[Plugin] RoundCorner - v3.3a - 18 Dec 18
Re: [Plugin] RoundCorner - v2.7a - 19 Oct 14
Postby zanthus » Mon Apr 13, 2015 1:42 pm
Thanks Fredo6
zanthus
Postby tmophoto » Sat Apr 25, 2015 3:59 am
why is it so hard to install and get these plugins to work? why dont you have them available in the extensions warehouse?
are there any other options for rounding corners in sketchup? I have just wasted half a day trying to get this to work
-1
tmophoto
Postby Dave R » Sat Apr 25, 2015 3:23 pm
tmophoto wrote:why is it so hard to install and get these plugins to work? why dont you have them available in the extensions warehouse?
It isn't difficult to get or install Fredo's plugins.
You're right. They aren't available in the Extension Warehouse but they are available through the SketchUcation Plugin Store which is clearly explained in the first post of this thread.
You could also install the Plugin Store toolset, which will automatically install plugins/extensions and give you all sorts of other options.
It shouldn't have taken you half a day to get this plugin to work, but if you don't want to use it, you can use Follow Me.
No plugins required.
Global Moderator
Postby pbacot » Sat Apr 25, 2015 4:04 pm
For me the Sketchucation Plugin store and toolset is better than the Extension Warehouse. Well perhaps that's not completely fair--I avoid using the Warehouse, so how can I compare?
Fredo's plugins come in automatically on the push of a button, always work, and the whole SCF Plugin setup is easy to understand. Fredo also provides an update window that tells you, within Sketchup, when his plugins have been updated and the status of versions you currently have. They have a lot of functionality and most require his "FredoLib" library plugin to be up to date, in order to run properly.
Top SketchUcator
Postby Pixero » Sun Apr 26, 2015 4:20 pm
I have an idea for the round corner plugin.
To get around the problem with altering a bevel on an object, what if the script would save a original "unbeveled" version of the object on a special hidden layer and if the user wants to change the bevel later on the script would fetch the original object and do a new bevel on it with the new settings.
Pixero
Postby Rich O Brien » Sun Apr 26, 2015 4:46 pm
Pixero wrote:save a original "unbeveled" version of the object on a special hidden layer and if the user wants to change the bevel later on the script would fetch the original object and do a new bevel on it with the new settings.
That's an awesome idea.
Rich O Brien
Administrator
Postby JQL » Sun Apr 26, 2015 5:17 pm
Yes that is! And fredo already owns most of the code for that on Ghostcomp
JQL
Premium Member
Premium Member
Postby driven » Sun Apr 26, 2015 5:20 pm
Pixero wrote:...save a original "unbeveled" version ...
could save it to the group definition maybe?
like TIG and TT do with editable 3dText...
john
driven
PluginStore Author
PluginStore Author
Postby thomthom » Sun Apr 26, 2015 8:45 pm
Pixero wrote:I have an idea for the round corner plugin.
I've been toying with the idea of extracting the technique I use in SUbD, by storing the original mesh in the definition's attributes. I'd love for there to be a generic library to handle this which developers can quickly hook up. Need to complete SUbD first though.
PluginStore Author
PluginStore Author
Postby lema » Wed May 13, 2015 6:41 pm
You make not symmetrical angle?
lema
Postby RunningUtes » Thu May 21, 2015 4:30 am
Getting a strange result after installing the rounded corner extension in Sketchup 2015.
I created a square, selected one edge, and ran the extension. The edge I selected is gone and instead I get this image below.
This is the first time using the extension
Any tips or help?
RunningUtes
Postby pilou » Thu May 21, 2015 8:14 am
Better if you post the SKP file! (Before,after ) ;)
That avoid to rebuild something maybe false different than your and lost time! :)
Speedy Galerie
Top SketchUcator
Postby Dave R » Thu May 21, 2015 9:54 am
RunningUtes wrote:Getting a strange result after installing the rounded corner extension in Sketchup 2015.
Any tips or help?
You say you made a square but I think you mean a cube? It looks as if you have the Offset (radius) value set too large. The setting you used for the radius is 1000mm but your cube can't be anywhere close to that size. Try changing the Offset to something small enough that it fits your cube.
Edit:
I duplicated your results by setting the radius much larger than the cube.
With a more appropriate setting, it rounds the edge as expected.
Take some time to read the instructions in the first post of this thread. There is also a PDF reference file available.
Global Moderator
Postby Noemi » Mon Jun 01, 2015 10:47 am
Hello!, i tryed to install roudedcorners directly through Sketchucation pluging stores, after instslling freddo library, and it appears this when autoinstall: ( inside a box)
You can Write to the Main Plugins Folder, and...
You have a Custom-Plugins Folder.
C:/ Users/noemi/appdata/roaming/sketchup/sketchup2015/sketchup/plugins
c:/ Programdata/sketchup/sketchup2015/sketchup/plugins
i don't find this folder and don't know what does it mean... should i create another folder, what should i do? thanks for any help!
