by nickdk » Thu Jan 12, 2012 4:39 am
how many sides do you think I'll need? I have attached WIP to give an idea of the shapes involved and the detailing  I did a test with 100 sides and the polygons were visible so I guess it does require quite a lot :S
nickdk
by Dave R » Thu Jan 12, 2012 4:53 am
I don't know. It's kind of dark so it's hard to see. Does this look like it is smooth enough?
That's 50 segments going around the long way.
Inspecting mirrors is a job I could easily see myself doing.
- Global Moderator
- Operating system: Windows
- SketchUp version: 8
- License type: Pro
- SketchUp use: woodworking
- Level of SketchUp: Advanced
by nickdk » Thu Jan 12, 2012 4:57 am
yes it looks perfect:) My problem is that the circular shapes I'm using in my design are differently scaled - some of them are 20meters in diameter so the 'jagged' faces are much more visible.
nickdk
by Dave R » Thu Jan 12, 2012 5:09 am
That ring is drawn at a bit over 5 meters in diameter but I doubt it would look any different at 20m or 200m.
- Global Moderator
- License type: Pro
by ayik37 » Tue Feb 07, 2012 9:56 pm
thanks sir,that plugin working very well in my sketchup
ayik37
- Name: fakhri
by petroulac » Mon Mar 26, 2012 12:47 pm
Thanks!!!
petroulac
- Name: petroula
by ilaliberte » Wed Mar 28, 2012 12:36 pm
Hello! I've downloaded this pluggin several times and just did again with this version, and it just won't work: I don't get the context menu option at all!
My friends at uni are using it on the same version of SketchUp Pro (7.1.6859) without a problem... Here are some screenshots to try to explain. The context menu screenshot is from when I clicked on the section cut plane - there isn' anything missing from that menu, I only cut the screenshot a bit too close.
Does it make a difference that I am still on the trial version of V-Ray?
many thanks. Best wishes Isabelle
ilaliberte
- Name: Issy
by Dave R » Wed Mar 28, 2012 1:31 pm
Looks like you've got your plugins in the incorrect folder. Plugins for SketchUp should be in Macintosh HD/Library/Application Support/Google SketchUp 7/SketchUp/Plugins.
If I had to guess, I'd say Zorro 2 doesn't work either.
- Global Moderator
- License type: Pro
by ilaliberte » Wed Mar 28, 2012 4:00 pm
Thank you so much for this, it works now! How embarrassing - but it's good that it was this easy to solve. Thank you, thank you, thank you!!!
(And yes, of course Zorro wasn't working either!)
ilaliberte
- Name: Issy
by chalky » Thu Mar 29, 2012 9:25 am
I'm sorry but am I the only one having problems..? seems like everytime I run the plugin SU freezes, tried on various projects and simple cube..same thing SU8 Pro Lion 10.7.3 latest version of plugin, any suggestions?
chalky
- Name: chalky_d
by TIG » Thu Mar 29, 2012 10:14 am
chalky wrote:I'm sorry but am I the only one having problems..? seems like everytime I run the plugin SU freezes, tried on various projects and simple cube..same thing SU8 Pro Lion 10.7.3 latest version of plugin, any suggestions?
I know of no issues causing 'freezing'... Open the Ruby Console. Run the tool. Any error messages in the Console or otherwise ? Report back...
- Global Moderator
- Name: TIG
- License type: Pro
- SketchUp use: architecture
by chalky » Fri Mar 30, 2012 11:45 am
Tried what you said but no messages in ruby console reported.
chalky
- Name: chalky_d
by TIG » Fri Mar 30, 2012 1:10 pm
I see you are on v7 with Lion. I know there were some fixes with v8M2 to address problems with Lion, perhaps that's the issue So... any Lion users out there [with v7/v8] who are getting error free use from this tool ??I'm also now wondering if you have one of the problem scripts loading that can affect core class/methods ill-advisedly - these include SketchyPhysics, DrivingDimensions, MatchBox and some 'Solar' tool I cant bring to mind... Although some of these are PC only I think... This tool should workaround potential pitfalls made in its legitimate code by these files, but there might still be a trip-up somewhere. If you have any of these other scripts try to disable them and restart [move the .rb/.rbs files out of the Plugins folder temporarily]. Does this do anything better ?
- Global Moderator
- Name: TIG
- License type: Pro
by chalky » Fri Mar 30, 2012 2:03 pm
Sorry wrong info in profile i'm running v8 double checked if had those plugs and I don't
chalky
- Name: chalky_d
by TIG » Fri Mar 30, 2012 2:07 pm
Do you have the latest v8 = v8M2 ? This specifically addressed some issues with Lion...
