[Plugin] Multi face offset
• Page 1 of 2 • 1, 2
Re: [plugin] Multi face offsetThanks Tig, I had no offset.rb.
Now works fine
Re: [plugin] Multi face offsetI havent got it, but im guessing its included in some other script. Thanks for the pointer by the way, i'll add it to the 1st post.
Re: [plugin] Multi face offsetIt's the simple things that are often the most complicated !
[¡Se trata de las cosas simples que a menudo son las más complicadas!] TIG
Re: [plugin] Multi face offsetPlease, register (free) to access all the attachments on the forums.
Re: [plugin] Multi face offsetA veritable Smörgåsbord of repeated functionality
Re: [plugin] Multi face offsetSmörgåsbord is a swedish word.
Protrude above can make that , just offset= 0 after use it and enable Height = that you want Only Protrude keep the selection For Push Pull multiple in general you can also use Joint Push Pull by Fredo6 or Projection2 by Didier Bur But both lost the selection! Please, register (free) to access all the attachments on the forums.
Re: [plugin] Multi face offset"Pilou" You're right, thank you very much
Re: [plugin] Multi face offsetHi Remus, first thanks for the useful script - i found out the offset may end reversed at times
Re: [plugin] Multi face offsetSo it does. I dont suppose youve found what causes it? Whatever it is, i suspect it is a bug in offset.rb, it would be good to be able to pass it on to rickw, though.
Re: [plugin] Multi face offsetthe hunch, says it may be something to do with the direction of the lines (start-end-front-back business..) - but i could not spot the pattern for sure yet
Re: [plugin] Multi face offsetRemus, couple of icons if needed..
Re: [plugin] Multi face offsetI dont know how to do toolbars
I'll give it a go, though, those icons are too nice to waste
Re: [plugin] Multi face offseti think it's something along these lines.. check out Chris's loft or other tools - they will make sense
Re: [Plugin] Multi face offsetHey All!
Does anyone has this fantastic plugin working in version 8?! I installed offset.rb and the latest Multifaceoffset.rb but only the input dialogue appears and it doesn't do anything... Thank you! Grtzz Pep ....or does anyone know how to offset multi faces in another way?!
It works fine in v8 for me [and others]. Have you tried running it with the Ruby Console open to see error messages. It seems to be failing after the dialog, so probbaly an 'offest' error/deficiency... You need both the Multifaceoffset.rb and the offset.rb in the main Plugins folder... TIG
Re: [Plugin] Multi face offsetHey TIG, Thanks!
I already placed the both *.rb files in the main plugins folder, just as usual...And I got the following error message in the Ruby Console but that is Chinese to me! I don't know what's wrong? Please, register (free) to access all the attachments on the forums.
Re: [Plugin] Multi face offsetWhat are the sizes of your box's faces and what size offset are you entering in the dialog - it might be that the face won't offset if there will be no result... How do you enter the offset exactly ? Can you take a screen-shot of the dialog just before you press OK...
This is a very simple few line script by Remus, it has very few things that could go wrong... TIG
Re: [Plugin] Multi face offsetHey Tig,
The size of the box is given in the capture en the amount of offset is 150mm...It has always done the trick...Can you mail me the offset.rb and the multifaceoffset.rb you are using? Thanks for your time! Grtz Pep Please, register (free) to access all the attachments on the forums.
Re: [Plugin] Multi face offset ![]() IT'S WORKING! Thank you!!! But the offset.rb and the multioffset.rb that can be downloaded from this topic are different than the ones you've send....strange huh? Nevertheless thank you!! Grtz and a happy new year! Pep
Re: [Plugin] Multi face offsetI have tweaked the code slightly over time BUT they should still be the same basic functions ?
Re: [Plugin] Multi face offsetHi guys, I know I'm poking into a discussion that is already 4 years old, but, il seems I have the same problem that pep 75 had... i have both multifaceoffset.rb and offset.rb, but gives me the same error message, and doesnt offset... could TIG perhaps post the scripts that he sent to pep75 that where working? I need it!!!!! thanxxx
Here they are... Please, register (free) to access all the attachments on the forums. TIG
Re: [Plugin] Multi face offsetHi all
I have a question, how can I get a rounded offset? For doing something like that ---> Please, register (free) to access all the attachments on the forums.
Re: [Plugin] Multi face offsetgood question!!
This is a great plugin. I know a simple way to improve it. After the plugin has executed the offsets....it should prompt the option: "Keep the offset face selected=1 Keep original faces selected = 0" (as in yes/no) Is this possible? It would allow JPP/scale (for example) immediately on offset faces, without having to select them all manually. Wings 3D has a similar feature with its multiple offset feature. Or a plugin to select inverse faces of a mesh? oli
Re: [Plugin] Multi face offsetAnd about the round Plugin from a Polygon above?
And there from the selection of all polygons because make one by one is a little tiedous
SketchUcation One-Liner AdvertsVertex Tools for SketchUp. Take control over each vertex with this vertex editor for SketchUp.
