[Plugin] RoundCorner - v3.3a - 18 Dec 18
Re: [Plugin] RoundCorner 2.0a - 9 Jul 09
Postby fredo6 » Fri Jul 10, 2009 3:29 pm
Pilou wrote:Yep with little measures that splatting soon as Enter!
Beginning to see the time scroll barr... then plaffffffffff! :D
Something like these measures for first tool!
Pilou,
First, this does not seem to me to be 'little measures' but more just a normal case (5 cm on 3m).
Second, are you sure the attached file is the one corresponding to the bugsplat. Its content indicates the operation terminated normally.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby mitcorb » Fri Jul 10, 2009 4:07 pm
Hi, Fredo:
This tool looks interesting.
Would this be complimentary to Bevel and Round Edges by Bezier?
mitcorb
mitcorb
Top SketchUcator
Postby TIG » Fri Jul 10, 2009 5:11 pm
Here's my error message...
FredoTraceRoundCorner[1mcube100mmbevel all edgesTIG].txt
Global Moderator
Postby boilingsnow » Fri Jul 10, 2009 7:21 pm
I have not tried this jet, but I am sooooooo exited that I must say something first!
I've been waiting this for ages.
Edit
I tested it just now, it seems this ruby is still not very stable?
It couses frequently sketchup errors and the program quits automatically everytime. Sometimes even when I was just do simple round corner on two sides, not to mention other more complicated objects. Perhaps that's only my problem due to my PC or some other personal settings? I don't know.
PS.
I tested it in sketchup 6 again (just now was in skechup 7), and it works nicely.
so I can imagine that the ruby still has some conflicts with sketchup 7.
But fredo I think you can make it better.
boilingsnow
Postby Stinkie » Fri Jul 10, 2009 10:00 pm
I have tried it, and it works great. This ruby is an enormous time saver. Really happy with it. :enlight:
Stinkie
Postby fredo6 » Fri Jul 10, 2009 10:34 pm
boilingsnow wrote:I tested it just now, it seems this ruby is still not very stable?
It seems you are one of the users who get a bugsplat with SU7 (even with simple geometry).
Would you mind to refer to this link http://forums.sketchucation.com/viewtopic.php?f=180&t=20485&st=0&sk=t&sd=a&start=15#p171844, use the modified file and report the txt.
I am unable to reproduce the bugsplat in my environments (actually I never got a splat when writing and testing teh plugin), so I need users getting it to give me some hints on where it could come from.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby fredo6 » Fri Jul 10, 2009 10:47 pm
TIG wrote:Here's my error message...
TIG,
Very strange. The trace files says that you executed the whole operation with no problem.
That was the same for Pilou's trace file.
Please keep the model where you can reproduce the bugsplat until I can identify the problem and find a solution.
If so, could you try again with the attached file (it still contain traces).
Also, do you see the hour glass before the splat?
Fred
[Edit 11 Jul 09] Attachment removed. Fix in release 2.0b
fredo6
PluginStore Author
PluginStore Author
Postby fredo6 » Fri Jul 10, 2009 10:52 pm
mitcorb wrote:Hi, Fredo:
mitcorb
RoundCorner includes a Sharp Mode as in RoundeEdges by Bezier. But you can keep both in parallel safely. RoundCorner also does Beveling (the green-gray icon).
fredo6
PluginStore Author
PluginStore Author
Postby mitcorb » Fri Jul 10, 2009 11:16 pm
We will all be eternally grateful to you, "Mr. Wizard". Thank you again.
mitcorb
Top SketchUcator
Postby boilingsnow » Fri Jul 10, 2009 11:33 pm
Fredo
Thank you for you reply.
hier is the first error report I got.
