[Plugin] RoundCorner - v3.3a - 18 Dec 18
Re: [Plugin] RoundCorner - v3.2d - 12 Aug 17
Postby countercharge » Thu Sep 28, 2017 4:52 pm
fredo6 wrote:
countercharge wrote:edit: nevermind, the interface showed up
Did you identify what was the problem (in case this happens to other users)?
Fredo
I did not, but I think it appeared when I closed and re-opened sketchup. I assumed it would load once the plugin was loaded and enabled.
Loving it so far but I can't figure out how to round edges that are on the inside/interior of an object. If I try to do that, it covers the opening. I'm sure that's somewhere in this long thread.. any idea what page to look at?
countercharge
Postby fredo6 » Thu Sep 28, 2017 5:21 pm
countercharge wrote:Loving it so far but I can't figure out how to round edges that are on the inside/interior of an object. If I try to do that, it covers the opening. I'm sure that's somewhere in this long thread.. any idea what page to look at?
Just erase the cover face(s). The rounding is underneath.
Fredo
fredo6
PluginStore Author
PluginStore Author
[Plugin] RoundCorner - v3.2e - 25 Oct 17
Postby fredo6 » Wed Oct 25, 2017 3:08 pm
NEW RELEASE: RoundCorner v3.2e - 25 Oct 17
RoundCorner 3.2e is a maintenance release. It fixes a weird issue on French platforms, preventing the plugin to launch (in relation with decimal separator differences)..
Home Page of RoundCorner for information and Download.
Main post of this thread.
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin] RoundCorner - v3.2e - 12 Oct 17
Postby jtri » Sat Nov 11, 2017 10:34 pm
I am working on knife and when I use the round over tool I loose faces. A copy of the handle is at 1000x as I wanted to show that scaling up does not fix the issue I have. My model is at the origin original size and it has a volume.
I have used this wonderful tool many times before but I seem to have developed this model in a way that is not compatible with the round over tool.
I used Cuviloft to skin if that is a factor. Also I welded all the perimeter lines hoping that might help, it did fix some issues.
Jeff
jtri
Postby Dave R » Sat Nov 11, 2017 11:33 pm
Even scaled up, the tiny radius on the round overs creates some bad geometry. Make a reasonable radius and it works. I used 10 in.
Global Moderator
Postby jtri » Sun Nov 12, 2017 12:20 am
Dave
Thanks for you quick reply but I am unable to duplicate your results. Maybe the screen shot can help
Jeff
jtri
Postby fredo6 » Sun Nov 12, 2017 12:32 am
It all depends on your geometry.
As it has been generated by Curviloft, I imagine it is triangulated. Just turn on Hidden Geometry to verify it.
In that case, I am afraid that RoundCorner will have difficulty to perfrom its task, whatever the scale is. Sorry for that. Another algorithm is needed to handle those cases.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Dave R » Sun Nov 12, 2017 12:33 am
Did you try with a larger radius? I used 10 in., not 5 in.
Edit to add: I redrew the shape rather than trying to reconstruct yours. I didn't use Curviloft so I didn't have the triangulation.
Global Moderator
Postby jtri » Sun Nov 12, 2017 2:14 am
Thanks so much for the help!
-1
jtri
Postby riuslyp » Tue Nov 21, 2017 11:11 am
I had some trouble in using this plugin. The object I had rounded seemed like useless afterwards, I could not move nor color it, or anything else since my SU 2013 would crash if I do that. Before rounding, I have set the offset etc to the appropriate value. Could someone advice me what to do? I have also installed the newest LibFred
riuslyp
Postby Dave R » Tue Nov 21, 2017 11:22 am
riuslyp wrote:I had some trouble in using this plugin. The object I had rounded seemed like useless afterwards, I could not move nor color it, or anything else since my SU 2013 would crash if I do that. Before rounding, I have set the offset etc to the appropriate value. Could someone advice me what to do? I have also installed the newest LibFred
Can you share an example?
What is your graphics card? Are it's drivers up to date?
Global Moderator
Postby riuslyp » Wed Nov 22, 2017 7:55 am
I use AMD A8-7410 APU with AMD Radeon R5 Graphics, 2200 Mhz, 4 Core(s), and yes, my graphic card is up to date.