- Global Moderator
- Name: TIG
- License type: Pro
by chalky » Fri Mar 30, 2012 2:30 pm
problem solved
chalky
- Name: chalky_d
by TIG » Fri Mar 30, 2012 2:37 pm
chalky wrote:problem solved
How? WE would like to know
- Global Moderator
- Name: TIG
- License type: Pro
by artsnot » Wed Apr 04, 2012 10:16 pm
I am new to this forum and seem to be experiencing a Sketchup crash every time I try to use section cut face. I am using Sketchup Pro 8 on a MacBook Pro i7 2.0 GHz with 8 MB RAM. I am not sure what the problem is. Has anyone else experience this?
artsnot
by TIG » Thu Apr 05, 2012 9:32 am
What MAC OS are you using ? OSX ?
- Global Moderator
- Name: TIG
- License type: Pro
by bmike » Thu Apr 05, 2012 6:55 pm
artsnot wrote:I am new to this forum and seem to be experiencing a Sketchup crash every time I try to use section cut face. I am using Sketchup Pro 8 on a MacBook Pro i7 2.0 GHz with 8 MB RAM. I am not sure what the problem is. Has anyone else experience this?
Running fine on mine:
bmike
by artsnot » Thu Apr 05, 2012 7:19 pm
I am running Snow Leopard 10.6.8.
artsnot
by TIG » Thu Apr 05, 2012 7:23 pm
SUFractal has reported a clash/crash with SectionCutFace [and some other scripts] if BIMtools is installed - we suspect that new tool might be inadvertently messing with native class/methods used correctly by other scripts, OR it has faulty observers that are messing with things like group creation... Do any of you experiencing problems have BIMtools installed ? If so, try disabling it and retry/report back...
- Global Moderator
- Name: TIG
- License type: Pro
by artsnot » Thu Apr 05, 2012 7:27 pm
How does one do that? Sorry, I am totally new and have no idea what that means. I appreciate your help.
artsnot
by TIG » Thu Apr 05, 2012 7:37 pm
Well... first have you [recently] installed BIMtools? If not don't worry. BUT if you did, then find the file you installed in Plugins - look inside the original 'zip' file to see what these were. There should be 'bim-tools.rb' and its folder of other files that it uses. So disabling 'bim-tools.rb' in Plugins will stop it auto-loading. You can either move that file out of the Plugins folder temporarily so Sketchup doesn't then find it when starting, so it is not auto-loaded; OR you could leave it where it is and rename it 'bim-tools.rb!' - only file-types '.rb' and '.rbs' are auto-loaded.
If you restart and try SectionCutFace now does it work... If so we have the culprit...
If you want to restore a disabled tool later on, then either move its file[s] back into Plugins, or if you have adopted the other approach, rename the file[s] back as 'xxx.rb' etc...
- Global Moderator
- Name: TIG
- License type: Pro
by artsnot » Thu Apr 05, 2012 8:19 pm
I don't recall having installed anything like that and a spotlight search reveals no files with such name. I've checked my SU folder as well and there doesn't seem to be any such script. Thoughts?
artsnot
by TIG » Thu Apr 05, 2012 10:10 pm
Post a detailed screenshot of your Plugins folder showing what is installed. Also post the full path to the folder...
- Global Moderator
- Name: TIG
- License type: Pro
by SUFractal » Thu Apr 05, 2012 11:54 pm
TIG wrote:Well... first have you [recently] installed BIMtools? If not don't worry. BUT if you did, then find the file you installed in Plugins - look inside the original 'zip' file to see what these were. There should be 'bim-tools.rb' and its folder of other files that it uses. So disabling 'bim-tools.rb' in Plugins will stop it auto-loading. You can either move that file out of the Plugins folder temporarily so Sketchup doesn't then find it when starting, so it is not auto-loaded; OR you could leave it where it is and rename it 'bim-tools.rb!' - only file-types '.rb' and '.rbs' are auto-loaded.
Folks ... the correct name of the troublesome script is 'SketchUpBIM'.
SUFractal
by artsnot » Fri Apr 06, 2012 1:58 am
Here you go.
artsnot
by artsnot » Fri Apr 06, 2012 2:30 am
Could my problem have to do with using Podium for Sketchup? When I try using Zorro to cut my model it also crashes immediately.
artsnot
by TIG » Fri Apr 06, 2012 10:40 am
You have very few scripts auto-loading from Plugins... You could try disabling both Zorro and Podium temporarily - add a ! onto the end of the file extension to prevent it auto-loading on a restart of Sketchup. Later on you can remove it back to .rb/.rbs as appropriate, so it enabled again. It's strange that you and a few more now and again have issues as it's been around for ages without problems...
Open Window > Ruby Console when running the SectionCutFace and see if there are any error messages when it fails.
Also in the Console type $LOAD_PATH [exactly as here] and there should be a list of the folders Plugins [for 'your' scripts] and Tools [for Google's scripts]; are there any other folders listed there that contain .rb/.rbs files ?
Can you post the SKP that has the issue so we can text it.
Can you also ZIP the actual script [.rb] and PM it to me so I can check it hasn't somehow become corrupted during your install... by ZIPping it it'll preserve its contents best...
- Global Moderator
- Name: TIG
- License type: Pro
Return to Plugins