[0.000000 ms] : Sat Jul 11 00:28:24 2009 - RUBY_PLATFORM = i386-mswin32
[0.000000 ms] : Preparing geometry
[0.000000 ms] : Compute corners 24
[0.030000 ms] : Compute edge roundings 36
[0.040000 ms] : Compute triangulated 0
[0.040000 ms] : End Preparing geometry
[0.040000 ms] : Launching the processing of geometry Nbsteps = 277
[0.040000 ms] : Scheduler processing: Step = 0 ipos = 0
[0.040000 ms] : Processing chunk: Init Step = 0 ipos = 0
[0.711000 ms] : Processing chunk: Terminate Step = 0 ipos = 0
[0.711000 ms] : Processing chunk: Init Step = 1 ipos = 0
[0.731000 ms] : Processing chunk: Terminate Step = 1 ipos = 0
[0.731000 ms] : Processing chunk: Init Step = 2 ipos = 0 grptempo = #<Sketchup::Group:0x11751360>
[0.901000 ms] : Processing chunk: Terminate Step = 2 ipos = 0
[0.901000 ms] : Processing chunk: Init Step = 3 ipos = 0 grptempo = #<Sketchup::Group:0x11751360>
[0.901000 ms] : Processing chunk: Terminate Step = 3 ipos = 0
[0.901000 ms] : Processing chunk: Init Step = 4 ipos = 0 grptempo = #<Sketchup::Group:0x11751360>
boilingsnow
Postby sepo » Fri Jul 10, 2009 11:35 pm
Fantastic Fredo....very smart ....Thanks very much.
sepo
Postby Karlfucious » Sat Jul 11, 2009 2:06 am
Works great, Thank you VERY much.
Karlfucious
Postby EscapeArtist » Sat Jul 11, 2009 3:47 am
As always, fantastic job Fredo. SU woudln't be what it is without all these fantastic community-made plugins.
EscapeArtist
Top SketchUcator
Postby Jörg » Sat Jul 11, 2009 7:41 am
Just amazing!!!!!!! :sketchstatic: :berserk: :ecstatic:
Thank you very, very much, Fredo!!!!!
Jörg
Jörg
Postby dylan » Sat Jul 11, 2009 8:43 am
Has anyone got this to work on a Mac?
I cannot get the plugin to show.
I have tried installing to the following locations:
Macintosh HD/Library/Application Support/Google SketchUp 7/SketchUp/plugins
User/Library/Application Support/Google SketchUp 7/SketchUp/plugins
dylan
Postby TIG » Sat Jul 11, 2009 12:21 pm
Fredo
Splats as before, hourglass appears very briefly before splat-screen.
Here's latest report...
FredoTraceRoundCorner[TIG-20090711].txt
Global Moderator
Postby bagatelo » Sat Jul 11, 2009 12:50 pm
With which words I could thank for your work, Fredo6? Simply fantastic.
And with me again, in SU 7 bug splat, SU 6, works fine.
Thanks again.
bagatelo
Postby fredo6 » Sat Jul 11, 2009 1:55 pm
About the bugsplat in SU7
TIG wrote:Fredo
It seems that the whole operation completes normally. The bugsplat may be right afterward.
I have tweaked the code, just in case, with the attached files.
If you can reproduce again the same situation you had before, would you mind to test.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby numerobis » Sat Jul 11, 2009 1:56 pm
WOW! This is incredible! :shock: :o :shock:
Great Work! :D
Thank You very very much!!!! :ecstatic:
the whole skp dev team (if there is one existing - don't know, after seeing v7) should quit developing new functions and concentrate on x64 and highpoly support ...or go home instead.
Sketchup v6.9 "Community Edition" rockz!!! 8-) :mrgreen:
numerobis
Postby fredo6 » Sat Jul 11, 2009 2:32 pm
I have been trying in SU7 on more complex models. Still does not get a bugsplat.
On 3D letters, RoundCorner gives better results than the old RoundEdge.
fredo6
PluginStore Author
PluginStore Author
Postby bagatelo » Sat Jul 11, 2009 4:30 pm
I have using SU 7 on Windows Vista x64 SP1 and I have always bug splat.
I have instaled Windows XP SP3 x86 on another HD and until now I don't have Bug Splat.