I was just trying to round a cube and I wanted to move it, but my SU then suddenly crashed. I had also tried to uncheck the 'hardware accelerator' but for no use.
riuslyp
Postby fredo6 » Wed Nov 22, 2017 9:45 am
Are you really running SU2013 (as your profile indicates)?
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby VancoD » Fri Feb 09, 2018 6:41 pm
Thanks for the plug-in Fredo. It seems to do a fine job.
My issue is not in getting the tool to work - my issue is what is happening you my shape after the round-over.
What I'm working on is not a complex shape - it's essentially a rectangle 15x100x455 mm. The top face has a radius of 254mm into it. It's a long box with a grove in it :)
My issue is that after I round all my edges the "entities" in SketchUp are basically lost. I now have an amorphous rectangle shape and I've lost all the "dimensional attributes" to all the elements/faces - I cannot submit this to a manufacturer for production with the dimensional data visible as I'd like to.
I am arguably very new to SketchUp - have I missed something obvious here - perhaps some sort of layering or overlay where I can apply the round-over and still have all the "square" reference data in place?
EDIT:
Well - I _can_ use the dimensions tool to indicate the dimensions, and that's technically "good enough" for my need. But I'm still curious to know if there's a way to keep that entity data in place.....
VancoD
Postby Dave R » Fri Feb 09, 2018 6:49 pm
How about sharing the SKP file so we can see exactly what you've got and give you some guidance?
Global Moderator
Postby fredo6 » Fri Feb 09, 2018 8:49 pm
VancoD wrote:My issue is that after I round all my edges the "entities" in SketchUp are basically lost. I now have an amorphous rectangle shape and I've lost all the "dimensional attributes" to all the elements/faces - I cannot submit this to a manufacturer for production with the dimensional data visible as I'd like to.
That's not a problem with the plugin. If you were doing the rounding manually, you would have the same problem. You need to modify the faces affected by the rounding and create new facets.
So, it's more the sequence in your workflow. Do the rounding first (and other editing tasks) and then put the decoration (dimensions, textures, ...)
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby 99hash » Sat Feb 24, 2018 11:00 am
Hi Fredo,
Absolutely amazing plugin, I am new to Sketchup and am busy playing with some designs to see if it is worth buying a 3d printer, no point in getting a printer if I cannot create designs to print. This plugin works perfectly for external corners but I cannot seem to get this to work on internal shapes. For example I have cube with a hole through it and would like the edge of the hole rounded. When I use this tool it just erases the hole completely. Is this normal behavior or am I being stupid?
Thank you for all this work you have put in your tool
Nick
99hash
Postby fredo6 » Sat Feb 24, 2018 11:24 am
99hash wrote:Hi Fredo,
Nick
This is a small inconvenience in the current version.
Just select the face occulting the hole and erase it. It should reveals the rounding of the hole.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Steuart » Mon Feb 26, 2018 6:08 pm
often when I use Round Corner it crashes Sketchup. If I am working and then click on round corner it almost always crashes. Then when I re-open SU and try using Round Corner it works fine. I have the same problem in SU17 and SU18. I am using a mac on the latest MacOS. (it has been happening for a long time in various versions of MacOS) Any solution to this? The only solution i have found is to close SU and reopen it, which is very frustrating if I am doing a lot of Round Corner. Thanks
Steuart
Postby fredo6 » Mon Feb 26, 2018 8:40 pm
Steuart wrote:often when I use Round Corner it crashes Sketchup. If I am working and then click on round corner it almost always crashes. Then when I re-open SU and try using Round Corner it works fine. I have the same problem in SU17 and SU18. I am using a mac on the latest MacOS. (it has been happening for a long time in various versions of MacOS) Any solution to this? The only solution i have found is to close SU and reopen it, which is very frustrating if I am doing a lot of Round Corner. Thanks
Actually, first time I hear about these crashes from users, and also that this has happened before.
I would suggest you give the list of the other plugins you run in your environment, as some are known to be in conflict with RoundCorner (and other plugins).
