[Plugin] RoundCorner - v3.3a - 18 Dec 18
Re: [Plugin] RoundCorner 2.1a - 27 Aug 09
Postby Arnold Layne » Mon Sep 21, 2009 8:07 pm
amazing..thanks :sketchstatic:
Arnold Layne
Postby SteveZissou! » Wed Sep 30, 2009 2:35 pm
i'm sorry if this is a foolish question, but i would really like to try the roundcorner ruby, but my screen says:
"You do not have the required permissions to view the files attached to this post."
what do i have to do to get permission?
thanks
brian
SteveZissou!
Postby jwlyon1 » Wed Sep 30, 2009 7:00 pm
I think all you have to do is register and login to the forum... Since you've done that try downloading again!
Macbook Pro/ iMac
OSX 10.7.2 Sketchup 8
rogue-z is here!
jwlyon1
Postby boofredlay » Wed Sep 30, 2009 9:07 pm
Justin is correct Brian, you have to register. But the best part... it's FREE :D
boofredlay
Global Moderator
Postby mitcorb » Thu Oct 01, 2009 12:37 pm
If Brian is able to post in the forum, doesn't that mean he is registered?
And if he is registered, could this be the Board Cookies Login problem?
At the Forum Index Page navigate to the bottom to the button "Delete All Board Cookies", select Yes, then select Return to the Forum Index.
Also, there is a red oval on the right side of the page at the top regarding this.
If this is not the problem, never mind.
mitcorb
Top SketchUcator
Postby Gaieus » Thu Oct 01, 2009 3:37 pm
It must rather be a browser cookie setting IMO. See this global announcement
viewtopic.php?f=18&t=19797
and delete your cookies in the browser.
(The registration/login help email would end up in my mailox anyway :) )
Postby Blackpercula » Thu Oct 01, 2009 4:24 pm
Thank
Blackpercula
Postby hamster3 » Tue Oct 06, 2009 11:37 am
Fredo, you make sketchup to become perfect!
Thank you! :ecstatic:
hamster3
Re: [Plugin] RoundCorner 2.1c - 08 Oct 09
Postby fredo6 » Thu Oct 08, 2009 9:32 pm
[Upgrade 08 Oct 09] RoundCorner 2.1c
Documentation translated to French by Christophe Plassais (the plugin itself was already available in French) and plugin translation to Spanish by Gaonirico.
See main post at http://forums.sketchucation.com/viewtopic.php?f=180&t=20485&st=0&sk=t&sd=a#p171721
fredo6
PluginStore Author
PluginStore Author
Postby jeff hammond » Thu Oct 15, 2009 7:15 am
can't believe i missed this update..
great work once again fredo!
thank you
dotdotdot
jeff hammond
Global Moderator
Postby EarthMover » Thu Oct 15, 2009 2:20 pm
Fredo...small request for a perfect plugin. In the next release, might you consider and option to drag out a visual offset? i.e. if I have a cube and want to round the corners, I could click on a corner and drag down the offset visually as you would the standard offset tool. With irregular shaped objects, I find myself entering 3 or 4 dimensions manually until I find one that doesn't overlap in tight corners and create a hole. If I could dynamically pull out the offset, I could see how far the offset could be before running into issues. Just a suggestions. Like I said...really just the perfect tool all the way around.
Content Creator at Skapeup
EarthMover
Premium Member
Premium Member
Postby jeff hammond » Thu Oct 15, 2009 4:29 pm
you fixed sketchup! :D
prior to this script, if i needed a corner to look like the one on the left (and i need them often), i had to draw it manually and while not incredibly difficult, it's certainly a waste of time.. SU+ follow me can't do it right..
when doing a corner which has a top radius looser than the profile radius... SU/follow me & RoundCorner produce the exact same results which are incorrect but i can deal with it a little easier..
the transparent planes show where the hidden lines should be.. the attached skp shows another problem as well.
of course, i'm using this plugin for an application far from its intent and i'm not asking you to try to fix this or anything... just pointing out a sketchup error that you happened to halfway fix..
thanks man -- great plugin here.
dotdotdot
jeff hammond
Global Moderator
Postby fredo6 » Thu Oct 15, 2009 10:22 pm
EarthMover wrote:Fredo...small request for a perfect plugin. In the next release, might you consider and option to drag out a visual offset?
Visual dragging was in my plan but is stuck with many other things I need to do on this plugin (non-uniform offset, custom profiles) and other plugins. I should also add a detector of holes and overlaps.
So point noted.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby plot-paris » Fri Oct 16, 2009 8:06 am
Fredo6 wrote:Visual dragging was in my plan but is stuck with many other things I need to do on this plugin (non-uniform offset, custom profiles) and other plugins. I should also add a detector of holes and overlaps.
cool! are we going to get christmas presents? :bounce: ... :D
plot-paris
Postby Fletch » Wed Oct 21, 2009 11:47 am
I just have to say that the more I use this plugin, the more amazing it becomes, it's simply one of my favorite plugins ever written for SketchUp.
My favorite part is the little toolbar that pops up with buttons and options on it, and that I can save 2 presets that I commonly use.