Maybe the problem is with Windows Vista.
bagatelo
Postby fredo6 » Sat Jul 11, 2009 4:44 pm
bagatelo wrote:I have using SU 7 on Windows Vista x64 SP1 and I have always bug splat.
I doubt this comes from the operating system. I have myself Vista x64 and does not have problem. Did you try with the latest ruby files I posted (2 messages above)?
fredo6
PluginStore Author
PluginStore Author
Postby delarc » Sat Jul 11, 2009 4:59 pm
This plug in works incredible and very easy to use :berserk: ... Thank you very much Fredo6...
delarc
Postby TIG » Sat Jul 11, 2009 5:12 pm
Fredo
I don't know what you did exactly to the files BUT all of the options now work perfectly... without a single bugsplat - despite my best [worst] efforts to make one !
Well fixed !!!
[Now all you have to do is stop it writing the 'FredoTraceRoundCorner.txt' file into Plugins and it'll be 'perfect'...]
Global Moderator
Postby fredo6 » Sat Jul 11, 2009 6:07 pm
TIG wrote:Fredo
Well fixed !!!
Apparently SU7 does not like calling GUI functions via UI.start_timer.
Before I release the fix, would you mind to test the attached file (still with traces) so that I am sure this is the problem (whether you get or not the splat, I would know what it is).
Again, thanks very much for your help.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby TIG » Sat Jul 11, 2009 6:19 pm
Fredo
I have tested the new version and it works perfectly too... even tried a very small bevel <1mm OK...
It still writes the temp txt file...
Global Moderator
Re: [Plugin] RoundCorner 2.0b - 11 Jul 09 (no bugsplat)
Postby fredo6 » Sat Jul 11, 2009 6:45 pm
NEW version 2.0b, hopefully fixing the bugsplat problem in SU7.
Thanks to TIG and others for helping debug this one.
See main post at http://forums.sketchucation.com/viewtopic.php?f=180&t=20485#p171721
fredo6
PluginStore Author
PluginStore Author
Postby fredo6 » Sat Jul 11, 2009 8:58 pm
Here is a question coming from another thread
Free Agent wrote:through the round corners parameters under Tools is ther any way to make is so that the geometry isnt automatically softened?
In the RoundCorner palette, you have 2 sections to set up the edge properties of the generated roundings: one for the borders (outer edges), one for the inner edges.
The 3 buttons are for Soft, Smooth and Hidden. When none are selected, it indeed means plain edges.
The default is Soft for borders and Soft + Smooth for inner edges (you can set these default by clicking on the small title button above).
fredo6
PluginStore Author
PluginStore Author
Re: {Plugin] RoundCorner 2.0a - 9 Jul 09
Postby fredo6 » Sat Jul 11, 2009 9:15 pm
DacaD wrote:I'm feeling bad for not helping you with nothing since your plugins more than once have helped finishing my (personal or professional) projects, and you never ask nothing in return for this plugins, so if you need any help in any project of yours, (modeling, texturing , rendering etc), some tips, tricks, toturials, info on software or whatever or even just a good discussion, anything that i can help just tell me. i would gladly help you.
David
Thanks for your encouragements and warm feelings.
I am just curious to see what RoundCorner gives when shapes are rendered with tools like Kerkythea, Podium and other nice engines.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby fredo6 » Sat Jul 11, 2009 11:10 pm
Not completely sure it could be very useful in practical life, but I forgot to mention that the algorithm used by the script allows for custom profiles, under 2 conditions:
  • The profile must be symmetrical
  • it only works in Round mode (not in Sharp mode)
Of course, I would need to build some GUI to design and select custom profiles.
I enclosed a few examples in the attached SKP file (SU7 format).
Fredo
fredo6
PluginStore Author
PluginStore Author
PreviousNext
Return to Plugins
Users browsing this forum: MARFAN, nguyenthanhvc, oliverclesio, paulmaler and 14 guests
