[Plugin] RoundCorner - v3.3a - 18 Dec 18
Re: [Plugin] RoundCorner - v3.3a - 18 Dec 18
Postby Drachenbauer » Sat Aug 08, 2020 8:13 pm
I have created a square-frame-object.
as i rounded the inner edges of this frame,the tool generated big square faces, that covered the hole of the frane, that it looked like a solid plate.
i had to remove theese faces to get the rounded frame-shape i wanted.
Maybe it was because the special case, that i wanted to merge the inner and outer rounded edges to a half circle profile.
Drachenbauer
Postby Dave R » Sat Aug 08, 2020 8:36 pm
That's a common thing in cases where you are rounding the edge of a hole. FredoCorner doesn't seem to do that however.
Global Moderator
Postby tsenilas501 » Sun Aug 16, 2020 2:14 pm
Thanks. Cant wait to use this plugin. :thumb:
tsenilas501
Postby fpsnyder » Mon Aug 24, 2020 5:54 pm
Receiving an error message when trying to run FredoCorner after updating SketchUp Pro 2020 to version 20.2.172. Message reads "This version of FredoCorner has expired. Please upgrade to latest version. Currently have version 3.3a of FredoCorner installed and it was working fine just prior to the SketchUp update. I tried re-installing FredoCorner multiple time without avail...any suggestions?
Apprecaited,
Frank
fpsnyder
Postby Gus R » Mon Aug 24, 2020 8:34 pm
What's the scoop on FredoCorner?
I just got a window to update and I went to the Pluginstore and downloaded RoundCorner_v3.3a.rbz and that was the wrong one so I found another page and downloaded FredoCorner_v2.0a.rbz which seems to be the right one.
Checking for updates didn't indicate anything other than the library.
It works now.
Gus R
Postby Gus R » Mon Aug 24, 2020 8:39 pm
Gus R wrote:What's the scoop on FredoCorner?
It works now.
Not enough sleep.
Gus R
Postby oszinapsugarbasel » Mon Oct 19, 2020 9:06 pm
Hello.
I have a Pro trial version
I installed the plugin
the plugin is in the extension manager. is enabled!
but I can't find it anywhere in the program ... Not in the tools menu either!
Where to find?
how can i bring it up
Thanks!
oszinapsugarbasel
Postby Dave R » Tue Oct 20, 2020 12:02 pm
oszinapsugarbasel wrote:I installed the plugin
Did you also install the required LibFredo6 files?
Global Moderator
Postby drobble » Tue Nov 03, 2020 10:48 pm
Hiya,
I have the plugin Fredo Corner vers. 1.9a installed on Sketchup 2017 (windows).
When I seleect this plugin it pops up a message saying
" This version of Fredo Corner has been expired. Please upgrade to the latest version."
What do I'm doing wrong or what goes wrong here?
Any hint is much appreciated.
<<<see attached screenshot?>>>
drobble
Postby fredo6 » Wed Nov 04, 2020 11:06 am
drobble wrote:I have the plugin Fredo Corner vers. 1.9a installed on Sketchup 2017 (windows).
Well, as the message says, just upgrade to FredoCorner 2.0a.
Do not forget to also upgrade to the most recent of LibFredo6. This is always good to keep my plugins up to date.
4
fredo6
PluginStore Author
PluginStore Author
Previous
Return to Plugins
Users browsing this forum: No registered users and 14 guests