Fletch
Twilight Render
Postby boofredlay » Wed Oct 21, 2009 2:16 pm
I agree. It is one of my most used scripts as well.
boofredlay
Global Moderator
Postby plot-paris » Fri Oct 23, 2009 3:11 pm
one of the most useful plugins indeed. especially when it comes to rendering, its so easy to add detail...
Fletch wrote:My favorite part is the little toolbar that pops up with buttons and options on it, and that I can save 2 presets that I commonly use.
cool, didn't notice that one. must have been blind! "doh"-moment
plot-paris
Postby Jackson » Fri Oct 23, 2009 3:40 pm
Just stumbled upon this amazing script- in common with Fredoscale, I'm stunned by its usefulness and intuitiveness- what an excellent UI. These two scripts (and Subsmooth & Divide) have completely transformed SU from orthogonal GE plaything into an organic surface modeller sufficient for most architects' needs. This is a simply stunning ruby, thank you, thank you, THANK YOU! Second donation on it's way as soon as pay day arrives! :D
Where did that "We're not worthy" smiley go to?
Jackson
Jackson
Postby fredo6 » Fri Oct 23, 2009 9:00 pm
Jackson wrote:Just stumbled upon this amazing script- in common with Fredoscale, I'm stunned by its usefulness and intuitiveness- what an excellent UI. These two scripts (and Subsmooth & Divide) have completely transformed SU from orthogonal GE plaything into an organic surface modeller sufficient for most architects' needs. This is a simply stunning ruby, thank you, thank you, THANK YOU! Second donation on it's way as soon as pay day arrives! :D
Jackson,
Thanks to you (and others) for your warm appreciation of the plugin. I am glad to see that it is useful in production work.
If you see things missing or inacurate, do not hesitate. RoundCorner is a recent script, where I am able to make evolutions.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Gruff » Fri Oct 23, 2009 10:05 pm
Thank you Fredo. Sweet and complete. :enlight: (I won't beg for variable radius fillets... Yet. :D )
It hanndles most of what I can throw at it cleanly.
Huge boost for SU.
~Gruff
Resistance is .... Character Forming. *Grin*
Gruff
Postby Ruturaj » Sat Oct 24, 2009 9:46 am
Hi, ;)
I'm very happy.......... :berserk:
Thanks you very much :)
Good job :thumb:
Thanks,
RuturaJ
Ruturaj
Postby arturmercurio » Fri Oct 30, 2009 4:50 pm
Hi guys it my first time posting in this forum. I am having issues with RoundCorner 2.1. To start, i have added the plugin that is necessary for RoundCorner to work (LibFredo6). And until now i have not been able to find a link to download RoundCorner 2.1a. I am a mac user working with Sketchup 7.1. If someone can give me some direction i'd much appreciate it. The RoundCorner plugin looks good.
Artur C
arturmercurio
Postby thomthom » Fri Oct 30, 2009 4:52 pm
At the bottom at the very first post in this thread. Make sure you go to the first page of this long thread.
PluginStore Author
PluginStore Author
Re: [Plugin] RoundCorner 2.1c - Chinese - 11 Nov 09
Postby fredo6 » Wed Nov 11, 2009 10:05 pm
[Chinese version - 11 Nov 09 - 21:50 CET
Diweiman and the SuBAR_CLT team at SketchupBar have translated the script into Chinese.
See main post at http://forums.sketchucation.com/viewtopic.php?f=180&t=20485&p=171721#p171721).
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin] RoundCorner 2.1c - 11 Nov 09 (Chinese)
Postby utiler » Wed Nov 11, 2009 11:44 pm
Fredo, is there a need for English users to update to this version?
Thanks for your tireless and generous work....!
utiler
Top SketchUcator
Postby fredo6 » Thu Nov 12, 2009 12:04 am
utiler wrote:Fredo, is there a need for English users to update to this version?
Good question.
The answer is NO. The script is the same. The Chinese translation is contained in the separate .lang file (as for all other languages).
fredo6
PluginStore Author
PluginStore Author
Postby humbucker » Fri Nov 13, 2009 9:15 am
I'm new to this forum and wanted to test this nice plugin, I got a fresh install of Sketchup 7 normal, but no plugin menu show up in Window or in any other menu, I've unzipped the file right, any prob with version 7 ?
Many thanks!!
humbucker
Postby Fong » Thu Nov 26, 2009 2:49 am
Had no idea Sketch Up could do any of this! As I set here pouring through the 3DS Bible, SU might deserve another look
Fong
Postby herrstirlitz » Fri Nov 27, 2009 2:59 pm
thank you for new buttons!
i'm not sure if i've found bug or if i just little stupid to use the plugin, but somehow i can't get the sharp corner round. instead i've get rounding that is oval.
i hope you can help.
here is a picture of this. like you can see the corners to the right are great, but not the left one.
herrstirlitz
Postby mambo.harts.u » Mon Nov 30, 2009 11:11 am
wohooooo!! thanks frodo! made it working already!
mambo.harts.u
PreviousNext
Return to Plugins
Users browsing this forum: a_cad29, cabooszer, Google Bot, manok and 10 guests