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Steuart » Tue Feb 27, 2018 12:08 pm
Hi Fredo, Thanks for fast reply. I have: Advanced Camera Tools, Dynamic Components, Sandbox, Trimble Connect (no idea what any of those do), plus your LibFredo6, Curviloft (looks great - only downloaded it yesterday, not tried it out yet), Round Corner. I used to have pipe along, which I think caused similar issues, but have not installed that in SU18. I am running the latest version of everything and Mac OS10.13.3 on a 2013 MacBook pro retina. (new iMac arriving tomorrow)
Steuart
Postby Steuart » Tue Feb 27, 2018 6:37 pm
Nick
Hi Nick, I have printed a number of things from sketchup drawings and it works very well. Good luck! (and I am far from being an expert!!) Steuart
Steuart
Postby Steuart » Mon Mar 05, 2018 12:59 pm
Fredo
Hi Fredo, (sorry - did not reply directly to your first reply - just learning the system) Thanks for fast reply. I have: Advanced Camera Tools, Dynamic Components, Sandbox, Trimble Connect (no idea what any of those do), plus your LibFredo6, Curviloft (looks great - only downloaded it yesterday, not tried it out yet), Round Corner. I used to have pipe along, which I think caused similar issues, but have not installed that in SU18. I am running the latest version of everything and Mac OS10.13.3 on a 2013 MacBook pro retina.
(love the plugin by the way!)
Steuart
Steuart
Postby fredo6 » Mon Mar 05, 2018 2:47 pm
Steuart,
I suggest you install the latest version of LibFredo6 (v8.1d) and tell me if you get crashes any longer. I fixed some problems of random bugsplats for Curviloft, and it might well be the same origin as for RoundCorner.
By curiosity,
1) do you have Souvenir also installed?
2) Does the crash happens when you launch RoundCorner right after you save the model
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Steuart » Mon Mar 05, 2018 3:07 pm
fredo6 wrote:Steuart,
By curiosity,
Fredo
Hi Fredo,
Thanks for your reply.
I dont have souvenir.
If SU crashed and then I re-launched it Round Corner usually worked fine.
Last few days I have not had a crash, but I have been regularly saving before trying round corner.
I have LibFredo6 8.1, but will try re-installing it, and update you.
Steuart
Steuart
Postby Steuart » Mon Mar 05, 2018 4:22 pm
By curiosity,
Fredo
Hi Fredo,
Update.
Just updated the libFredo6 to 8.1d (I had not realised there were variations of the 8.1), and restarted the computer, but unfortunately it has not helped as I have just crashed again.
Recap:
No Souvenir installed.
It does not happen if I have had a crash and relaunch SU and straight away start using RoundCorner. On this occasion i was using an existing drawing and worked for about 20/30 mins, then clicked on round corner and it instantly crashed. If I save first then click on Round Corner it is less likely to crash.
I have still not used Curviloft and don't know if that would cause the same problem. I dont have any other forms of rendering packages and the only plugins I have are yours and the Tremble ones listed above.
A mystery!
Steuart
Steuart
Postby fredo6 » Mon Mar 05, 2018 7:03 pm
If you get another bugsplat, could you please fill the report dalogbox, send it and send me the Crash report number.
Many thanks
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby ModelMayhem » Wed Mar 07, 2018 7:06 pm
Hi Fredo
Amazing plugins! I use Round corner all the time however since upgrading to any version from 2016 onwards, every time I run the plugin, it appears to effect the faces of the geometry where I get this strange grey to white gradient on the face, then when I try to render it in Keyshot the geometry behaves as if the object was slightly concave, I dont have this issue in version 2015 and earlier, any thoughts as to what this could be? Ive attached some screen shots
Thanks in advance
Chris
ModelMayhem
Postby Dave R » Wed Mar 07, 2018 7:17 pm
I'm unable to duplicate that in SU2018. Can you show the settings you are using when you get it?
Global Moderator
Postby juju » Wed Mar 07, 2018 10:13 pm
I've seen this before, when there's a bit of smoove going on. Not always desirable.
21 Sept. 2020. Please support this thread on the SketchUp forum to resolve Extension Warehouse problems. Faults being ignored is not an option.
juju
Premium Member
Premium Member
PreviousNext
Return to Plugins
Users browsing this forum: Alexa Bot, endstar973, JonFar, season_x and 9 guests