Noemi
Re: [Plugin] RoundCorner - v3.0a - 09 Jul 15
Postby fredo6 » Thu Jul 09, 2015 3:20 pm
NEW RELEASE: RoundCorner v3.0a - 09 Jul 15
RoundCorner 3.0a is refresh of this now old plugin.
The main evolutions are related to the User Interface:
  1. Updated button palette, separating the buttons in 4 areas: Edges selection, Parameters, Edge properties and Geometry Generation.
  2. Post-modification: You can now modify the parameters after the generation of the geometry without reselecting edges. When one or several parameters are changed, you can apply to the previous generation by clicking on “APPLY CHANGE”. As soon as you select an edge, this option is no more available and the parameters will apply to the next generation.
  3. Detection of Overlaps: RoundCorner now detects the situations of overlaps and show them in Preview mode and display a warning message before generation of the geometry.
  4. Edge properties: there is an additional control for edges bordering the corners.
See main post of this thread for Download.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby massimo » Thu Jul 09, 2015 5:50 pm
Thank you very much for this update Fredo.
Fredo6 wrote:You can now modify the parameters after the generation of the geometry without reselecting edges.
This is a great new feature and a huge time saver. :thumb:
massimo
Postby pbacot » Thu Jul 09, 2015 7:36 pm
This may be the paragon of your plugins, Fredo, which are all superb at that. A hugely useful and essential tool that only gets better and more refined over time!
Top SketchUcator
Postby jcyber » Sat Jul 11, 2015 1:50 pm
Thank you so much fredo6
jcyber
Re: [Plugin] RoundCorner - v3.0b - 17 Jul 15
Postby fredo6 » Fri Jul 17, 2015 9:36 pm
NEW RELEASE: RoundCorner v3.0b - 17 Jul 15
RoundCorner 3.0b fixes a major bug preventing the plugin to launch for Sketchup 2013 and earlier versions.
So it is IMPORTANT to upgrade to v3.0b if you run these versions of Sketchup.
Sorry for inconvenience
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby z200121 » Wed Jul 22, 2015 9:40 am
Yep with little measures that splatting soon as Enter!
z200121
Postby TIG » Wed Jul 22, 2015 12:58 pm
z200121 wrote:Yep with little measures that splatting soon as Enter!
No a very clear comment :roll:
If you mean that using very small dimensions causes a BugSplat, then this a well know limitation of SketchUp -both in SketchUp's native tools and many Plugins...
Models with edges [and any faces they might support] < 1/1000" long can 'exist', BUT they cannot be 'created' - this is because at that size the tolerance built in to SketchUp means that it takes the edge's start/end points to be coincident.
The work around is to scale the geometry up x100 or more, do the intricate creation and scale back down afterwards.
As I said - the tiny geometry can exist, but it cannot be created...
Global Moderator
Postby derei » Wed Jul 22, 2015 11:03 pm
TIG wrote:...can exist, but it cannot be created...
Use this as your motto, is cool ! :D :mrgreen:
DESIGNER AND ARTIST DEREI.UK
derei
Postby littleche » Sun Jul 26, 2015 6:03 pm
its great ! thanks fredo .
littleche
Postby DDK » Wed Jul 29, 2015 9:19 pm
One of the best plug-ins ever, thank you!!! makes my models look more realistic. the best part of this is it keeps the faces grouped as one. cheers keep making more :)
DDK
Postby kashiu » Tue Aug 11, 2015 7:50 am
Hi fredo
I have the su2015 & Im interstate in the round corner pouring, can you help me?
kashiu
Postby littleche » Thu Aug 13, 2015 4:06 pm
HI
I Have problem with this model . round corner can't rounding this model and recive overlab error.
How can I fix this problem?
P & P.skp
thanks
littleche
Postby fredo6 » Thu Aug 13, 2015 9:43 pm
littleche wrote:HI
thanks
Unfortunately, with the current algorithm, this is not possible.
At the sharp corner, you have edges which are smaller than the offset.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby littleche » Sun Aug 16, 2015 6:40 pm
fredo6 wrote:
littleche wrote:HI
thanks
Fredo
Thank you fredo . You are always trying to develop this plugin.And I thank you very much.If you are not a thing of SketchUp shortage!
I hope you can fix algorithm in the next version .Always sincerely pray for your success...
littleche
Postby Will C » Mon Aug 24, 2015 4:49 am
I've been using this plugin for a while now and it's pretty awesome. Makes curving edges a lot faster with less frustration. Thanks for making this.
Will C
Postby Tony2015 » Sun Sep 27, 2015 2:40 pm
thx fredo
Tony2015
PreviousNext
Return to Plugins
Users browsing this forum: Araicucu, juan_sketch, Rideout33, sketbo8, Татьяна Каширина and 9 guests
