, you need Zorro instead.
Thank you Dave, that worked almost perfectly for me, the only bad thing is that I have to fill every wall to get a black filled effect when I uses de Section Cut, and also when I do a manual cut the SketchUp crash, I don't know why...
juanchiarq
by Dave R » Fri Jul 06, 2012 1:55 am
Not without seeing your model.
- Global Moderator
- License type: Pro
by yi_design » Fri Jul 27, 2012 5:59 am
awsome!
yi_design
- Name: zouyi
by whitelock » Fri Aug 10, 2012 11:37 am
Hi, I love this tool however I occasionally get a problem when trying to add section cut face. It will sometimes only fill in the faces of a few of the objects, and then some faces are left open. Is this a glitch? has anyone else experienced this and does anyone know a workaround.
Luke
whitelock
- Name: luke whitelock
by TIG » Fri Aug 10, 2012 3:03 pm
If you are having intersecting objects it can't always double-guess which should be solid and which should be void. This was discussed not so long ago. viewtopic.php?p=406295#p406295It'd be impossible to have an algorithm that'd be right 100% because what you see as solid might be more logically void and vice versa... If you leave the option ON to keep all edges a manual fix is relatively straight forward. Sometimes tiny or gigantic objects cause intersection issues too, but that's rare...
- Global Moderator
- Name: TIG
- License type: Pro
by whitelock » Wed Aug 29, 2012 8:18 am
I have a question, sometimes when using this plugin I take the section view into Layout and when I try and Dimension the section the Dimension tool will not snap to any points around where there is a cut face. Am I doing something wrong?
whitelock
by TIG » Wed Aug 29, 2012 9:33 am
There are no edges on a native Section-cut, so you can't snap to anything.
The SectionCutFace tool adds edges/faces to the selected Section-cut, but by default unfaced edges will be removed - so set 'Keep Un-Faced Edges'==Yes to keep them. Also all edges are 'hidden' by default, so they are not there to snap to either - so set 'Hide Edges'==No so you can see them.
Then you should have some edges to snap on to in the Section-cut...
- Global Moderator
- Name: TIG
- License type: Pro
by MartinK » Tue Sep 25, 2012 2:22 pm
Thanks TIG, This just saved a colleague a ton of time.
MartinK
- Name: Martin
- License type: Pro
by Jorocco » Thu Oct 18, 2012 6:43 pm
Thanks TIG for this excellent plugin.
I have a section in my drawing that creates two separate closed shapes. You could imagine a plane sectioning a donut. SectionCutFace creates the section face for only one of these shapes. The other one is left alone. I was wondering if there were any options or workarounds to get the other shape filled in with a face.
Thanks, John
Jorocco
- Name: John
by TIG » Thu Oct 18, 2012 7:11 pm
Jorocco wrote:Thanks TIG for this excellent plugin.
Thanks, John
I must imagine the form.. if you have two overlapping shapes the tool has to decide which parts are solid and which are void. There's a discussion and example images in an earlier post in this thread. Sometimes it guessing wrong when there are several possibilities. If your forms don't overlap, or are properly intersected solids without ambiguous 'internal partitions' then you won't get this. However, it is relative simple to fix in a post process... Set the options to include unfaced edges, show edges etc. After the section-face is made temporarily set your view to Monochrome mode; then edit its container [group] and remove any unwanted faces by selecting them + delete OR to add missing faces over-draw an edge to auto-form a face etc where it's wanted. Because all of the edges are coplanar they should all potentially auto-face with an edge-over-draw... but sometimes SketchUp can't cope with complex outlines and you'll have to add temporary 'diagonal lines' across the required face outline to form several facets; when you have all of the face pieces made you can erase the unwanted coplanar temporary edges to merge them back into a single face.
- Global Moderator
- Name: TIG
- License type: Pro
by Jorocco » Thu Oct 18, 2012 7:32 pm
TIG wrote:Jorocco wrote:Thanks TIG for this excellent plugin.
Thanks, John
Well, my donut example was maybe not the best because I created such a shape as a test, and the sections were added perfectly. I have attached my actual drawing. There are three closed shapes in this section, and the plugin has correctly filled two in red. However the shape that's like an upside down 'U' has not been filled in. I will experiment with the instructions you've given in your reply (I'm having a little trouble following it but maybe with some practice...) but wanted to clarify the problem. Thanks, John
Jorocco
- Name: John
by TIG » Fri Oct 19, 2012 5:10 pm
John I'm unsure why this might be failing - indeed it looks like it ought to work It's not perfect, but if you use the settings I suggested then you should get something that is quickly editable/fixable...
- Global Moderator
- Name: TIG
- License type: Pro
by nramadhiny » Sat Dec 15, 2012 1:35 am
installed the plugin in the right location and the ruby console have successfully loaded it, but when I clicked 'Add section cut face' on the right-click menu, it wouldn't show the dialog option. Even resulted that the command "add section-cut face-parameter" vanished when I moved my cursor somewhere. Help me!
nramadhiny
- Name: Nurina Ramadhiny
- License type: Pro
- Level of SketchUp: Beginner
by Dave R » Sat Dec 15, 2012 3:50 am
nramadhiny wrote:installed the plugin in the right location and the ruby console have successfully loaded it, but when I clicked 'Add section cut face' on the right-click menu, it wouldn't show the dialog option. Even resulted that the command "add section-cut face-parameter" vanished when I moved my cursor somewhere. Help me!
Which Mac version? Do you have both read and write permissions set for the Plugins folder for your username?
- Global Moderator
- License type: Pro
by TIG » Sat Dec 15, 2012 1:18 pm
Put the .rb file in the root HD.../plugins folder, NOT the 'users' equivalent. The 'plugins' folder needs to have full read+write permissions. I don't understand what you say about the Ruby Console Once the script is in the correct plugins folder and you restart Sketchup you need do no more... It auto-loads. When you have just one Section-Plane selected, then a context-menu entry [which will run the tool] is added to the context-memu's list of commands. Do NOT try to [re]load or run it from the Ruby Console - this will break things ! On picking the tool from the context-menu... a dialog appears and you choose options, on OK it processes and adds a SectionCutFace group [obviously you need to be cutting through something to get a face forming etc]...
- Global Moderator
- Name: TIG
- License type: Pro
by caronte01 » Thu Dec 20, 2012 4:30 pm
Thanks TIG. I use this plugin a lot with Layout.
caronte01
- Name: Santiago Molina
- License type: Pro
by duchuy2001 » Thu Jan 17, 2013 3:11 pm
first of all thank you TIG on this ruby, but I have one small problem like the one below!please fix it, I used SU8
duchuy2001
- Name: chuot
- SketchUp version: pre-6
- License type: Pro
- SketchUp use: engineering and mechanical design
by Dave R » Thu Jan 17, 2013 6:56 pm
I don't see a problem with that. Could you actually explain the problem you are having?
- Global Moderator
- License type: Pro
by TIG » Thu Jan 17, 2013 8:42 pm
What problem? Is it the colors' lists' lengths ? The list of available colors is all current model-materials and then all 'standard colors'. The default is 'Black'. The list will be longer that SketchUp's native inputbox can handle 'on-screen' BUT if you select the field and type the first letter of the color desired - e.g. you want 'White' so press W - it jumps to 'Wheat' then use the up/down arrow-keys to select the one desired - 'White'... You can always accept the defaults and later edit the grouped faces and give them any color/material you like... Also you can edit the current Style for the SectionCut so the edge color and width are also changed...
- Global Moderator
- Name: TIG
- License type: Pro
Return to Plugins
